  5. Fehlermeldungen im Log
    5.1k
javascript
3 Beiträge 3 Kommentatoren 522 Aufrufe 2 Beobachtet
    djsirius
    Moin.
    Ich habe seit gestern ein großes Problem mit dem iobroker. Der iobroker stürzt regelmäßig ab und im Log befinden sich jede Menge Warnungen zum Javascript-Adapter.
    Kann mir jemand sagen was da los ist? Es hat doch vorher alles wunderbar funktioniert.
    Hier ein Auszug:
    javascript.0	2020-01-04 09:02:52.962	error	Longitude or latitude does not set. Cannot use astro.
    javascript.0	2020-01-04 09:02:52.959	error	Longitude or latitude does not set. Cannot use astro.
    javascript.0	2020-01-04 09:02:52.957	warn	at Timer.processTimers (timers.js:223:10)
    javascript.0	2020-01-04 09:02:52.957	warn	at listOnTimeout (timers.js:263:5)
    javascript.0	2020-01-04 09:02:52.957	warn	at tryOnTimeout (timers.js:300:5)
    javascript.0	2020-01-04 09:02:52.957	warn	at ontimeout (timers.js:436:11)
    javascript.0	2020-01-04 09:02:52.957	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
    javascript.0	2020-01-04 09:02:52.957	warn	at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
    javascript.0	2020-01-04 09:02:52.957	warn	at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
    javascript.0	2020-01-04 09:02:52.957	warn	at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1181:34)
    javascript.0	2020-01-04 09:02:52.957	warn	at Object.<anonymous> (script.js.smarthome.system.zeiten_v01:85:5)
    javascript.0	2020-01-04 09:02:52.957	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
    javascript.0	2020-01-04 09:02:52.957	warn	Wrong type of javascript.0.zeiten.tageslaenge_differenz: "number". Please fix, while deprecated and will not work in next versions.
    javascript.0	2020-01-04 09:02:52.957	error	Longitude or latitude does not set. Cannot use astro.
    javascript.0	2020-01-04 09:02:52.953	error	Longitude or latitude does not set. Cannot use astro.
    javascript.0	2020-01-04 09:02:52.947	warn	at Timer.processTimers (timers.js:223:10)
    javascript.0	2020-01-04 09:02:52.947	warn	at listOnTimeout (timers.js:263:5)
    javascript.0	2020-01-04 09:02:52.947	warn	at tryOnTimeout (timers.js:300:5)
    javascript.0	2020-01-04 09:02:52.947	warn	at ontimeout (timers.js:436:11)
    javascript.0	2020-01-04 09:02:52.947	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
    javascript.0	2020-01-04 09:02:52.947	warn	at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
    javascript.0	2020-01-04 09:02:52.947	warn	at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
    javascript.0	2020-01-04 09:02:52.947	warn	at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1181:34)
    javascript.0	2020-01-04 09:02:52.947	warn	at Object.<anonymous> (script.js.hm_meldungen:82:5)
    javascript.0	2020-01-04 09:02:52.947	warn	at countService (script.js.hm_meldungen:47:27)
    javascript.0	2020-01-04 09:02:52.947	warn	at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:771:29)
    javascript.0	2020-01-04 09:02:52.946	warn	at script.js.hm_meldungen:48:7
    javascript.0	2020-01-04 09:02:52.946	warn	at count (script.js.hm_meldungen:32:20)
    javascript.0	2020-01-04 09:02:52.946	warn	getState "hm-rpc.0.NEQ0077231.0.CONFIG_PENDING" not found (3) states[id]=null
    javascript.0	2020-01-04 09:02:52.946	warn	at Timer.processTimers (timers.js:223:10)
    javascript.0	2020-01-04 09:02:52.946	warn	at listOnTimeout (timers.js:263:5)
    javascript.0	2020-01-04 09:02:52.946	warn	at tryOnTimeout (timers.js:300:5)
    javascript.0	2020-01-04 09:02:52.946	warn	at ontimeout (timers.js:436:11)
    javascript.0	2020-01-04 09:02:52.946	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
