  4. Problem mit dem Unifi Adapter
unifi
9 Beiträge 5 Kommentatoren 2.3k Aufrufe 4 Beobachtet
    sectorchan
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Synology Diskstation DS 216+
    Arbeitsspeicher: 4GB
    Festplattenart: WD RED
    Betriebssystem: Synology DSM -Linux (Docker)
    Node-Version: 10.x.x
    Nodejs-Version: 10.17.10
    NPM-Version: 6.11.3
    Installationsart: Docker
    Image genutzt: Ja
    Ort/Name der Imagedatei: buanet iobroker
    Ich bekomme bei der LOG den folgenden Fehler:
    host.buanet-iobroker2	2020-01-08 10:52:21.736	error	Caught by controller[0]: at traverseArray (/opt/iobroker/node_modules/iobroker.unifi/main.js:165:7)
    host.buanet-iobroker2	2020-01-08 10:52:21.736	error	Caught by controller[0]: at Array.every (<anonymous>)
    host.buanet-iobroker2	2020-01-08 10:52:21.736	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.unifi/main.js:168:7
    host.buanet-iobroker2	2020-01-08 10:52:21.736	error	Caught by controller[0]: at traverse (/opt/iobroker/node_modules/iobroker.unifi/main.js:155:5)
    host.buanet-iobroker2	2020-01-08 10:52:21.736	error	Caught by controller[0]: at traverseObject (/opt/iobroker/node_modules/iobroker.unifi/main.js:178:27)
    host.buanet-iobroker2	2020-01-08 10:52:21.736	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.unifi/main.js:288:13
    host.buanet-iobroker2	2020-01-08 10:52:21.735	error	Caught by controller[0]: at traverseObject (/opt/iobroker/node_modules/iobroker.unifi/main.js:184:7)
    host.buanet-iobroker2	2020-01-08 10:52:21.735	error	Caught by controller[0]: at traverse (/opt/iobroker/node_modules/iobroker.unifi/main.js:156:32)
    host.buanet-iobroker2	2020-01-08 10:52:21.735	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.unifi/main.js:292:58
    host.buanet-iobroker2	2020-01-08 10:52:21.735	error	Caught by controller[0]: TypeError: Cannot read property 'subsystem' of null
    host.buanet-iobroker2	2020-01-09 09:57:40.721	error	Caught by controller[0]: at traverseArray (/opt/iobroker/node_modules/iobroker.unifi/main.js:165:7)
    host.buanet-iobroker2	2020-01-09 09:57:40.721	error	Caught by controller[0]: at Array.every (<anonymous>)
    host.buanet-iobroker2	2020-01-09 09:57:40.721	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.unifi/main.js:168:7
    host.buanet-iobroker2	2020-01-09 09:57:40.721	error	Caught by controller[0]: at traverse (/opt/iobroker/node_modules/iobroker.unifi/main.js:155:5)
    host.buanet-iobroker2	2020-01-09 09:57:40.721	error	Caught by controller[0]: at traverseObject (/opt/iobroker/node_modules/iobroker.unifi/main.js:178:27)
    host.buanet-iobroker2	2020-01-09 09:57:40.720	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.unifi/main.js:288:13
    host.buanet-iobroker2	2020-01-09 09:57:40.720	error	Caught by controller[0]: at traverse (/opt/iobroker/node_modules/iobroker.unifi/main.js:155:5)
    host.buanet-iobroker2	2020-01-09 09:57:40.720	error	Caught by controller[0]: at traverseObject (/opt/iobroker/node_modules/iobroker.unifi/main.js:184:7)
    host.buanet-iobroker2	2020-01-09 09:57:40.720	error	Caught by controller[0]: at traverse (/opt/iobroker/node_modules/iobroker.unifi/main.js:156:32)
    host.buanet-iobroker2	2020-01-09 09:57:40.720	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.unifi/main.js:292:58
    host.buanet-iobroker2	2020-01-09 09:57:40.719	error	Caught by controller[0]: TypeError: Cannot read property 'subsystem' of null
    unifi.0	2020-01-09 09:57:40.195	info	(15549) Terminated (NO_ERROR): Without reason
    unifi.0	2020-01-09 09:57:40.194	info	(15549) terminating
    unifi.0	2020-01-09 09:57:40.147	info	(15549) cleaned everything up...
