  4. IoBroker läuft nicht stabiel, stürzt ab
abstur instabiel läuft nicht
43 Beiträge 8 Kommentatoren 5.8k Aufrufe 4 Beobachtet
  • R RalfEngelberth
    Hatte heute wieder einen Absturz um 7:34
    Ich hatte in IoBroker unter Objekte die Historydaten abfragen wollen.
    Hier der LOG
    2019-11-10 07:34:12.882 - info: web.0 (30403) <==Disconnect system.user.admin from ::ffff:192.168.1.67 flot
    2019-11-10 07:34:12.936 - info: web.0 (30403) ==>Connected system.user.admin from ::ffff:192.168.1.67
    2019-11-10 07:34:14.097 - info: web.0 (30403) <==Disconnect system.user.admin from ::ffff:192.168.1.20 flot
    2019-11-10 07:34:28.156 - info: host.raspberrypi Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
    2019-11-10 07:17:13.294 - info: host.raspberrypi iobroker.js-controller version 2.0.39 js-controller starting
    2019-11-10 07:17:13.307 - info: host.raspberrypi Copyright (c) 2014-2019 bluefox, 2014 hobbyquaker
    2019-11-10 07:17:13.308 - info: host.raspberrypi hostname: raspberrypi, node: v10.17.0
    2019-11-10 07:17:13.312 - info: host.raspberrypi ip addresses: 192.168.1.54 2003:ce:c71a:f100:67e5:fad9:8d9a:849 fec0::8be3:3298:9264:245e fe80::4fe3:6694:39c8:48c9
    2019-11-10 07:17:15.520 - info: host.raspberrypi connected to Objects and States
    2019-11-10 07:17:15.979 - info: host.raspberrypi 50 instances found
    2019-11-10 07:17:16.254 - info: host.raspberrypi starting 36 instances
    2019-11-10 07:17:16.414 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 609
    2019-11-10 07:17:20.291 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 620
    2019-11-10 07:17:20.774 - info: admin.0 (609) starting. Version 3.6.12 in /opt/iobroker/node_modules/iobroker.admin, node: v10.17.0
    2019-11-10 07:17:20.919 - info: admin.0 (609) requesting all states
    2019-11-10 07:17:20.921 - info: admin.0 (609) requesting all objects
    2019-11-10 07:17:24.668 - info: host.raspberrypi instance system.adapter.info.0 started with pid 635
    2019-11-10 07:17:25.487 - info: admin.0 (609) received all objects
    2019-11-10 07:17:25.567 - info: discovery.0 (620) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v10.17.0
    2019-11-10 07:17:26.183 - info: admin.0 (609) http server listening on port 8081
    2019-11-10 07:17:26.184 - info: admin.0 (609) Use link "http://localhost:8081" to configure.
    2019-11-10 07:17:28.281 - info: host.raspberrypi instance system.adapter.web.0 started with pid 670
    2019-11-10 07:17:31.384 - info: web.0 (670) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.web, node: v10.17.0
    2019-11-10 07:17:32.153 - info: web.0 (670) socket.io server listening on port 8082
    2019-11-10 07:17:33.361 - info: info.0 (635) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.info, node: v10.17.0
    2019-11-10 07:17:32.225 - info: web.0 (670) Install extension on /proxy.0/sonos/
    2019-11-10 07:17:33.318 - info: web.0 (670) {"target":"http://localhost:8083","ws":true,"secure":false,"changeOrigin":false,"proxyTimeout":10000,"xfwd":true,"pathRewrite":{"^/proxy.0/sonos/":"/"}}
    2019-11-10 07:17:33.357 - info: web.0 (670) Install extension on /proxy.0/api/
    2019-11-10 07:17:33.359 - info: web.0 (670) {"target":"http://localhost:8084","ws":true,"secure":false,"changeOrigin":false,"proxyTimeout":10000,"xfwd":true,"pathRewrite":{"^/proxy.0/api/":"/"}}
    2019-11-10 07:17:33.364 - info: web.0 (670) Install extension on /proxy.0/node-red/
    2019-11-10 07:17:33.365 - info: web.0 (670) {"target":"http://localhost:1880","ws":true,"secure":false,"changeOrigin":false,"proxyTimeout":10000,"xfwd":true,"pathRewrite":{"^/proxy.0/node-red/":"/"}}
    2019-11-10 07:17:33.368 - info: web.0 (670) Connect extension "proxy/lib/proxy.js"
    2019-11-10 07:17:33.375 - info: web.0 (670) http server listening on port 8082
    2019-11-10 07:43:25.353 - info: info.0 (635) Reading CPU current speed every 3 seconds.
    2019-11-10 07:43:25.389 - info: info.0 (635) Reading CPU data every 3 seconds.
    2019-11-10 07:43:25.451 - warn: vis.0 (685) no connection to objects DB
    2019-11-10 07:43:25.543 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 851
    2019-11-10 07:43:25.584 - info: info.0 (635) Reading disk data every 8 seconds.
    2019-11-10 07:43:25.759 - info: info.0 (635) Reading memory data every 3 seconds.
    Jan1
    @RalfEngelberth
    ist das nicht ein etwas kurzes Intervall?
    R 1 Antwort Letzte Antwort
    • J Jan1
      @RalfEngelberth
      RalfEngelberth
      @Jan1 sagte in IoBroker läuft nicht stabiel, stürzt ab:
      @RalfEngelberth
      Wie kann ich das ändern?
      J 1 Antwort Letzte Antwort
      • R RalfEngelberth
        @RalfEngelberth
        Jan1
        @RalfEngelberth
        weiß ich nicht, kommt mir nur etwas komisch vor, da ich so was bei mir noch nicht gesehen habe.
        Hast Du ein Adapter laufen der da was überwacht?
        • J Jan1
          @RalfEngelberth
          RalfEngelberth
          @Jan1
          ich logge einige Daten mit History
          Aber hier ist die Datenabfrage alle 2 min
          • R RalfEngelberth
            @Jan1
            Jan1
            @RalfEngelberth
            Irgendwas fragt alle 3 Sekunden Deine CPU ab und das kenne ich eben nicht. Bei nem Pi dürfte das in Kombination mit anderen Scripten schon mal dazu führen, dass es eng wird.
            Mal warten ob da noch einer was dazu sagen kann.
            • J Jan1
              @RalfEngelberth
              RalfEngelberth
              schrieb am zuletzt editiert von RalfEngelberth
              @Jan1
              7:43 war der Startvorgang vom Raspberry.
              Danach habe ich solche Einträge nicht mehr in der Log
              Ich habe so die Vermutung, dass ich den Fehler mal beim Raspberry 4 suchen sollte.
              Vielleicht ist hier was nicht in Ordnung.
              Ist WLAN zb. aus oder an bzw. ist hier alles auf dem neusten Stand.
              Vielleich kann mir ja hier einer noch nützliche Tipps geben
                RalfEngelberth
                Habe den Fehler gefunden. Aber warum?
                Ich hatte den Raspberry über einen Switch Netgear GS108 in meinem Netzwerk eingebunden.
                Jetzt habe ich ihn direkt an der Fritzbox angeschlossen.
                Ich hatte danach schon min. 2 Tage keinen Absturz mehr.
                Auch die Cam´s die ich über Vis eingebunden habe und manchmal nicht zu sehen waren sind auf einmal alle da.
                Warum geht es denn nicht mit dem Switch oder welche Einstellungen muss ich am Switch vornehmen damit es funktioniert?
                • R RalfEngelberth
                  BBTownB Offline
                  BBTownB Offline
                  BBTown
                  @RalfEngelberth
                  Meinst Du dass das ioBroker Forum der richtige Platz ist um Probleme zwichen einem Netgear Switch in Verbindung mit einem Raspberry zu lösen?
                  ioBroker auf NUC (VM debian v13 (Trixie ), node v22.22.0 npm v10.9.4, js-controller v7.2.2 jsonl/jsonl / HomeMatic CCU-2 (Wired und Funk) / Philips HUE / echo.DOT / Broadlink RM pro / SONOS
                  • BBTownB BBTown
                    @RalfEngelberth
                    RalfEngelberth
                    @BBTown
                    Auf dem Raspberry ist ja IoBroker installiert.
                    Und das war nicht stabil.
                    Und deswegen hier im Forum
                    • apollon77A Offline
                      Was sagt den /var/log/syslog so zu dem zeitpunkt?
                      • apollon77A apollon77
                        RalfEngelberth
                        @apollon77
                        Hatte gerade nochmal einen Absturz mit IoBroker
                        Hier der Log und der syslog
                        16:17 war der Absturz und 16:46 wurde mit Netzstecker ziehen neu gestartet von mir.
                        Mir fällt nichts ungewöhnliches auf.
                        Außer, dass die Zeiten so durcheinander sind.
                        Ich hatte auch nun schon 2 Tage keinen Absturz mehr
                        LOG
                        2019-11-17 16:12:00.011 - info: javascript.0 (4408) script.js.common.Kostal_Umrichter_Abfrage_mehrmals: Auslöser: Schedule
                        2019-11-17 16:12:00.012 - info: javascript.0 (4408) script.js.common.Kostal_Umrichter_Abfrage_mehrmals: Piko 5.5 auslesen
                        2019-11-17 16:12:00.039 - info: host.raspberrypi instance system.adapter.weatherunderground.0 started with pid 27153
                        2019-11-17 16:12:03.444 - info: weatherunderground.0 (27153) starting. Version 3.1.6 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v10.17.0
                        2019-11-17 16:12:08.252 - info: weatherunderground.0 (27153) Terminated (NO_ERROR): Without reason
                        2019-11-17 16:12:09.918 - info: host.raspberrypi instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
                        2019-11-17 16:15:00.031 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 30943
                        2019-11-17 16:15:04.868 - info: dwd.0 (30943) starting. Version 2.4.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.17.0
                        2019-11-17 16:15:06.176 - info: dwd.0 (30943) Terminated (NO_ERROR): Without reason
                        2019-11-17 16:15:06.718 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
                        2019-11-17 16:17:00.008 - info: javascript.0 (4408) script.js.common.Kostal_Umrichter_Abfrage_mehrmals: Auslöser: Schedule
                        2019-11-17 16:17:00.008 - info: javascript.0 (4408) script.js.common.Kostal_Umrichter_Abfrage_mehrmals: Piko 5.5 auslesen
                        2019-11-17 16:20:00.027 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 4696
                        2019-11-17 16:20:03.367 - info: dwd.0 (4696) starting. Version 2.4.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.17.0
                        2019-11-17 16:20:04.997 - info: dwd.0 (4696) Terminated (NO_ERROR): Without reason
                        2019-11-17 16:20:05.536 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
                        2019-11-17 16:22:00.009 - info: javascript.0 (4408) script.js.common.Kostal_Umrichter_Abfrage_mehrmals: Auslöser: Schedule
                        2019-11-17 16:22:00.010 - info: javascript.0 (4408) script.js.common.Kostal_Umrichter_Abfrage_mehrmals: Piko 5.5 auslesen
                        2019-11-17 16:22:51.575 - info: info.0 (18118) Popup news was read...
                        2019-11-17 16:23:00.038 - info: host.raspberrypi instance system.adapter.openweathermap.0 started with pid 8457
                        2019-11-17 16:23:05.014 - info: openweathermap.0 (8457) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v10.17.0
                        2019-11-17 16:23:08.624 - info: openweathermap.0 (8457) Terminated (NO_ERROR): Without reason
                        2019-11-17 16:23:09.161 - info: host.raspberrypi instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
                        2019-11-17 16:25:00.028 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 10939
                        2019-11-17 16:25:03.882 - info: dwd.0 (10939) starting. Version 2.4.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.17.0
                        2019-11-17 16:25:05.105 - info: dwd.0 (10939) Terminated (NO_ERROR): Without reason
                        2019-11-17 16:25:05.640 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
                        2019-11-17 16:27:00.011 - info: javascript.0 (4408) script.js.common.Kostal_Umrichter_Abfrage_mehrmals: Auslöser: Schedule
                        2019-11-17 16:27:00.013 - info: javascript.0 (4408) script.js.common.Kostal_Umrichter_Abfrage_mehrmals: Piko 5.5 auslesen
                        2019-11-17 16:30:00.028 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 17054
                        2019-11-17 16:30:03.601 - info: dwd.0 (17054) starting. Version 2.4.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.17.0
                        2019-11-17 16:30:04.047 - info: host.raspberrypi instance system.adapter.ical.0 started with pid 17211
                        2019-11-17 16:30:05.628 - info: dwd.0 (17054) Terminated (NO_ERROR): Without reason
                        2019-11-17 16:30:06.152 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
                        2019-11-17 16:30:08.267 - info: ical.0 (17211) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.ical, node: v10.17.0
                        2019-11-17 16:30:10.304 - info: ical.0 (17211) processing URL: KalenderMüll https://calendar.google.com/calendar/ical/q5m7u32s8bqm35sl4fcrplrnoc%40group.calendar.google.com/public/basic.ics
                        2019-11-17 16:30:10.534 - info: javascript.0 (4408) script.js.common.Müllkalender: Start update
                        2019-11-17 16:30:10.536 - info: javascript.0 (4408) script.js.common.Müllkalender: ###
                        2019-11-17 16:30:10.537 - info: javascript.0 (4408) script.js.common.Müllkalender: Rest: 2019-11-18
                        2019-11-17 16:30:10.538 - info: javascript.0 (4408) script.js.common.Müllkalender: ###
                        2019-11-17 16:30:10.539 - info: javascript.0 (4408) script.js.common.Müllkalender: ###
                        2019-11-17 16:30:10.540 - info: javascript.0 (4408) script.js.common.Müllkalender: 18.11.2019
                        2019-11-17 16:30:10.541 - info: javascript.0 (4408) script.js.common.Müllkalender: Bio: 2019-11-18
                        2019-11-17 16:30:10.542 - info: javascript.0 (4408) script.js.common.Müllkalender: ###
                        2019-11-17 16:30:10.543 - info: javascript.0 (4408) script.js.common.Müllkalender: ###
                        2019-11-17 16:30:10.545 - info: javascript.0 (4408) script.js.common.Müllkalender: ###
                        2019-11-17 16:30:10.546 - info: javascript.0 (4408) script.js.common.Müllkalender: Gelb: 2019-12-09
                        2019-11-17 16:30:10.547 - info: javascript.0 (4408) script.js.common.Müllkalender: ###
                        2019-11-17 16:30:10.547 - info: javascript.0 (4408) script.js.common.Müllkalender: Papier: 2019-12-09
                        2019-11-17 16:30:10.548 - info: javascript.0 (4408) script.js.common.Müllkalender: ###
                        2019-11-17 16:30:10.549 - info: javascript.0 (4408) script.js.common.Müllkalender: ###
                        2019-11-17 16:30:10.550 - info: javascript.0 (4408) script.js.common.Müllkalender: ###
                        2019-11-17 16:30:16.062 - info: ical.0 (17211) Terminated (NO_ERROR): Without reason
                        2019-11-17 16:30:16.587 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                        2019-11-17 16:17:15.109 - info: host.raspberrypi iobroker.js-controller version 2.1.0 js-controller starting
                        2019-11-17 16:17:15.122 - info: host.raspberrypi Copyright (c) 2014-2019 bluefox, 2014 hobbyquaker
                        2019-11-17 16:17:15.123 - info: host.raspberrypi hostname: raspberrypi, node: v10.17.0
                        2019-11-17 16:17:15.127 - info: host.raspberrypi ip addresses: 2003:ce:c71a:f100:67e5:fad9:8d9a:849 fec0::8be3:3298:9264:245e fe80::4fe3:6694:39c8:48c9
                        2019-11-17 16:17:17.300 - info: host.raspberrypi connected to Objects and States
                        2019-11-17 16:17:17.769 - info: host.raspberrypi 46 instances found
                        2019-11-17 16:17:17.959 - info: host.raspberrypi starting 34 instances
                        2019-11-17 16:17:18.108 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 608
                        2019-11-17 16:17:21.984 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 619
                        2019-11-17 16:17:22.660 - info: admin.0 (608) starting. Version 3.6.12 in /opt/iobroker/node_modules/iobroker.admin, node: v10.17.0
                        2019-11-17 16:17:22.768 - info: admin.0 (608) requesting all states
                        2019-11-17 16:17:22.770 - info: admin.0 (608) requesting all objects
                        2019-11-17 16:17:26.547 - info: host.raspberrypi instance system.adapter.info.0 started with pid 634
                        2019-11-17 16:17:27.361 - info: discovery.0 (619) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v10.17.0
                        2019-11-17 16:17:27.764 - info: admin.0 (608) received all objects
                        2019-11-17 16:17:28.339 - info: admin.0 (608) http server listening on port 8081
                        2019-11-17 16:17:28.340 - info: admin.0 (608) Use link "http://localhost:8081" to configure.
                        2019-11-17 16:17:30.437 - info: host.raspberrypi instance system.adapter.web.0 started with pid 657
                        2019-11-17 16:17:34.405 - info: web.0 (657) starting. Version 2.4.10 in /opt/iobroker/node_modules/iobroker.web, node: v10.17.0
                        2019-11-17 16:46:08.563 - info: web.0 (657) socket.io server listening on port 8082
                        2019-11-17 16:46:08.844 - info: info.0 (634) starting. Version 1.5.7 in /opt/iobroker/node_modules/iobroker.info, node: v10.17.0
                        2019-11-17 16:46:11.079 - info: info.0 (634) Reading CPU current speed every 3 seconds.
                        2019-11-17 16:46:11.139 - info: info.0 (634) Reading CPU data every 3 seconds.
                        2019-11-17 16:46:11.400 - info: host.raspberrypi instance system.adapter.history.0 started with pid 859
                        2019-11-17 16:46:11.719 - info: vis.0 (668) starting. Version 1.2.2 in /opt/iobroker/node_modules/iobroker.vis, node: v10.17.0
                        2019-11-17 16:46:11.368 - info: info.0 (634) Reading disk data every 8 seconds.
                        2019-11-17 16:46:11.607 - info: info.0 (634) Reading memory data every 3 seconds.
                        2019-11-17 16:46:11.970 - info: info.0 (634) Reading user data every 8 seconds.
                        2019-11-17 16:46:12.160 - info: vis.0 (668) vis license is OK.
                        2019-11-17 16:46:08.609 - info: web.0 (657) Install extension on /proxy.0/sonos/
                        2019-11-17 16:46:12.078 - info: web.0 (657) {"target":"http://localhost:8083","ws":true,"secure":false,"changeOrigin":false,"proxyTimeout":10000,"xfwd":true,"pathRewrite":{"^/proxy.0/sonos/":"/"}}
                        2019-11-17 16:46:12.124 - info: web.0 (657) Install extension on /proxy.0/api/
                        2019-11-17 16:46:12.126 - info: web.0 (657) {"target":"http://localhost:8084","ws":true,"secure":false,"changeOrigin":false,"proxyTimeout":10000,"xfwd":true,"pathRewrite":{"^/proxy.0/api/":"/"}}
                        2019-11-17 16:46:12.131 - info: web.0 (657) Install extension on /proxy.0/node-red/
                        2019-11-17 16:46:12.132 - info: web.0 (657) {"target":"http://localhost:1880","ws":true,"secure":false,"changeOrigin":false,"proxyTimeout":10000,"xfwd":true,"pathRewrite":{"^/proxy.0/node-red/":"/"}}
                        2019-11-17 16:46:12.136 - info: web.0 (657) Connect extension "proxy/lib/proxy.js"
                        2019-11-17 16:46:12.148 - info: web.0 (657) http server listening on port 8082
                        2019-11-17 16:46:12.154 - info: info.0 (634) Reading battery data every 8 seconds.
                        2019-11-17 16:46:12.161 - info: info.0 (634) Reading CPU temp data every 3 seconds.
