  4. Script Engine Update Error
javascriptscript engineupdate error
4 Beiträge 3 Kommentatoren 1.2k Aufrufe 2 Beobachtet
  • J Offline
    Jaschkopf
    Systemdata Bitte Ausfüllen
    Hardwaresystem: RPi4
    Arbeitsspeicher: 4GB
    Festplattenart: SD-Karte
    Betriebssystem: Linux
    Node-Version: v10.17.0
    Nodejs-Version: v10.17.0
    NPM-Version: 6.11.3
    Installationsart: Manuell
    Image genutzt: Nein
    Ort/Name der Imagedatei: Link
    Servus. Bei mir bricht das Update von Script Engine von v4.3.2 auf 4.3.4 mit folgendem Fehler an:
    $ ./iobroker upgrade javascript
    Update javascript from @4.3.2 to @4.3.4
    NPM version: 6.11.3
    npm install iobroker.javascript@4.3.4 --loglevel error --prefix "/opt/iobroker" (System call)
    npm ERR! code EACCESnpm ERR! syscall accessnpm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.stat
    npm ERR! errno -13
    npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.stat'npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.stat']npm ERR!   stack:npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.stat\'',npm ERR!   errno: -13,npm ERR!   code: 'EACCES',npm ERR!   syscall: 'access',npm ERR!   path:npm ERR!    '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.stat' }
    npm ERR! npm ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current usernpm ERR! npm ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-12-21T13_06_18_408Z-debug.log
    ERROR: host.raspberrypi Cannot install iobroker.javascript@4.3.4: 243
    Anbei auch das Log:
    Kann mir da jemand weiter helfen?
    GlasfaserG HomoranH 2 Antworten Letzte Antwort
    • J Jaschkopf
      NPM-Version: 6.11.3
      Image genutzt: Nein
      NPM version: 6.11.3
      npm ERR! errno -13
      Anbei auch das Log:
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      @Jaschkopf
      Du hast keine Rechte …
      Lasse den Fixer vorher mal drüber laufen .
      • J Jaschkopf
        NPM-Version: 6.11.3
        Image genutzt: Nein
        NPM version: 6.11.3
        npm ERR! errno -13
        Anbei auch das Log:
        @Jaschkopf
        Wie alt ist die Installation?
        als root? oder einfacher User installiert?
        Ich würde mal den Fixer drüberjagen.
        • J Offline
          Jaschkopf
          Super hat gereicht den fixer laufen zu lassen. Anschließend einmal reboot und das update lief problemlos durch. Viele Dank für die schnelle Hilfe! 👍
