  4. [gelöst] - js-controller nach update nicht mehr zu starten
    1.0k
    6.1k
39 Beiträge 14 Kommentatoren 46.9k Aufrufe 4 Beobachtet
  • I Offline
    I Offline
    iobroker-6043
    Hach dem Update von heute kann ich den js-controller nicht mehr starten.
    npm install iobroker.js-controller –production klappt nicht und iobroker start ergibt
    module.js:327
    throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    at Function.Module._resolveFilename (module.js:325:15)
    at Function.Module._load (module.js:276:25)
    at Function.Module.runMain (module.js:441:10)
    at startup (node.js:139:18)
    at node.js:968:3
    Alles nicht so schlimm, neu installiert ist schnell nur fehlen mir meine JavaScripts. Wie komme ich denn an die ran ? :( :( :( :(
    root@raspberrypi:/opt/iobroker# iobroker stop
    module.js:327
    throw err;
    at node.js:968:3
    root@raspberrypi:/opt/iobroker# iobroker update module.js:327
    throw err;
    at node.js:968:3
    root@raspberrypi:/opt/iobroker# iobroker upgrade module.js:327
    throw err;
    at node.js:968:3
    root@raspberrypi:/opt/iobroker# npm install iobroker.js-controller
    iobroker.js-controller@0.10.1 install /opt/iobroker/node_modules/iobroker.js-controller
    node lib/setup.js setup first
    fs.js:549
    return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
    Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../killall.sh'
    at Error (native)
    at Object.fs.openSync (fs.js:549:18)
    at Object.fs.writeFileSync (fs.js:1156:15)
    at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:213:24)
    at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:513:23
    at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:534:11)
    at Module._compile (module.js:409:26)
    at Object.Module._extensions..js (module.js:416:10)
    at Module.load (module.js:343:32)
    at Function.Module._load (module.js:300:12)
    npm ERR! Linux 4.4.11-v7+
    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.js-controller"
    npm ERR! node v4.4.5
    npm ERR! npm v2.15.5
    npm ERR! code ELIFECYCLE
    npm ERR! iobroker.js-controller@0.10.1 install: node lib/setup.js setup first
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@0.10.1 install script 'node lib/setup.js setup first'.
    npm ERR! This is most likely a problem with the iobroker.js-controller package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR! node lib/setup.js setup first
    npm ERR! You can get information on how to open an issue for this project with:
    npm ERR! npm bugs iobroker.js-controller
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR!
    npm ERR! npm owner ls iobroker.js-controller
    npm ERR! There is likely additional logging output above.</anonymous>
      Bist du sicher, dass du im normalen Installationsordner "drüber"installiert hast?
      nicht dass du jetzt eine zweite ioBroker Installation hast.
      rainer
      • I Offline
        I Offline
        iobroker-6043
        Hallo Rainer
        Ja, gehe davon aus. Verzeichnis war immer /opt/iobroker
        root@raspberrypi****:/opt/iobroker#**** ls -lsa
        insgesamt 1360
        4 drwxrwxrwx 6 root root 4096 Jul 18 14:22 .
        4 drwxr-xr-x 8 root root 4096 Jun 8 16:54 ..
        4 drwxr-xr-x 2 root root 4096 Jun 8 16:55 etc
        4 -rwxr-xr-x 1 root root 297 Jun 8 16:58 install.sh
        4 -rwxrwxrwx 1 root root 67 Jun 8 16:58 iobroker
        4 drwxr-xr-x 4 root root 4096 Jun 8 16:59 iobroker-data
        4 -rwxr-xr-x 1 root root 90 Jun 8 16:57 killall.sh
        4 drwxr-xr-x 2 root root 4096 Jul 18 05:01 log
        4 drwxr-xr-x 11 pi pi 4096 Jul 18 14:22 node_modules
        1320 -rw-r–r-- 1 root root 1350135 Jul 18 14:22 npm-debug.log
        4 -rwxr-xr-x 1 root root 284 Jun 8 16:57 reinstall.sh
        root@raspberrypi:/# which iobroker
        /usr/bin/iobroker
        root@raspberrypi:/# find / -name iobroker
        /opt/iobroker
        /opt/iobroker/iobroker
        /usr/bin/iobroker
        root@raspberrypi:/#
        • BluefoxB Offline
          BluefoxB Offline
          @iobroker-6043:
          Hallo Rainer
          insgesamt 1360
          /usr/bin/iobroker
          /opt/iobroker
          /usr/bin/iobroker
          root@raspberrypi:/# `
          cd /opt/iobroker
          sudo chmod 777 * -R
          sudo npm install iobroker.js-controller --production
            Das hattest du doch vor ein paar Tagen schon mal gepostet. Die Lösung wusste ich nicht mehr :oops:
            Ich habe nach "EACCESS" gesucht und nichts gefunden :(
            Rainer
            • I Offline
              I Offline
              iobroker-6043
              Besten Dank, hat geklappt.