                        Syslog
                        Nov 17 15:51:14 raspberrypi rngd[350]: stats: FIPS 140-2(2001-10-10) Runs: 0
                        Nov 17 15:51:14 raspberrypi rngd[350]: stats: FIPS 140-2(2001-10-10) Long run: 0
                        Nov 17 15:51:14 raspberrypi rngd[350]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
                        Nov 17 15:51:14 raspberrypi rngd[350]: stats: HRNG source speed: (min=628.297; avg=937.073; max=1004.901)Kibits/s
                        Nov 17 15:51:14 raspberrypi rngd[350]: stats: FIPS tests speed: (min=2.158; avg=8.209; max=14.160)Mibits/s
                        Nov 17 15:51:14 raspberrypi rngd[350]: stats: Lowest ready-buffers level: 2
                        Nov 17 15:51:14 raspberrypi rngd[350]: stats: Entropy starvations: 0
                        Nov 17 15:51:14 raspberrypi rngd[350]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
                        Nov 17 16:07:54 raspberrypi dhcpcd[532]: eth0: DHCPv6 REPLY: in stateless mode
                        Nov 17 16:17:01 raspberrypi CRON[1034]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
                        Nov 17 16:31:16 raspberrypi bash[18057]: Send diag info: {"uuid":"856a113a-5105-9c48-b6cb-de7489b7d58a","language":"de","country":"Germany","hosts":[{"version":"2.1.0","platform":"Javascript/Node.js","type":"linux"}],"node":"v10.17.0","a
                        rch":"arm","adapters":{"admin":{"version":"3.6.12","platform":"Javascript/Node.js"},"discovery":{"version":"2.0.0","platform":"Javascript/Node.js"},"info":{"version":"1.5.7","platform":"Javascript/Node.js"},"mqtt":{"version":"2.1.1","pla
                        tform":"Javascript/Node.js"},"web":{"version":"2.4.10","platform":"Javascript/Node.js"},"vis":{"version":"1.2.2","platform":"Javascript/Node.js"},"cloud":{"version":"2.8.0","platform":"Javascript/Node.js"},"backitup":{"version":"1.2.2","
                        platform":"Javascript/Node.js"},"alexa2":{"version":"2.6.4","platform":"Javascript/Node.js"},"fritzbox":{"version":"0.2.1","platform":"Javascript/Node.js"},"fritzdect":{"version":"0.2.4","platform":"Javascript/Node.js"},"history":{"versi
                        on":"1.8.7","platform":"Javascript/Node.js"},"js2fs":{"version":"0.1.5","platform":"Javascript/Node.js"},"shelly":{"version":"3.1.1","platform":"Javascript/Node.js"},"sonoff":{"version":"2.3.2","platform":"Javascript/Node.js"},"javascrip
                        t":{"version":"4.3.3","platform":"Javascript/Node.js"},"onvif":{"version":"0.0.2","platform":"Javascript/Node.js"},"sql":{"version":"1.9.5","platform":"Javascript/Node.js"},"parser":{"version":"1.0.7","platform":"Javascript/Node.js"},"vi
                        s-weather":{"version":"2.4.0","platform":"Javascript/Node.js"},"yr":{"version":"2.0.3","platform":"Javascript/Node.js"},"dwd":{"version":"2.4.3","platform":"javascript/Node.js"},"daswetter":{"version":"2.8.1","platform":"Javascript/Node.
                        js"},"iqontrol":{"version":"0.2.14","platform":"Javascript/Node.js"},"vis-bars":{"version":"0.1.4","platform":"Javascript/Node.js"},"vis-history":{"version":"1.0.0","platform":"Javascript/Node.js"},"vis-keyboard":{"version":"0.0.2","plat
                        form":"Javascript/Node.js"},"proxy":{"version":"1.1.1","platform":"Javascript/Node.js"},"openweathermap":{"version":"0.1.0","platform":"Javascript/Node.js"},"vis-timeandweather":{"version":"1.1.7","platform":"Javascript/Node.js"},"scenes
                        ":{"version":"1.1.0","platform":"Javascript/Node.js"},"weatherunderground":{"version":"3.1.6","platform":"Javascript/Node.js"},"pollenflug":{"version":"1.0.4","platform":"Javascript/Node.js"},"mobile":{"version":"0.5.0","platform":"javas
                        cript/Node.js"},"vis-jqui-mfd":{"version":"1.0.12","platform":"Javascript/Node.js"},"simple-api":{"version":"2.3.2","platform":"Javascript/Node.js"},"worx":{"version":"0.4.0","platform":"Javascript/Node.js"},"yahka":{"version":"0.9.2","p
                        latform":"Javascript/Node.js"},"ical":{"version":"1.7.0","platform":"Javascript/Node.js"},"icons-icons8":{"version":"0.0.1","platform":"javascript/Node.js"},"vis-hqwidgets":{"version":"1.1.3","platform":"Javascript/Node.js"},"vis-plumb":
                        {"version":"1.0.2","platform":"Javascript/Node.js"},"vis-materialdesign":{"version":"0.1.5","platform":"Javascript/Node.js"},"landroid":{"version":"1.0.3","platform":"Javascript/Node.js"},"telegram":{"version":"1.4.3","platform":"Javascr
                        ipt/Node.js"},"text2command":{"version":"1.3.1","platform":"Javascript/Node.js"},"hmip":{"version":"0.0.11","platform":"Javascript/Node.js"},"hm-rpc":{"version":"1.11.0","platform":"Javascript/Node.js"},"hm-rega":{"version":"2.4.12","pla
                        tform":"Javascript/Node.js"},"flot":{"version":"1.9.2","platform":"javascript/Node.js"}},"statesType":"file","objectsType":"file","model":"ARMv7 Processor rev 4 (v7l)","cpus":4,"mem":971063296,"ostype":"Linux","city":"Windeck","vis":742}
                        Nov 17 14:51:14 raspberrypi rngd[350]: stats: entropy added to kernel pool: 874336
                        Nov 17 14:51:14 raspberrypi rngd[350]: stats: FIPS 140-2 successes: 46
                        Nov 17 14:51:14 raspberrypi rngd[350]: stats: FIPS 140-2 failures: 0
                        Nov 17 14:51:14 raspberrypi rngd[350]: stats: FIPS 140-2(2001-10-10) Monobit: 0
                        Nov 17 14:51:14 raspberrypi rngd[350]: stats: FIPS 140-2(2001-10-10) Poker: 0
                        Nov 17 14:51:14 raspberrypi rngd[350]: stats: FIPS 140-2(2001-10-10) Runs: 0
                        Nov 17 14:51:14 raspberrypi rngd[350]: stats: FIPS 140-2(2001-10-10) Long run: 0
                        Nov 17 14:51:14 raspberrypi rngd[350]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
                        Nov 17 14:51:14 raspberrypi rngd[350]: stats: HRNG source speed: (min=628.297; avg=937.114; max=1004.901)Kibits/s
                        Nov 17 14:51:14 raspberrypi rngd[350]: stats: FIPS tests speed: (min=2.158; avg=8.270; max=14.160)Mibits/s
                        Nov 17 14:51:14 raspberrypi rngd[350]: stats: Lowest ready-buffers level: 2
                        Nov 17 14:51:14 raspberrypi rngd[350]: stats: Entropy starvations: 0
                        Nov 17 14:51:14 raspberrypi rngd[350]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
                        Nov 17 15:05:23 raspberrypi dhcpcd[532]: eth0: DHCPv6 REPLY: in stateless mode
                        Nov 17 15:17:01 raspberrypi CRON[19773]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
                        Nov 17 15:51:14 raspberrypi rngd[350]: stats: bits received from HRNG source: 960064
                        Nov 17 15:51:14 raspberrypi rngd[350]: stats: bits sent to kernel pool: 904096
                        Nov 17 15:51:14 raspberrypi rngd[350]: stats: entropy added to kernel pool: 904096
                        Nov 17 15:51:14 raspberrypi rngd[350]: stats: FIPS 140-2 successes: 48
                        Nov 17 15:51:14 raspberrypi rngd[350]: stats: FIPS 140-2 failures: 0
                        Nov 17 15:51:14 raspberrypi rngd[350]: stats: FIPS 140-2(2001-10-10) Monobit: 0
                        Nov 17 15:51:14 raspberrypi rngd[350]: stats: FIPS 140-2(2001-10-10) Poker: 0
                        Nov 17 16:34:17 raspberrypi kernel: [110590.976425] INFO: task kworker/3:0:17358 blocked for more than 120 seconds.
                        Nov 17 16:34:22 raspberrypi kernel: [110590.976435]       Tainted: G         C        4.19.66-v7+ #1253
                        Nov 17 16:34:26 raspberrypi kernel: [110590.976438] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
                        Nov 17 16:34:31 raspberrypi kernel: [110590.976443] kworker/3:0     D    0 17358      2 0x00000000
                        Nov 17 16:34:37 raspberrypi kernel: [110590.976464] Workqueue: events_freezable mmc_rescan
                        Nov 17 16:34:40 raspberrypi kernel: [110590.976486] [<80830934>] (__schedule) from [<80830fa4>] (schedule+0x50/0xa8)
                        Nov 17 16:34:40 raspberrypi kernel: [110590.976496] [<80830fa4>] (schedule) from [<80686520>] (__mmc_claim_host+0x120/0x228)
                        Nov 17 16:34:40 raspberrypi kernel: [110590.976505] [<80686520>] (__mmc_claim_host) from [<80686660>] (mmc_get_card+0x38/0x3c)
                        Nov 17 16:34:40 raspberrypi kernel: [110590.976514] [<80686660>] (mmc_get_card) from [<8068f6cc>] (mmc_sd_detect+0x24/0x7c)
                        Nov 17 16:34:40 raspberrypi kernel: [110590.976523] [<8068f6cc>] (mmc_sd_detect) from [<80688c88>] (mmc_rescan+0x1cc/0x39c)
                        Nov 17 16:34:40 raspberrypi kernel: [110590.976535] [<80688c88>] (mmc_rescan) from [<8013bf0c>] (process_one_work+0x170/0x458)
                        Nov 17 16:34:40 raspberrypi kernel: [110590.976545] [<8013bf0c>] (process_one_work) from [<8013c250>] (worker_thread+0x5c/0x5a4)
                        Nov 17 16:34:40 raspberrypi kernel: [110590.976554] [<8013c250>] (worker_thread) from [<8014253c>] (kthread+0x138/0x168)
                        Nov 17 16:34:40 raspberrypi kernel: [110590.976564] [<8014253c>] (kthread) from [<801010ac>] (ret_from_fork+0x14/0x28)
                        Nov 17 16:34:40 raspberrypi kernel: [110590.976569] Exception stack(0x85d3dfb0 to 0x85d3dff8)
                        Nov 17 16:34:40 raspberrypi kernel: [110590.976574] dfa0:                                     00000000 00000000 00000000 00000000
                        Nov 17 16:34:40 raspberrypi kernel: [110590.976581] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                        Nov 17 16:34:40 raspberrypi kernel: [110590.976586] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000
                        Nov 17 16:36:20 raspberrypi kernel: [110713.857586] INFO: task kworker/3:0:17358 blocked for more than 120 seconds.
                        Nov 17 16:36:28 raspberrypi kernel: [110713.857595]       Tainted: G         C        4.19.66-v7+ #1253
                        Nov 17 16:36:35 raspberrypi kernel: [110713.857598] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
                        Nov 17 16:36:39 raspberrypi kernel: [110713.857603] kworker/3:0     D    0 17358      2 0x00000000
                        Nov 17 16:36:46 raspberrypi kernel: [110713.857625] Workqueue: events_freezable mmc_rescan
                        Nov 17 16:36:53 raspberrypi kernel: [110713.857648] [<80830934>] (__schedule) from [<80830fa4>] (schedule+0x50/0xa8)
                        Nov 17 16:36:59 raspberrypi kernel: [110713.857658] [<80830fa4>] (schedule) from [<80686520>] (__mmc_claim_host+0x120/0x228)
                        Nov 17 16:37:05 raspberrypi kernel: [110713.857667] [<80686520>] (__mmc_claim_host) from [<80686660>] (mmc_get_card+0x38/0x3c)
                        Nov 17 16:37:11 raspberrypi kernel: [110713.857675] [<80686660>] (mmc_get_card) from [<8068f6cc>] (mmc_sd_detect+0x24/0x7c)
                        Nov 17 16:37:18 raspberrypi kernel: [110713.857684] [<8068f6cc>] (mmc_sd_detect) from [<80688c88>] (mmc_rescan+0x1cc/0x39c)
                        Nov 17 16:37:25 raspberrypi kernel: [110713.857695] [<80688c88>] (mmc_rescan) from [<8013bf0c>] (process_one_work+0x170/0x458)
                        Nov 17 16:37:33 raspberrypi kernel: [110713.857705] [<8013bf0c>] (process_one_work) from [<8013c250>] (worker_thread+0x5c/0x5a4)
                        Nov 17 16:37:38 raspberrypi kernel: [110713.857715] [<8013c250>] (worker_thread) from [<8014253c>] (kthread+0x138/0x168)
                        Nov 17 16:37:47 raspberrypi kernel: [110713.857725] [<8014253c>] (kthread) from [<801010ac>] (ret_from_fork+0x14/0x28)
                        Nov 17 16:37:54 raspberrypi kernel: [110713.857729] Exception stack(0x85d3dfb0 to 0x85d3dff8)
                        Nov 17 16:38:01 raspberrypi kernel: [110713.857735] dfa0:                                     00000000 00000000 00000000 00000000
                        Nov 17 16:38:10 raspberrypi kernel: [110713.857741] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                        Nov 17 16:38:17 raspberrypi kernel: [110713.857747] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000
                        Nov 17 16:38:24 raspberrypi kernel: [110836.738726] INFO: task kworker/3:0:17358 blocked for more than 120 seconds.
                        Nov 17 16:38:37 raspberrypi kernel: [110836.738737]       Tainted: G         C        4.19.66-v7+ #1253
                        Nov 17 16:38:43 raspberrypi kernel: [110836.738740] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
                        Nov 17 16:38:48 raspberrypi kernel: [110836.738744] kworker/3:0     D    0 17358      2 0x00000000
                        Nov 17 16:38:54 raspberrypi kernel: [110836.738765] Workqueue: events_freezable mmc_rescan
                        Nov 17 16:39:00 raspberrypi kernel: [110836.738787] [<80830934>] (__schedule) from [<80830fa4>] (schedule+0x50/0xa8)
                        Nov 17 16:39:07 raspberrypi kernel: [110836.738796] [<80830fa4>] (schedule) from [<80686520>] (__mmc_claim_host+0x120/0x228)
                        Nov 17 16:39:14 raspberrypi kernel: [110836.738805] [<80686520>] (__mmc_claim_host) from [<80686660>] (mmc_get_card+0x38/0x3c)
                        Nov 17 16:39:22 raspberrypi kernel: [110836.738814] [<80686660>] (mmc_get_card) from [<8068f6cc>] (mmc_sd_detect+0x24/0x7c)
                        Nov 17 16:39:29 raspberrypi kernel: [110836.738823] [<8068f6cc>] (mmc_sd_detect) from [<80688c88>] (mmc_rescan+0x1cc/0x39c)
                        Nov 17 16:39:35 raspberrypi kernel: [110836.738834] [<80688c88>] (mmc_rescan) from [<8013bf0c>] (process_one_work+0x170/0x458)
                        Nov 17 16:39:45 raspberrypi kernel: [110836.738843] [<8013bf0c>] (process_one_work) from [<8013c250>] (worker_thread+0x5c/0x5a4)
                        Nov 17 16:39:51 raspberrypi kernel: [110836.738853] [<8013c250>] (worker_thread) from [<8014253c>] (kthread+0x138/0x168)
                        Nov 17 16:39:57 raspberrypi kernel: [110836.738864] [<8014253c>] (kthread) from [<801010ac>] (ret_from_fork+0x14/0x28)
                        Nov 17 16:40:03 raspberrypi kernel: [110836.738868] Exception stack(0x85d3dfb0 to 0x85d3dff8)
                        Nov 17 16:40:09 raspberrypi kernel: [110836.738874] dfa0:                                     00000000 00000000 00000000 00000000
                        Nov 17 16:40:15 raspberrypi kernel: [110836.738880] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                        Nov 17 16:40:20 raspberrypi kernel: [110836.738885] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000
                        Nov 17 16:40:28 raspberrypi kernel: [110959.619889] INFO: task kworker/3:0:17358 blocked for more than 120 seconds.
                        Nov 17 16:40:34 raspberrypi kernel: [110959.619898]       Tainted: G         C        4.19.66-v7+ #1253
                        Nov 17 16:40:41 raspberrypi kernel: [110959.619901] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
                        Nov 17 16:40:49 raspberrypi kernel: [110959.619906] kworker/3:0     D    0 17358      2 0x00000000
                        Nov 17 16:40:55 raspberrypi kernel: [110959.619926] Workqueue: events_freezable mmc_rescan
                        Nov 17 16:41:10 raspberrypi kernel: [110959.619948] [<80830934>] (__schedule) from [<80830fa4>] (schedule+0x50/0xa8)
                        Nov 17 16:41:18 raspberrypi kernel: [110959.619958] [<80830fa4>] (schedule) from [<80686520>] (__mmc_claim_host+0x120/0x228)
                        Nov 17 16:41:26 raspberrypi kernel: [110959.619967] [<80686520>] (__mmc_claim_host) from [<80686660>] (mmc_get_card+0x38/0x3c)
                        Nov 17 16:41:50 raspberrypi kernel: [110959.619975] [<80686660>] (mmc_get_card) from [<8068f6cc>] (mmc_sd_detect+0x24/0x7c)
                        Nov 17 16:42:02 raspberrypi kernel: [110959.619984] [<8068f6cc>] (mmc_sd_detect) from [<80688c88>] (mmc_rescan+0x1cc/0x39c)
                        Nov 17 16:42:09 raspberrypi kernel: [110959.619995] [<80688c88>] (mmc_rescan) from [<8013bf0c>] (process_one_work+0x170/0x458)
                        Nov 17 16:42:17 raspberrypi kernel: [110959.620005] [<8013bf0c>] (process_one_work) from [<8013c250>] (worker_thread+0x5c/0x5a4)
                        Nov 17 16:42:23 raspberrypi kernel: [110959.620015] [<8013c250>] (worker_thread) from [<8014253c>] (kthread+0x138/0x168)
                        Nov 17 16:42:32 raspberrypi kernel: [110959.620025] [<8014253c>] (kthread) from [<801010ac>] (ret_from_fork+0x14/0x28)
                        Nov 17 16:42:43 raspberrypi kernel: [110959.620030] Exception stack(0x85d3dfb0 to 0x85d3dff8)
                        Nov 17 16:42:50 raspberrypi kernel: [110959.620036] dfa0:                                     00000000 00000000 00000000 00000000
                        Nov 17 16:42:59 raspberrypi kernel: [110959.620042] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                        Nov 17 16:43:07 raspberrypi kernel: [110959.620048] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000
                        Nov 17 16:43:15 raspberrypi kernel: [111082.501015] INFO: task kworker/3:0:17358 blocked for more than 120 seconds.
                        Nov 17 16:43:24 raspberrypi kernel: [111082.501025]       Tainted: G         C        4.19.66-v7+ #1253
                        Nov 17 16:43:33 raspberrypi kernel: [111082.501028] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
                        Nov 17 16:43:42 raspberrypi kernel: [111082.501034] kworker/3:0     D    0 17358      2 0x00000000
                        Nov 17 16:43:51 raspberrypi kernel: [111082.501054] Workqueue: events_freezable mmc_rescan
                        Nov 17 16:43:59 raspberrypi kernel: [111082.501077] [<80830934>] (__schedule) from [<80830fa4>] (schedule+0x50/0xa8)
                        Nov 17 16:44:07 raspberrypi kernel: [111082.501086] [<80830fa4>] (schedule) from [<80686520>] (__mmc_claim_host+0x120/0x228)
                        Nov 17 16:44:15 raspberrypi kernel: [111082.501095] [<80686520>] (__mmc_claim_host) from [<80686660>] (mmc_get_card+0x38/0x3c)
                        Nov 17 16:44:20 raspberrypi kernel: [111082.501104] [<80686660>] (mmc_get_card) from [<8068f6cc>] (mmc_sd_detect+0x24/0x7c)
                        Nov 17 16:44:29 raspberrypi kernel: [111082.501112] [<8068f6cc>] (mmc_sd_detect) from [<80688c88>] (mmc_rescan+0x1cc/0x39c)
                        Nov 17 16:44:37 raspberrypi kernel: [111082.501123] [<80688c88>] (mmc_rescan) from [<8013bf0c>] (process_one_work+0x170/0x458)
                        Nov 17 16:44:46 raspberrypi kernel: [111082.501133] [<8013bf0c>] (process_one_work) from [<8013c250>] (worker_thread+0x5c/0x5a4)
                        Nov 17 16:17:04 raspberrypi fake-hwclock[100]: Sun 17 Nov 15:17:01 UTC 2019
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started File System Check Daemon to report status.
