  4. hm-rpc bleibt gelb
hm-rpc bleibt gelb
hm-rpc
3 Beiträge 2 Kommentatoren 219 Aufrufe 1 Beobachtet
    Malz1902
    Hallo meine beiden Instanzen hm-rbc0 nund hm-rpc1 bleiben gelb. hm-rega ist grün und klappt.
    Hier er Log:
    hm-rpc.0	2020-02-07 09:58:18.405	error	(3099) init error: Error: Unknown XML-RPC tag 'TITLE'
    hm-rpc.0	2020-02-07 09:58:18.397	debug	(3099) xmlrpc -> 192.168.188.64:2001/ init ["http://192.168.188.64:2002","hm-rpc.0"]
    hm-rpc.1	2020-02-07 09:58:16.030	error	(3089) init error: Error: Unknown XML-RPC tag 'TITLE'
    hm-rpc.1	2020-02-07 09:58:16.021	debug	(3089) xmlrpc -> 192.168.188.64:2010/ init ["http://192.168.188.64:2011","hm-rpc.1"]
    hm-rpc.0	2020-02-07 09:57:48.413	error	(3099) init error: Error: Unknown XML-RPC tag 'TITLE'
    hm-rpc.0	2020-02-07 09:57:48.397	debug	(3099) xmlrpc -> 192.168.188.64:2001/ init ["http://192.168.188.64:2002","hm-rpc.0"]
    hm-rpc.1	2020-02-07 09:57:46.027	error	(3089) init error: Error: Unknown XML-RPC tag 'TITLE'
    hm-rpc.1	2020-02-07 09:57:46.021	debug	(3089) xmlrpc -> 192.168.188.64:2010/ init ["http://192.168.188.64:2011","hm-rpc.1"]
    hm-rpc.0	2020-02-07 09:57:43.132	debug	(3099) system.adapter.admin.0: logging true
    hm-rpc.1	2020-02-07 09:57:43.131	debug	(3089) system.adapter.admin.0: logging true
    hm-rpc.0	2020-02-07 09:57:18.416	error	(3099) init error: Error: Unknown XML-RPC tag 'TITLE'
    hm-rpc.0	2020-02-07 09:57:18.396	debug	(3099) start connecting interval
    hm-rpc.0	2020-02-07 09:57:18.382	debug	(3099) xmlrpc -> 192.168.188.64:2001/ init ["http://192.168.188.64:2002","hm-rpc.0"]
    hm-rpc.0	2020-02-07 09:57:18.381	debug	(3099) Connect...
    hm-rpc.0	2020-02-07 09:57:18.379	info	(3099) xmlrpc client is trying to connect to 192.168.188.64:2001/ with ["http://192.168.188.64:2002","hm-rpc.0"]
    hm-rpc.0	2020-02-07 09:57:18.379	info	(3099) xmlrpc server is trying to listen on 192.168.188.64:2002
    hm-rpc.0	2020-02-07 09:57:16.483	debug	(3099) [META] Meta data updated
    hm-rpc.0	2020-02-07 09:57:16.167	info	(3099) starting. Version 1.12.6 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v10.18.1
    hm-rpc.1	2020-02-07 09:57:16.041	error	(3089) init error: Error: Unknown XML-RPC tag 'TITLE'
    hm-rpc.1	2020-02-07 09:57:16.020	debug	(3089) start connecting interval
    hm-rpc.1	2020-02-07 09:57:16.006	debug	(3089) xmlrpc -> 192.168.188.64:2010/ init ["http://192.168.188.64:2011","hm-rpc.1"]
    hm-rpc.1	2020-02-07 09:57:16.005	debug	(3089) Connect...
    hm-rpc.1	2020-02-07 09:57:16.004	info	(3089) xmlrpc client is trying to connect to 192.168.188.64:2010/ with ["http://192.168.188.64:2011","hm-rpc.1"]
    hm-rpc.1	2020-02-07 09:57:16.003	info	(3089) xmlrpc server is trying to listen on 192.168.188.64:2011
    hm-rpc.1	2020-02-07 09:57:14.787	debug	(3089) [META] Meta data updated
    hm-rpc.1	2020-02-07 09:57:14.549	info	(3089) starting. Version 1.12.6 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v10.18.1
    hm-rpc.0	2020-02-07 09:57:14.169	debug	(3099) statesDB connected
    hm-rpc.0	2020-02-07 09:57:14.169	debug	(3099) States connected to redis: 127.0.0.1:9000
    hm-rpc.0	2020-02-07 09:57:14.152	debug	(3099) States create System PubSub Client
    hm-rpc.0	2020-02-07 09:57:14.150	debug	(3099) States create User PubSub Client
    hm-rpc.0	2020-02-07 09:57:14.139	debug	(3099) Redis States: Use Redis connection: 127.0.0.1:9000
    hm-rpc.0	2020-02-07 09:57:14.137	debug	(3099) objectDB connected
    hm-rpc.0	2020-02-07 09:57:14.127	debug	(3099) Objects connected to redis: 127.0.0.1:9001
    hm-rpc.0	2020-02-07 09:57:14.104	debug	(3099) Objects client initialize lua scripts
    hm-rpc.0	2020-02-07 09:57:14.104	debug	(3099) Objects create User PubSub Client
    hm-rpc.0	2020-02-07 09:57:14.102	debug	(3099) Objects create System PubSub Client
    hm-rpc.0	2020-02-07 09:57:14.098	debug	(3099) Objects client ready ... initialize now
    hm-rpc.0	2020-02-07 09:57:14.050	debug	(3099) Redis Objects: Use Redis connection: 127.0.0.1:9001
    hm-rpc.1	2020-02-07 09:57:13.411	debug	(3089) statesDB connected
    hm-rpc.1	2020-02-07 09:57:13.410	debug	(3089) States connected to redis: 127.0.0.1:9000
    hm-rpc.1	2020-02-07 09:57:13.391	debug	(3089) States create System PubSub Client
    hm-rpc.1	2020-02-07 09:57:13.388	debug	(3089) States create User PubSub Client
    hm-rpc.1	2020-02-07 09:57:13.377	debug	(3089) Redis States: Use Redis connection: 127.0.0.1:9000
    hm-rpc.1	2020-02-07 09:57:13.371	debug	(3089) objectDB connected
    hm-rpc.1	2020-02-07 09:57:13.355	debug	(3089) Objects connected to redis: 127.0.0.1:9001
    hm-rpc.1	2020-02-07 09:57:13.324	debug	(3089) Objects client initialize lua scripts
    hm-rpc.1	2020-02-07 09:57:13.323	debug	(3089) Objects create User PubSub Client
    hm-rpc.1	2020-02-07 09:57:13.321	debug	(3089) Objects create System PubSub Client
    hm-rpc.1	2020-02-07 09:57:13.316	debug	(3089) Objects client ready ... initialize now
    hm-rpc.1	2020-02-07 09:57:13.231	debug	(3089) Redis Objects: Use Redis connection: 127.0.0.1:9001
      Malz1902
      die LED an der Zentrale die am Pi angeschlossen leuchtet auch rot. Habe auch schon den Pi neugestartet
      • M Malz1902
        Hier er Log:
        @Malz1902 sagte in hm-rpc bleibt gelb:
        • was sind das für welche
        • und wie ist die Konfiguration?
        • Was ist in der Firewall der CCU eingestellt?
        • was steht im log bei restart der Instanzen?
        • was steht im Mouseover bei der Ampel?
        82.9k
