  4. Script engine has problem with Selector
script engineselector
3 Beiträge 2 Kommentatoren 717 Aufrufe 2 Beobachtet
  • V Offline
    V Offline
    Vadim
    schrieb am zuletzt editiert von Vadim
    Dear Sirs
    I`ve found, Selector with ENUM for 0_userdata.0 is working with errors.
    Problem exists for 0_userdata.0 only.
    For example:
    on({id: 'telegram.0.communicate.request', change: "any"}, function (obj) {
    $('state(rooms=mbrwc)').each(function (id, i) {
        log(id,'warn');
    Result Log (* We got objects from the room "chwc" too: 4 and 5 lines):
    12/28/2019, 11:39:26 PM.140	[info ]: javascript.0 (32608) Start javascript script.js.Developing.Test3
    12/28/2019, 11:39:26 PM.143	[info ]: javascript.0 (32608) script.js.Developing.Test3: subscribe: {"pattern":{"id":"telegram.0.communicate.request","change":"any","q":0},"name":"script.js.Developing.Test3"}
    12/28/2019, 11:39:26 PM.144	[info ]: javascript.0 (32608) script.js.Developing.Test3: registered 1 subscription and 0 schedules
    12/28/2019, 11:39:32 PM.995	[warn ]: javascript.0 (32608) script.js.Developing.Test3: 0_userdata.0.CHWC_Fan_Auto_enable
    12/28/2019, 11:39:32 PM.995	[warn ]: javascript.0 (32608) script.js.Developing.Test3: 0_userdata.0.CHWC_Fan_enable
    12/28/2019, 11:39:32 PM.995	[warn ]: javascript.0 (32608) script.js.Developing.Test3: 0_userdata.0.MBRWC_Fan_Auto_enable
    12/28/2019, 11:39:32 PM.995	[warn ]: javascript.0 (32608) script.js.Developing.Test3: 0_userdata.0.MBRWC_Fan_enable
    12/28/2019, 11:39:32 PM.995	[warn ]: javascript.0 (32608) script.js.Developing.Test3: megadd.0.p18_MBRWC_FH
    12/28/2019, 11:39:32 PM.995	[warn ]: javascript.0 (32608) script.js.Developing.Test3: megadd.0.p22_MBRWC_Fan
    12/28/2019, 11:39:32 PM.996	[warn ]: javascript.0 (32608) script.js.Developing.Test3: megadd.0.p7_MBRWC_FHTemp1
    12/28/2019, 11:39:32 PM.996	[warn ]: javascript.0 (32608) script.js.Developing.Test3: megadd.0.p8_MBRWC_FHTemp2
    12/28/2019, 11:39:32 PM.996	[warn ]: javascript.0 (32608) script.js.Developing.Test3: mihome.0.devices.sensor_ht_158d0001f4fdbc.humidity
    12/28/2019, 11:39:32 PM.996	[warn ]: javascript.0 (32608) script.js.Developing.Test3: mihome.0.devices.sensor_ht_158d0001f4fdbc.temperature
    My ENUMs\Objects:
    /s
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Khadas VIM3 Pro
    Arbeitsspeicher: 4GB
    Festplattenart: 32Gb eMMC
    Betriebssystem: Armbian
    Node-Version: 10.17.0
    Nodejs-Version: 10.17.0
    NPM-Version: 6.13.4
    Installationsart: Skript
    Image genutzt: No
    Ort/Name der Imagedatei: No
    Script Engine version: 4.3.4
    Admin version: v3.6.12
    js-controller: 2.1.1
    • V Vadim
      Dear Sirs
      For example:
          log(id,'warn');
      My ENUMs\Objects:
      /s
      NPM-Version: 6.13.4
      Image genutzt: No
      @Vadim Please create an GitHub issue with JavaScript adapter. We need to check this.
      V 1 Antwort Letzte Antwort
      • apollon77A apollon77
        V Offline
        V Offline
        Vadim
        @apollon77
        Done.
        GitHub
        Thank you