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started Apply Kernel Variables.
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started udev Coldplug all Devices.
                        Nov 17 16:17:04 raspberrypi systemd[1]: Starting Helper to synchronize boot up for ifupdown...
                        Nov 17 16:17:04 raspberrypi systemd-fsck[126]: e2fsck 1.44.5 (15-Dec-2018)
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started Helper to synchronize boot up for ifupdown.
                        Nov 17 16:17:04 raspberrypi systemd-fsck[126]: rootfs: clean, 132715/1822992 files, 1510848/7612416 blocks
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started File System Check on Root Device.
                        Nov 17 16:17:04 raspberrypi systemd[1]: Starting Remount Root and Kernel File Systems...
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started Set the console keyboard layout.
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started Remount Root and Kernel File Systems.
                        Nov 17 16:17:04 raspberrypi systemd[1]: Starting Load/Save Random Seed...
                        Nov 17 16:17:04 raspberrypi systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
                        Nov 17 16:17:04 raspberrypi systemd[1]: Starting Flush Journal to Persistent Storage...
                        Nov 17 16:17:04 raspberrypi systemd[1]: Starting Create System Users...
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000] Booting Linux on physical CPU 0x0
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000] Linux version 4.19.66-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1253 SMP Thu Aug 15 11:49:46 BST 2019
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started Load/Save Random Seed.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000] CPU: div instructions available: patching division code
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started Flush Journal to Persistent Storage.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000] Memory policy: Data cache writealloc
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000] cma: Reserved 8 MiB at 0x3ac00000
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started Create System Users.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000] On node 0 totalpages: 242688
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000]   Normal zone: 2133 pages used for memmap
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000]   Normal zone: 0 pages reserved
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000]   Normal zone: 242688 pages, LIFO batch:63
                        Nov 17 16:17:04 raspberrypi systemd[1]: Starting Create Static Device Nodes in /dev...
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000] random: get_random_bytes called from start_kernel+0xac/0x4b4 with crng_init=0
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000] percpu: Embedded 17 pages/cpu s39488 r8192 d21952 u69632
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started Create Static Device Nodes in /dev.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000] pcpu-alloc: s39488 r8192 d21952 u69632 alloc=17*4096
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 240555
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=9263b30d-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
                        Nov 17 16:17:04 raspberrypi systemd[1]: Starting udev Kernel Device Manager...
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000] Memory: 939088K/970752K available (8192K kernel code, 629K rwdata, 2176K rodata, 1024K init, 821K bss, 23472K reserved, 8192K cma-reserved)
                        Nov 17 16:17:04 raspberrypi systemd[1]: Reached target Local File Systems (Pre).
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000] Virtual kernel memory layout:
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000]     vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000]     lowmem  : 0x80000000 - 0xbb400000   ( 948 MB)
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started udev Kernel Device Manager.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000]     modules : 0x7f000000 - 0x80000000   (  16 MB)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (9184 kB)
                        Nov 17 16:17:04 raspberrypi systemd[1]: Found device /dev/serial1.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000]       .init : 0x(ptrval) - 0x(ptrval)   (1024 kB)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 630 kB)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 822 kB)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                        Nov 17 16:17:04 raspberrypi systemd[1]: Found device /dev/disk/by-partuuid/9263b30d-01.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000] ftrace: allocating 26394 entries in 78 pages
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000] rcu: Hierarchical RCU implementation.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
                        Nov 17 16:17:04 raspberrypi systemd[1]: Starting File System Check on /dev/disk/by-partuuid/9263b30d-01...
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000023] Switching to timer-based delay loop, resolution 52ns
                        Nov 17 16:17:04 raspberrypi mtp-probe: checking bus 1, device 3: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1"
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000287] Console: colour dummy device 80x30
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000912] console [tty1] enabled
                        Nov 17 16:17:04 raspberrypi kernel: [    0.000970] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.001015] pid_max: default: 32768 minimum: 301
                        Nov 17 16:17:04 raspberrypi mtp-probe: bus: 1, device: 3 was not an MTP device
                        Nov 17 16:17:04 raspberrypi kernel: [    0.001374] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.001410] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.002346] CPU: Testing write buffer coherency: ok
                        Nov 17 16:17:04 raspberrypi kernel: [    0.002835] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                        Nov 17 16:17:04 raspberrypi systemd-udevd[140]: Using default interface naming scheme 'v240'.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.003502] Setting up static identity map for 0x100000 - 0x10003c
                        Nov 17 16:17:04 raspberrypi kernel: [    0.003670] rcu: Hierarchical SRCU implementation.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.004485] smp: Bringing up secondary CPUs ...
                        Nov 17 16:17:04 raspberrypi kernel: [    0.005339] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                        Nov 17 16:17:04 raspberrypi systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.006264] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
                        Nov 17 16:17:04 raspberrypi kernel: [    0.007122] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
                        Nov 17 16:17:04 raspberrypi kernel: [    0.007243] smp: Brought up 1 node, 4 CPUs
                        Nov 17 16:17:04 raspberrypi systemd-fsck[222]: fsck.fat 4.1 (2017-01-24)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.007324] SMP: Total of 4 processors activated (153.60 BogoMIPS).
                        Nov 17 16:17:04 raspberrypi kernel: [    0.007348] CPU: All CPU(s) started in HYP mode.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.007369] CPU: Virtualization extensions available.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.008357] devtmpfs: initialized
                        Nov 17 16:17:04 raspberrypi systemd-fsck[222]: 0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.021277] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
                        Nov 17 16:17:04 raspberrypi kernel: [    0.021552] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                        Nov 17 16:17:04 raspberrypi systemd-fsck[222]:  Automatically removing dirty bit.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.021600] futex hash table entries: 1024 (order: 4, 65536 bytes)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.022206] pinctrl core: initialized pinctrl subsystem
                        Nov 17 16:17:04 raspberrypi kernel: [    0.023090] NET: Registered protocol family 16
                        Nov 17 16:17:04 raspberrypi kernel: [    0.026034] DMA: preallocated 1024 KiB pool for atomic coherent allocations
                        Nov 17 16:17:04 raspberrypi systemd-fsck[222]: Performing changes.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.031739] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.031776] hw-breakpoint: maximum watchpoint size is 8 bytes.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.031996] Serial: AMBA PL011 UART driver
                        Nov 17 16:17:04 raspberrypi kernel: [    0.034297] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
                        Nov 17 16:17:04 raspberrypi systemd-fsck[222]: /dev/mmcblk0p1: 223 files, 80104/516191 clusters
                        Nov 17 16:17:04 raspberrypi kernel: [    0.069441] bcm2835-dma 3f007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
                        Nov 17 16:17:04 raspberrypi kernel: [    0.071366] SCSI subsystem initialized
                        Nov 17 16:17:04 raspberrypi systemd-udevd[142]: Using default interface naming scheme 'v240'.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.071604] usbcore: registered new interface driver usbfs
                        Nov 17 16:17:04 raspberrypi kernel: [    0.071686] usbcore: registered new interface driver hub
                        Nov 17 16:17:04 raspberrypi kernel: [    0.071799] usbcore: registered new device driver usb
                        Nov 17 16:17:04 raspberrypi kernel: [    0.090301] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-08-15 12:06, variant start
                        Nov 17 16:17:04 raspberrypi kernel: [    0.100131] raspberrypi-firmware soc:firmware: Firmware hash is 0e6daa5106dd4164474616408e0dc24f997ffcf3
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started File System Check on /dev/disk/by-partuuid/9263b30d-01.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.111770] clocksource: Switched to clocksource arch_sys_counter
                        Nov 17 16:17:04 raspberrypi kernel: [    0.200874] VFS: Disk quotas dquot_6.6.0
                        Nov 17 16:17:04 raspberrypi systemd[1]: Condition check resulted in Huge Pages File System being skipped.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.200986] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.201163] FS-Cache: Loaded
                        Nov 17 16:17:04 raspberrypi kernel: [    0.201389] CacheFiles: Loaded
                        Nov 17 16:17:04 raspberrypi systemd[1]: Condition check resulted in FUSE Control File System being skipped.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.211385] NET: Registered protocol family 2
                        Nov 17 16:17:04 raspberrypi kernel: [    0.212207] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.212271] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.212401] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
                        Nov 17 16:17:04 raspberrypi systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.212606] TCP: Hash tables configured (established 8192 bind 8192)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.212761] UDP hash table entries: 512 (order: 2, 16384 bytes)
                        Nov 17 16:17:04 raspberrypi systemd[1]: Mounting /boot...
                        Nov 17 16:17:04 raspberrypi kernel: [    0.212827] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.213155] NET: Registered protocol family 1
                        Nov 17 16:17:04 raspberrypi kernel: [    0.213735] RPC: Registered named UNIX socket transport module.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.213762] RPC: Registered udp transport module.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.213784] RPC: Registered tcp transport module.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.213806] RPC: Registered tcp NFSv4.1 backchannel transport module.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.215509] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
                        Nov 17 16:17:04 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status...
                        Nov 17 16:17:04 raspberrypi kernel: [    0.218552] Initialise system trusted keyrings
                        Nov 17 16:17:04 raspberrypi kernel: [    0.218761] workingset: timestamp_bits=14 max_order=18 bucket_order=4
                        Nov 17 16:17:04 raspberrypi kernel: [    0.228739] FS-Cache: Netfs 'nfs' registered for caching
                        Nov 17 16:17:04 raspberrypi kernel: [    0.229346] NFS: Registering the id_resolver key type
                        Nov 17 16:17:04 raspberrypi systemd[1]: Mounted /boot.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.229392] Key type id_resolver registered
                        Nov 17 16:17:04 raspberrypi kernel: [    0.229414] Key type id_legacy registered
                        Nov 17 16:17:04 raspberrypi kernel: [    0.229446] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                        Nov 17 16:17:04 raspberrypi kernel: [    0.231743] Key type asymmetric registered
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.231847] Asymmetric key parser 'x509' registered
                        Nov 17 16:17:04 raspberrypi kernel: [    0.231917] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
                        Nov 17 16:17:04 raspberrypi systemd[1]: Reached target Local File Systems.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.232098] io scheduler noop registered
                        Nov 17 16:17:04 raspberrypi kernel: [    0.232122] io scheduler deadline registered (default)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.232316] io scheduler cfq registered
                        Nov 17 16:17:04 raspberrypi kernel: [    0.232340] io scheduler mq-deadline registered (default)
                        Nov 17 16:17:04 raspberrypi systemd[1]: Starting Create Volatile Files and Directories...
                        Nov 17 16:17:04 raspberrypi kernel: [    0.232364] io scheduler kyber registered
                        Nov 17 16:17:04 raspberrypi kernel: [    0.235522] bcm2708_fb soc:fb: FB found 1 display(s)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.244427] Console: switching to colour frame buffer device 82x26
                        Nov 17 16:17:04 raspberrypi systemd[1]: Starting Set console font and keymap...
                        Nov 17 16:17:04 raspberrypi kernel: [    0.251242] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
                        Nov 17 16:17:04 raspberrypi kernel: [    0.257987] bcm2835-rng 3f104000.rng: hwrng registered
                        Nov 17 16:17:04 raspberrypi systemd[1]: Starting Preprocess NFS configuration...
                        Nov 17 16:17:04 raspberrypi systemd[1]: Starting Raise network interfaces...
                        Nov 17 16:17:04 raspberrypi systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
                        Nov 17 16:17:04 raspberrypi systemd[1]: nfs-config.service: Succeeded.
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started Preprocess NFS configuration.
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started Set console font and keymap.
                        Nov 17 16:17:04 raspberrypi systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
                        Nov 17 16:17:04 raspberrypi systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
                        Nov 17 16:17:04 raspberrypi systemd[1]: Reached target NFS client services.
                        Nov 17 16:17:04 raspberrypi systemd[1]: Reached target Remote File Systems (Pre).
                        Nov 17 16:17:04 raspberrypi systemd[1]: Reached target Remote File Systems.
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started Create Volatile Files and Directories.
                        Nov 17 16:17:04 raspberrypi systemd[1]: Starting Network Time Synchronization...
                        Nov 17 16:17:04 raspberrypi systemd[1]: Starting Update UTMP about System Boot/Shutdown...
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started Update UTMP about System Boot/Shutdown.
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started Raise network interfaces.
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started Network Time Synchronization.
                        Nov 17 16:17:04 raspberrypi systemd[1]: Reached target System Time Synchronized.
                        Nov 17 16:17:04 raspberrypi systemd[1]: Reached target System Initialization.
                        Nov 17 16:17:04 raspberrypi systemd[1]: Listening on D-Bus System Message Bus Socket.
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started Daily rotation of log files.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.260678] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
                        Nov 17 16:17:04 raspberrypi systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.265990] vc-sm: Videocore shared memory driver
                        Nov 17 16:17:04 raspberrypi kernel: [    0.268752] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
                        Nov 17 16:17:04 raspberrypi kernel: [    0.284605] brd: module loaded
                        Nov 17 16:17:04 raspberrypi kernel: [    0.297246] loop: module loaded
                        Nov 17 16:17:04 raspberrypi systemd[1]: Listening on triggerhappy.socket.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.300300] Loading iSCSI transport class v2.0-870.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.303491] libphy: Fixed MDIO Bus: probed
                        Nov 17 16:17:04 raspberrypi systemd[1]: Reached target Sockets.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.306002] usbcore: registered new interface driver lan78xx
                        Nov 17 16:17:04 raspberrypi kernel: [    0.308460] usbcore: registered new interface driver smsc95xx
                        Nov 17 16:17:04 raspberrypi kernel: [    0.310816] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.341128] dwc_otg 3f980000.usb: base=(ptrval)
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started Daily man-db regeneration.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.543755] Core Release: 2.80a
                        Nov 17 16:17:04 raspberrypi kernel: [    0.546145] Setting default values for core params
                        Nov 17 16:17:04 raspberrypi kernel: [    0.548593] Finished setting default values for core params
                        Nov 17 16:17:04 raspberrypi systemd[1]: Reached target Basic System.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.751349] Using Buffer DMA mode
                        Nov 17 16:17:04 raspberrypi kernel: [    0.753759] Periodic Transfer Interrupt Enhancement - disabled
                        Nov 17 16:17:04 raspberrypi kernel: [    0.756184] Multiprocessor Interrupt Enhancement - disabled
                        Nov 17 16:17:04 raspberrypi systemd[1]: Starting dphys-swapfile - set up, mount/unmount, and delete a swap file...
                        Nov 17 16:17:04 raspberrypi kernel: [    0.758556] OTG VER PARAM: 0, OTG VER FLAG: 0
                        Nov 17 16:17:04 raspberrypi kernel: [    0.760894] Dedicated Tx FIFOs mode
                        Nov 17 16:17:04 raspberrypi kernel: [    0.763634] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = bad04000 dma = 0xfad04000 len=9024
                        Nov 17 16:17:04 raspberrypi kernel: [    0.768208] FIQ FSM acceleration enabled for :
                        Nov 17 16:17:04 raspberrypi systemd[1]: Starting Login Service...
                        Nov 17 16:17:04 raspberrypi kernel: [    0.768208] Non-periodic Split Transactions
                        Nov 17 16:17:04 raspberrypi kernel: [    0.768208] Periodic Split Transactions
                        Nov 17 16:17:04 raspberrypi kernel: [    0.768208] High-Speed Isochronous Endpoints
                        Nov 17 16:17:04 raspberrypi kernel: [    0.768208] Interrupt/Control Split Transaction hack enabled
                        Nov 17 16:17:04 raspberrypi systemd[1]: Condition check resulted in Turn on SSH if /boot/ssh is present being skipped.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.779106] dwc_otg: Microframe scheduler enabled
                        Nov 17 16:17:04 raspberrypi kernel: [    0.779159] WARN::hcd_init_fiq:457: FIQ on core 1
                        Nov 17 16:17:04 raspberrypi kernel: [    0.781378] WARN::hcd_init_fiq:458: FIQ ASM at 80654f4c length 36
                        Nov 17 16:17:04 raspberrypi kernel: [    0.783588] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
                        Nov 17 16:17:04 raspberrypi systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
                        Nov 17 16:17:04 raspberrypi kernel: [    0.785863] dwc_otg 3f980000.usb: DWC OTG Controller
                        Nov 17 16:17:04 raspberrypi kernel: [    0.788119] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
                        Nov 17 16:17:04 raspberrypi systemd[1]: Starting triggerhappy global hotkey daemon...
                        Nov 17 16:17:04 raspberrypi kernel: [    0.790435] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
                        Nov 17 16:17:04 raspberrypi kernel: [    0.792756] Init: Port Power? op_state=1
                        Nov 17 16:17:04 raspberrypi kernel: [    0.794995] Init: Power Port (0)
                        Nov 17 16:17:04 raspberrypi systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
                        Nov 17 16:17:04 raspberrypi systemd[1]: Starting Configure Bluetooth Modems connected by UART...
                        Nov 17 16:17:04 raspberrypi systemd[1]: Starting rng-tools.service...
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started Regular background program processing daemon.
                        Nov 17 16:17:04 raspberrypi systemd[1]: Condition check resulted in getty on tty2-tty6 if dbus and logind are not available being skipped.
                        Nov 17 16:17:04 raspberrypi systemd[1]: Starting System Logging Service...
                        Nov 17 16:17:04 raspberrypi kernel: [    0.797407] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
                        Nov 17 16:17:04 raspberrypi systemd[1]: Condition check resulted in Copy user wpa_supplicant.conf being skipped.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.801939] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                        Nov 17 16:17:04 raspberrypi kernel: [    0.804350] usb usb1: Product: DWC OTG Controller
                        Nov 17 16:17:04 raspberrypi kernel: [    0.806712] usb usb1: Manufacturer: Linux 4.19.66-v7+ dwc_otg_hcd
                        Nov 17 16:17:04 raspberrypi kernel: [    0.809128] usb usb1: SerialNumber: 3f980000.usb
                        Nov 17 16:17:04 raspberrypi systemd[1]: Starting dhcpcd on all interfaces...
                        Nov 17 16:17:04 raspberrypi kernel: [    0.812160] hub 1-0:1.0: USB hub found
                        Nov 17 16:17:04 raspberrypi kernel: [    0.814437] hub 1-0:1.0: 1 port detected
                        Nov 17 16:17:04 raspberrypi kernel: [    0.817192] dwc_otg: FIQ enabled
                        Nov 17 16:17:04 raspberrypi rng-tools[338]: Starting Hardware RNG entropy gatherer daemon: rngd.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.817198] dwc_otg: NAK holdoff enabled
                        Nov 17 16:17:04 raspberrypi kernel: [    0.817203] dwc_otg: FIQ split-transaction FSM enabled
                        Nov 17 16:17:04 raspberrypi cron[345]: (CRON) INFO (pidfile fd = 3)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.817214] Module dwc_common_port init
                        Nov 17 16:17:04 raspberrypi kernel: [    0.817478] usbcore: registered new interface driver usb-storage
                        Nov 17 16:17:04 raspberrypi kernel: [    0.819936] mousedev: PS/2 mouse device common for all mice
                        Nov 17 16:17:04 raspberrypi rngd[352]: rngd 2-unofficial-mt.14 starting up...