              cd /opt/iobroker
              sudo chmod 777 * -R
              sudo npm install iobroker.js-controller –production
                pix
                Kannst du schnell das im Topic das "HILFE !!" gegen "GELÖST" austauschen (ersten Post editieren), dann lösche ich diesen Eintrag wieder.
                Pix
                  Semenchkare
                  Hallo Rainer,
                  ja, ihabe Armbian, mit dem BananapiM2 hast nicht viele alternativen!
                  gelöst! Tatsächlich geht der Autostart mit der Node-Version 4.5.
                  Vielen Dank für Deine Mühe und dass Du geholfen hast!
                  Jetzt muss ich nur noch nach dem Flot-Update die Links Checken, denn meine Charts wollen nicht mehr…
                  Herzlichen Dank!
                  Viele Grüße
                  Semenchkare
                  raspberry 5 8GB mit iobroker,
                  raspberry 5 8GB mit Raspberrymatic
                    Snuupy
                    Hallo zusammen, vielen Dank für diese Anleitung, das hat bei mir aber irgendwie immer noch nicht funktioniert.
                    Ich probiere nun schon mehrere Stunden daran herum, und ich bekomme die Installation einfach nicht sauber hin.
                    Mein Verdacht: defekte SD-Karte! Alles andere funktioniert sauber, nur bei der Installation von iobroker passieren komische Dinge. Ich habe iobroker jetzt auf einen USB-Stick installiert, das hat sofort funktioniert. Leider geht auch hier der Autostart nicht - das war das ursprüngliche Problem, welchem ich nachgegangen bin… Das muss ich mir nochmal ansehen.
                    • ruhr70R Offline
                      ruhr70R Offline
                      ruhr70
                      @Snuupy:
                      Mein Verdacht: defekte SD-Karte! Alles andere funktioniert sauber, nur bei der Installation von iobroker passieren komische Dinge. Ich habe iobroker jetzt auf einen USB-Stick installiert, das hat sofort funktioniert. Leider geht auch hier der Autostart nicht - das war das ursprüngliche Problem, welchem ich nachgegangen bin… Das muss ich mir nochmal ansehen. `
                      Schon einmal prima, dass Deine aktuelle Installation funktioniert!
                      Willkommen im Forum und viel Spaß mit ioBroker.
                      Zu Deinem Post. Der Thread ist als gelöst markiert. Bitte nicht wundern, wenn über Deinen Post dann nur wenige stolpern und damit kaum Antworten zu erwarten sind.
                      Ich kann bestätigen, dass es mit der aktuellen Version ein Problem mit dem Autostart gibt. Voran das liegt…? (ioBroker, node.js Version, npm Version, ...?).
                      Hier findest Du ein paar Lösungen/Workarounds dazu:
                      http://forum.iobroker.net/viewtopic.php?f=17&t=10154
                      • C Offline
                        C1500
                        Servus
                        musste heute feststellen das mein ioBroker-Pi nicht mehr läuft.
                        Die Fehlermeldungen führten mich zu diesem Threat.
                        Doch leider hilft mir die Anleitung von Bluefox nicht weiter.
                        Es kommt folgende Fehlermeldung:
                        pi@ioBroker-Pi3:/opt/iobroker $ sudo npm install iobroker.js-controller --production
                        npm WARN deprecated localhost.daplie.me-certificates@1.3.5: this package has been deprecated
                        npm ERR! path /opt/iobroker/node_modules/npm/node_modules/ansistyles
                        npm ERR! code ENOENT
                        npm ERR! errno -2
                        npm ERR! syscall rename
                        npm ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/npm/node_modules/ansistyles' -> '/opt/iobroker/node_modules/npm/node_modules/.ansistyles.DELETE'
                        npm ERR! enoent This is related to npm not being able to find a file.
