  4. terminating http server on port 8081
terminating http server port 8erroriobroker absturzstartet nicht error
1 Beiträge 1 Kommentatoren 344 Aufrufe 1 Beobachtet
  • O Offline
    O Offline
    oggy1979
    schrieb am zuletzt editiert von oggy1979
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi4
    Arbeitsspeicher: 4GB
    Festplattenart: SD-Karte
    Betriebssystem: Raspbian light Buster
    Node-Version: 10.18.1
    Nodejs-Version: 10.18.1
    NPM-Version: 6.13.4
    Installationsart: Manuell
    Image genutzt: Ja
    Ort/Name der Imagedatei: https://www.iobroker.net/#de/download
    2020-01-14 18:35:28.356  - info: admin.0 (1437) terminating http server on port 8081
    2020-01-14 18:35:28.432  - info: admin.0 (1437) terminating
    2020-01-14 18:35:28.434  - info: admin.0 (1437) Terminated (NO_ERROR): Without reason
    2020-01-14 18:35:29.305  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read property 'isValidUTF8' of undefined
    2020-01-14 18:35:29.306  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/ws/lib/Receiver.js:532:29
    2020-01-14 18:35:29.306  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/ws/lib/Receiver.js:368:7
    2020-01-14 18:35:29.306  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/ws/lib/PerMessageDeflate.js:249:5
    2020-01-14 18:35:29.306  - error: host.raspberrypi Caught by controller[0]:     at afterWrite (_stream_writable.js:485:3)
    2020-01-14 18:35:29.306  - error: host.raspberrypi Caught by controller[0]:     at onwrite (_stream_writable.js:476:7)
    2020-01-14 18:35:29.307  - error: host.raspberrypi Caught by controller[0]:     at InflateRaw.afterTransform (_stream_transform.js:94:3)
    2020-01-14 18:35:29.307  - error: host.raspberrypi Caught by controller[0]:     at Zlib.processCallback (zlib.js:557:8)
    2020-01-14 18:35:29.307  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
    2020-01-14 18:35:29.307  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
    Fehler wird seit Neustart des Raspbian geloggt. Zuvor ist er durch einen Stromausfall leider wenige Sekunden vom Stromnetz getrennt gewesen :-/
    Was ist das bzw wie kann ich das lösen?