                        Nov 17 16:17:04 raspberrypi kernel: [    0.823138] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                        Nov 17 16:17:04 raspberrypi kernel: [    0.825764] bcm2835-cpufreq: min=600000 max=1200000
                        Nov 17 16:17:04 raspberrypi kernel: [    0.828584] sdhci: Secure Digital Host Controller Interface driver
                        Nov 17 16:17:04 raspberrypi kernel: [    0.830989] sdhci: Copyright(c) Pierre Ossman
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started D-Bus System Message Bus.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.833806] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
                        Nov 17 16:17:04 raspberrypi kernel: [    0.836717] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
                        Nov 17 16:17:04 raspberrypi kernel: [    0.839390] sdhci-pltfm: SDHCI platform and OF driver helper
                        Nov 17 16:17:04 raspberrypi thd[334]: Found socket passed from systemd
                        Nov 17 16:17:04 raspberrypi kernel: [    0.843507] ledtrig-cpu: registered to indicate activity on CPUs
                        Nov 17 16:17:04 raspberrypi kernel: [    0.846282] hidraw: raw HID events driver (C) Jiri Kosina
                        Nov 17 16:17:04 raspberrypi kernel: [    0.849048] usbcore: registered new interface driver usbhid
                        Nov 17 16:17:04 raspberrypi kernel: [    0.851675] usbhid: USB HID core driver
                        Nov 17 16:17:04 raspberrypi rngd[352]: entropy feed to the kernel ready
                        Nov 17 16:17:04 raspberrypi kernel: [    0.855054] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
                        Nov 17 16:17:04 raspberrypi kernel: [    0.859118] [vc_sm_connected_init]: start
                        Nov 17 16:17:04 raspberrypi kernel: [    0.867838] [vc_sm_connected_init]: end - returning 0
                        Nov 17 16:17:04 raspberrypi kernel: [    0.871380] Initializing XFRM netlink socket
                        Nov 17 16:17:04 raspberrypi kernel: [    0.873841] NET: Registered protocol family 17
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started Manage Sound Card State (restore and store).
                        Nov 17 16:17:04 raspberrypi kernel: [    0.876340] Key type dns_resolver registered
                        Nov 17 16:17:04 raspberrypi kernel: [    0.879181] Registering SWP/SWPB emulation handler
                        Nov 17 16:17:04 raspberrypi systemd[1]: Starting Save/Restore Sound Card State...
                        Nov 17 16:17:04 raspberrypi kernel: [    0.882321] registered taskstats version 1
                        Nov 17 16:17:04 raspberrypi kernel: [    0.884728] Loading compiled-in X.509 certificates
                        Nov 17 16:17:04 raspberrypi cron[345]: (CRON) INFO (Running @reboot jobs)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.894312] uart-pl011 3f201000.serial: cts_event_workaround enabled
                        Nov 17 16:17:04 raspberrypi kernel: [    0.896840] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started Daily Cleanup of Temporary Directories.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.903613] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
                        Nov 17 16:17:04 raspberrypi kernel: [    0.906150] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
                        Nov 17 16:17:04 raspberrypi kernel: [    0.934776] sdhost: log_buf @ (ptrval) (fad07000)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.972070] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.976042] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.979897] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                        Nov 17 16:17:04 raspberrypi alsactl[368]: alsactl 1.1.8 daemon started
                        Nov 17 16:17:04 raspberrypi kernel: [    0.984917] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.987041] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
                        Nov 17 16:17:04 raspberrypi kernel: [    0.990395] of_cfs_init
                        Nov 17 16:17:04 raspberrypi kernel: [    0.992558] of_cfs_init: OK
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started Daily apt download activities.
                        Nov 17 16:17:04 raspberrypi kernel: [    0.995015] Waiting for root device PARTUUID=9263b30d-02...
                        Nov 17 16:17:04 raspberrypi kernel: [    1.031894] Indeed it is in host mode hprt0 = 00021501
                        Nov 17 16:17:04 raspberrypi kernel: [    1.101794] mmc0: host does not support reading read-only switch, assuming write-enable
                        Nov 17 16:17:04 raspberrypi kernel: [    1.104437] random: fast init done
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
                        Nov 17 16:17:04 raspberrypi kernel: [    1.109073] mmc0: new high speed SDHC card at address 59b4
                        Nov 17 16:17:04 raspberrypi kernel: [    1.112480] mmcblk0: mmc0:59b4 SMI   29.3 GiB
                        Nov 17 16:17:04 raspberrypi kernel: [    1.116752]  mmcblk0: p1 p2
                        Nov 17 16:17:04 raspberrypi kernel: [    1.145228] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                        Nov 17 16:17:04 raspberrypi systemd[1]: Reached target Timers.
                        Nov 17 16:17:04 raspberrypi kernel: [    1.147461] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                        Nov 17 16:17:04 raspberrypi kernel: [    1.177006] mmc1: new high speed SDIO card at address 0001
                        Nov 17 16:17:04 raspberrypi avahi-daemon[333]: Found user 'avahi' (UID 108) and group 'avahi' (GID 113).
                        Nov 17 16:17:04 raspberrypi kernel: [    1.241830] usb 1-1: new high-speed USB device number 2 using dwc_otg
                        Nov 17 16:17:04 raspberrypi kernel: [    1.244173] Indeed it is in host mode hprt0 = 00001101
                        Nov 17 16:17:04 raspberrypi kernel: [    1.334298] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
                        Nov 17 16:17:04 raspberrypi kernel: [    1.367968] EXT4-fs (mmcblk0p2): 10 orphan inodes deleted
                        Nov 17 16:17:04 raspberrypi avahi-daemon[333]: Successfully dropped root privileges.
                        Nov 17 16:17:04 raspberrypi kernel: [    1.370243] EXT4-fs (mmcblk0p2): recovery complete
                        Nov 17 16:17:04 raspberrypi kernel: [    1.481450] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                        Nov 17 16:17:04 raspberrypi kernel: [    1.482070] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
                        Nov 17 16:17:04 raspberrypi avahi-daemon[333]: avahi-daemon 0.7 starting up.
                        Nov 17 16:17:04 raspberrypi kernel: [    1.486338] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                        Nov 17 16:17:04 raspberrypi kernel: [    1.491318] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
                        Nov 17 16:17:04 raspberrypi kernel: [    1.497466] hub 1-1:1.0: USB hub found
                        Nov 17 16:17:04 raspberrypi systemd[1]: Starting WPA supplicant...
                        Nov 17 16:17:04 raspberrypi kernel: [    1.500223] hub 1-1:1.0: 5 ports detected
                        Nov 17 16:17:04 raspberrypi kernel: [    1.504652] devtmpfs: mounted
                        Nov 17 16:17:04 raspberrypi kernel: [    1.512544] Freeing unused kernel memory: 1024K
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started triggerhappy global hotkey daemon.
                        Nov 17 16:17:04 raspberrypi kernel: [    1.515515] Run /sbin/init as init process
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started rng-tools.service.
                        Nov 17 16:17:04 raspberrypi kernel: [    1.821824] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
                        Nov 17 16:17:04 raspberrypi kernel: [    1.952144] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
                        Nov 17 16:17:04 raspberrypi kernel: [    1.957330] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
                        Nov 17 16:17:04 raspberrypi kernel: [    1.962746] smsc95xx v1.0.6
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started Save/Restore Sound Card State.
                        Nov 17 16:17:04 raspberrypi kernel: [    2.055358] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:51:8b:e9
                        Nov 17 16:17:04 raspberrypi kernel: [    2.257268] NET: Registered protocol family 10
                        Nov 17 16:17:04 raspberrypi kernel: [    2.261625] Segment Routing with IPv6
                        Nov 17 16:17:04 raspberrypi dhcpcd[351]: dev: loaded udev
                        Nov 17 16:17:04 raspberrypi kernel: [    3.160933] random: systemd: uninitialized urandom read (16 bytes read)
                        Nov 17 16:17:04 raspberrypi kernel: [    3.175021] random: systemd: uninitialized urandom read (16 bytes read)
                        Nov 17 16:17:04 raspberrypi systemd[1]: Reached target Sound Card.
                        Nov 17 16:17:04 raspberrypi rsyslogd: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd.  [v8.1901.0]
                        Nov 17 16:17:04 raspberrypi rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="350" x-info="https://www.rsyslog.com"] start
                        Nov 17 16:17:04 raspberrypi kernel: [    3.218236] random: systemd: uninitialized urandom read (16 bytes read)
                        Nov 17 16:17:04 raspberrypi kernel: [    4.038789] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                        Nov 17 16:17:04 raspberrypi kernel: [    4.760882] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
                        Nov 17 16:17:04 raspberrypi kernel: [    4.763542] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                        Nov 17 16:17:04 raspberrypi kernel: [    4.763558] [vc_sm_connected_init]: start
                        Nov 17 16:17:04 raspberrypi kernel: [    4.777575] media: Linux media interface: v0.10
                        Nov 17 16:17:04 raspberrypi kernel: [    4.780378] [vc_sm_connected_init]: installed successfully
                        Nov 17 16:17:04 raspberrypi kernel: [    4.822572] videodev: Linux video capture interface: v2.00
                        Nov 17 16:17:04 raspberrypi kernel: [    4.924063] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                        Nov 17 16:17:04 raspberrypi kernel: [    4.926990] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                        Nov 17 16:17:04 raspberrypi kernel: [    4.945095] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
                        Nov 17 16:17:04 raspberrypi kernel: [    4.962366] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
                        Nov 17 16:17:04 raspberrypi kernel: [    4.974292] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                        Nov 17 16:17:04 raspberrypi kernel: [    4.974306] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                        Nov 17 16:17:04 raspberrypi kernel: [    4.984139] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                        Nov 17 16:17:04 raspberrypi kernel: [    4.984153] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                        Nov 17 16:17:04 raspberrypi kernel: [    5.020637] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                        Nov 17 16:17:04 raspberrypi kernel: [    5.020652] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                        Nov 17 16:17:04 raspberrypi kernel: [    5.024930] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
                        Nov 17 16:17:04 raspberrypi kernel: [    5.049885] bcm2835_audio soc:audio: card created with 8 channels
                        Nov 17 16:17:04 raspberrypi kernel: [    5.096154] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                        Nov 17 16:17:04 raspberrypi kernel: [    5.214880] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                        Nov 17 16:17:04 raspberrypi kernel: [    5.308881] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
                        Nov 17 16:17:04 raspberrypi kernel: [    5.316711] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
                        Nov 17 16:17:04 raspberrypi kernel: [    5.316975] usbcore: registered new interface driver brcmfmac
                        Nov 17 16:17:04 raspberrypi kernel: [    5.533533] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
                        Nov 17 16:17:04 raspberrypi kernel: [    5.533656] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
                        Nov 17 16:17:04 raspberrypi kernel: [    5.534455] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
                        Nov 17 16:17:04 raspberrypi kernel: [    7.047087] random: crng init done
                        Nov 17 16:17:04 raspberrypi kernel: [    7.047122] random: 7 urandom warning(s) missed due to ratelimiting
                        Nov 17 16:17:04 raspberrypi kernel: [    7.180425] uart-pl011 3f201000.serial: no DMA platform data
                        Nov 17 16:17:04 raspberrypi dphys-swapfile[327]: want /var/swap=100MByte, checking existing: keeping it
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started System Logging Service.
                        Nov 17 16:17:04 raspberrypi kernel: [    7.279896] 8021q: 802.1Q VLAN Support v1.8
                        Nov 17 16:17:04 raspberrypi raspi-config[335]: Checking if shift key is held down:Error opening '/dev/input/event*': No such file or directory
                        Nov 17 16:17:04 raspberrypi raspi-config[335]:  No. Switching to ondemand scaling governor.
                        Nov 17 16:17:04 raspberrypi kernel: [    7.339170] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
                        Nov 17 16:17:04 raspberrypi dbus-daemon[353]: [system] Successfully activated service 'org.freedesktop.systemd1'
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started Login Service.
                        Nov 17 16:17:04 raspberrypi wpa_supplicant[384]: Successfully initialized wpa_supplicant
                        Nov 17 16:17:04 raspberrypi avahi-daemon[333]: Successfully called chroot().
                        Nov 17 16:17:04 raspberrypi avahi-daemon[333]: Successfully dropped remaining capabilities.
                        Nov 17 16:17:04 raspberrypi avahi-daemon[333]: No service file found in /etc/avahi/services.
                        Nov 17 16:17:04 raspberrypi avahi-daemon[333]: Network interface enumeration completed.
                        Nov 17 16:17:04 raspberrypi avahi-daemon[333]: Server startup complete. Host name is raspberrypi.local. Local service cookie is 3071460515.
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started dphys-swapfile - set up, mount/unmount, and delete a swap file.
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started Avahi mDNS/DNS-SD Stack.
                        Nov 17 16:17:04 raspberrypi systemd[1]: Started WPA supplicant.
                        Nov 17 16:17:05 raspberrypi dhcpcd[351]: wlan0: starting wpa_supplicant
                        Nov 17 16:17:05 raspberrypi dhcpcd-run-hooks[416]: wlan0: starting wpa_supplicant
                        Nov 17 16:17:05 raspberrypi kernel: [    7.534552] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
                        Nov 17 16:17:05 raspberrypi kernel: [    7.534563] brcmfmac: power management disabled
                        Nov 17 16:17:05 raspberrypi dhcpcd[351]: eth0: waiting for carrier
                        Nov 17 16:17:05 raspberrypi dhcpcd[351]: wlan0: waiting for carrier
                        Nov 17 16:17:05 raspberrypi dhcpcd[351]: wlan0: carrier acquired
                        Nov 17 16:17:05 raspberrypi kernel: [    7.882994] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
                        Nov 17 16:17:05 raspberrypi dhcpcd[351]: DUID 00:01:00:01:24:b7:ec:04:b8:27:eb:04:de:bc
                        Nov 17 16:17:05 raspberrypi dhcpcd[351]: wlan0: IAID eb:04:de:bc
                        Nov 17 16:17:05 raspberrypi dhcpcd[351]: wlan0: adding address fe80::9d5e:c4f3:4eb1:f245
                        Nov 17 16:17:05 raspberrypi avahi-daemon[333]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::9d5e:c4f3:4eb1:f245.
                        Nov 17 16:17:05 raspberrypi avahi-daemon[333]: New relevant interface wlan0.IPv6 for mDNS.
                        Nov 17 16:17:05 raspberrypi dhcpcd[351]: wlan0: carrier lost
                        Nov 17 16:17:05 raspberrypi avahi-daemon[333]: Registering new address record for fe80::9d5e:c4f3:4eb1:f245 on wlan0.*.
                        Nov 17 16:17:05 raspberrypi dhcpcd[351]: wlan0: deleting address fe80::9d5e:c4f3:4eb1:f245
                        Nov 17 16:17:05 raspberrypi avahi-daemon[333]: Withdrawing address record for fe80::9d5e:c4f3:4eb1:f245 on wlan0.
                        Nov 17 16:17:05 raspberrypi avahi-daemon[333]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::9d5e:c4f3:4eb1:f245.
                        Nov 17 16:17:05 raspberrypi avahi-daemon[333]: Interface wlan0.IPv6 no longer relevant for mDNS.
                        Nov 17 16:17:05 raspberrypi dhcpcd[351]: eth0: carrier acquired
                        Nov 17 16:17:05 raspberrypi dhcpcd[351]: eth0: IAID eb:51:8b:e9
                        Nov 17 16:17:05 raspberrypi dhcpcd[351]: eth0: adding address fe80::4fe3:6694:39c8:48c9
                        Nov 17 16:17:05 raspberrypi avahi-daemon[333]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::4fe3:6694:39c8:48c9.
                        Nov 17 16:17:05 raspberrypi avahi-daemon[333]: New relevant interface eth0.IPv6 for mDNS.
                        Nov 17 16:17:05 raspberrypi avahi-daemon[333]: Registering new address record for fe80::4fe3:6694:39c8:48c9 on eth0.*.
                        Nov 17 16:17:05 raspberrypi dhcpcd[351]: eth0: rebinding lease of 192.168.1.54
                        Nov 17 16:17:06 raspberrypi dhcpcd[351]: eth0: carrier lost
                        Nov 17 16:17:06 raspberrypi dhcpcd[351]: eth0: deleting address fe80::4fe3:6694:39c8:48c9
                        Nov 17 16:17:06 raspberrypi avahi-daemon[333]: Withdrawing address record for fe80::4fe3:6694:39c8:48c9 on eth0.
                        Nov 17 16:17:06 raspberrypi avahi-daemon[333]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::4fe3:6694:39c8:48c9.
                        Nov 17 16:17:06 raspberrypi avahi-daemon[333]: Interface eth0.IPv6 no longer relevant for mDNS.
                        Nov 17 16:17:07 raspberrypi dhcpcd[351]: eth0: carrier acquired
                        Nov 17 16:17:07 raspberrypi kernel: [   10.366091] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC1E1
                        Nov 17 16:17:07 raspberrypi dhcpcd[351]: eth0: IAID eb:51:8b:e9
                        Nov 17 16:17:07 raspberrypi dhcpcd[351]: eth0: adding address fe80::4fe3:6694:39c8:48c9
                        Nov 17 16:17:07 raspberrypi avahi-daemon[333]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::4fe3:6694:39c8:48c9.
                        Nov 17 16:17:07 raspberrypi avahi-daemon[333]: New relevant interface eth0.IPv6 for mDNS.
                        Nov 17 16:17:07 raspberrypi avahi-daemon[333]: Registering new address record for fe80::4fe3:6694:39c8:48c9 on eth0.*.
                        Nov 17 16:17:08 raspberrypi dhcpcd[351]: eth0: soliciting an IPv6 router
                        Nov 17 16:17:08 raspberrypi dhcpcd[351]: eth0: rebinding lease of 192.168.1.54
                        Nov 17 16:17:08 raspberrypi systemd[1]: systemd-rfkill.service: Succeeded.
                        Nov 17 16:17:09 raspberrypi kernel: [   11.937946] Bluetooth: Core ver 2.22
                        Nov 17 16:17:09 raspberrypi kernel: [   11.938044] NET: Registered protocol family 31
                        Nov 17 16:17:09 raspberrypi kernel: [   11.938051] Bluetooth: HCI device and connection manager initialized
                        Nov 17 16:17:09 raspberrypi kernel: [   11.938074] Bluetooth: HCI socket layer initialized
                        Nov 17 16:17:09 raspberrypi kernel: [   11.938088] Bluetooth: L2CAP socket layer initialized
                        Nov 17 16:17:09 raspberrypi kernel: [   11.938127] Bluetooth: SCO socket layer initialized
                        Nov 17 16:17:09 raspberrypi kernel: [   11.957466] Bluetooth: HCI UART driver ver 2.3
                        Nov 17 16:17:09 raspberrypi kernel: [   11.957480] Bluetooth: HCI UART protocol H4 registered
                        Nov 17 16:17:09 raspberrypi kernel: [   11.957605] Bluetooth: HCI UART protocol Three-wire (H5) registered
                        Nov 17 16:17:09 raspberrypi kernel: [   11.957837] Bluetooth: HCI UART protocol Broadcom registered
                        Nov 17 16:17:09 raspberrypi btuart[336]: bcm43xx_init
                        Nov 17 16:17:09 raspberrypi btuart[336]: Flash firmware /lib/firmware/brcm/BCM43430A1.hcd
                        Nov 17 16:17:09 raspberrypi btuart[336]: Set BDADDR UART: b8:27:eb:fb:21:43
                        Nov 17 16:17:09 raspberrypi btuart[336]: Set Controller UART speed to 921600 bit/s
                        Nov 17 16:17:09 raspberrypi btuart[336]: Device setup complete
                        Nov 17 16:17:09 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status...
                        Nov 17 16:17:09 raspberrypi systemd[1]: Started Configure Bluetooth Modems connected by UART.
                        Nov 17 16:17:09 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
                        Nov 17 16:17:09 raspberrypi systemd[1]: Created slice system-bthelper.slice.
                        Nov 17 16:17:09 raspberrypi systemd[1]: Starting Bluetooth service...
                        Nov 17 16:17:09 raspberrypi bluetoothd[463]: Bluetooth daemon 5.50
                        Nov 17 16:17:09 raspberrypi systemd[1]: Started Bluetooth service.
                        Nov 17 16:17:09 raspberrypi systemd[1]: Reached target Bluetooth.
                        Nov 17 16:17:09 raspberrypi systemd[1]: Started Raspberry Pi bluetooth helper.