                        npm ERR! enoent
                        npm ERR!     /root/.npm/_logs/2018-02-02T19_40_55_092Z-debug.log
                        node -v bringt sagt mir v9.4.0
                        Ich hoffe ihr habt noch einen Tip für mich.
                        Gruß Peer
                        • eric2905E Offline
                          eric2905E Offline
                          eric2905
                          Node v9 (ungerade Zahlen sind übrigens Entwickler-Versionen, die man nur nutzen sollte, „wenn man weiß, was man tut“) bringt npm v5 mit. Und damit gibt es bekanntermaßen Probleme mit ioBroker.
                          Downgrade auf Node 6 (bringt npm 3 oder 4 mit).
                          Dann weiter probieren.
                          Gruß,
                          Eric
                          Von unterwegs getippert
                          • C Offline
                            C1500
                            Servus Eric
                            bin wieder einen Schritt weiter aber noch nicht am Ziel ;o)
                            pi@ioBroker-Pi3:/opt/iobroker $ node -v
                            v6.12.3
                            > iobroker.js-controller@1.2.3 install /opt/iobroker/node_modules/iobroker.js-controller
                            > node iobroker.js setup first
                            iobroker@1.0.0 /opt/iobroker
                            └─┬ iobroker.js-controller@1.2.3
                              └─┬ npm@2.15.12
                                ├── ansistyles@0.1.3
                                └── path-is-inside@1.0.2
                            npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.discovery/package.json'
                            npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.node-red/package.json'
                            Was nun?
                            Sorry bin nicht so fit in Linux…
                            • eric2905E Offline
                              eric2905E Offline
                              eric2905
                              Ich denke, ein
                              npm -v
                              bringt 2.15.x - zumindest laut dem Log-Auszug.
                              Du solltest auch npm updaten (v3 oder 4).
                              npm install -g npm@4
                              Gruß,
                              Eric
                              • C Offline
                                C1500
                                Servus
                                Jetzt startet ioBroker zwar (ganz neue optik?)
                                Aber alle Adapter außer Admin bleiben rot
                                Help please ;o)
                                • eric2905E Offline
                                  eric2905E Offline
                                  eric2905
                                  Das ist der Admin 3.
                                  Stehen Updates an?
                                  Gruß,
                                  Eric
                                  • C Offline
                                    C1500
                                    Servus Eric
                                    Kam erst jetzt zum weitermachen.
                                    Bisher kannte ich nur den Admin 3
                                    Hab ein "sudo iobroker update" probiert.
                                    Erster Eintrag dann direkt "Adapter "admin" : 2.0.9 , installed 3.1.7"
                                    Er nutzt also anscheinend den 2.0.9 obwohl der 3.1.7 installier ist.
                                    Im ioBroker selber steht rechts oben sogar das er 2.0.7 nutzt
                                    Sehr verwirrend
                                    Aber das könnte das Probelm mit den Adaptern erklären die nicht wie bisher normal funktoieren.
                                    Wie kann ich ioBroker denn davon überzeugen, das er die neue und schon installierten 3.1.7 nutzen soll?
                                    So, jetzt wird es noch schlimmer
                                    Ich hab versucht im über den Github ein Upgrade zu machen.
                                    Nach der Meldung "Erfolgreich" ging gar nix mehr.
                                    Jetzt steht da nur noch "cannot GET /"
                                    Hat noch jemand eine hilfreiche Idee?
