  4. Installation issues due to npm node.js version compatibility
installnpm versionnode.js
2 Beiträge 2 Kommentatoren 1.2k Aufrufe 1 Beobachtet
    matyi
    Hello all,
    I started using ioBroker yesterday and it took me till today to get it started. I guess it's good to share the experience to improve the scripts/workflow/documentation. I was going through the following while until setting up ioBorder successfully (roughly reproduced):
    1. trial:
    • setting up a VM with Debian Buster including updating the system.
    • First I was following the instructions using this guide: https://www.iobroker.net/docu/index-15.htm?page_id=8323&lang=de
      I googled for the current node.js version and installed version 10.x intuitively. Axecuting the following command indicated my main issue already
    node -v
    nodejs -v
    npm -v
    the command npm couln'd be found! I simply ignored this issueand installted ioBroker. I couldn't load the ioBroker configuration page.
    1. trial:
    • uninstalled all packages by using:
    update-rc.d iobroker.sh remove
    sudo apt-get remove nodejs
    sudo apt-get remove npm
    • Subsequently, I used the following instructions to install your software: https://www.iobroker.net/#de/download
    • some warnings appeared during installation including that npm is not compatible with the installed nodejs version. I couldn't load the ioBroker configuration page again.
    • I tried to fix this issue by using this troubleshooting instruchtions https://www.iobroker.net/docu/index-26.htm?page_id=3928&lang=de and installing the recent version of npm:
    curl https://www.npmjs.com/install.sh | sudo sh
    from here: https://github.com/nodejs/help/issues/1877
    however no success again
    1. trial
    • since I lost the overview of installed software I reseted the VM to the point after updating the operating system.
    • Again I tried to use the instructions from here: https://www.iobroker.net/#de/download without success.
    • After reseting again I used the following sequence of commands:
    curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
    sudo apt-get install -y nodejs
    curl -sL https://iobroker.net/install.sh | bash -
    With success!!! Now I'm happy to be able to load the web interface of ioBroker. 😊
    I'm curious to learn how it works 😀
    Cheers,
    Matyi
    Systemdata
    Hardwaresystem: Virtual Box
    Arbeitsspeicher: 1GB
    Festplattenart: 8 GB
    Betriebssystem: Debian Buster with Raspberry Pi Desktop
    Node-Version: 10.15.2
    Nodejs-Version: 10.15.2
    NPM-Version: 6.13.7
    Installationsart: Skript
    Image genutzt: Nein
    • M matyi
      Hello all,
      1. trial:
      node -v
      nodejs -v
      npm -v
      1. trial:
      1. trial
      Cheers,
      Matyi
      Systemdata
      NPM-Version: 6.13.7
      Image genutzt: Nein
      @matyi sagte in Installation issues due to npm node.js version compatibility:
      This ist outdated!
      This is the actual version:
      https://www.iobroker.net/#en/documentation/install/linux.md
      floow the link to the docu in the header of the forum