                        Nov 17 16:17:09 raspberrypi bluetoothd[463]: Starting SDP server
                        Nov 17 16:17:09 raspberrypi kernel: [   12.204956] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                        Nov 17 16:17:09 raspberrypi kernel: [   12.204964] Bluetooth: BNEP filters: protocol multicast
                        Nov 17 16:17:09 raspberrypi kernel: [   12.204980] Bluetooth: BNEP socket layer initialized
                        Nov 17 16:17:09 raspberrypi bluetoothd[463]: Bluetooth management interface 1.14 initialized
                        Nov 17 16:17:09 raspberrypi dbus-daemon[353]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.5' (uid=0 pid=463 comm="/usr/lib/bluetooth/bluetoothd ")
                        Nov 17 16:17:09 raspberrypi bluetoothd[463]: Sap driver initialization failed.
                        Nov 17 16:17:09 raspberrypi bluetoothd[463]: sap-server: Operation not permitted (1)
                        Nov 17 16:17:09 raspberrypi systemd[1]: bthelper@hci0.service: Succeeded.
                        Nov 17 16:17:09 raspberrypi systemd[1]: Starting Hostname Service...
                        Nov 17 16:17:09 raspberrypi bluetoothd[463]: Failed to set privacy: Rejected (0x0b)
                        Nov 17 16:17:09 raspberrypi dhcpcd[351]: eth0: Router Advertisement from fe80::9a9b:cbff:fea9:c707
                        Nov 17 16:17:09 raspberrypi dhcpcd[351]: eth0: adding address 2003:ce:c71a:f100:67e5:fad9:8d9a:849/64
                        Nov 17 16:17:09 raspberrypi dhcpcd[351]: eth0: adding route to 2003:ce:c71a:f100::/64
                        Nov 17 16:17:09 raspberrypi avahi-daemon[333]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::4fe3:6694:39c8:48c9.
                        Nov 17 16:17:09 raspberrypi dhcpcd[351]: eth0: adding default route via fe80::9a9b:cbff:fea9:c707
                        Nov 17 16:17:09 raspberrypi avahi-daemon[333]: Joining mDNS multicast group on interface eth0.IPv6 with address 2003:ce:c71a:f100:67e5:fad9:8d9a:849.
                        Nov 17 16:17:09 raspberrypi avahi-daemon[333]: Registering new address record for 2003:ce:c71a:f100:67e5:fad9:8d9a:849 on eth0.*.
                        Nov 17 16:17:09 raspberrypi dhcpcd[351]: eth0: soliciting a DHCPv6 lease
                        Nov 17 16:17:09 raspberrypi avahi-daemon[333]: Withdrawing address record for fe80::4fe3:6694:39c8:48c9 on eth0.
                        Nov 17 16:17:09 raspberrypi dhcpcd[351]: eth0: Router Advertisement from fe80::3ece:73ff:fe8f:d03f
                        Nov 17 16:17:09 raspberrypi dhcpcd[351]: eth0: adding address fec0::8be3:3298:9264:245e/64
                        Nov 17 16:17:09 raspberrypi avahi-daemon[333]: Registering new address record for fec0::8be3:3298:9264:245e on eth0.*.
                        Nov 17 16:17:09 raspberrypi dhcpcd[351]: eth0: adding route to fec0::/64
                        Nov 17 16:17:10 raspberrypi dbus-daemon[353]: [system] Successfully activated service 'org.freedesktop.hostname1'
                        Nov 17 16:17:10 raspberrypi systemd[1]: Started Hostname Service.
                        Nov 17 16:17:10 raspberrypi dhcpcd[351]: eth0: DHCPv6 REPLY: in stateless mode
                        Nov 17 16:17:11 raspberrypi dhcpcd[351]: Too few arguments.
                        Nov 17 16:17:11 raspberrypi dhcpcd[351]: forked to background, child pid 531
                        Nov 17 16:17:11 raspberrypi dhcpcd[531]: eth0: DHCPv6 REPLY: in stateless mode
                        Nov 17 16:17:11 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
                        Nov 17 16:17:11 raspberrypi systemd[1]: Reached target Network.
                        Nov 17 16:17:11 raspberrypi systemd[1]: Starting Permit User Sessions...
                        Nov 17 16:17:11 raspberrypi systemd[1]: Started ioBroker Server.
                        Nov 17 16:17:11 raspberrypi systemd[1]: Starting OpenBSD Secure Shell server...
                        Nov 17 16:17:11 raspberrypi systemd[1]: Starting /etc/rc.local Compatibility...
                        Nov 17 16:17:11 raspberrypi systemd[1]: Condition check resulted in fast remote file copy program daemon being skipped.
                        Nov 17 16:17:11 raspberrypi systemd[1]: Started Permit User Sessions.
                        Nov 17 16:17:11 raspberrypi systemd[1]: Started /etc/rc.local Compatibility.
                        Nov 17 16:17:11 raspberrypi systemd[1]: Started Getty on tty1.
                        Nov 17 16:17:11 raspberrypi systemd[1]: Reached target Login Prompts.
                        Nov 17 16:17:11 raspberrypi systemd[1]: Started OpenBSD Secure Shell server.
                        Nov 17 16:17:11 raspberrypi systemd[1]: Reached target Multi-User System.
                        Nov 17 16:17:11 raspberrypi systemd[1]: Reached target Graphical Interface.
                        Nov 17 16:17:11 raspberrypi systemd[1]: Starting Update UTMP about System Runlevel Changes...
                        Nov 17 16:17:12 raspberrypi systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
                        Nov 17 16:17:12 raspberrypi systemd[1]: Started Update UTMP about System Runlevel Changes.
                        Nov 17 16:17:12 raspberrypi systemd[1]: Startup finished in 2.064s (kernel) + 12.414s (userspace) = 14.479s.
                        Nov 17 16:17:12 raspberrypi dhcpcd[531]: eth0: probing address 192.168.1.54/24
                        Nov 17 16:17:13 raspberrypi dhcpcd[531]: eth0: DHCPv6 REPLY: in stateless mode
                        Nov 17 16:17:14 raspberrypi systemd[1]: systemd-rfkill.service: Succeeded.
                        Nov 17 16:17:16 raspberrypi dhcpcd[531]: eth0: DHCPv6 REPLY: in stateless mode
                        Nov 17 16:17:17 raspberrypi dhcpcd[531]: eth0: leased 192.168.1.54 for 864000 seconds
                        Nov 17 16:17:17 raspberrypi dhcpcd[531]: eth0: adding route to 192.168.1.0/24
                        Nov 17 16:17:17 raspberrypi dhcpcd[531]: eth0: adding default route via 192.168.1.1
                        Nov 17 16:17:17 raspberrypi avahi-daemon[333]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.1.54.
                        Nov 17 16:17:17 raspberrypi avahi-daemon[333]: New relevant interface eth0.IPv4 for mDNS.
                        Nov 17 16:17:17 raspberrypi avahi-daemon[333]: Registering new address record for 192.168.1.54 on eth0.IPv4.
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.admin.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.discovery.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.info.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.mqtt.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.web.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.vis.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.backitup.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.fritzbox.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.fritzdect.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.history.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.shelly.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.sonoff.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.javascript.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.onvif.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.sql.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.parser.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.vis-weather.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.dwd.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.vis-bars.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.vis-history.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.vis-keyboard.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.proxy.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.openweathermap.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.vis-timeandweather.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.scenes.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.daswetter.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.weatherunderground.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.pollenflug.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.mobile.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.vis-jqui-mfd.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.simple-api.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.worx.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.yahka.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.ical.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.vis-hqwidgets.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.vis-plumb.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.vis-materialdesign.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.landroid.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.telegram.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.text2command.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.hmip.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.hm-rpc.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.hm-rega.0" for host "raspberrypi"
                        Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.hm-rpc.1" for host "raspberrypi"
                        Nov 17 16:17:24 raspberrypi dhcpcd[531]: eth0: DHCPv6 REPLY: in stateless mode
                        Nov 17 16:17:33 raspberrypi systemd[1]: systemd-fsckd.service: Succeeded.
                        Nov 17 16:46:08 raspberrypi systemd-timesyncd[288]: Synchronized to time server for the first time [2a01:4f8:211:2093::1]:123 (2.debian.pool.ntp.org).
                        Nov 17 16:46:13 raspberrypi dhcpcd[531]: eth0: DHCPv6 REPLY: in stateless mode
                        Nov 17 16:46:13 raspberrypi systemd[1]: systemd-hostnamed.service: Succeeded.
                        Nov 17 16:46:25 raspberrypi bash[533]: Send diag info: {"uuid":"856a113a-5105-9c48-b6cb-de7489b7d58a","language":"de","country":"Germany","hosts":[{"version":"2.1.0","platform":"Javascript/Node.js","type":"linux"}],"node":"v10.17.0","arch":"arm","adapters":{"admin":{"version":"3.6.12","platform":"Javascript/Node.js"},"discovery":{"version":"2.0.0","platform":"Javascript/Node.js"},"info":{"version":"1.5.7","platform":"Javascript/Node.js"},"mqtt":{"version":"2.1.1","platform":"Javascript/Node.js"},"web":{"version":"2.4.10","platform":"Javascript/Node.js"},"vis":{"version":"1.2.2","platform":"Javascript/Node.js"},"cloud":{"version":"2.8.0","platform":"Javascript/Node.js"},"backitup":{"version":"1.2.2","platform":"Javascript/Node.js"},"alexa2":{"version":"2.6.4","platform":"Javascript/Node.js"},"fritzbox":{"version":"0.2.1","platform":"Javascript/Node.js"},"fritzdect":{"version":"0.2.4","platform":"Javascript/Node.js"},"history":{"version":"1.8.7","platform":"Javascript/Node.js"},"js2fs":{"version":"0.1.5","platform":"Javascript/Node.js"},"shelly":{"version":"3.1.1","platform":"Javascript/Node.js"},"sonoff":{"version":"2.3.2","platform":"Javascript/Node.js"},"javascript":{"version":"4.3.3","platform":"Javascript/Node.js"},"onvif":{"version":"0.0.2","platform":"Javascript/Node.js"},"sql":{"version":"1.9.5","platform":"Javascript/Node.js"},"parser":{"version":"1.0.7","platform":"Javascript/Node.js"},"vis-weather":{"version":"2.4.0","platform":"Javascript/Node.js"},"yr":{"version":"2.0.3","platform":"Javascript/Node.js"},"dwd":{"version":"2.4.3","platform":"javascript/Node.js"},"daswetter":{"version":"2.8.1","platform":"Javascript/Node.js"},"iqontrol":{"version":"0.2.14","platform":"Javascript/Node.js"},"vis-bars":{"version":"0.1.4","platform":"Javascript/Node.js"},"vis-history":{"version":"1.0.0","platform":"Javascript/Node.js"},"vis-keyboard":{"version":"0.0.2","platform":"Javascript/Node.js"},"proxy":{"version":"1.1.1","platform":"Javascript/Node.js"},"openweathermap":{"version":"0.1.0","platform":"Javascript/Node.js"},"vis-timeandweather":{"version":"1.1.7","platform":"Javascript/Node.js"},"scenes":{"version":"1.1.0","platform":"Javascript/Node.js"},"weatherunderground":{"version":"3.1.6","platform":"Javascript/Node.js"},"pollenflug":{"version":"1.0.4","platform":"Javascript/Node.js"},"mobile":{"version":"0.5.0","platform":"javascript/Node.js"},"vis-jqui-mfd":{"version":"1.0.12","platform":"Javascript/Node.js"},"simple-api":{"version":"2.3.2","platform":"Javascript/Node.js"},"worx":{"version":"0.4.0","platform":"Javascript/Node.js"},"yahka":{"version":"0.9.2","pla:
                        Nov 17 16:46:25 raspberrypi bash[533]: Send diag info: {"uuid":"856a113a-5105-9c48-b6cb-de7489b7d58a","language":"de","country":"Germany","hosts":[{"version":"2.1.0","platform":"Javascript/Node.js","type":"linux"}],"node":"v10.17.0","arch":"arm","adapters":{"admin":{"version":"3.6.12","platform":"Javascript/Node.js"},"discovery":{"version":"2.0.0","platform":"Javascript/Node.js"},"info":{"version":"1.5.7","platform":"Javascript/Node.js"},"mqtt":{"version":"2.1.1","platform":"Javascript/Node.js"},"web":{"version":"2.4.10","platform":"Javascript/Node.js"},"vis":{"version":"1.2.2","platform":"Javascript/Node.js"},"cloud":{"version":"2.8.0","platform":"Javascript/Node.js"},"backitup":{"version":"1.2.2","platform":"Javascript/Node.js"},"alexa2":{"version":"2.6.4","platform":"Javascript/Node.js"},"fritzbox":{"version":"0.2.1","platform":"Javascript/Node.js"},"fritzdect":{"version":"0.2.4","platform":"Javascript/Node.js"},"history":{"version":"1.8.7","platform":"Javascript/Node.js"},"js2fs":{"version":"0.1.5","platform":"Javascript/Node.js"},"shelly":{"version":"3.1.1","platform":"Javascript/Node.js"},"sonoff":{"version":"2.3.2","platform":"Javascript/Node.js"},"javascript":{"version":"4.3.3","platform":"Javascript/Node.js"},"onvif":{"version":"0.0.2","platform":"Javascript/Node.js"},"sql":{"version":"1.9.5","platform":"Javascript/Node.js"},"parser":{"version":"1.0.7","platform":"Javascript/Node.js"},"vis-weather":{"version":"2.4.0","platform":"Javascript/Node.js"},"yr":{"version":"2.0.3","platform":"Javascript/Node.js"},"dwd":{"version":"2.4.3","platform":"javascript/Node.js"},"daswetter":{"version":"2.8.1","platform":"Javascript/Node.js"},"iqontrol":{"version":"0.2.14","platform":"Javascript/Node.js"},"vis-bars":{"version":"0.1.4","platform":"Javascript/Node.js"},"vis-history":{"version":"1.0.0","platform":"Javascript/Node.js"},"vis-keyboard":{"version":"0.0.2","platform":"Javascript/Node.js"},"proxy":{"version":"1.1.1","platform":"Javascript/Node.js"},"openweathermap":{"version":"0.1.0","platform":"Javascript/Node.js"},"vis-timeandweather":{"version":"1.1.7","platform":"Javascript/Node.js"},"scenes":{"version":"1.1.0","platform":"Javascript/Node.js"},"weatherunderground":{"version":"3.1.6","platform":"Javascript/Node.js"},"pollenflug":{"version":"1.0.4","platform":"Javascript/Node.js"},"mobile":{"version":"0.5.0","platform":"javascript/Node.js"},"vis-jqui-mfd":{"version":"1.0.12","platform":"Javascript/Node.js"},"simple-api":{"version":"2.3.2","platform":"Javascript/Node.js"},"worx":{"version":"0.4.0","platform":"Javascript/Node.js"},"yahka":{"version":"0.9.2","platform":"Javascript/Node.js"},"ical":{"version":"1.7.0","platform":"Javascript/Node.js"},"icons-icons8":{"version":"0.0.1","platform":"javascript/Node.js"},"vis-hqwidgets":{"version":"1.1.3","platform":"Javascript/Node.js"},"vis-plumb":{"version":"1.0.2","platform":"Javascript/Node.js"},"vis-materialdesign":{"version":"0.1.5","platform":"Javascript/Node.js"},"landroid":{"version":"1.0.3","platform":"Javascript/Node.js"},"telegram":{"version":"1.4.3","platform":"Javascript/Node.js"},"text2command":{"version":"1.3.1","platform":"Javascript/Node.js"},"hmip":{"version":"0.0.11","platform":"Javascript/Node.js"},"hm-rpc":{"version":"1.11.0","platform":"Javascript/Node.js"},"hm-rega":{"version":"2.4.12","platform":"Javascript/Node.js"},"flot":{"version":"1.9.2","platform":"javascript/Node.js"}},"statesType":"file","objectsType":"file","model":"ARMv7 Processor rev 4 (v7l)","cpus":4,"mem":971063296,"ostype":"Linux","city":"Windeck","vis":742}
                        Nov 17 16:46:42 raspberrypi dhcpcd[531]: eth0: DHCPv6 REPLY: in stateless mode
                        Nov 17 16:47:01 raspberrypi bash[533]: Sun, 17 Nov 2019 15:47:01 GMT EventedHTTPServer Server listening on port 33513
                        Nov 17 16:47:01 raspberrypi bash[533]: Sun, 17 Nov 2019 15:47:01 GMT EventedHTTPServer Server listening on port 37451
                        Nov 17 16:47:05 raspberrypi bash[533]: Sun, 17 Nov 2019 15:47:05 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
                        Nov 17 16:47:05 raspberrypi bash[533]: In the future, you will have to enable it yourself.
                        Nov 17 16:47:05 raspberrypi bash[533]: See https://github.com/yagop/node-telegram-bot-api/issues/319. at internal/modules/cjs/loader.js:778:30
                        Nov 17 16:47:27 raspberrypi bash[533]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
                        Nov 17 16:47:43 raspberrypi dhcpcd[531]: eth0: DHCPv6 REPLY: in stateless mode
                        Nov 17 16:49:49 raspberrypi dhcpcd[531]: eth0: DHCPv6 REPLY: in stateless mode
                        Nov 17 16:54:11 raspberrypi dhcpcd[531]: eth0: DHCPv6 REPLY: in stateless mode
                        Nov 17 17:00:53 raspberrypi systemd[1]: Starting Cleanup of Temporary Directories...
                        Nov 17 17:00:54 raspberrypi systemd[1]: systemd-tmpfiles-clean.service: Succeeded.
                        Nov 17 17:00:54 raspberrypi systemd[1]: Started Cleanup of Temporary Directories.
                        Nov 17 17:02:22 raspberrypi systemd[1]: Created slice User Slice of UID 1000.
                        Nov 17 17:02:22 raspberrypi systemd[1]: Starting User Runtime Directory /run/user/1000...
                        Nov 17 17:02:22 raspberrypi systemd[1]: Started User Runtime Directory /run/user/1000.
                        Nov 17 17:02:22 raspberrypi systemd[1]: Starting User Manager for UID 1000...
                        Nov 17 17:02:23 raspberrypi systemd[20168]: Listening on GnuPG network certificate management daemon.
                        Nov 17 17:02:23 raspberrypi systemd[20168]: Reached target Timers.
                        Nov 17 17:02:23 raspberrypi systemd[20168]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
                        Nov 17 17:02:23 raspberrypi systemd[20168]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
                        Nov 17 17:02:23 raspberrypi systemd[20168]: Listening on GnuPG cryptographic agent and passphrase cache.
                        Nov 17 17:02:23 raspberrypi systemd[20168]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
                        Nov 17 17:02:23 raspberrypi systemd[20168]: Reached target Sockets.
                        Nov 17 17:02:23 raspberrypi systemd[20168]: Reached target Paths.
                        Nov 17 17:02:23 raspberrypi systemd[20168]: Reached target Basic System.
                        Nov 17 17:02:23 raspberrypi systemd[1]: Started User Manager for UID 1000.
                        Nov 17 17:02:23 raspberrypi systemd[1]: Started Session c1 of user pi.
                        Nov 17 17:02:23 raspberrypi systemd[20168]: Reached target Default.
                        Nov 17 17:02:23 raspberrypi systemd[20168]: Startup finished in 267ms.
                        Nov 17 17:02:44 raspberrypi dhcpcd[531]: eth0: DHCPv6 REPLY: in stateless mode
                        Nov 17 17:03:05 raspberrypi bash[533]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
                        • J Offline
                          JoergK
                          Hi zusammen,
                          das Problem mit dem abgestürztem Pi hatte ich in letzter Zeit auch ab und zu.
                          Aufgetreten ist dies immer bei einem Update eines Adapters.
                          So wahnsinnig viele Adapter habe ich nicht installiert aber die Auslagerungsdatei war immer recht voll.
                          Standardmäßig ist die Auslagerungsdatei bei 100MB. Diesen Wert habe ich auf 500MB erhöht. Seit dem läuft das System stabil und ohne Abstütze. Auch einige Updates hatte ich schon wieder durchgeführt.
                          Jetzt ist die Auslagerungsdatei bei mir im Normalbetrieb mit 140MB gefüllt.
                          Wie es geht, habe ich hier gelesen.
                          Vielleicht hilft es euch auch weiter?
