  4. Sonoff error in log
Sonoff error in log
sonoff-adapter error
4 Beiträge 2 Kommentatoren 543 Aufrufe 2 Beobachtet
    roland1000
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Raspberry pi4 .
    Arbeitsspeicher: 4GB
    Festplattenart: SD-Karte
    Betriebssystem: RasbianBuster
    Node-Version: 10.17.0
    Nodejs-Version: 10.17.0
    NPM-Version: 6.11.3
    Installationsart: Skript
    Image genutzt: Nein
    Ort/Name der Imagedatei: Link
    Hallo ioBroker-Gemeinde
    Ich habe folgendes Problem und zwar seit ich den Host-Js-Controller geupdatet auf 2.1.1 gibt der Sonoff-Adapter folgende fehler Meldungen raus:
    host.ioBroker
    2019-11-22 17:53:00.926
    error
    Caught by controller[0]: at DestroyableTransform.onreadable (/opt/iobroker/node_modules/duplexify/index.js:134:10)
    host.ioBroker
    error
    Caught by controller[0]: at Connection.Duplexify._forward (/opt/iobroker/node_modules/duplexify/index.js:170:26)
    host.ioBroker
    error
    Caught by controller[0]: at Connection.Readable.push (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_readable.js:245:10)
    host.ioBroker
    2019-11-22 17:53:00.925
    error
    Caught by controller[0]: at readableAddChunk (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_readable.js:278:11)
    host.ioBroker
    error
    Caught by controller[0]: at addChunk (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_readable.js:291:12)
    host.ioBroker
    error
    Caught by controller[0]: at Connection.emit (events.js:198:13)
    host.ioBroker
    error
    Caught by controller[0]: at Connection.emitPacket (/opt/iobroker/node_modules/mqtt-connection/connection.js:10:8)
    host.ioBroker
    error
    host.ioBroker
    error
    Caught by controller[0]: at Connection.client.on.packet (/opt/iobroker/node_modules/iobroker.sonoff/lib/server.js:1558:21)
    host.ioBroker
    2019-11-22 17:53:00.924
    error
    Caught by controller[0]: at receivedTopic (/opt/iobroker/node_modules/iobroker.sonoff/lib/server.js:1067:30)
    host.ioBroker
    error
    Caught by controller[0]: TypeError: Cannot read property 'topic' of undefined
    sonoff.0
    2019-11-22 17:52:59.890
    error
    sonoff.0
    error
    sonoff.0
    error
    sonoff.0
    error
    sonoff.0
    error
    sonoff.0
    error
    sonoff.0
    error
    sonoff.0
    error
    sonoff.0
    error
    sonoff.0
    error
    sonoff.0
    error
    (8323) TypeError: Cannot read property 'topic' of undefined
    sonoff.0
    2019-11-22 17:52:59.888
    error
    (8323) uncaught exception: Cannot read property 'topic' of undefined```
    Die Topic habe ich auch schon mal geändert Ein Neustart bringt keine Besserung .Es läuft zwar noch der MQTT-Adapter mit weil, ich vier ESP32 BT als Anwesendheitserkennung installiert habe. Die beiden Adapter laufen schon auf zwei unterschiedliche Port. Was kann das noch sein?
    Erstmal danke für eure Hilfe.
    LG
    Roland1000
      roland1000
      Moin
      Bitte Thema schliesen. Fehler gefunden .🙂
      LG Roland1000
      • R roland1000
        Moin
        LG Roland1000
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        @roland1000 sagte in Sonoff error in log:
        Und was war das Problem?
        ist für andere User eventuell auch interessant.
        ° Fixer ---> iob fix
          roland1000
          Hallo Negalein
          War schwierig weil die Sonoff bzw Esp12f keinen Error gemacht haben .Zuletzt waren es die ersten S20 die haben das Firmware update nicht verstanden. Nach den flashen mit der Blank 1MB firmware .War es ein Kinderspiel. Ich habe die Hälfte der Esp12f nach und nach wieder online gestellt und gewartet ob fehler kamen . Bei den letzten viertel ⚡ kam die ersten Fehler. Danach war es ein Kinderspiel neue Firmware drauf und es lief wieder normal.
          Lg Roland