                                    Gruß Peer
                                    Nachtrag:
                                    Das sind jetzt die aktuellen Versionen:
                                    pi@ioBroker-Pi3:/opt/iobroker $ iobroker admin -v
                                    3.1.10
                                    pi@ioBroker-Pi3:/opt/iobroker $ npm -v
                                    4.6.1
                                    v6.12.3
                                    Hier noch die Ausgabe von "sudo iobroker update"
                                    ! pi@ioBroker-Pi3:/opt/iobroker $ sudo iobroker update
                                    ! Used repository: default
                                    ! update done
                                    ! Adapter "admin" : 2.0.9 , installed 3.1.10
                                    ! Adapter "amazon-dash" : 0.2.7
                                    ! Adapter "artnet" : 0.1.6
                                    ! Adapter "b-control-em" : 0.2.1
                                    ! Adapter "benq" : 0.2.0
                                    ! Adapter "ble" : 0.3.4
                                    ! Adapter "bmw" : 1.3.1
                                    ! Adapter "botvac" : 1.0.0
                                    ! Adapter "broadlink2" : 1.8.0
                                    ! Adapter "chromecast" : 1.3.5
                                    ! Adapter "cloud" : 2.4.4 , installed 2.4.4
                                    ! Adapter "cul" : 0.2.2
                                    ! Adapter "daikin" : 0.2.3
                                    ! Adapter "daswetter" : 1.0.1
                                    ! Adapter "deconz" : 0.1.1
                                    ! Adapter "discovery" : 1.0.1
                                    ! Adapter "dwd" : 2.2.1 , installed 2.2.1
                                    ! Adapter "egigeozone" : 0.1.2
                                    ! Adapter "email" : 1.0.2
                                    ! Adapter "epson_stylus_px830": 0.0.2
                                    ! Adapter "fakeroku" : 0.2.1
                                    ! Adapter "feiertage" : 1.0.0
                                    ! Adapter "fhem" : 0.4.1
                                    ! Adapter "find-my-iphone": 0.2.15
                                    ! Adapter "firetv" : 0.0.27
                                    ! Adapter "flot" : 1.7.5 , installed 1.7.5
                                    ! Adapter "foobar2000" : 1.0.0
                                    ! Adapter "fritzbox" : 0.2.1
                                    ! Adapter "fritzdect" : 0.0.10
                                    ! Adapter "fronius" : 1.0.2
                                    ! Adapter "fullcalendar" : 0.2.4
                                    ! Adapter "g-homa" : 0.2.0
                                    ! Adapter "geofency" : 0.2.0
                                    ! Adapter "haier" : 1.0.0
                                    ! Adapter "harmony" : 0.9.0
                                    ! Adapter "hid" : 0.1.16
                                    ! Adapter "history" : 1.6.3 , installed 1.7.1
                                    ! Adapter "hm-rega" : 1.6.6 , installed 1.7.0
                                    ! Adapter "hm-rpc" : 1.4.14 , installed 1.5.1
                                    ! Adapter "hmm" : 1.0.1
                                    ! Adapter "homepilot" : 0.3.1
                                    ! Adapter "hue" : 0.6.9
                                    ! Adapter "ical" : 1.4.0 , installed 1.4.0
                                    ! Adapter "icons-addictive-flavour-png": 0.1.0
                                    ! Adapter "icons-fatcow-hosting": 0.1.0
                                    ! Adapter "icons-icons8" : 0.0.1
                                    ! Adapter "icons-material-png": 0.1.0
                                    ! Adapter "icons-material-svg": 0.1.0
                                    ! Adapter "icons-mfd-png" : 1.0.2
                                    ! Adapter "icons-mfd-svg" : 1.0.2
                                    ! Adapter "icons-open-icon-library-png": 0.1.3
                                    ! Adapter "icons-ultimate-png": 1.0.1
                                    ! Adapter "influxdb" : 1.4.5
                                    ! Adapter "innogy-smarthome": 0.1.17
                                    ! Adapter "javascript" : 3.5.1 , installed 3.6.3
                                    ! Controller "js-controller" : 1.2.3 , installed 1.2.3
                                    ! Adapter "js2fs" : 0.1.3
                                    ! Adapter "km200" : 1.1.6
                                    ! Adapter "knx" : 0.8.6
                                    ! Adapter "kodi" : 1.0.0
                                    ! Adapter "landroid" : 1.0.0
                                    ! Adapter "lgtv" : 1.0.2
                                    ! Adapter "lgtv-rs" : 0.0.4
                                    ! Adapter "lifx" : 0.0.4
                                    ! Adapter "lightify" : 0.2.16
                                    ! Adapter "loxone" : 0.4.0
                                    ! Adapter "maxcul" : 0.3.0
                                    ! Adapter "megad" : 1.2.1
                                    ! Adapter "megadd" : 0.2.0
                                    ! Adapter "megaesp" : 0.1.0 , installed 0.1.0
                                    ! Adapter "miele" : 0.1.5
                                    ! Adapter "mihome" : 1.0.4
                                    ! Adapter "mihome-plug" : 0.1.1
                                    ! Adapter "mihome-vacuum" : 0.6.0