                          Jörg
                          • R RalfEngelberth
                            @apollon77
                            Hatte gerade nochmal einen Absturz mit IoBroker
                            Hier der Log und der syslog
                            16:17 war der Absturz und 16:46 wurde mit Netzstecker ziehen neu gestartet von mir.
                            Mir fällt nichts ungewöhnliches auf.
                            Außer, dass die Zeiten so durcheinander sind.
                            Ich hatte auch nun schon 2 Tage keinen Absturz mehr
                            LOG
                            2019-11-17 16:12:00.011 - info: javascript.0 (4408) script.js.common.Kostal_Umrichter_Abfrage_mehrmals: Auslöser: Schedule
                            2019-11-17 16:12:00.012 - info: javascript.0 (4408) script.js.common.Kostal_Umrichter_Abfrage_mehrmals: Piko 5.5 auslesen
                            2019-11-17 16:12:00.039 - info: host.raspberrypi instance system.adapter.weatherunderground.0 started with pid 27153
                            2019-11-17 16:12:03.444 - info: weatherunderground.0 (27153) starting. Version 3.1.6 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v10.17.0
                            2019-11-17 16:12:08.252 - info: weatherunderground.0 (27153) Terminated (NO_ERROR): Without reason
                            2019-11-17 16:12:09.918 - info: host.raspberrypi instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
                            2019-11-17 16:15:00.031 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 30943
                            2019-11-17 16:15:04.868 - info: dwd.0 (30943) starting. Version 2.4.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.17.0
                            2019-11-17 16:15:06.176 - info: dwd.0 (30943) Terminated (NO_ERROR): Without reason
                            2019-11-17 16:15:06.718 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
                            2019-11-17 16:17:00.008 - info: javascript.0 (4408) script.js.common.Kostal_Umrichter_Abfrage_mehrmals: Auslöser: Schedule
                            2019-11-17 16:17:00.008 - info: javascript.0 (4408) script.js.common.Kostal_Umrichter_Abfrage_mehrmals: Piko 5.5 auslesen
                            2019-11-17 16:20:00.027 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 4696
                            2019-11-17 16:20:03.367 - info: dwd.0 (4696) starting. Version 2.4.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.17.0
                            2019-11-17 16:20:04.997 - info: dwd.0 (4696) Terminated (NO_ERROR): Without reason
                            2019-11-17 16:20:05.536 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
                            2019-11-17 16:22:00.009 - info: javascript.0 (4408) script.js.common.Kostal_Umrichter_Abfrage_mehrmals: Auslöser: Schedule
                            2019-11-17 16:22:00.010 - info: javascript.0 (4408) script.js.common.Kostal_Umrichter_Abfrage_mehrmals: Piko 5.5 auslesen
                            2019-11-17 16:22:51.575 - info: info.0 (18118) Popup news was read...
                            2019-11-17 16:23:00.038 - info: host.raspberrypi instance system.adapter.openweathermap.0 started with pid 8457
                            2019-11-17 16:23:05.014 - info: openweathermap.0 (8457) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v10.17.0
                            2019-11-17 16:23:08.624 - info: openweathermap.0 (8457) Terminated (NO_ERROR): Without reason
                            2019-11-17 16:23:09.161 - info: host.raspberrypi instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
                            2019-11-17 16:25:00.028 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 10939
                            2019-11-17 16:25:03.882 - info: dwd.0 (10939) starting. Version 2.4.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.17.0
                            2019-11-17 16:25:05.105 - info: dwd.0 (10939) Terminated (NO_ERROR): Without reason
                            2019-11-17 16:25:05.640 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
                            2019-11-17 16:27:00.011 - info: javascript.0 (4408) script.js.common.Kostal_Umrichter_Abfrage_mehrmals: Auslöser: Schedule
                            2019-11-17 16:27:00.013 - info: javascript.0 (4408) script.js.common.Kostal_Umrichter_Abfrage_mehrmals: Piko 5.5 auslesen
                            2019-11-17 16:30:00.028 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 17054
                            2019-11-17 16:30:03.601 - info: dwd.0 (17054) starting. Version 2.4.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.17.0
                            2019-11-17 16:30:04.047 - info: host.raspberrypi instance system.adapter.ical.0 started with pid 17211
                            2019-11-17 16:30:05.628 - info: dwd.0 (17054) Terminated (NO_ERROR): Without reason
                            2019-11-17 16:30:06.152 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
                            2019-11-17 16:30:08.267 - info: ical.0 (17211) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.ical, node: v10.17.0
                            2019-11-17 16:30:10.304 - info: ical.0 (17211) processing URL: KalenderMüll https://calendar.google.com/calendar/ical/q5m7u32s8bqm35sl4fcrplrnoc%40group.calendar.google.com/public/basic.ics
                            2019-11-17 16:30:10.534 - info: javascript.0 (4408) script.js.common.Müllkalender: Start update
                            2019-11-17 16:30:10.536 - info: javascript.0 (4408) script.js.common.Müllkalender: ###
                            2019-11-17 16:30:10.537 - info: javascript.0 (4408) script.js.common.Müllkalender: Rest: 2019-11-18
                            2019-11-17 16:30:10.538 - info: javascript.0 (4408) script.js.common.Müllkalender: ###
                            2019-11-17 16:30:10.539 - info: javascript.0 (4408) script.js.common.Müllkalender: ###
                            2019-11-17 16:30:10.540 - info: javascript.0 (4408) script.js.common.Müllkalender: 18.11.2019
                            2019-11-17 16:30:10.541 - info: javascript.0 (4408) script.js.common.Müllkalender: Bio: 2019-11-18
                            2019-11-17 16:30:10.542 - info: javascript.0 (4408) script.js.common.Müllkalender: ###
                            2019-11-17 16:30:10.543 - info: javascript.0 (4408) script.js.common.Müllkalender: ###
                            2019-11-17 16:30:10.545 - info: javascript.0 (4408) script.js.common.Müllkalender: ###
                            2019-11-17 16:30:10.546 - info: javascript.0 (4408) script.js.common.Müllkalender: Gelb: 2019-12-09
                            2019-11-17 16:30:10.547 - info: javascript.0 (4408) script.js.common.Müllkalender: ###
                            2019-11-17 16:30:10.547 - info: javascript.0 (4408) script.js.common.Müllkalender: Papier: 2019-12-09
                            2019-11-17 16:30:10.548 - info: javascript.0 (4408) script.js.common.Müllkalender: ###
                            2019-11-17 16:30:10.549 - info: javascript.0 (4408) script.js.common.Müllkalender: ###
                            2019-11-17 16:30:10.550 - info: javascript.0 (4408) script.js.common.Müllkalender: ###
                            2019-11-17 16:30:16.062 - info: ical.0 (17211) Terminated (NO_ERROR): Without reason
                            2019-11-17 16:30:16.587 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                            2019-11-17 16:17:15.109 - info: host.raspberrypi iobroker.js-controller version 2.1.0 js-controller starting
                            2019-11-17 16:17:15.122 - info: host.raspberrypi Copyright (c) 2014-2019 bluefox, 2014 hobbyquaker
                            2019-11-17 16:17:15.123 - info: host.raspberrypi hostname: raspberrypi, node: v10.17.0
                            2019-11-17 16:17:15.127 - info: host.raspberrypi ip addresses: 2003:ce:c71a:f100:67e5:fad9:8d9a:849 fec0::8be3:3298:9264:245e fe80::4fe3:6694:39c8:48c9
                            2019-11-17 16:17:17.300 - info: host.raspberrypi connected to Objects and States
                            2019-11-17 16:17:17.769 - info: host.raspberrypi 46 instances found
                            2019-11-17 16:17:17.959 - info: host.raspberrypi starting 34 instances
                            2019-11-17 16:17:18.108 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 608
                            2019-11-17 16:17:21.984 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 619
                            2019-11-17 16:17:22.660 - info: admin.0 (608) starting. Version 3.6.12 in /opt/iobroker/node_modules/iobroker.admin, node: v10.17.0
                            2019-11-17 16:17:22.768 - info: admin.0 (608) requesting all states
                            2019-11-17 16:17:22.770 - info: admin.0 (608) requesting all objects
                            2019-11-17 16:17:26.547 - info: host.raspberrypi instance system.adapter.info.0 started with pid 634
                            2019-11-17 16:17:27.361 - info: discovery.0 (619) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v10.17.0
                            2019-11-17 16:17:27.764 - info: admin.0 (608) received all objects
                            2019-11-17 16:17:28.339 - info: admin.0 (608) http server listening on port 8081
                            2019-11-17 16:17:28.340 - info: admin.0 (608) Use link "http://localhost:8081" to configure.
                            2019-11-17 16:17:30.437 - info: host.raspberrypi instance system.adapter.web.0 started with pid 657
                            2019-11-17 16:17:34.405 - info: web.0 (657) starting. Version 2.4.10 in /opt/iobroker/node_modules/iobroker.web, node: v10.17.0
                            2019-11-17 16:46:08.563 - info: web.0 (657) socket.io server listening on port 8082
                            2019-11-17 16:46:08.844 - info: info.0 (634) starting. Version 1.5.7 in /opt/iobroker/node_modules/iobroker.info, node: v10.17.0
                            2019-11-17 16:46:11.079 - info: info.0 (634) Reading CPU current speed every 3 seconds.
                            2019-11-17 16:46:11.139 - info: info.0 (634) Reading CPU data every 3 seconds.
                            2019-11-17 16:46:11.400 - info: host.raspberrypi instance system.adapter.history.0 started with pid 859
                            2019-11-17 16:46:11.719 - info: vis.0 (668) starting. Version 1.2.2 in /opt/iobroker/node_modules/iobroker.vis, node: v10.17.0
                            2019-11-17 16:46:11.368 - info: info.0 (634) Reading disk data every 8 seconds.
                            2019-11-17 16:46:11.607 - info: info.0 (634) Reading memory data every 3 seconds.
                            2019-11-17 16:46:11.970 - info: info.0 (634) Reading user data every 8 seconds.
                            2019-11-17 16:46:12.160 - info: vis.0 (668) vis license is OK.
                            2019-11-17 16:46:08.609 - info: web.0 (657) Install extension on /proxy.0/sonos/
                            2019-11-17 16:46:12.078 - info: web.0 (657) {"target":"http://localhost:8083","ws":true,"secure":false,"changeOrigin":false,"proxyTimeout":10000,"xfwd":true,"pathRewrite":{"^/proxy.0/sonos/":"/"}}
                            2019-11-17 16:46:12.124 - info: web.0 (657) Install extension on /proxy.0/api/
                            2019-11-17 16:46:12.126 - info: web.0 (657) {"target":"http://localhost:8084","ws":true,"secure":false,"changeOrigin":false,"proxyTimeout":10000,"xfwd":true,"pathRewrite":{"^/proxy.0/api/":"/"}}
                            2019-11-17 16:46:12.131 - info: web.0 (657) Install extension on /proxy.0/node-red/
                            2019-11-17 16:46:12.132 - info: web.0 (657) {"target":"http://localhost:1880","ws":true,"secure":false,"changeOrigin":false,"proxyTimeout":10000,"xfwd":true,"pathRewrite":{"^/proxy.0/node-red/":"/"}}
                            2019-11-17 16:46:12.136 - info: web.0 (657) Connect extension "proxy/lib/proxy.js"
                            2019-11-17 16:46:12.148 - info: web.0 (657) http server listening on port 8082
                            2019-11-17 16:46:12.154 - info: info.0 (634) Reading battery data every 8 seconds.
                            2019-11-17 16:46:12.161 - info: info.0 (634) Reading CPU temp data every 3 seconds.
                            Syslog
                            Nov 17 15:51:14 raspberrypi rngd[350]: stats: FIPS 140-2(2001-10-10) Runs: 0
                            Nov 17 15:51:14 raspberrypi rngd[350]: stats: FIPS 140-2(2001-10-10) Long run: 0
                            Nov 17 15:51:14 raspberrypi rngd[350]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
                            Nov 17 15:51:14 raspberrypi rngd[350]: stats: HRNG source speed: (min=628.297; avg=937.073; max=1004.901)Kibits/s
                            Nov 17 15:51:14 raspberrypi rngd[350]: stats: FIPS tests speed: (min=2.158; avg=8.209; max=14.160)Mibits/s
                            Nov 17 15:51:14 raspberrypi rngd[350]: stats: Lowest ready-buffers level: 2
                            Nov 17 15:51:14 raspberrypi rngd[350]: stats: Entropy starvations: 0
                            Nov 17 15:51:14 raspberrypi rngd[350]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
                            Nov 17 16:07:54 raspberrypi dhcpcd[532]: eth0: DHCPv6 REPLY: in stateless mode
                            Nov 17 16:17:01 raspberrypi CRON[1034]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
                            Nov 17 16:31:16 raspberrypi bash[18057]: Send diag info: {"uuid":"856a113a-5105-9c48-b6cb-de7489b7d58a","language":"de","country":"Germany","hosts":[{"version":"2.1.0","platform":"Javascript/Node.js","type":"linux"}],"node":"v10.17.0","a
                            Nov 17 14:51:14 raspberrypi rngd[350]: stats: entropy added to kernel pool: 874336
                            Nov 17 14:51:14 raspberrypi rngd[350]: stats: FIPS 140-2 successes: 46
                            Nov 17 14:51:14 raspberrypi rngd[350]: stats: FIPS 140-2 failures: 0
                            Nov 17 14:51:14 raspberrypi rngd[350]: stats: FIPS 140-2(2001-10-10) Monobit: 0
                            Nov 17 14:51:14 raspberrypi rngd[350]: stats: FIPS 140-2(2001-10-10) Poker: 0
                            Nov 17 14:51:14 raspberrypi rngd[350]: stats: FIPS 140-2(2001-10-10) Runs: 0
                            Nov 17 14:51:14 raspberrypi rngd[350]: stats: FIPS 140-2(2001-10-10) Long run: 0
                            Nov 17 14:51:14 raspberrypi rngd[350]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
                            Nov 17 14:51:14 raspberrypi rngd[350]: stats: HRNG source speed: (min=628.297; avg=937.114; max=1004.901)Kibits/s
                            Nov 17 14:51:14 raspberrypi rngd[350]: stats: FIPS tests speed: (min=2.158; avg=8.270; max=14.160)Mibits/s
                            Nov 17 14:51:14 raspberrypi rngd[350]: stats: Lowest ready-buffers level: 2
                            Nov 17 14:51:14 raspberrypi rngd[350]: stats: Entropy starvations: 0
                            Nov 17 14:51:14 raspberrypi rngd[350]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
                            Nov 17 15:05:23 raspberrypi dhcpcd[532]: eth0: DHCPv6 REPLY: in stateless mode
                            Nov 17 15:17:01 raspberrypi CRON[19773]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
                            Nov 17 15:51:14 raspberrypi rngd[350]: stats: bits received from HRNG source: 960064
                            Nov 17 15:51:14 raspberrypi rngd[350]: stats: bits sent to kernel pool: 904096
                            Nov 17 15:51:14 raspberrypi rngd[350]: stats: entropy added to kernel pool: 904096
                            Nov 17 15:51:14 raspberrypi rngd[350]: stats: FIPS 140-2 successes: 48
                            Nov 17 15:51:14 raspberrypi rngd[350]: stats: FIPS 140-2 failures: 0
                            Nov 17 15:51:14 raspberrypi rngd[350]: stats: FIPS 140-2(2001-10-10) Monobit: 0
                            Nov 17 15:51:14 raspberrypi rngd[350]: stats: FIPS 140-2(2001-10-10) Poker: 0
                            Nov 17 16:34:17 raspberrypi kernel: [110590.976425] INFO: task kworker/3:0:17358 blocked for more than 120 seconds.
                            Nov 17 16:34:22 raspberrypi kernel: [110590.976435]       Tainted: G         C        4.19.66-v7+ #1253
                            Nov 17 16:34:26 raspberrypi kernel: [110590.976438] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
                            Nov 17 16:34:31 raspberrypi kernel: [110590.976443] kworker/3:0     D    0 17358      2 0x00000000
                            Nov 17 16:34:37 raspberrypi kernel: [110590.976464] Workqueue: events_freezable mmc_rescan
                            Nov 17 16:34:40 raspberrypi kernel: [110590.976486] [<80830934>] (__schedule) from [<80830fa4>] (schedule+0x50/0xa8)
                            Nov 17 16:34:40 raspberrypi kernel: [110590.976496] [<80830fa4>] (schedule) from [<80686520>] (__mmc_claim_host+0x120/0x228)
                            Nov 17 16:34:40 raspberrypi kernel: [110590.976505] [<80686520>] (__mmc_claim_host) from [<80686660>] (mmc_get_card+0x38/0x3c)
                            Nov 17 16:34:40 raspberrypi kernel: [110590.976514] [<80686660>] (mmc_get_card) from [<8068f6cc>] (mmc_sd_detect+0x24/0x7c)
                            Nov 17 16:34:40 raspberrypi kernel: [110590.976523] [<8068f6cc>] (mmc_sd_detect) from [<80688c88>] (mmc_rescan+0x1cc/0x39c)
                            Nov 17 16:34:40 raspberrypi kernel: [110590.976535] [<80688c88>] (mmc_rescan) from [<8013bf0c>] (process_one_work+0x170/0x458)
                            Nov 17 16:34:40 raspberrypi kernel: [110590.976545] [<8013bf0c>] (process_one_work) from [<8013c250>] (worker_thread+0x5c/0x5a4)
                            Nov 17 16:34:40 raspberrypi kernel: [110590.976554] [<8013c250>] (worker_thread) from [<8014253c>] (kthread+0x138/0x168)
                            Nov 17 16:34:40 raspberrypi kernel: [110590.976564] [<8014253c>] (kthread) from [<801010ac>] (ret_from_fork+0x14/0x28)
                            Nov 17 16:34:40 raspberrypi kernel: [110590.976569] Exception stack(0x85d3dfb0 to 0x85d3dff8)
                            Nov 17 16:34:40 raspberrypi kernel: [110590.976574] dfa0:                                     00000000 00000000 00000000 00000000
                            Nov 17 16:34:40 raspberrypi kernel: [110590.976581] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                            Nov 17 16:34:40 raspberrypi kernel: [110590.976586] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000
                            Nov 17 16:36:20 raspberrypi kernel: [110713.857586] INFO: task kworker/3:0:17358 blocked for more than 120 seconds.
                            Nov 17 16:36:28 raspberrypi kernel: [110713.857595]       Tainted: G         C        4.19.66-v7+ #1253
                            Nov 17 16:36:35 raspberrypi kernel: [110713.857598] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
                            Nov 17 16:36:39 raspberrypi kernel: [110713.857603] kworker/3:0     D    0 17358      2 0x00000000
                            Nov 17 16:36:46 raspberrypi kernel: [110713.857625] Workqueue: events_freezable mmc_rescan
                            Nov 17 16:36:53 raspberrypi kernel: [110713.857648] [<80830934>] (__schedule) from [<80830fa4>] (schedule+0x50/0xa8)
                            Nov 17 16:36:59 raspberrypi kernel: [110713.857658] [<80830fa4>] (schedule) from [<80686520>] (__mmc_claim_host+0x120/0x228)
                            Nov 17 16:37:05 raspberrypi kernel: [110713.857667] [<80686520>] (__mmc_claim_host) from [<80686660>] (mmc_get_card+0x38/0x3c)
                            Nov 17 16:37:11 raspberrypi kernel: [110713.857675] [<80686660>] (mmc_get_card) from [<8068f6cc>] (mmc_sd_detect+0x24/0x7c)
                            Nov 17 16:37:18 raspberrypi kernel: [110713.857684] [<8068f6cc>] (mmc_sd_detect) from [<80688c88>] (mmc_rescan+0x1cc/0x39c)
                            Nov 17 16:37:25 raspberrypi kernel: [110713.857695] [<80688c88>] (mmc_rescan) from [<8013bf0c>] (process_one_work+0x170/0x458)
                            Nov 17 16:37:33 raspberrypi kernel: [110713.857705] [<8013bf0c>] (process_one_work) from [<8013c250>] (worker_thread+0x5c/0x5a4)
                            Nov 17 16:37:38 raspberrypi kernel: [110713.857715] [<8013c250>] (worker_thread) from [<8014253c>] (kthread+0x138/0x168)
                            Nov 17 16:37:47 raspberrypi kernel: [110713.857725] [<8014253c>] (kthread) from [<801010ac>] (ret_from_fork+0x14/0x28)
                            Nov 17 16:37:54 raspberrypi kernel: [110713.857729] Exception stack(0x85d3dfb0 to 0x85d3dff8)
                            Nov 17 16:38:01 raspberrypi kernel: [110713.857735] dfa0:                                     00000000 00000000 00000000 00000000
                            Nov 17 16:38:10 raspberrypi kernel: [110713.857741] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                            Nov 17 16:38:17 raspberrypi kernel: [110713.857747] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000
                            Nov 17 16:38:24 raspberrypi kernel: [110836.738726] INFO: task kworker/3:0:17358 blocked for more than 120 seconds.
