  5. TR-064 community Adapter - Wie mit javascript?
    5.1k
javascriptcommunication
6 Beiträge 3 Kommentatoren 1.0k Aufrufe 3 Beobachtet
  • L Offline
    LoxDUS
    Liebe Gemeinde,
    ich bekomme es einfach nicht hin mit dem TR064 community Adapter über den "command" Datenpunkt bestimmte Werte aus der Fritzbox auszulesen.
    Kann mir jemand ein Codebeispiel in Javascript geben wie man z.B. die Externe IP-Adresse ausließt?
    Was ich bisher versucht habe:
    //command = '{"service": "urn:dslforum-org:service:WANCommonInterfaceConfig:1","action": "NewByteReceiveRate","params": {}}';
    // NOK setState('tr-064-community.0.states.command', '{"service": "urn:dslforum-org:service:GetExternalIPAddress","action": "NewExternalIPAddress", "params":{}', true);
    // NOK setState('tr-064-community.0.states.command', '{"service": "urn:WANCIfConfig-com:serviceId:WANCommonInterfaceConfig1", "action": "GetTotalBytesSent", "params": { "NewTotalBytesSent"}};', true);
    // NOK setState('tr-064-community.0.states.command', '{"service": "urn:dslforum-org:service:WLANConfiguration:1","action": "X_AVM-DE_SetWPSConfig","params": {"NewX_AVM-DE_WPSMode": "pbc","NewX_AVM-DE_WPSClientPIN": ""}}', true);
    // NOK setState('tr-064-community.0.states.command', '{"service": "urn:dslforum-org:service:WANIPConnection:1","action": "GetGenericPortMappingEntry","params": {"NewExternalPort": ""}}', true);
    setState('tr-064-community.0.states.command', '{"service": "urn:dslforum-org:service:WANIPConnection:1","action": "GetInfo","params": {"": ""}}',  (err, state) => {
      log("SetState: " + JSON.stringify(state));
        for(var index in state) {
                log(index);
                log(JSON.stringify(state[index]));
    // NOK setState('tr-064-community.0.states.command', '{"service": "urn:dslforum-org:service:WANIPConnection:1","action": "GetInfo","params": {"": ""}}',  true);
    // NOK setState('tr-064-community.0.states.command', '{"service": "urn:dslforum-org:service:WANIPConnection:1","action": "GetExternalIPAddress","params": {"NewExternalIPAddress": ""}};', true);
    setState('tr-064-community.0.states.command', '{"service": "urn:dslforum-org:service:WANIPConnection:1","action": "GetExternalIPAddress","params": {"NewExternalIPAddress": ""}};',  (err, status) => {
        if(err) log("Fehler:" + err);
        log("SetState: " + JSON.stringify(status));
        getState("tr-064-community.0.states.commandResult", (err, state) => {
            log("GetState: " + JSON.stringify(state));
                    log(index);
    Dann wird aber immer die irgendwann mal einmalig funktionierende GetInfo Action ausgegeben. Der Wert in "CommandResult" ändert sich irgendwie gar nicht mehr.
