  4. Fehler NUC Debian Iobroker Visualisierung
iobroker vis
1 Beiträge 1 Kommentatoren 165 Aufrufe 1 Beobachtet
    digino
    Systemdata Bitte Ausfüllen
    Hardwaresystem: NUC Intel(R) Core(TM) i5-7260U
    Arbeitsspeicher: 16GB
    Festplattenart: 256 SSD M.2
    Betriebssystem: Debian 10.2.0
    Node-Version: 10.18.1
    Nodejs-Version: 10.18.1
    NPM-Version: 6.13.4
    Installationsart: Skript/Manuell
    Image genutzt: Ja/Nein
    Ort/Name der Imagedatei: Link
    Ich bekomme bei der Installation von iobroker folgende Fehler.
        Installing ioBroker (3/4)
    In file included from ../src/main.cpp:3:
    ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
    ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’}  -Wcast-function-type]
         , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
    In file included from ../../nan/nan.h:54,
    ../src/main.cpp: At global scope:
    /root/.cache/node-gyp/10.18.1/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /root/.cache/node-gyp/10.18.1/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(diskusage, Init)
    In file included from /root/.cache/node-gyp/10.18.1/include/node/node.h:63,
    /root/.cache/node-gyp/10.18.1/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
    /root/.cache/node-gyp/10.18.1/include/node/node_object_wrap.h:84:78:   required from here
    /root/.cache/node-gyp/10.18.1/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                    reinterpret_cast<Callback>(callback), type);
    /root/.cache/node-gyp/10.18.1/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
    ../../nan/nan_object_wrap.h:65:61:   required from here
    /root/.cache/node-gyp/10.18.1/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
    In file included from ../src/unix_dgram.cc:5:
    ../src/unix_dgram.cc: At global scope:
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(unix_dgram, Initialize)
    Some packets could not be installed. Please install them manually
        Finalizing installation (4/4)
    Enabling autostart...
    Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service.
    Autostart enabled!
        ioBroker was installed successfully
        Open http://192.168.2.111:8081 in a browser and start configuring!
    iobroker lässt sich auch starten, aber wenn ich vis installiere bekomme ich immer folgenden fehler : main/vis-views.json Not exists danach Keine Views am Server gefunden am.
    Erzeugen main/vis-views.json? wenn ich ein neues projekt anlegen will der selbe fehler...
    Ich habe schon die platte getauscht den speicher alles mit su und su - immer das selbe ergebnis... kann mir hier wer helfen?
    Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