                            Nov 17 16:38:37 raspberrypi kernel: [110836.738737]       Tainted: G         C        4.19.66-v7+ #1253
                            Nov 17 16:38:43 raspberrypi kernel: [110836.738740] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
                            Nov 17 16:38:48 raspberrypi kernel: [110836.738744] kworker/3:0     D    0 17358      2 0x00000000
                            Nov 17 16:38:54 raspberrypi kernel: [110836.738765] Workqueue: events_freezable mmc_rescan
                            Nov 17 16:39:00 raspberrypi kernel: [110836.738787] [<80830934>] (__schedule) from [<80830fa4>] (schedule+0x50/0xa8)
                            Nov 17 16:39:07 raspberrypi kernel: [110836.738796] [<80830fa4>] (schedule) from [<80686520>] (__mmc_claim_host+0x120/0x228)
                            Nov 17 16:39:14 raspberrypi kernel: [110836.738805] [<80686520>] (__mmc_claim_host) from [<80686660>] (mmc_get_card+0x38/0x3c)
                            Nov 17 16:39:22 raspberrypi kernel: [110836.738814] [<80686660>] (mmc_get_card) from [<8068f6cc>] (mmc_sd_detect+0x24/0x7c)
                            Nov 17 16:39:29 raspberrypi kernel: [110836.738823] [<8068f6cc>] (mmc_sd_detect) from [<80688c88>] (mmc_rescan+0x1cc/0x39c)
                            Nov 17 16:39:35 raspberrypi kernel: [110836.738834] [<80688c88>] (mmc_rescan) from [<8013bf0c>] (process_one_work+0x170/0x458)
                            Nov 17 16:39:45 raspberrypi kernel: [110836.738843] [<8013bf0c>] (process_one_work) from [<8013c250>] (worker_thread+0x5c/0x5a4)
                            Nov 17 16:39:51 raspberrypi kernel: [110836.738853] [<8013c250>] (worker_thread) from [<8014253c>] (kthread+0x138/0x168)
                            Nov 17 16:39:57 raspberrypi kernel: [110836.738864] [<8014253c>] (kthread) from [<801010ac>] (ret_from_fork+0x14/0x28)
                            Nov 17 16:40:03 raspberrypi kernel: [110836.738868] Exception stack(0x85d3dfb0 to 0x85d3dff8)
                            Nov 17 16:40:09 raspberrypi kernel: [110836.738874] dfa0:                                     00000000 00000000 00000000 00000000
                            Nov 17 16:40:15 raspberrypi kernel: [110836.738880] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                            Nov 17 16:40:20 raspberrypi kernel: [110836.738885] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000
                            Nov 17 16:40:28 raspberrypi kernel: [110959.619889] INFO: task kworker/3:0:17358 blocked for more than 120 seconds.
                            Nov 17 16:40:34 raspberrypi kernel: [110959.619898]       Tainted: G         C        4.19.66-v7+ #1253
                            Nov 17 16:40:41 raspberrypi kernel: [110959.619901] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
                            Nov 17 16:40:49 raspberrypi kernel: [110959.619906] kworker/3:0     D    0 17358      2 0x00000000
                            Nov 17 16:40:55 raspberrypi kernel: [110959.619926] Workqueue: events_freezable mmc_rescan
                            Nov 17 16:41:10 raspberrypi kernel: [110959.619948] [<80830934>] (__schedule) from [<80830fa4>] (schedule+0x50/0xa8)
                            Nov 17 16:41:18 raspberrypi kernel: [110959.619958] [<80830fa4>] (schedule) from [<80686520>] (__mmc_claim_host+0x120/0x228)
                            Nov 17 16:41:26 raspberrypi kernel: [110959.619967] [<80686520>] (__mmc_claim_host) from [<80686660>] (mmc_get_card+0x38/0x3c)
                            Nov 17 16:41:50 raspberrypi kernel: [110959.619975] [<80686660>] (mmc_get_card) from [<8068f6cc>] (mmc_sd_detect+0x24/0x7c)
                            Nov 17 16:42:02 raspberrypi kernel: [110959.619984] [<8068f6cc>] (mmc_sd_detect) from [<80688c88>] (mmc_rescan+0x1cc/0x39c)
                            Nov 17 16:42:09 raspberrypi kernel: [110959.619995] [<80688c88>] (mmc_rescan) from [<8013bf0c>] (process_one_work+0x170/0x458)
                            Nov 17 16:42:17 raspberrypi kernel: [110959.620005] [<8013bf0c>] (process_one_work) from [<8013c250>] (worker_thread+0x5c/0x5a4)
                            Nov 17 16:42:23 raspberrypi kernel: [110959.620015] [<8013c250>] (worker_thread) from [<8014253c>] (kthread+0x138/0x168)
                            Nov 17 16:42:32 raspberrypi kernel: [110959.620025] [<8014253c>] (kthread) from [<801010ac>] (ret_from_fork+0x14/0x28)
                            Nov 17 16:42:43 raspberrypi kernel: [110959.620030] Exception stack(0x85d3dfb0 to 0x85d3dff8)
                            Nov 17 16:42:50 raspberrypi kernel: [110959.620036] dfa0:                                     00000000 00000000 00000000 00000000
                            Nov 17 16:42:59 raspberrypi kernel: [110959.620042] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                            Nov 17 16:43:07 raspberrypi kernel: [110959.620048] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000
                            Nov 17 16:43:15 raspberrypi kernel: [111082.501015] INFO: task kworker/3:0:17358 blocked for more than 120 seconds.
                            Nov 17 16:43:24 raspberrypi kernel: [111082.501025]       Tainted: G         C        4.19.66-v7+ #1253
                            Nov 17 16:43:33 raspberrypi kernel: [111082.501028] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
                            Nov 17 16:43:42 raspberrypi kernel: [111082.501034] kworker/3:0     D    0 17358      2 0x00000000
                            Nov 17 16:43:51 raspberrypi kernel: [111082.501054] Workqueue: events_freezable mmc_rescan
                            Nov 17 16:43:59 raspberrypi kernel: [111082.501077] [<80830934>] (__schedule) from [<80830fa4>] (schedule+0x50/0xa8)
                            Nov 17 16:44:07 raspberrypi kernel: [111082.501086] [<80830fa4>] (schedule) from [<80686520>] (__mmc_claim_host+0x120/0x228)
                            Nov 17 16:44:15 raspberrypi kernel: [111082.501095] [<80686520>] (__mmc_claim_host) from [<80686660>] (mmc_get_card+0x38/0x3c)
                            Nov 17 16:44:20 raspberrypi kernel: [111082.501104] [<80686660>] (mmc_get_card) from [<8068f6cc>] (mmc_sd_detect+0x24/0x7c)
                            Nov 17 16:44:29 raspberrypi kernel: [111082.501112] [<8068f6cc>] (mmc_sd_detect) from [<80688c88>] (mmc_rescan+0x1cc/0x39c)
                            Nov 17 16:44:37 raspberrypi kernel: [111082.501123] [<80688c88>] (mmc_rescan) from [<8013bf0c>] (process_one_work+0x170/0x458)
                            Nov 17 16:44:46 raspberrypi kernel: [111082.501133] [<8013bf0c>] (process_one_work) from [<8013c250>] (worker_thread+0x5c/0x5a4)
                            Nov 17 16:17:04 raspberrypi fake-hwclock[100]: Sun 17 Nov 15:17:01 UTC 2019
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started File System Check Daemon to report status.
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started Apply Kernel Variables.
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started udev Coldplug all Devices.
                            Nov 17 16:17:04 raspberrypi systemd[1]: Starting Helper to synchronize boot up for ifupdown...
                            Nov 17 16:17:04 raspberrypi systemd-fsck[126]: e2fsck 1.44.5 (15-Dec-2018)
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started Helper to synchronize boot up for ifupdown.
                            Nov 17 16:17:04 raspberrypi systemd-fsck[126]: rootfs: clean, 132715/1822992 files, 1510848/7612416 blocks
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started File System Check on Root Device.
                            Nov 17 16:17:04 raspberrypi systemd[1]: Starting Remount Root and Kernel File Systems...
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started Set the console keyboard layout.
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started Remount Root and Kernel File Systems.
                            Nov 17 16:17:04 raspberrypi systemd[1]: Starting Load/Save Random Seed...
                            Nov 17 16:17:04 raspberrypi systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
                            Nov 17 16:17:04 raspberrypi systemd[1]: Starting Flush Journal to Persistent Storage...
                            Nov 17 16:17:04 raspberrypi systemd[1]: Starting Create System Users...
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000] Booting Linux on physical CPU 0x0
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000] Linux version 4.19.66-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1253 SMP Thu Aug 15 11:49:46 BST 2019
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started Load/Save Random Seed.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000] CPU: div instructions available: patching division code
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started Flush Journal to Persistent Storage.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000] Memory policy: Data cache writealloc
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000] cma: Reserved 8 MiB at 0x3ac00000
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started Create System Users.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000] On node 0 totalpages: 242688
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000]   Normal zone: 2133 pages used for memmap
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000]   Normal zone: 0 pages reserved
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000]   Normal zone: 242688 pages, LIFO batch:63
                            Nov 17 16:17:04 raspberrypi systemd[1]: Starting Create Static Device Nodes in /dev...
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000] random: get_random_bytes called from start_kernel+0xac/0x4b4 with crng_init=0
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000] percpu: Embedded 17 pages/cpu s39488 r8192 d21952 u69632
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started Create Static Device Nodes in /dev.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000] pcpu-alloc: s39488 r8192 d21952 u69632 alloc=17*4096
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 240555
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=9263b30d-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
                            Nov 17 16:17:04 raspberrypi systemd[1]: Starting udev Kernel Device Manager...
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000] Memory: 939088K/970752K available (8192K kernel code, 629K rwdata, 2176K rodata, 1024K init, 821K bss, 23472K reserved, 8192K cma-reserved)
                            Nov 17 16:17:04 raspberrypi systemd[1]: Reached target Local File Systems (Pre).
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000] Virtual kernel memory layout:
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000]     vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000]     lowmem  : 0x80000000 - 0xbb400000   ( 948 MB)
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started udev Kernel Device Manager.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000]     modules : 0x7f000000 - 0x80000000   (  16 MB)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (9184 kB)
                            Nov 17 16:17:04 raspberrypi systemd[1]: Found device /dev/serial1.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000]       .init : 0x(ptrval) - 0x(ptrval)   (1024 kB)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 630 kB)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 822 kB)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                            Nov 17 16:17:04 raspberrypi systemd[1]: Found device /dev/disk/by-partuuid/9263b30d-01.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000] ftrace: allocating 26394 entries in 78 pages
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000] rcu: Hierarchical RCU implementation.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
                            Nov 17 16:17:04 raspberrypi systemd[1]: Starting File System Check on /dev/disk/by-partuuid/9263b30d-01...
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000023] Switching to timer-based delay loop, resolution 52ns
                            Nov 17 16:17:04 raspberrypi mtp-probe: checking bus 1, device 3: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1"
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000287] Console: colour dummy device 80x30
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000912] console [tty1] enabled
                            Nov 17 16:17:04 raspberrypi kernel: [    0.000970] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.001015] pid_max: default: 32768 minimum: 301
                            Nov 17 16:17:04 raspberrypi mtp-probe: bus: 1, device: 3 was not an MTP device
                            Nov 17 16:17:04 raspberrypi kernel: [    0.001374] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.001410] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.002346] CPU: Testing write buffer coherency: ok
                            Nov 17 16:17:04 raspberrypi kernel: [    0.002835] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                            Nov 17 16:17:04 raspberrypi systemd-udevd[140]: Using default interface naming scheme 'v240'.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.003502] Setting up static identity map for 0x100000 - 0x10003c
                            Nov 17 16:17:04 raspberrypi kernel: [    0.003670] rcu: Hierarchical SRCU implementation.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.004485] smp: Bringing up secondary CPUs ...
                            Nov 17 16:17:04 raspberrypi kernel: [    0.005339] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                            Nov 17 16:17:04 raspberrypi systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.006264] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
                            Nov 17 16:17:04 raspberrypi kernel: [    0.007122] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
                            Nov 17 16:17:04 raspberrypi kernel: [    0.007243] smp: Brought up 1 node, 4 CPUs
                            Nov 17 16:17:04 raspberrypi systemd-fsck[222]: fsck.fat 4.1 (2017-01-24)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.007324] SMP: Total of 4 processors activated (153.60 BogoMIPS).
                            Nov 17 16:17:04 raspberrypi kernel: [    0.007348] CPU: All CPU(s) started in HYP mode.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.007369] CPU: Virtualization extensions available.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.008357] devtmpfs: initialized
                            Nov 17 16:17:04 raspberrypi systemd-fsck[222]: 0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.021277] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
                            Nov 17 16:17:04 raspberrypi kernel: [    0.021552] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                            Nov 17 16:17:04 raspberrypi systemd-fsck[222]:  Automatically removing dirty bit.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.021600] futex hash table entries: 1024 (order: 4, 65536 bytes)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.022206] pinctrl core: initialized pinctrl subsystem
                            Nov 17 16:17:04 raspberrypi kernel: [    0.023090] NET: Registered protocol family 16
                            Nov 17 16:17:04 raspberrypi kernel: [    0.026034] DMA: preallocated 1024 KiB pool for atomic coherent allocations
                            Nov 17 16:17:04 raspberrypi systemd-fsck[222]: Performing changes.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.031739] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.031776] hw-breakpoint: maximum watchpoint size is 8 bytes.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.031996] Serial: AMBA PL011 UART driver
                            Nov 17 16:17:04 raspberrypi kernel: [    0.034297] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
                            Nov 17 16:17:04 raspberrypi systemd-fsck[222]: /dev/mmcblk0p1: 223 files, 80104/516191 clusters
                            Nov 17 16:17:04 raspberrypi kernel: [    0.069441] bcm2835-dma 3f007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
                            Nov 17 16:17:04 raspberrypi kernel: [    0.071366] SCSI subsystem initialized
                            Nov 17 16:17:04 raspberrypi systemd-udevd[142]: Using default interface naming scheme 'v240'.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.071604] usbcore: registered new interface driver usbfs
                            Nov 17 16:17:04 raspberrypi kernel: [    0.071686] usbcore: registered new interface driver hub
                            Nov 17 16:17:04 raspberrypi kernel: [    0.071799] usbcore: registered new device driver usb
                            Nov 17 16:17:04 raspberrypi kernel: [    0.090301] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-08-15 12:06, variant start
                            Nov 17 16:17:04 raspberrypi kernel: [    0.100131] raspberrypi-firmware soc:firmware: Firmware hash is 0e6daa5106dd4164474616408e0dc24f997ffcf3
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started File System Check on /dev/disk/by-partuuid/9263b30d-01.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.111770] clocksource: Switched to clocksource arch_sys_counter
                            Nov 17 16:17:04 raspberrypi kernel: [    0.200874] VFS: Disk quotas dquot_6.6.0
                            Nov 17 16:17:04 raspberrypi systemd[1]: Condition check resulted in Huge Pages File System being skipped.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.200986] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.201163] FS-Cache: Loaded
                            Nov 17 16:17:04 raspberrypi kernel: [    0.201389] CacheFiles: Loaded
                            Nov 17 16:17:04 raspberrypi systemd[1]: Condition check resulted in FUSE Control File System being skipped.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.211385] NET: Registered protocol family 2
                            Nov 17 16:17:04 raspberrypi kernel: [    0.212207] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.212271] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.212401] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
                            Nov 17 16:17:04 raspberrypi systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.212606] TCP: Hash tables configured (established 8192 bind 8192)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.212761] UDP hash table entries: 512 (order: 2, 16384 bytes)
                            Nov 17 16:17:04 raspberrypi systemd[1]: Mounting /boot...
                            Nov 17 16:17:04 raspberrypi kernel: [    0.212827] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.213155] NET: Registered protocol family 1
                            Nov 17 16:17:04 raspberrypi kernel: [    0.213735] RPC: Registered named UNIX socket transport module.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.213762] RPC: Registered udp transport module.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.213784] RPC: Registered tcp transport module.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.213806] RPC: Registered tcp NFSv4.1 backchannel transport module.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.215509] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
                            Nov 17 16:17:04 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status...
                            Nov 17 16:17:04 raspberrypi kernel: [    0.218552] Initialise system trusted keyrings
                            Nov 17 16:17:04 raspberrypi kernel: [    0.218761] workingset: timestamp_bits=14 max_order=18 bucket_order=4
                            Nov 17 16:17:04 raspberrypi kernel: [    0.228739] FS-Cache: Netfs 'nfs' registered for caching
                            Nov 17 16:17:04 raspberrypi kernel: [    0.229346] NFS: Registering the id_resolver key type
                            Nov 17 16:17:04 raspberrypi systemd[1]: Mounted /boot.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.229392] Key type id_resolver registered
                            Nov 17 16:17:04 raspberrypi kernel: [    0.229414] Key type id_legacy registered
                            Nov 17 16:17:04 raspberrypi kernel: [    0.229446] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                            Nov 17 16:17:04 raspberrypi kernel: [    0.231743] Key type asymmetric registered
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.231847] Asymmetric key parser 'x509' registered
                            Nov 17 16:17:04 raspberrypi kernel: [    0.231917] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
                            Nov 17 16:17:04 raspberrypi systemd[1]: Reached target Local File Systems.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.232098] io scheduler noop registered
                            Nov 17 16:17:04 raspberrypi kernel: [    0.232122] io scheduler deadline registered (default)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.232316] io scheduler cfq registered
                            Nov 17 16:17:04 raspberrypi kernel: [    0.232340] io scheduler mq-deadline registered (default)
                            Nov 17 16:17:04 raspberrypi systemd[1]: Starting Create Volatile Files and Directories...
                            Nov 17 16:17:04 raspberrypi kernel: [    0.232364] io scheduler kyber registered
                            Nov 17 16:17:04 raspberrypi kernel: [    0.235522] bcm2708_fb soc:fb: FB found 1 display(s)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.244427] Console: switching to colour frame buffer device 82x26
                            Nov 17 16:17:04 raspberrypi systemd[1]: Starting Set console font and keymap...
                            Nov 17 16:17:04 raspberrypi kernel: [    0.251242] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
                            Nov 17 16:17:04 raspberrypi kernel: [    0.257987] bcm2835-rng 3f104000.rng: hwrng registered
                            Nov 17 16:17:04 raspberrypi systemd[1]: Starting Preprocess NFS configuration...
                            Nov 17 16:17:04 raspberrypi systemd[1]: Starting Raise network interfaces...
                            Nov 17 16:17:04 raspberrypi systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
                            Nov 17 16:17:04 raspberrypi systemd[1]: nfs-config.service: Succeeded.
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started Preprocess NFS configuration.
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started Set console font and keymap.
                            Nov 17 16:17:04 raspberrypi systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
                            Nov 17 16:17:04 raspberrypi systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
                            Nov 17 16:17:04 raspberrypi systemd[1]: Reached target NFS client services.
                            Nov 17 16:17:04 raspberrypi systemd[1]: Reached target Remote File Systems (Pre).
                            Nov 17 16:17:04 raspberrypi systemd[1]: Reached target Remote File Systems.
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started Create Volatile Files and Directories.
                            Nov 17 16:17:04 raspberrypi systemd[1]: Starting Network Time Synchronization...
