  4. HM-RPC Adapter starten nicht mehr!
hm-rpcdebmaticiobroker
28 Beiträge 3 Kommentatoren 3.3k Aufrufe 2 Beobachtet
  • M Michi_Pi
    @foxriver76 nein leider nicht, war zwar grün und auch nur der hm-rpc.1 aber es wurden keine Daten von den Geräten empfangen.
    hab jetzt mal den debug modus noch gestartet
    hm-rpc.1	2020-01-23 21:20:30.251	error	(32310) init error: Error: Unknown XML-RPC tag 'TITLE'
    hm-rpc.1	2020-01-23 21:20:30.238	debug	(32310) xmlrpc -> 192.168.178.6:2010/ init ["http://127.0.0.1:2011","hm-rpc.1"]
    hm-rpc.0	2020-01-23 21:20:14.791	error	(32275) init error: Error: Unknown XML-RPC tag 'TITLE'
    hm-rpc.0	2020-01-23 21:20:14.719	debug	(32275) start connecting interval
    hm-rpc.0	2020-01-23 21:20:14.677	debug	(32275) xmlrpc -> 192.168.178.6:2001/ init ["http://192.168.178.6:1024","hm-rpc.0"]
    hm-rpc.0	2020-01-23 21:20:14.674	debug	(32275) Connect...
    hm-rpc.0	2020-01-23 21:20:14.668	info	(32275) xmlrpc client is trying to connect to 192.168.178.6:2001/ with ["http://192.168.178.6:1024","hm-rpc.0"]
    hm-rpc.0	2020-01-23 21:20:14.665	info	(32275) xmlrpc server is trying to listen on 192.168.178.6:1024
    hm-rpc.1	2020-01-23 21:20:00.252	error	(32310) init error: Error: Unknown XML-RPC tag 'TITLE'
    hm-rpc.1	2020-01-23 21:20:00.237	debug	(32310) xmlrpc -> 192.168.178.6:2010/ init ["http://127.0.0.1:2011","hm-rpc.1"]
    hm-rpc.1	2020-01-23 21:19:30.261	error	(32310) init error: Error: Unknown XML-RPC tag 'TITLE'
    hm-rpc.1	2020-01-23 21:19:30.237	debug	(32310) xmlrpc -> 192.168.178.6:2010/ init ["http://127.0.0.1:2011","hm-rpc.1"]
    hm-rpc.1	2020-01-23 21:19:00.317	error	(32310) init error: Error: Unknown XML-RPC tag 'TITLE'
    hm-rpc.1	2020-01-23 21:19:00.235	debug	(32310) start connecting interval
    hm-rpc.1	2020-01-23 21:19:00.192	debug	(32310) xmlrpc -> 192.168.178.6:2010/ init ["http://127.0.0.1:2011","hm-rpc.1"]
    hm-rpc.1	2020-01-23 21:19:00.189	debug	(32310) Connect...
    hm-rpc.1	2020-01-23 21:19:00.183	info	(32310) xmlrpc client is trying to connect to 192.168.178.6:2010/ with ["http://127.0.0.1:2011","hm-rpc.1"]
    hm-rpc.1	2020-01-23 21:19:00.181	info	(32310) xmlrpc server is trying to listen on 127.0.0.1:2011
    hm-rpc.1	2020-01-23 21:18:57.079	info	(32310) [META] Meta data updated
    hm-rpc.1	2020-01-23 21:18:56.382	info	(32310) starting. Version 1.12.1 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v10.18.1
    hm-rpc.1	2020-01-23 21:18:55.777	debug	(32310) States connected to redis: 127.0.0.1:9000
    hm-rpc.1	2020-01-23 21:18:55.693	debug	(32310) statesDB connected
    hm-rpc.1	2020-01-23 21:18:55.689	debug	(32310) States create PubSub Client
    hm-rpc.1	2020-01-23 21:18:55.672	debug	(32310) Objects connected to redis: 127.0.0.1:9001
    hm-rpc.1	2020-01-23 21:18:55.662	debug	(32310) Redis States: Use Redis connection: 127.0.0.1:9000
    hm-rpc.1	2020-01-23 21:18:55.654	debug	(32310) objectDB connected
    hm-rpc.1	2020-01-23 21:18:55.604	debug	(32310) Objects client initialize lua scripts
    hm-rpc.1	2020-01-23 21:18:55.600	debug	(32310) Objects create PubSub Client
    hm-rpc.1	2020-01-23 21:18:55.586	debug	(32310) Objects client ready ... initialize now
    hm-rpc.1	2020-01-23 21:18:55.417	debug	(32310) Redis Objects: Use Redis connection: 127.0.0.1:9001
    foxriver76F Offline
    foxriver76F Offline
    foxriver76
    schrieb am zuletzt editiert von foxriver76
    @Michi_Pi und auf CCU Seite die Firewall korrekt konfiguriert? Wobei ich da ein anderes Fehlerbild erwarten würde.
