  4. Meldungen während frischer Installation
installationinstallationsfehler
1 Beiträge 1 Kommentatoren 556 Aufrufe 1 Beobachtet
  • tcjT Offline
    tcjT Offline
    tcj
    schrieb am zuletzt editiert von tcj
    ich installierte iobroker gerade auf einem ganz frisch aufgesetzten ubuntu server 19.10
    apt-get update & upgrade wurden auch noch gemacht
    per
    curl -sL https://iobroker.net/install.sh | bash -
    Dabei warf mir der Rechner dann folgende Meldungen entgegen
    Ist das
    • mein Fehler?
    • ubuntus Fehler?
    • Fehler im Installationsscript?
    • kein Fehler und kann ich ignorieren?
        Installing ioBroker (3/4)
    In file included from ../src/main.cpp:3:
    ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
    ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
     2298 |     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
    In file included from ../../nan/nan.h:54,
    ../src/main.cpp: At global scope:
    /home/thomas/.cache/node-gyp/10.18.1/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
      573 |       (node::addon_register_func) (regfunc),                          \
    /home/thomas/.cache/node-gyp/10.18.1/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
      607 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
       42 | NODE_MODULE(diskusage, Init)
    In file included from /home/thomas/.cache/node-gyp/10.18.1/include/node/node.h:63,
    /home/thomas/.cache/node-gyp/10.18.1/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
    /home/thomas/.cache/node-gyp/10.18.1/include/node/node_object_wrap.h:84:78:   required from here
    /home/thomas/.cache/node-gyp/10.18.1/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
     9502 |                reinterpret_cast<Callback>(callback), type);
    /home/thomas/.cache/node-gyp/10.18.1/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
    ../../nan/nan_object_wrap.h:65:61:   required from here
    /home/thomas/.cache/node-gyp/10.18.1/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
    In file included from ../src/unix_dgram.cc:5:
    ../src/unix_dgram.cc: At global scope:
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
      404 | NODE_MODULE(unix_dgram, Initialize)
    Thomas
    LG
    Thomas
    „Am Ende wird alles gut.
    Wenn es nicht gut wird,
    ist es noch nicht das Ende.“
