  4. KNX Adapter stürzt nach Warnung ab
knxdptdatenpunkt
1 Beiträge 1 Kommentatoren 209 Aufrufe 1 Beobachtet
  • C Offline
    cortezz
    Moin moin,
    ich gebe einen wert über ein input-Feld an eine GA. Dies soll ein wert 0-100% sein. Offenbar geht dies aber falsch an den adapter. Nachdem ich einen wert eingebe stürzt der KNX adapter ab und ich erhalte folgendes im log:
    2020-01-18 21:04:16.445 - warn: knx.0 (30431) States pmessage knx.0.Rolladen.Rolladen_Position.Rolladen_Position_Buero {"val":"80","ack":false,"ts":1579377856428,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1579377856428} The "list[1]" argument must be one of type Array, Buffer, or Uint8Array. Received type string
    2020-01-18 21:04:16.451 - warn: knx.0 (30431) TypeError [ERR_INVALID_ARG_TYPE]: The "list[1]" argument must be one of type Array, Buffer, or Uint8Array. Received type string
    at Function.concat (buffer.js:479:13)
    at CustomProtocolWriter.ProtocolWriter$raw [as raw] (/opt/iobroker/node_modules/binary-protocol/lib/writer.js:74:24)
    at CustomProtocolWriter.write (/opt/iobroker/node_modules/iobroker.knx/lib/knx-mod/src/KnxProtocol.js:415:14)
    at CustomProtocolWriter.(anonymous function) [as APDU] (/opt/iobroker/node_modules/binary-protocol/lib/writer.js:20:18)
    at CustomProtocolWriter.write (/opt/iobroker/node_modules/iobroker.knx/lib/knx-mod/src/KnxProtocol.js:501:8)
    at CustomProtocolWriter.(anonymous function) [as CEMI] (/opt/iobroker/node_modules/binary-protocol/lib/writer.js:20:18)
    at CustomProtocolWriter.write (/opt/iobroker/node_modules/iobroker.knx/lib/knx-mod/src/KnxProtocol.js:594:35)
    at CustomProtocolWriter.(anonymous function) [as KNXNetHeader] (/opt/iobroker/node_modules/binary-protocol/lib/writer.js:20:18)
    at fsm.FSM.send (/opt/iobroker/node_modules/iobroker.knx/lib/knx-mod/src/Connection.js:172:28)
    at fsm._onEnter (/opt/iobroker/node_modules/iobroker.knx/lib/knx-mod/src/FSM.js:236:14)
    Wie kann ich das Argument so anpassen, dass es passt? Ich habe "ganz normal" die ID aus der Liste für das Inputfeld gewählt. Ich nutze .Vis im MD CSS von Uhula.
    Danke für eure Unterstützung!
    Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