    Lassen sich Geräte noch steuern via CCU? Und mal CCU Log posten am besten. Evtl findet man da was auffälliges.
    Videotutorials & mehr
    • foxriver76F foxriver76
      Michi_Pi
      schrieb am zuletzt editiert von Michi_Pi
      @foxriver76 unter debmatic habe ich keine Möglichkeit eine Firewall zu aktivieren, zumindest weis ich nicht wo.
      Geräte lassen sich nicht bedienen.
      die Log-Datei von der CCU ist ziemlich groß und ich konnte da nichts auffälliges finden, außer diesen Log
      Jan 13 00:23:03 raspberrypi kernel: [ 2051.837181] rpi_firmware_get_throttled: 7 callbacks suppressed
      Jan 13 00:23:03 raspberrypi kernel: [ 2051.837186] Voltage normalised (0x00000000)
      • M Michi_Pi
        foxriver76F Offline
        foxriver76F Offline
        foxriver76
        @Michi_Pi Kam das einmalig im Log oder kommt das häufig?
          Michi_Pi
          @foxriver76 das kam sehr häufig!
          • foxriver76F Offline
            foxriver76F Offline
            foxriver76
            Scheint bei Undervoltage aufzutreten. Kannst du sehen ob die Fehlermeldungen schon da waren, als noch alles stabil lief? Ansonsten könnte es durchaus damit zusammenhängen.
            Ansonsten würde ich mal im HM Forum nachfragen, da ist der Entwickler Alex Reinert meines Wissens nach auch sehr aktiv, da ich das Problem eher auf der 'CCU' Seite sehe und er sich da sicher besser auskennt.
            M 2 Antworten Letzte Antwort
              Michi_Pi
              @foxriver76 hab gerade nachgesehen, der Fehler trat vorher auch schon auf.
              Okay, danke schon mal. :)
                Michi_Pi
                @foxriver76 hab mich jetzt nochmal ein wenig gespielt. Hab die debmatic info nochmal abgerufen und dabei kommt folgendes
                debmatic version: 3.49.17-40
                Kernel modules: Not available
                Raw UART dev:   Not available
                Rasp.Pi3 UART:  Assigned to GPIO pins
                HMRF Hardware:  unknown
                HMIP Hardware:  unknown
                Board serial:   unknown
                Radio MAC:      unknown
                SGTIN:          unknown
                Es wird das Funkmodul schon gar nicht erkannt.
                Jetzt wollt ich mir das genauer anschauen, hab aber gesehen dass ich "ttyAMA0" gar nicht mehr auf dem System habe, finde die Datei auch gar nicht dazu. Kann das sein? Oder hab ich die Anbindung zu "ttyS0"
                lrwxrwxrwx 1 root root  5 Jan 24 16:58 /dev/serial1 -> ttyS0
                /dev/serial:
                insgesamt 0
                drwxr-xr-x 2 root root 60 Jan 24 16:55 by-id
                drwxr-xr-x 2 root root 60 Jan 24 16:55 by-path
                wie kann ich ttyAMA0 wieder anlegen?
                • M Michi_Pi
                  Radio MAC:      unknown
                  SGTIN:          unknown
                  /dev/serial:
                  insgesamt 0
                  foxriver76F Offline
                  foxriver76F Offline
                  foxriver76
                  @Michi_Pi sorry, da bin ich raus. Wie gesagt, Alex kann dir bestimmt weiterhelfen.