    14:28:05.828	info	javascript.1 (14753) script.js.common.Testumgebung: SetState: undefined
    14:28:05.830	info	javascript.1 (14753) script.js.common.Testumgebung: GetState: {"val":"{\"NewEnable\":\"1\",\"NewConnectionStatus\":\"Connected\",\"NewPossibleConnectionTypes\":\"IP_Routed, IP_Bridged\",\"NewConnectionType\":\"IP_Routed\",\"NewName\":\"internet\",\"NewUptime\":\"5687998\",\"NewLastConnectionError\":\"ERROR_NONE\",\"NewRSIPAvailable\":\"0\",\"NewNATEnabled\":\"1\",\"NewExternalIPAddress\":\"...rausgelöscht...\",\"NewDNSServers\":\"...rausgelöscht..., ...rausgelöscht...\",\"NewMACAddress\":\"rausgelöscht\",\"NewConnectionTrigger\":\"OnDemand\",\"NewRouteProtocolRx\":\"Off\",\"NewDNSEnabled\":\"1\",\"NewDNSOverrideAllowed\":\"1\"}","ack":true,"ts":1577866696482,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1577866696482}
    14:28:05.832	info	javascript.1 (14753) script.js.common.Testumgebung: val
    14:28:05.833	info	javascript.1 (14753) script.js.common.Testumgebung: "{\"NewEnable\":\"1\",\"NewConnectionStatus\":\"Connected\",\"NewPossibleConnectionTypes\":\"IP_Routed, IP_Bridged\",\"NewConnectionType\":\"IP_Routed\",\"NewName\":\"internet\",\"NewUptime\":\"5687998\",\"NewLastConnectionError\":\"ERROR_NONE\",\"NewRSIPAvailable\":\"0\",\"NewNATEnabled\":\"1\",\"NewExternalIPAddress\":\"...rausgelöscht...\",\"NewDNSServers\":\"...rausgelöscht..., ...rausgelöscht...\",\"NewMACAddress\":\"....rausgelöscht...\",\"NewConnectionTrigger\":\"OnDemand\",\"NewRouteProtocolRx\":\"Off\",\"NewDNSEnabled\":\"1\",\"NewDNSOverrideAllowed\":\"1\"}"
    14:28:05.834	info	javascript.1 (14753) script.js.common.Testumgebung: ack
    14:28:05.834	info	javascript.1 (14753) script.js.common.Testumgebung: true
    14:28:05.835	info	javascript.1 (14753) script.js.common.Testumgebung: ts
    14:28:05.835	info	javascript.1 (14753) script.js.common.Testumgebung: 1577866696482
    14:28:05.835	info	javascript.1 (14753) script.js.common.Testumgebung: q
    14:28:05.836	info	javascript.1 (14753) script.js.common.Testumgebung: 0
    14:28:05.836	info	javascript.1 (14753) script.js.common.Testumgebung: from
    14:28:05.837	info	javascript.1 (14753) script.js.common.Testumgebung: "system.adapter.tr-064-community.0"
    14:28:05.837	info	javascript.1 (14753) script.js.common.Testumgebung: user
    14:28:05.837	info	javascript.1 (14753) script.js.common.Testumgebung: "system.user.admin"
    14:28:05.838	info	javascript.1 (14753) script.js.common.Testumgebung: lc
    14:28:05.838	info	javascript.1 (14753) script.js.common.Testumgebung: 1577866696482
    Ich brauche nur ein einfaches Beispiel wie das gehen soll. Wie geschrieben ich habe das einmalig hinbekommen aber seit dem ändert sich der Wert im datenpunkt "CommandResult" nicht mehr auch nicht wenn ich andere Parameter über den TR-064 aus der Fritzbox abfragen will.
    Vielen Dank,
    • L LoxDUS
      Liebe Gemeinde,
                  log(index);
                      log(index);
      Vielen Dank,
      Dominik F.D Offline
      Dominik F.D Offline
      Dominik F.
      @LoxDUS
      die externe IP Adresse ist bei mir unter folgendem Datenpunkt zu finden :
      tr-064-community.0.states.externalIP.
      Dafür brauchst du kein Script schreiben.
      L 1 Antwort Letzte Antwort
      • Dominik F.D Dominik F.
        @LoxDUS
        LoxDUS
        @Dominik-F
        Bei mir ist dieser Datenpunkt leer, wahrscheinlich weil ich von UnityMedia nur eine IP V6 IpAdresse bekomme. Es geht mir aber nicht unbedingt um die Externe Adresse sondern um z.B Download und Upload Raten und vor allem um den Status der Internetanbindung weil hier schon mal öfters bei UnityMedia die INternetverbindung wegbricht.
        Dominik F.D bahnuhrB 2 Antworten Letzte Antwort
        • L LoxDUS
          @Dominik-F
          Dominik F.D Offline
          Dominik F.D Offline
          Dominik F.
          @LoxDUS
          okay, dann bin ich bei dem Adapter raus. Ich ziehe mir die Download und Upload raten und sonstiges aus dem UPNP Adapter.
          • L Offline
            LoxDUS
            Weiß denn niemand wie man über den TR-064 Adapter per command Datenpunkt Werte aus der Fritzbox abfragen kann?
            • L LoxDUS
              @Dominik-F
              bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              @LoxDUS sagte in TR-064 community Adapter - Wie mit javascript?:
              Ich habe ausschließlich ipv6. Bei mir ist dieser Punkt befüllt.
              Danke.
