  4. Test Adapter mihome-vacuum v1.9.x
    5.4k
mi vacuumxiaomivaletudo
47 Beiträge 10 Kommentatoren 8.2k Aufrufe 9 Beobachtet
  • MeistertrM Meistertr
    @tazdevil20 das ist richtig, ab RE6 wurde auf eine binärdatei umgestelllt( Diese wird direkt vom roboter generiert). das endschlüsseln macht dann der adapter, der kann beides, die json und die bin datei
    tazdevil20
    @Meistertr
    Stimmt. Habe gerade mal die latest-Seite aufgerufen. Ist bei mir auch wieder eine Datei... Das hätte ich auch mal früher machen können.
    • MeistertrM Offline
      MeistertrM Offline
      Meistertr
      so bitte mal von git installierten, hab da noch ein fehler abgefangen...
        base
        schrieb am zuletzt editiert von base
        nach der Installation hab ich jetzt was in Map64 und MapURL drin und auch keine Fehlermeldungen mehr. Leider wird keine Karte dargestellt:
        MeistertrM 1 Antwort Letzte Antwort
        • B base
          MeistertrM Offline
          MeistertrM Offline
          Meistertr
          @base schick mal alles was in map64 drin steht
          B 1 Antwort Letzte Antwort
            base
            @Meistertr
            <img src="data:image/png;base64,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" /style="width: auto ;height: 100%;">
            • B base
              @Meistertr
              MeistertrM Offline
              MeistertrM Offline
              Meistertr
              @base ok das sieht auf dem ersten blick schon merkwürdig aus. und im valetudo webinterface ist die normale karte zu sehen?
                base
                @Meistertr ja, da wird sie flüssig aufgebaut.
                Wenn ich ein Werksreset mache, ist dann die Orginal-Software wieder drauf? Würde gern neu aufbauen, der Robi lässt sich aber über rrcc nicht mehr flashen...
                Fehlermeldung: Roboter sendet keine Firmwarepaketanforderung!
                  base
                  so, nach Werksreset habe ich auf Valetudo RE 0.8 geflasht. Karte wurde im Adapter korrekt aufgebaut. Leider hat der Robi dann nach ca. einer Minute die Verbindung verloren. Danach Update auf 0.8.1 Karte wird im Webinterface aufgebaut, in iobroker wieder nur verpixelt. Danach wieder Werksreset und direkt 0.8.1 mit rrcc geflasht ohne Änderungen. Habe auch weitere Probleme mit 0.8.1: Timer lässt sich nicht setzen und Saugstärke nicht ändern.
                  Gehe jetzt nochmal auf 0.8 zurück....
                  • KnallochseK Offline
                    KnallochseK Offline
                    Knallochse
                    Ich habe den Adapter auch auf die 1.9.x angehoben.
                    Funktioniert alles tadellos. Also auch die Kartenfunktion in Verbindung mit ValetudoRE auf meinen Model 1.
                    Ich hatte vorher das Kartenscript am laufen.
                    Ist eine Integration von Telegram (wie im Script) geplant?
                    Grüße
                    HM&HMIP über 100 Geräte + IoBroker auf DS918+ uvm.
                      base
                      Ich habe jetzt die Valetudo RE 0.8.2 istalliert. Karte wird jetzt korrekt aufgebaut. Scheint auch sonst soweit zu funktionieren.....
                        base
                        Die verpixelte Kartendarstellung liegt an der neuen 2008 Firmware. Anscheinend hat sich da etwas bei der Verschlüsselung geändert. Gibt es eine Möglichkeit die Karten der neuen Firmware darzustellen?
                        • B base
                          MeistertrM Offline
                          MeistertrM Offline
                          Meistertr
                          @base versuch mal die version 1.10.4 damit sollte die Karte wieder gehen. wenn ich die originale 2008 aufspiele kann ich über ein factory reset zurück? will nämlich auf original um die cloud anzubinden
                            base
                            @Meistertr werde es heute abend testen. Es gibt jetzt auch eine neue Beta von rand256 mit 2008er Firmware die ich heute abend antesten will. Werde dann Rückmeldung geben.
                            Habe mir zum Testen die Orginal-2008 FW von https://vacuumz.info/download/gen2/stock/ gezogen. Durch Factory Reset hatte ich die alte Firmware wieder drauf...
                            • B base
                              MeistertrM Offline
                              MeistertrM Offline
                              Meistertr
                              @base danke, ich versuche dies we noch die cloud Verbindung im Adapter einzubauen.. Dann geht die Karte über alle Wege..
                                base
                                @Meistertr konnte den Adapter erfoglreich mit der neuen Valetudo RE 0.9.0-beta testen. Karte wird in iobroker angezeigt. Räume werden zumindest in Valetudo erkannt, in iobroker waren die jetzt noch nicht da. Muss ich morgen aber nochmal mit der gesammten Fläche testen.
                                Tausend Dank für deine Arbeit!!!
                                Edit: Jetzt fehlt nur noch das Laden von Karten im Adapter...😀
                                  MeistertrM Offline
                                  Meistertr
                                  so langsam nimmt es formen an!! Der Login geht und die aufwendige Token Findung hat endlich ein ende!!
                                  noch ein paar Feinheiten und es kann online gehen
                                    MeistertrM Offline
                                    Meistertr
                                    2020-02-10_21h02_01.png das sieht in iobroker doch schonmal aus wie in der app :)
                                    Agria4800A 1 Antwort Letzte Antwort
                                      base
                                      sieht super aus...
                                        Agria4800A Offline
                                        Agria4800A Offline
                                        Agria4800
                                        @Meistertr das ist mal fein, darauf warte ich schon lange 😊
                                        Wann ist es verfügbar?
                                        • Agria4800A Agria4800
                                          MeistertrM Offline
                                          MeistertrM Offline
                                          Meistertr
                                          @Agria4800 schätze zum Wochenende
                                          Agria4800A DiginixD 2 Antworten Letzte Antwort