    unifi.0	2020-01-09 09:57:40.143	error	(15549) TypeError: Cannot read property 'subsystem' of null at /opt/iobroker/node_modules/iobroker.unifi/main.js:292:58 at traverse (/opt/iobroker/node_modules/iobroker.unifi/main.js:156:32)
    unifi.0	2020-01-09 09:57:40.143	error	(15549) uncaught exception: Cannot read property 'subsystem' of null
    Ja das ist eine dumme floskel, aber da ich in der letzten Zeit keine Möglichkeit hatte an der iobroker Installation weiter zu konfigurieren, kommt nun dieser Fehler.
    Der Unifi Adapter hat auch schon gearbeitet und war Grün. Nun ist aber beides Rot, Verbunden mit Host und Lebenszeichen
    Wie ich das letzte mal geschaut habe (vor Weihnachten) waren alle Adapter Grün. Nun kommt diese Fehermeldung.
    Kann es ein Problem am Adapter sein? Denn auf den Unifi Controller (ebenfalls Docker Container, zugreifbar über Hostnetzwerk) funktioniert meines Erachtens Tadellos
    Mod-Edit: Code/Log in Code Tags gepackt und zusammengeführt. Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
      TorbenNW
      schrieb am zuletzt editiert von TorbenNW
      Ist glaube ich ein altbekannter Fehler. Der Adapter wird aktuell auch nicht weiterentwickelt und verbraucht recht viel Ressourcen.
      Eine Lösung wird hier angeboten:
      https://forum.iobroker.net/topic/4514/adapter-iobroker-unifi/255
      • T TorbenNW
        @TorbenNW sagte in Problem mit dem Unifi Adapter:
        ist glaube ich ein altbekannter Fehler.
        Läuft bei mir einwandfrei!
        das stimmt allerdings
        Ich vermute die Ursache eher hier:
        @sectorchan sagte in Problem mit dem Unifi Adapter:
        Da bin ich aber leider raus, da ich wegen solcher Probleme nicht mit Containern wie Docker oder lxc arbeite
          sectorchan
          Was hast du? Einen Cloud Key?
          Ich kann mir das schlecht vorstellen dass das an dem Docker liegen soll, da sich der Docker mit dem Hostnetzwerk, ja wie eine reale installation verhalten soll.
          Interessanterweise, lief es bei dieser IOBroker installation ca 2wochen :-/
          Ich teste es mal mit einer OSX Controller installation ohne Adaptierte Geräte
            SirLance
            Hiho ich klinke mich hier mal ein.
            Meine Situation ist eine ähnliche. Aufbau der ganzen konfig
            Docker-container -> iobroker -> unifi
            Hardware:
            3 AC's 1 USG 1 Server
            Firmware:
            Unifi Controller 5.12.35
            Unifi Adapter 0.3.1
            diese sind auch noch so konfiguriert das sie intern über reverse proxys arbeiten können (traefik und eigener dns)
            freigegebene ports sind soweit alle die unifi zum kommunizieren braucht kann auch alles anpingen usw. kann daran also nicht liegen.