                                    ! Adapter "mikrotik" : 1.0.0
                                    ! Adapter "milight" : 0.3.3 , installed 0.3.3
                                    ! Adapter "milight-smart-light": 0.0.5
                                    ! Adapter "mobile" : 0.4.11 , installed 0.4.11
                                    ! Adapter "modbus" : 1.0.3
                                    ! Adapter "mpd" : 1.0.0
                                    ! Adapter "mqtt" : 1.4.1 , installed 1.4.2
                                    ! Adapter "mqtt-client" : 1.0.1
                                    ! Adapter "mysensors" : 1.0.10
                                    ! Adapter "netatmo" : 1.3.0
                                    ! Adapter "node-red" : 1.4.1
                                    ! Adapter "noolite" : 0.0.1
                                    ! Adapter "nut" : 1.1.1
                                    ! Adapter "onkyo" : 0.2.1
                                    ! Adapter "openhab" : 0.2.1
                                    ! Adapter "opi" : 0.1.1
                                    ! Adapter "owfs" : 0.4.1
                                    ! Adapter "owntracks" : 0.2.0
                                    ! Adapter "panasonic-viera": 0.1.0
                                    ! Adapter "parser" : 1.0.1
                                    ! Adapter "paw" : 0.0.7 , installed 0.0.7
                                    ! Adapter "phantomjs" : 0.1.2
                                    ! Adapter "piface" : 1.0.0
                                    ! Adapter "pimatic" : 0.1.5
                                    ! Adapter "ping" : 1.3.2
                                    ! Adapter "proxy" : 0.2.0
                                    ! Adapter "pushbullet" : 0.0.11
                                    ! Adapter "pushover" : 1.0.4
                                    ! Adapter "pushsafer" : 0.1.7
                                    ! Adapter "radar" : 1.1.3
                                    ! Adapter "rflink" : 1.1.6
                                    ! Adapter "rickshaw" : 0.4.5
                                    ! Adapter "rpi2" : 0.3.2 , installed 0.3.2
                                    ! Adapter "rwe-smarthome" : 0.1.11
                                    ! Adapter "s7" : 1.1.3
                                    ! Adapter "samsung" : 0.2.9
                                    ! Adapter "sayit" : 1.6.6 , installed 1.6.6
                                    ! Adapter "sbfspot" : 2.0.1
                                    ! Adapter "scenes" : 1.0.2
                                    ! Adapter "simple-api" : 1.6.2 , installed 1.6.2
                                    ! Adapter "smartmeter" : 1.0.0
                                    ! Adapter "socketio" : 1.8.6 , installed 1.8.6
                                    ! Adapter "solarwetter" : 1.0.0
                                    ! Adapter "sonoff" : 1.0.0
                                    ! Adapter "sonos" : 1.6.2
                                    ! Adapter "sony-bravia" : 0.1.0
                                    ! Adapter "sql" : 1.5.6
                                    ! Adapter "squeezebox" : 0.2.1
                                    ! Adapter "starline" : 1.0.0
                                    ! Adapter "tankerkoenig" : 1.0.4 , installed 1.0.4
                                    ! Adapter "telegram" : 1.0.9 , installed 1.1.0
                                    ! Adapter "terminal" : 0.1.2
                                    ! Adapter "text2command" : 1.1.6
                                    ! Adapter "tr-064" : 0.4.14 , installed 0.4.17
                                    ! Adapter "tradfri" : 1.0.6
                                    ! Adapter "tvspielfilm" : 1.0.4
                                    ! Adapter "unifi" : 0.3.1
                                    ! Adapter "upnp" : 0.3.6 , installed 0.3.6
                                    ! Adapter "vcard" : 0.0.9
                                    ! Adapter "viessmann" : 0.2.6 , installed 0.4.0
                                    ! Adapter "vis" : 1.1.1 , installed 1.1.1
                                    ! Adapter "vis-bars" : 0.1.4
                                    ! Adapter "vis-canvas-gauges": 0.1.5 , installed 0.1.5
                                    ! Adapter "vis-colorpicker": 1.1.1 , installed 1.1.1
                                    ! Adapter "vis-fancyswitch": 1.1.0
                                    ! Adapter "vis-google-fonts": 0.1.0
                                    ! Adapter "vis-history" : 0.2.7 , installed 0.2.7
                                    ! Adapter "vis-hqwidgets" : 1.1.1 , installed 1.1.1
                                    ! Adapter "vis-jqui-mfd" : 1.0.9
                                    ! Adapter "vis-justgage" : 1.0.0
                                    ! Adapter "vis-keyboard" : 0.0.2
                                    ! Adapter "vis-lcars" : 1.0.4
                                    ! Adapter "vis-map" : 1.0.1
                                    ! Adapter "vis-metro" : 1.1.2
                                    ! Adapter "vis-players" : 0.1.5
                                    ! Adapter "vis-plumb" : 1.0.1 , installed 1.0.1
                                    ! Adapter "vis-rgraph" : 0.0.2
                                    ! Adapter "vis-timeandweather": 1.1.7 , installed 1.1.7
                                    ! Adapter "vis-weather" : 1.1.2
                                    ! Adapter "weatherunderground": 1.1.1
                                    ! Adapter "web" : 2.1.9 , installed 2.1.9
                                    ! Adapter "wetty" : 0.1.1
                                    ! Adapter "wifilight" : 0.2.0