    javascript.0	2020-01-04 09:02:52.946	warn	at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
    javascript.0	2020-01-04 09:02:52.946	warn	at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
    javascript.0	2020-01-04 09:02:52.946	warn	at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1181:34)
    javascript.0	2020-01-04 09:02:52.946	warn	at Object.<anonymous> (script.js.hm_meldungen:82:5)
    javascript.0	2020-01-04 09:02:52.946	warn	at countService (script.js.hm_meldungen:47:27)
    javascript.0	2020-01-04 09:02:52.946	warn	at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:771:29)
    javascript.0	2020-01-04 09:02:52.945	warn	getState "hm-rpc.0.OEQ0888039.0.CONFIG_PENDING" not found (3) states[id]=null
    javascript.0	2020-01-04 09:02:52.945	warn	at Timer.processTimers (timers.js:223:10)
    javascript.0	2020-01-04 09:02:52.945	warn	at listOnTimeout (timers.js:263:5)
    javascript.0	2020-01-04 09:02:52.945	warn	at tryOnTimeout (timers.js:300:5)
    javascript.0	2020-01-04 09:02:52.945	warn	at ontimeout (timers.js:436:11)
    javascript.0	2020-01-04 09:02:52.945	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
    javascript.0	2020-01-04 09:02:52.945	warn	at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
    javascript.0	2020-01-04 09:02:52.944	warn	at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
    javascript.0	2020-01-04 09:02:52.944	warn	at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1181:34)
    javascript.0	2020-01-04 09:02:52.944	warn	at Object.<anonymous> (script.js.hm_meldungen:82:5)
    javascript.0	2020-01-04 09:02:52.944	warn	at countService (script.js.hm_meldungen:39:20)
    javascript.0	2020-01-04 09:02:52.943	warn	at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:771:29)
    javascript.0	2020-01-04 09:02:52.943	warn	at script.js.hm_meldungen:40:7
    javascript.0	2020-01-04 09:02:52.943	warn	at count (script.js.hm_meldungen:32:20)
    javascript.0	2020-01-04 09:02:52.943	warn	getState "hm-rpc.0.NEQ0077231.0.UNREACH" not found (3) states[id]=null
    javascript.0	2020-01-04 09:02:52.943	warn	at Timer.processTimers (timers.js:223:10)
    javascript.0	2020-01-04 09:02:52.943	warn	at listOnTimeout (timers.js:263:5)
    javascript.0	2020-01-04 09:02:52.943	warn	at tryOnTimeout (timers.js:300:5)
    javascript.0	2020-01-04 09:02:52.943	warn	at ontimeout (timers.js:436:11)
    javascript.0	2020-01-04 09:02:52.943	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
    javascript.0	2020-01-04 09:02:52.943	warn	at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
    javascript.0	2020-01-04 09:02:52.943	warn	at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
    javascript.0	2020-01-04 09:02:52.943	warn	at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1181:34)
    javascript.0	2020-01-04 09:02:52.943	warn	at Object.<anonymous> (script.js.hm_meldungen:82:5)
    javascript.0	2020-01-04 09:02:52.943	warn	at countService (script.js.hm_meldungen:39:20)
    javascript.0	2020-01-04 09:02:52.942	warn	at count (script.js.hm_meldungen:32:20)
    javascript.0	2020-01-04 09:02:52.942	warn	getState "hm-rpc.0.OEQ0888039.0.UNREACH" not found (3) states[id]=null
    Vielen Dank!
    Gruß Sirius
    djsirius
    • D djsirius
      Moin.
      Hier ein Auszug:
      Vielen Dank!
      Gruß Sirius
      dslraserD Offline
      dslraserD Offline
      dslraser
      @djsirius
      dieses Script findet dieses Gerät nicht.
      • dslraserD dslraser
        @djsirius
        @dslraser sagte:
        Oder der Datenpunkt hat (noch) keinen Zustand. Dann hilft, manuell false einzutragen.
