  4. [Fehler] Multihost Update Admin # LOG falsch
1 Beiträge 1 Kommentatoren 600 Aufrufe
  • derAugeD Offline
    derAugeD Offline
    derAuge
    Hallo Bluefox
    habe heute auf dem Master (DS) Admin auf 1.2.3 gebracht. => Alles OK
    2016-06-06 07:18:50.797  - info: iobroker host.DS Adapter "system.adapter.admin.0" is started
    2016-06-06 07:18:50.958  - info: iobroker npm install --production --prefix "/volume2/ioBroker/Master/node_modules/iobroker.admin" (System call)
    2016-06-06 07:18:55.626  - info: admin.0 starting. Version 1.2.3 in /volume2/ioBroker/Master/node_modules/iobroker.admin
    2016-06-06 07:18:55.756  - info: admin.0 requesting all states
    2016-06-06 07:18:55.760  - info: admin.0 requesting all objects
    2016-06-06 07:18:55.762  - info: admin.0 Request actual repository...
    2016-06-06 07:18:55.766  - info: admin.0 http server listening on port 8081
    2016-06-06 07:18:55.766  - info: admin.0 Use link "http://localhost:8081" to configure.
    2016-06-06 07:18:57.052  - info: admin.0 received all states
    2016-06-06 07:18:57.445  - info: admin.0 received all objects
    2016-06-06 07:18:58.126  - info: host.DS Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    2016-06-06 07:18:58.241  - info: iobroker got /volume2/ioBroker/Master/node_modules/iobroker.admin/admin
    2016-06-06 07:18:58.278  - info: iobroker upload [1] admin.admin /volume2/ioBroker/Master/node_modules/iobroker.admin/admin/index.html index.html text/html
    2016-06-06 07:18:58.385  - info: iobroker Update "system.adapter.admin.0"
    2016-06-06 07:18:58.404  - info: host.DS object change system.adapter.admin.0
    2016-06-06 07:18:58.405  - info: host.DS stopInstance system.adapter.admin.0
    2016-06-06 07:18:58.405  - info: host.DS stopInstance system.adapter.admin.0 killing pid 16054
    2016-06-06 07:18:58.422  - info: admin.0 terminating http server on port 8081
    2016-06-06 07:18:58.422  - info: iobroker upload [0] admin.admin /volume2/ioBroker/Master/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    2016-06-06 07:18:58.456  - info: admin.0 terminating
    2016-06-06 07:18:58.641  - info: host.DS instance system.adapter.admin.0 terminated with code 0 (OK)
    2016-06-06 07:18:58.787  - info: iobroker Adapter "admin" updated
    2016-06-06 07:18:58.802  - info: iobroker exit 0
    2016-06-06 07:18:50.810  - info: host.DS object change system.adapter.admin.0
    2016-06-06 07:18:50.811  - info: host.DS "system.adapter.admin.0" enabled
    2016-06-06 07:18:50.910  - info: host.DS instance system.adapter.admin.0 started with pid 16054
    2016-06-06 07:19:00.967  - info: host.DS instance system.adapter.admin.0 started with pid 16109
    2016-06-06 07:19:03.650  - info: admin.0 starting. Version 1.2.3 in /volume2/ioBroker/Master/node_modules/iobroker.admin
    2016-06-06 07:19:03.746  - info: admin.0 requesting all states
    2016-06-06 07:19:03.749  - info: admin.0 requesting all objects
    2016-06-06 07:19:03.751  - info: admin.0 Request actual repository...
    2016-06-06 07:19:03.754  - info: admin.0 http server listening on port 8081
    2016-06-06 07:19:03.754  - info: admin.0 Use link "http://localhost:8081" to configure.
    2016-06-06 07:19:04.628  - info: admin.0 received all states
    2016-06-06 07:19:04.958  - info: admin.0 received all objects
    2016-06-06 07:19:05.078  - info: host.DS Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    2016-06-06 07:19:05.409  - info: admin.0 Repository received successfully.
    2016-06-06 07:19:06.990  - warn: host.DS "system.host.RPi2-1" is offline
    2016-06-06 07:19:06.992  - warn: host.DS too delayed answer
    2016-06-06 07:19:07.345  - warn: host.DS "system.host.RPi2-1" is offline
    2016-06-06 07:19:07.346  - warn: host.DS too delayed answer
    Danach habe ich den Host umgeschaltet auf den Slave (RPi2-1)
    Dort habe ich den Admin-Adapter auch aktualisiert. => Sauber durchgelaufen.
    Parallel dazu habe ich das LOG beobachtet:
    dort wird der Host (DS) angegeben und nicht der Host (RPi2-1)
    2016-06-06 07:19:48.122  - info: host.DS object change system.adapter.admin.0
    2016-06-06 07:19:48.128  - info: admin.0 terminating http server on port 8081
    2016-06-06 07:19:48.123  - info: host.DS "system.adapter.admin.0" disabled
    2016-06-06 07:19:48.124  - info: host.DS stopInstance system.adapter.admin.0
    2016-06-06 07:19:48.124  - info: host.DS stopInstance system.adapter.admin.0 killing pid 16109
    2016-06-06 07:19:48.167  - info: admin.0 terminating
    2016-06-06 07:19:48.221  - info: host.DS instance system.adapter.admin.0 terminated with code 0 (OK)
    2016-06-06 07:21:31.062  - info: host.DS object change system.adapter.admin.0
    2016-06-06 07:21:31.065  - info: host.DS "system.adapter.admin.0" enabled
    2016-06-06 07:21:31.085  - info: host.DS instance system.adapter.admin.0 started with pid 16598
    2016-06-06 07:21:33.885  - info: admin.0 starting. Version 1.2.3 in /volume2/ioBroker/Master/node_modules/iobroker.admin
    2016-06-06 07:21:33.968  - info: admin.0 requesting all states
    2016-06-06 07:21:33.974  - info: admin.0 requesting all objects
    2016-06-06 07:21:33.976  - info: admin.0 Request actual repository...
    2016-06-06 07:21:33.979  - info: admin.0 http server listening on port 8081
    2016-06-06 07:21:33.979  - info: admin.0 Use link "http://localhost:8081" to configure.
    2016-06-06 07:21:34.772  - info: admin.0 received all states
    2016-06-06 07:21:35.075  - info: admin.0 received all objects
    2016-06-06 07:21:35.180  - info: host.DS Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    2016-06-06 07:21:35.521  - info: admin.0 Repository received successfully.
    Wird der LOG für Slaves anders gespeichert?
    Jürgen
