  4. Log Fehlermeldung Sonoff Adapter
sonoff adapterlogerror
2 Beiträge 1 Kommentatoren 453 Aufrufe 1 Beobachtet
    schubs2802
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi3
    Arbeitsspeicher: 1GB
    Festplattenart: SD-Karte
    Betriebssystem:
    Node-Version: 10.18.0
    Nodejs-Version: 10.18.0
    NPM-Version: 6.13.4
    Installationsart: Skript
    Image genutzt: Ja
    Ort/Name der Imagedatei: Link
    Hallo, seit heute Morgen laufen ständig Fehlermeldungen in der Log auf und die über Sonoff geschalteten Geräte tun es nicht mehr. Der Adapter startet ständig neu.
    Die Log sieht so aus.
    host.raspberrypi-io	2020-01-07 15:56:29.138	error	Caught by controller[0]: at Connection.Readable.push (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:245:10)
    host.raspberrypi-io	2020-01-07 15:56:29.137	error	Caught by controller[0]: at readableAddChunk (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:278:11)
    host.raspberrypi-io	2020-01-07 15:56:29.137	error	Caught by controller[0]: at addChunk (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:291:12)
    host.raspberrypi-io	2020-01-07 15:56:29.137	error	Caught by controller[0]: at Connection.emit (events.js:198:13)
    host.raspberrypi-io	2020-01-07 15:56:29.136	error	Caught by controller[0]: at Object.onceWrapper (events.js:286:20)
    host.raspberrypi-io	2020-01-07 15:56:29.136	error	Caught by controller[0]: at Connection.<anonymous> (/opt/iobroker/node_modules/mqtt-connection/connection.js:53:12)
    host.raspberrypi-io	2020-01-07 15:56:29.135	error	Caught by controller[0]: at Connection.emit (events.js:198:13)
    host.raspberrypi-io	2020-01-07 15:56:29.135	error	Caught by controller[0]: at Connection.emitPacket (/opt/iobroker/node_modules/mqtt-connection/connection.js:10:8)
    host.raspberrypi-io	2020-01-07 15:56:29.134	error	Caught by controller[0]: at Connection.client.on.options (/opt/iobroker/node_modules/iobroker.sonoff/lib/server.js:1368:58)
    host.raspberrypi-io	2020-01-07 15:56:29.133	error	Caught by controller[0]: TypeError: Cannot read property 'toString' of undefined
    sonoff.0	2020-01-07 15:56:28.577	info	(1513) Terminated (NO_ERROR): Without reason
    sonoff.0	2020-01-07 15:56:28.574	info	(1513) terminating
    sonoff.0	2020-01-07 15:56:28.044	error	at Connection.Readable.push (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:245:10)
    sonoff.0	2020-01-07 15:56:28.044	error	at readableAddChunk (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:278:11)
    sonoff.0	2020-01-07 15:56:28.044	error	at addChunk (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:291:12)
    sonoff.0	2020-01-07 15:56:28.044	error	at Connection.emit (events.js:198:13)
    sonoff.0	2020-01-07 15:56:28.044	error	at Object.onceWrapper (events.js:286:20)
    sonoff.0	2020-01-07 15:56:28.044	error	at Connection.<anonymous> (/opt/iobroker/node_modules/mqtt-connection/connection.js:53:12)
    sonoff.0	2020-01-07 15:56:28.044	error	at Connection.emitPacket (/opt/iobroker/node_modules/mqtt-connection/connection.js:10:8)
    sonoff.0	2020-01-07 15:56:28.044	error	at Connection.client.on.options (/opt/iobroker/node_modules/iobroker.sonoff/lib/server.js:1368:58)
    sonoff.0	2020-01-07 15:56:28.044	error	(1513) TypeError: Cannot read property 'toString' of undefined
    sonoff.0	2020-01-07 15:56:28.042	error	(1513) uncaught exception: Cannot read property 'toString' of undefined
    sonoff.0	2020-01-07 15:56:26.331	info	(1513) Client [Sofa] connected with secret 1578408986329_452
    sonoff.0	2020-01-07 15:56:26.220	info	(1513) Client [hwr] connected with secret 1578408986217_8249
    sonoff.0	2020-01-07 15:56:26.208	info	(1513) Client [Bad] connected with secret 1578408986207_5157
    sonoff.0	2020-01-07 15:56:25.908	info	(1513) Client [Lichterkette] connected with secret 1578408985907_1590
    sonoff.0	2020-01-07 15:56:25.686	info	(1513) Client [Arbeitszimmer] connected with secret 1578408985676_4041
    sonoff.0	2020-01-07 15:56:25.649	info	(1513) Client [Schwibbogen-Arbeitszimmer] connected with secret 1578408985635_6441
    sonoff.0	2020-01-07 15:56:25.645	info	(1513) Client [LED-Schlafzimmer] connected with secret 1578408985633_1059
    sonoff.0	2020-01-07 15:56:25.469	info	(1513) Client [LED-Kueche] connected with secret 1578408985445_9272
    sonoff.0	2020-01-07 15:56:24.989	info	(1513) Starting MQTT authenticated server on port 1883
    sonoff.0	2020-01-07 15:56:24.898	info	(1513) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.sonoff, node: v10.18.0
    host.raspberrypi-io	2020-01-07 15:56:22.409	info	instance system.adapter.sonoff.0 started with pid 1513
    host.raspberrypi-io	2020-01-07 15:55:52.374	info	Restart adapter system.adapter.sonoff.0 because enabled
    Kann mir einer von den erfahrenen helfen, wo das Problem liegt. Bin absoluter Laie. Danke schubs28
    Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
      schubs2802
      Moin, habe den Fehler gefunden. Es lag an einem Sonoff Touch T2 Schalter. Habe ihn nochmal mit dem Tamplate für den T1 gefläscht, nun läuft alles.
