  4. KNX adapter?
    5.7k
KNX adapter?
93 Beiträge 7 Kommentatoren 19.8k Aufrufe
  • L Offline
    LJTom
    #61
    HI!
    Nein leider :
    root@raspberrypi:~# systemctl status knxd.service
    ● knxd.service - KNX Daemon
       Loaded: loaded (/lib/systemd/system/knxd.service; enabled)
       Active: activating (auto-restart) (Result: exit-code) since Sa 2016-08-20 12:25:31 CEST; 7s ago
      Process: 2297 ExecStart=/usr/bin/knxd $KNXD_OPTS (code=exited, status=1/FAILURE)
     Main PID: 2297 (code=exited, status=1/FAILURE)
    Aug 20 12:25:31 raspberrypi systemd[1]: knxd.service: main process exited, c...E
    Aug 20 12:25:31 raspberrypi systemd[1]: Failed to start KNX Daemon.
    Aug 20 12:25:31 raspberrypi systemd[1]: Unit knxd.service entered failed state.
    Hint: Some lines were ellipsized, use -l to show in full.
    • ruhigundrelaxedR Offline
      ruhigundrelaxed
      #62
      Hmmm… was passiert denn wenn du:
      sudo /usr/bin/knxd --eibaddr=0.0.230 -u /tmp/eib -u /var/run/knx -i -DTRS -b ipt:192.168.1.106
      abfeuerst?
      iobroker auf debian bullseye amd64 (i5-8259U)
      homematic -> homegear -> HM-CFG-LAN ~> 11 x hm-cc-rt-dn | 3 x hm-sec-sd
      knx -> eibd -> SCN‐IP000.01 ~> 4 x AMS-1216.01 | (1 x JAL-0810.01 | 1 x JAL-0410.01) | 2 x BE-16000.01 | …
      • L Offline
        LJTom
        #63
        Da passiert:
        E00000013: OpenInetSocket 6720: bind: Address already in use
        initialisation of the knxd inet protocol failed: Address already in use
          ruhigundrelaxed
          #64
          Aha!
          Was sagt:````
          sudo netstat -tulpen|grep 6720
          • L Offline
            LJTom
            #65
            Das meint:
            tcp6       0      0 :::6720                 :::*                    LISTEN      0          7512        1/init
              ruhigundrelaxed
              #66
              sudo ps aux |grep eibd
              und
              sudo ps aux |grep knxd
              • L Offline
                LJTom
                #67
                root      1060  0.2  3.1 125832 29520 ?        Sl   11:57   0:05 io.eibd.0
                root      2650  0.0  0.1   4300  1840 pts/0    S+   12:41   0:00 grep eibd
                root      2662  0.0  0.1   4296  1812 pts/0    S+   12:41   0:00 grep knxd
                  ruhigundrelaxed
                  #68
                  Ich bin verwirrt….
                  Warum ist den der socket offen?
                  Was sagt:
                  systemctl -all list-sockets |grep 6720
                  • L Offline
                    LJTom
                    #69
                    Der sagt:
                    [::]:6720                       knxd.socket                     knxd.service
                      ruhigundrelaxed
                      #70
                      Aber trotzdem sagt systemd das der Dienst nicht startet…
                      Machmal:
                      > systemctl stop knxd
                      dannach nochmal schauen ob der socket zu ist:
                      • L Offline
                        LJTom
                        #71
                        Jetzt schauts so aus:
                        root@raspberrypi:~# systemctl stop knxd
                        Warning: Stopping knxd.service, but it can still be activated by:
                          knxd.socket
                        root@raspberrypi:~# systemctl -all list-sockets |grep 6720
                          ruhigundrelaxed
                          #72
                          Ich erinnere mich dunkel an einen cre podcast mit Lennart Poettering dem maintainer von systemd. Ein neues feature von systemd ist wohl, dass dienste "ondemand" gestartet werden können….
                          Das ist wohl hier der fall..
                          Versuch mal:
                          systemctl disable knxd
                          • L Offline
                            LJTom
                            #73
                            Mal kein fehler:
                            Synchronizing state for knxd.service with sysvinit using update-rc.d...
                            Executing /usr/sbin/update-rc.d knxd defaults
                            Executing /usr/sbin/update-rc.d knxd disable
                            insserv: warning: current start runlevel(s) (empty) of script `knxd' overrides LSB defaults (2 3 4 5).
                            insserv: warning: current stop runlevel(s) (0 1 2 3 4 5 6) of script `knxd' overrides LSB defaults (0 1 6).
                            Removed symlink /etc/systemd/system/sockets.target.wants/knxd.socket.
                              ruhigundrelaxed
                              #74
                              Ok…
                              jetzt nochmal:
                              Wenn alles gut ist, meckert er wegen root… egal...
                              • L Offline
                                LJTom
                                #75
                                Neeee leider
                                  ruhigundrelaxed
                                  #76
                                  Pfff.. Renitente Kiste…
                                  Dann auf die harte nummer:
                                  In "/etc/default/knxd" den daemon deaktivieren und neustarten (reboot).
                                  also:
                                  START_KNXD=YES -> START_KNXD=NO
                                  reboot
                                  dann nochmal:
                                  • L Offline
                                    LJTom
                                    #77
                                    Und wieder das selbe wie oben schon geschrieben.
                                      ruhigundrelaxed
                                      #78
                                      OK! Wieder was gelernt…
                                      Also:
                                      cd /etc/systemd/system/sockets.target.wants/
                                      mv knxd.socket knxd.socket_tmp
                                      reboot
                                      Probieren ob es nun geht…
                                      • L Offline
                                        LJTom
                                        #79
                                        Mal wieder was neues:
                                        root@raspberrypi:/etc/systemd/system/sockets.target.wants# mv knxd.socket knxd.socket_tmp
                                        mv: der Aufruf von stat für „knxd.socket“ ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                                          ruhigundrelaxed
                                          #80
                                          Sehr verwunderlich….
                                          was sagt: sudo systemctl disable knxd.socket
                                          was sagt: systemctl list-unit-files