            Der Unifi controller lief auch schon mal und hat daten gesammelt. Das alles hat er gemacht als noch kein USG installiert war. Seitdem das USG auch integriert wurde geht nichts mehr in dem Unifi Adapter. Selbe Fehlermeldung wie der TE.
            actuell mal ein Screenshot von den Daten die ohne USG reingekommen sind
              SirLance
              So nach etwas suchen in den Issues kann auch das ein Grund sein wieso es nicht funktioniert
              https://github.com/jens-maus/ioBroker.unifi/issues/17
              ich werde mich dem mal annehmen und den Adapter debuggen und sehen ob ich einen Pull Request durch bekomme.
                sectorchan
                Bei mir war es nicht so, das USG habe ich schon seit meinem Start mit Unifi im Netzwerk.
                Wie bereits gesagt, ging es von "heute auf morgen" nicht mehr und der Fehler kam.
                Ich habe eine If clause in dem Adapter gesetzt wie bei dem link von @TorbenNW - Der angesprochene Fehler war dann weg
                  SaschaS
                  Ich bin auf Controller 5.12.35-12979-1 und erhalte nachstehende Fehler ...
                  Noch eine Chance hierbei etwas zu beheben?
                  host.raspberrypi	2020-02-13 21:06:46.266	info	instance system.adapter.unifi.0 terminated with code 0 (NO_ERROR)
                  host.raspberrypi	2020-02-13 21:06:46.265	error	Caught by controller[0]: at traverseArray (/opt/iobroker/node_modules/iobroker.unifi/main.js:165:7)
                  host.raspberrypi	2020-02-13 21:06:46.265	error	Caught by controller[0]: at Array.every (<anonymous>)
                  host.raspberrypi	2020-02-13 21:06:46.265	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.unifi/main.js:168:7
                  host.raspberrypi	2020-02-13 21:06:46.265	error	Caught by controller[0]: at traverse (/opt/iobroker/node_modules/iobroker.unifi/main.js:155:5)
                  host.raspberrypi	2020-02-13 21:06:46.265	error	Caught by controller[0]: at traverseObject (/opt/iobroker/node_modules/iobroker.unifi/main.js:178:27)
                  host.raspberrypi	2020-02-13 21:06:46.264	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.unifi/main.js:288:13
                  host.raspberrypi	2020-02-13 21:06:46.264	error	Caught by controller[0]: at traverse (/opt/iobroker/node_modules/iobroker.unifi/main.js:155:5)
                  host.raspberrypi	2020-02-13 21:06:46.264	error	Caught by controller[0]: at traverseObject (/opt/iobroker/node_modules/iobroker.unifi/main.js:184:7)
                  host.raspberrypi	2020-02-13 21:06:46.263	error	Caught by controller[0]: at traverse (/opt/iobroker/node_modules/iobroker.unifi/main.js:156:32)
                  host.raspberrypi	2020-02-13 21:06:46.263	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.unifi/main.js:292:58
                  host.raspberrypi	2020-02-13 21:06:46.262	error	Caught by controller[0]: TypeError: Cannot read property 'subsystem' of null
                  unifi.0	2020-02-13 21:06:39.559	info	(30725) Terminated (NO_ERROR): Without reason
                  unifi.0	2020-02-13 21:06:39.556	info	(30725) terminating
                  unifi.0	2020-02-13 21:06:39.495	info	(30725) cleaned everything up...
                  unifi.0	2020-02-13 21:06:39.493	error	(30725) TypeError: Cannot read property 'subsystem' of null at /opt/iobroker/node_modules/iobroker.unifi/main.js:292:58 at traverse (/opt/iobroker/node_modules/iobroker.unifi/main.js:156:32)
                  unifi.0	2020-02-13 21:06:39.491	error	(30725) uncaught exception: Cannot read property 'subsystem' of null
                  unifi.0	2020-02-13 21:06:39.415	info	(30725) getSitesStats: default
                  unifi.0	2020-02-13 21:06:36.016	info	(30725) controller = 192.168.1.17:8443
                  • S SaschaS
                    sectorchan
                    @SaschaS hast du schon https://forum.iobroker.net/topic/4514/adapter-iobroker-unifi/255 versucht wie von @TorbenNW vorgeschlagen? Bei mir halfs