                                    ! Adapter "wm-bus" : 0.1.12
                                    ! Adapter "wolf" : 0.9.2
                                    ! Adapter "xs1" : 1.0.2
                                    ! Adapter "yahka" : 0.5.5
                                    ! Adapter "yamaha" : 0.3.18
                                    ! Adapter "yr" : 1.0.6
                                    ! Adapter "zwave" : 1.0.0
                                    Nachtrag 2:
                                    Komischerweise funktioniert die VIS und ich kann auch die eine MiLight Lampe die aktuell in der VIS ist schalten.
                                    Nur http://iobroker:8081 bringt den Fehler…
                                    • C Offline
                                      C1500
                                      Hi
                                      immerhin läuft jetzt eine Admin Instanz wieder
                                      Was mich total verwirrt ist die Angabe der Version von Admin.
                                      Installiert 3.1.11 Verfügbar 2.0.9 und rechts oben dann ioBroker.admin 2.0.7
                                      Hier ein Screenshot:
                                      Ist das die Alte oder neue Optik von ioBroker?
                                      Ich kannte bisher nur die andere ohne großes Logo links oben.
                                      Unter Instanzen bleiben so gut wie alle Instanzen rot.
                                      Ich hoffe mir kann jemand helfen.
                                      Gruß Peer
                                        Arnulf
                                        leider scheint diese Lösung wohl nicht mehr zu funktionieren.
                                        Eine andere Lösung
                                        cd /opt/iobroker
                                        sudo rm -rf node_modules
                                        curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/stable-installer/installer.sh | bash -
                                        Bring mir leider nur den Fehler, dass iobroker nicht über iobroker installiert werden kann.
                                        Obwohl ich der Meinung bin, dass mit den ersten Befehlen alles (bis auf die Daten) gelöscht werden würde
                                        Hat jemand ein erbarmen mit mir?
                                        stephan1827S 1 Antwort Letzte Antwort
                                        • A Arnulf
                                          Eine andere Lösung
                                          cd /opt/iobroker
                                          stephan1827S Offline
                                          stephan1827
                                          pi@raspberrypi:/opt/iobroker/node_modules $ sudo npm install iobroker.js-controller --production
                                          npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                          npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                          > iobroker.js-controller@4.0.21 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                                          > node lib/preinstallCheck.js
                                          NPM version: 6.14.16
                                          > iobroker.js-controller@4.0.21 install /opt/iobroker/node_modules/iobroker.js-controller
                                          Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
                                          Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
                                          Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iob.bat'
                                          Uncaught Rejection: Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
                                              at Object.mkdirSync (fs.js:921:3)
                                              at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:1054:16)
                                              at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:571:23)
                                              at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3314:5)
                                              at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24)
                                              at Module._compile (internal/modules/cjs/loader.js:999:30)
                                              at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
                                              at Module.load (internal/modules/cjs/loader.js:863:32)
                                              at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                                              at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
                                          npm ERR! errno 6
                                          npm ERR! iobroker.js-controller@4.0.21 install: `node iobroker.js setup first`
                                          npm ERR! Exit status 6
                                          npm ERR!
                                          npm ERR! Failed at the iobroker.js-controller@4.0.21 install script.
                                          npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                                          npm ERR!     /root/.npm/_logs/2022-04-29T04_58_56_926Z-debug.log
                                          Bei mir startet iobroker ebenfalls nicht mehr. Ich habe versucht js neu zu installieren aber bekomme eine Fehlermeldung. Der Ordner /opt/iobroker/node_modules/iobroker.js-controller existiert nicht. Hat jemand noch eine Idee?
                                          Stephan
