  4. [Gelöst]web Adapter - callback is not a function
web adapterexception
2 Beiträge 1 Kommentatoren 644 Aufrufe 1 Beobachtet
  • N Offline
    N Offline
    NightWatcher
    schrieb am zuletzt editiert von NightWatcher
    Moin,
    habe den Fehler schon einige Zeit und komme nun erst dazu, mir dies mal genauer anzusehen.
    Sobald ich z.b. die App "iogo" starte, erscheint im Log unter anderem:
    web.1	2019-12-08 14:08:39.919	warn	(9684) Alias alias.0.Beleuchtung_Wohnzimmer has no target 12
    web.1	2019-12-08 13:35:40.400	error	(9280) TypeError: callback is not a function at Adapter._addAliasSubscribe (C:\ioBroker\node_modules\iobroker.js-controller\lib\adapter.js:6030:17) at objects.getObject (C:\ioBroker\node_modul
    web.1	2019-12-08 13:35:40.399	error	(9280) uncaught exception: callback is not a function
    und auch
    host.SERVER(SmartHome)	2019-12-08 13:37:54.188	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
    host.SERVER(SmartHome)	2019-12-08 13:37:54.188	error	Caught by controller[0]: at promise.then (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\standard-as-callback\built\index.js:19:49)
    host.SERVER(SmartHome)	2019-12-08 13:37:54.188	error	Caught by controller[0]: at tryCatcher (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\standard-as-callback\built\utils.js:11:23)
    host.SERVER(SmartHome)	2019-12-08 13:37:54.188	error	Caught by controller[0]: at (anonymous function).(anonymous function) (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\iobroker.objects-redis\index.js:17:63857)
    host.SERVER(SmartHome)	2019-12-08 13:37:54.188	error	Caught by controller[0]: at objects.getObject (C:\ioBroker\node_modules\iobroker.js-controller\lib\adapter.js:6224:42)
    host.SERVER(SmartHome)	2019-12-08 13:37:54.188	error	Caught by controller[0]: at Adapter._addAliasSubscribe (C:\ioBroker\node_modules\iobroker.js-controller\lib\adapter.js:6030:17)
    host.SERVER(SmartHome)	2019-12-08 13:37:54.188	error	Caught by controller[0]: TypeError: callback is not a function
    Der entsprechende web Adapter stürzt dann ab und fährt im Anschluss wieder neu hoch. Ich vermute, das kam mit dem einrichten der Alias Variablen, kann es aber nicht 100% zuordnen. Dafür ist es aber schon zu lange her 😧
    Über einen andere web Adapter Instanz hingegen kann ich über die Web Oberfläche die Alias Variablen normal ansprechen und steuern.
    Wago 750-881 - mit über 200 Ein- und Ausgängen, DMX512 Art-Net für Beleuchtung, 1-Wire für Umweltsensoren Aussen und Innen, ioBroker als Visualisierung
    • N Offline
      N Offline
      NightWatcher
      Gelöst - Problem war, dass ich einen channel als Read/Write Onjekt gesetzt hatte...