                            Nov 17 16:17:04 raspberrypi systemd[1]: Starting Update UTMP about System Boot/Shutdown...
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started Update UTMP about System Boot/Shutdown.
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started Raise network interfaces.
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started Network Time Synchronization.
                            Nov 17 16:17:04 raspberrypi systemd[1]: Reached target System Time Synchronized.
                            Nov 17 16:17:04 raspberrypi systemd[1]: Reached target System Initialization.
                            Nov 17 16:17:04 raspberrypi systemd[1]: Listening on D-Bus System Message Bus Socket.
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started Daily rotation of log files.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.260678] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
                            Nov 17 16:17:04 raspberrypi systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.265990] vc-sm: Videocore shared memory driver
                            Nov 17 16:17:04 raspberrypi kernel: [    0.268752] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
                            Nov 17 16:17:04 raspberrypi kernel: [    0.284605] brd: module loaded
                            Nov 17 16:17:04 raspberrypi kernel: [    0.297246] loop: module loaded
                            Nov 17 16:17:04 raspberrypi systemd[1]: Listening on triggerhappy.socket.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.300300] Loading iSCSI transport class v2.0-870.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.303491] libphy: Fixed MDIO Bus: probed
                            Nov 17 16:17:04 raspberrypi systemd[1]: Reached target Sockets.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.306002] usbcore: registered new interface driver lan78xx
                            Nov 17 16:17:04 raspberrypi kernel: [    0.308460] usbcore: registered new interface driver smsc95xx
                            Nov 17 16:17:04 raspberrypi kernel: [    0.310816] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.341128] dwc_otg 3f980000.usb: base=(ptrval)
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started Daily man-db regeneration.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.543755] Core Release: 2.80a
                            Nov 17 16:17:04 raspberrypi kernel: [    0.546145] Setting default values for core params
                            Nov 17 16:17:04 raspberrypi kernel: [    0.548593] Finished setting default values for core params
                            Nov 17 16:17:04 raspberrypi systemd[1]: Reached target Basic System.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.751349] Using Buffer DMA mode
                            Nov 17 16:17:04 raspberrypi kernel: [    0.753759] Periodic Transfer Interrupt Enhancement - disabled
                            Nov 17 16:17:04 raspberrypi kernel: [    0.756184] Multiprocessor Interrupt Enhancement - disabled
                            Nov 17 16:17:04 raspberrypi systemd[1]: Starting dphys-swapfile - set up, mount/unmount, and delete a swap file...
                            Nov 17 16:17:04 raspberrypi kernel: [    0.758556] OTG VER PARAM: 0, OTG VER FLAG: 0
                            Nov 17 16:17:04 raspberrypi kernel: [    0.760894] Dedicated Tx FIFOs mode
                            Nov 17 16:17:04 raspberrypi kernel: [    0.763634] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = bad04000 dma = 0xfad04000 len=9024
                            Nov 17 16:17:04 raspberrypi kernel: [    0.768208] FIQ FSM acceleration enabled for :
                            Nov 17 16:17:04 raspberrypi systemd[1]: Starting Login Service...
                            Nov 17 16:17:04 raspberrypi kernel: [    0.768208] Non-periodic Split Transactions
                            Nov 17 16:17:04 raspberrypi kernel: [    0.768208] Periodic Split Transactions
                            Nov 17 16:17:04 raspberrypi kernel: [    0.768208] High-Speed Isochronous Endpoints
                            Nov 17 16:17:04 raspberrypi kernel: [    0.768208] Interrupt/Control Split Transaction hack enabled
                            Nov 17 16:17:04 raspberrypi systemd[1]: Condition check resulted in Turn on SSH if /boot/ssh is present being skipped.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.779106] dwc_otg: Microframe scheduler enabled
                            Nov 17 16:17:04 raspberrypi kernel: [    0.779159] WARN::hcd_init_fiq:457: FIQ on core 1
                            Nov 17 16:17:04 raspberrypi kernel: [    0.781378] WARN::hcd_init_fiq:458: FIQ ASM at 80654f4c length 36
                            Nov 17 16:17:04 raspberrypi kernel: [    0.783588] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
                            Nov 17 16:17:04 raspberrypi systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
                            Nov 17 16:17:04 raspberrypi kernel: [    0.785863] dwc_otg 3f980000.usb: DWC OTG Controller
                            Nov 17 16:17:04 raspberrypi kernel: [    0.788119] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
                            Nov 17 16:17:04 raspberrypi systemd[1]: Starting triggerhappy global hotkey daemon...
                            Nov 17 16:17:04 raspberrypi kernel: [    0.790435] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
                            Nov 17 16:17:04 raspberrypi kernel: [    0.792756] Init: Port Power? op_state=1
                            Nov 17 16:17:04 raspberrypi kernel: [    0.794995] Init: Power Port (0)
                            Nov 17 16:17:04 raspberrypi systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
                            Nov 17 16:17:04 raspberrypi systemd[1]: Starting Configure Bluetooth Modems connected by UART...
                            Nov 17 16:17:04 raspberrypi systemd[1]: Starting rng-tools.service...
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started Regular background program processing daemon.
                            Nov 17 16:17:04 raspberrypi systemd[1]: Condition check resulted in getty on tty2-tty6 if dbus and logind are not available being skipped.
                            Nov 17 16:17:04 raspberrypi systemd[1]: Starting System Logging Service...
                            Nov 17 16:17:04 raspberrypi kernel: [    0.797407] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
                            Nov 17 16:17:04 raspberrypi systemd[1]: Condition check resulted in Copy user wpa_supplicant.conf being skipped.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.801939] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                            Nov 17 16:17:04 raspberrypi kernel: [    0.804350] usb usb1: Product: DWC OTG Controller
                            Nov 17 16:17:04 raspberrypi kernel: [    0.806712] usb usb1: Manufacturer: Linux 4.19.66-v7+ dwc_otg_hcd
                            Nov 17 16:17:04 raspberrypi kernel: [    0.809128] usb usb1: SerialNumber: 3f980000.usb
                            Nov 17 16:17:04 raspberrypi systemd[1]: Starting dhcpcd on all interfaces...
                            Nov 17 16:17:04 raspberrypi kernel: [    0.812160] hub 1-0:1.0: USB hub found
                            Nov 17 16:17:04 raspberrypi kernel: [    0.814437] hub 1-0:1.0: 1 port detected
                            Nov 17 16:17:04 raspberrypi kernel: [    0.817192] dwc_otg: FIQ enabled
                            Nov 17 16:17:04 raspberrypi rng-tools[338]: Starting Hardware RNG entropy gatherer daemon: rngd.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.817198] dwc_otg: NAK holdoff enabled
                            Nov 17 16:17:04 raspberrypi kernel: [    0.817203] dwc_otg: FIQ split-transaction FSM enabled
                            Nov 17 16:17:04 raspberrypi cron[345]: (CRON) INFO (pidfile fd = 3)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.817214] Module dwc_common_port init
                            Nov 17 16:17:04 raspberrypi kernel: [    0.817478] usbcore: registered new interface driver usb-storage
                            Nov 17 16:17:04 raspberrypi kernel: [    0.819936] mousedev: PS/2 mouse device common for all mice
                            Nov 17 16:17:04 raspberrypi rngd[352]: rngd 2-unofficial-mt.14 starting up...
                            Nov 17 16:17:04 raspberrypi kernel: [    0.823138] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                            Nov 17 16:17:04 raspberrypi kernel: [    0.825764] bcm2835-cpufreq: min=600000 max=1200000
                            Nov 17 16:17:04 raspberrypi kernel: [    0.828584] sdhci: Secure Digital Host Controller Interface driver
                            Nov 17 16:17:04 raspberrypi kernel: [    0.830989] sdhci: Copyright(c) Pierre Ossman
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started D-Bus System Message Bus.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.833806] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
                            Nov 17 16:17:04 raspberrypi kernel: [    0.836717] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
                            Nov 17 16:17:04 raspberrypi kernel: [    0.839390] sdhci-pltfm: SDHCI platform and OF driver helper
                            Nov 17 16:17:04 raspberrypi thd[334]: Found socket passed from systemd
                            Nov 17 16:17:04 raspberrypi kernel: [    0.843507] ledtrig-cpu: registered to indicate activity on CPUs
                            Nov 17 16:17:04 raspberrypi kernel: [    0.846282] hidraw: raw HID events driver (C) Jiri Kosina
                            Nov 17 16:17:04 raspberrypi kernel: [    0.849048] usbcore: registered new interface driver usbhid
                            Nov 17 16:17:04 raspberrypi kernel: [    0.851675] usbhid: USB HID core driver
                            Nov 17 16:17:04 raspberrypi rngd[352]: entropy feed to the kernel ready
                            Nov 17 16:17:04 raspberrypi kernel: [    0.855054] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
                            Nov 17 16:17:04 raspberrypi kernel: [    0.859118] [vc_sm_connected_init]: start
                            Nov 17 16:17:04 raspberrypi kernel: [    0.867838] [vc_sm_connected_init]: end - returning 0
                            Nov 17 16:17:04 raspberrypi kernel: [    0.871380] Initializing XFRM netlink socket
                            Nov 17 16:17:04 raspberrypi kernel: [    0.873841] NET: Registered protocol family 17
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started Manage Sound Card State (restore and store).
                            Nov 17 16:17:04 raspberrypi kernel: [    0.876340] Key type dns_resolver registered
                            Nov 17 16:17:04 raspberrypi kernel: [    0.879181] Registering SWP/SWPB emulation handler
                            Nov 17 16:17:04 raspberrypi systemd[1]: Starting Save/Restore Sound Card State...
                            Nov 17 16:17:04 raspberrypi kernel: [    0.882321] registered taskstats version 1
                            Nov 17 16:17:04 raspberrypi kernel: [    0.884728] Loading compiled-in X.509 certificates
                            Nov 17 16:17:04 raspberrypi cron[345]: (CRON) INFO (Running @reboot jobs)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.894312] uart-pl011 3f201000.serial: cts_event_workaround enabled
                            Nov 17 16:17:04 raspberrypi kernel: [    0.896840] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started Daily Cleanup of Temporary Directories.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.903613] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
                            Nov 17 16:17:04 raspberrypi kernel: [    0.906150] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
                            Nov 17 16:17:04 raspberrypi kernel: [    0.934776] sdhost: log_buf @ (ptrval) (fad07000)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.972070] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.976042] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.979897] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                            Nov 17 16:17:04 raspberrypi alsactl[368]: alsactl 1.1.8 daemon started
                            Nov 17 16:17:04 raspberrypi kernel: [    0.984917] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.987041] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
                            Nov 17 16:17:04 raspberrypi kernel: [    0.990395] of_cfs_init
                            Nov 17 16:17:04 raspberrypi kernel: [    0.992558] of_cfs_init: OK
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started Daily apt download activities.
                            Nov 17 16:17:04 raspberrypi kernel: [    0.995015] Waiting for root device PARTUUID=9263b30d-02...
                            Nov 17 16:17:04 raspberrypi kernel: [    1.031894] Indeed it is in host mode hprt0 = 00021501
                            Nov 17 16:17:04 raspberrypi kernel: [    1.101794] mmc0: host does not support reading read-only switch, assuming write-enable
                            Nov 17 16:17:04 raspberrypi kernel: [    1.104437] random: fast init done
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
                            Nov 17 16:17:04 raspberrypi kernel: [    1.109073] mmc0: new high speed SDHC card at address 59b4
                            Nov 17 16:17:04 raspberrypi kernel: [    1.112480] mmcblk0: mmc0:59b4 SMI   29.3 GiB
                            Nov 17 16:17:04 raspberrypi kernel: [    1.116752]  mmcblk0: p1 p2
                            Nov 17 16:17:04 raspberrypi kernel: [    1.145228] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                            Nov 17 16:17:04 raspberrypi systemd[1]: Reached target Timers.
                            Nov 17 16:17:04 raspberrypi kernel: [    1.147461] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                            Nov 17 16:17:04 raspberrypi kernel: [    1.177006] mmc1: new high speed SDIO card at address 0001
                            Nov 17 16:17:04 raspberrypi avahi-daemon[333]: Found user 'avahi' (UID 108) and group 'avahi' (GID 113).
                            Nov 17 16:17:04 raspberrypi kernel: [    1.241830] usb 1-1: new high-speed USB device number 2 using dwc_otg
                            Nov 17 16:17:04 raspberrypi kernel: [    1.244173] Indeed it is in host mode hprt0 = 00001101
                            Nov 17 16:17:04 raspberrypi kernel: [    1.334298] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
                            Nov 17 16:17:04 raspberrypi kernel: [    1.367968] EXT4-fs (mmcblk0p2): 10 orphan inodes deleted
                            Nov 17 16:17:04 raspberrypi avahi-daemon[333]: Successfully dropped root privileges.
                            Nov 17 16:17:04 raspberrypi kernel: [    1.370243] EXT4-fs (mmcblk0p2): recovery complete
                            Nov 17 16:17:04 raspberrypi kernel: [    1.481450] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                            Nov 17 16:17:04 raspberrypi kernel: [    1.482070] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
                            Nov 17 16:17:04 raspberrypi avahi-daemon[333]: avahi-daemon 0.7 starting up.
                            Nov 17 16:17:04 raspberrypi kernel: [    1.486338] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                            Nov 17 16:17:04 raspberrypi kernel: [    1.491318] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
                            Nov 17 16:17:04 raspberrypi kernel: [    1.497466] hub 1-1:1.0: USB hub found
                            Nov 17 16:17:04 raspberrypi systemd[1]: Starting WPA supplicant...
                            Nov 17 16:17:04 raspberrypi kernel: [    1.500223] hub 1-1:1.0: 5 ports detected
                            Nov 17 16:17:04 raspberrypi kernel: [    1.504652] devtmpfs: mounted
                            Nov 17 16:17:04 raspberrypi kernel: [    1.512544] Freeing unused kernel memory: 1024K
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started triggerhappy global hotkey daemon.
                            Nov 17 16:17:04 raspberrypi kernel: [    1.515515] Run /sbin/init as init process
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started rng-tools.service.
                            Nov 17 16:17:04 raspberrypi kernel: [    1.821824] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
                            Nov 17 16:17:04 raspberrypi kernel: [    1.952144] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
                            Nov 17 16:17:04 raspberrypi kernel: [    1.957330] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
                            Nov 17 16:17:04 raspberrypi kernel: [    1.962746] smsc95xx v1.0.6
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started Save/Restore Sound Card State.
                            Nov 17 16:17:04 raspberrypi kernel: [    2.055358] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:51:8b:e9
                            Nov 17 16:17:04 raspberrypi kernel: [    2.257268] NET: Registered protocol family 10
                            Nov 17 16:17:04 raspberrypi kernel: [    2.261625] Segment Routing with IPv6
                            Nov 17 16:17:04 raspberrypi dhcpcd[351]: dev: loaded udev
                            Nov 17 16:17:04 raspberrypi kernel: [    3.160933] random: systemd: uninitialized urandom read (16 bytes read)
                            Nov 17 16:17:04 raspberrypi kernel: [    3.175021] random: systemd: uninitialized urandom read (16 bytes read)
                            Nov 17 16:17:04 raspberrypi systemd[1]: Reached target Sound Card.
                            Nov 17 16:17:04 raspberrypi rsyslogd: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd.  [v8.1901.0]
                            Nov 17 16:17:04 raspberrypi rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="350" x-info="https://www.rsyslog.com"] start
                            Nov 17 16:17:04 raspberrypi kernel: [    3.218236] random: systemd: uninitialized urandom read (16 bytes read)
                            Nov 17 16:17:04 raspberrypi kernel: [    4.038789] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                            Nov 17 16:17:04 raspberrypi kernel: [    4.760882] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
                            Nov 17 16:17:04 raspberrypi kernel: [    4.763542] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                            Nov 17 16:17:04 raspberrypi kernel: [    4.763558] [vc_sm_connected_init]: start
                            Nov 17 16:17:04 raspberrypi kernel: [    4.777575] media: Linux media interface: v0.10
                            Nov 17 16:17:04 raspberrypi kernel: [    4.780378] [vc_sm_connected_init]: installed successfully
                            Nov 17 16:17:04 raspberrypi kernel: [    4.822572] videodev: Linux video capture interface: v2.00
                            Nov 17 16:17:04 raspberrypi kernel: [    4.924063] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                            Nov 17 16:17:04 raspberrypi kernel: [    4.926990] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                            Nov 17 16:17:04 raspberrypi kernel: [    4.945095] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
                            Nov 17 16:17:04 raspberrypi kernel: [    4.962366] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
                            Nov 17 16:17:04 raspberrypi kernel: [    4.974292] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                            Nov 17 16:17:04 raspberrypi kernel: [    4.974306] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                            Nov 17 16:17:04 raspberrypi kernel: [    4.984139] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                            Nov 17 16:17:04 raspberrypi kernel: [    4.984153] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                            Nov 17 16:17:04 raspberrypi kernel: [    5.020637] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                            Nov 17 16:17:04 raspberrypi kernel: [    5.020652] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                            Nov 17 16:17:04 raspberrypi kernel: [    5.024930] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
                            Nov 17 16:17:04 raspberrypi kernel: [    5.049885] bcm2835_audio soc:audio: card created with 8 channels
                            Nov 17 16:17:04 raspberrypi kernel: [    5.096154] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                            Nov 17 16:17:04 raspberrypi kernel: [    5.214880] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                            Nov 17 16:17:04 raspberrypi kernel: [    5.308881] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
                            Nov 17 16:17:04 raspberrypi kernel: [    5.316711] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
                            Nov 17 16:17:04 raspberrypi kernel: [    5.316975] usbcore: registered new interface driver brcmfmac
                            Nov 17 16:17:04 raspberrypi kernel: [    5.533533] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
                            Nov 17 16:17:04 raspberrypi kernel: [    5.533656] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
                            Nov 17 16:17:04 raspberrypi kernel: [    5.534455] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
                            Nov 17 16:17:04 raspberrypi kernel: [    7.047087] random: crng init done
                            Nov 17 16:17:04 raspberrypi kernel: [    7.047122] random: 7 urandom warning(s) missed due to ratelimiting
                            Nov 17 16:17:04 raspberrypi kernel: [    7.180425] uart-pl011 3f201000.serial: no DMA platform data
                            Nov 17 16:17:04 raspberrypi dphys-swapfile[327]: want /var/swap=100MByte, checking existing: keeping it
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started System Logging Service.
                            Nov 17 16:17:04 raspberrypi kernel: [    7.279896] 8021q: 802.1Q VLAN Support v1.8
                            Nov 17 16:17:04 raspberrypi raspi-config[335]: Checking if shift key is held down:Error opening '/dev/input/event*': No such file or directory
                            Nov 17 16:17:04 raspberrypi raspi-config[335]:  No. Switching to ondemand scaling governor.
                            Nov 17 16:17:04 raspberrypi kernel: [    7.339170] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
                            Nov 17 16:17:04 raspberrypi dbus-daemon[353]: [system] Successfully activated service 'org.freedesktop.systemd1'
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started Login Service.
                            Nov 17 16:17:04 raspberrypi wpa_supplicant[384]: Successfully initialized wpa_supplicant
                            Nov 17 16:17:04 raspberrypi avahi-daemon[333]: Successfully called chroot().
                            Nov 17 16:17:04 raspberrypi avahi-daemon[333]: Successfully dropped remaining capabilities.
                            Nov 17 16:17:04 raspberrypi avahi-daemon[333]: No service file found in /etc/avahi/services.
                            Nov 17 16:17:04 raspberrypi avahi-daemon[333]: Network interface enumeration completed.
                            Nov 17 16:17:04 raspberrypi avahi-daemon[333]: Server startup complete. Host name is raspberrypi.local. Local service cookie is 3071460515.
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started dphys-swapfile - set up, mount/unmount, and delete a swap file.
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started Avahi mDNS/DNS-SD Stack.
                            Nov 17 16:17:04 raspberrypi systemd[1]: Started WPA supplicant.
                            Nov 17 16:17:05 raspberrypi dhcpcd[351]: wlan0: starting wpa_supplicant
                            Nov 17 16:17:05 raspberrypi dhcpcd-run-hooks[416]: wlan0: starting wpa_supplicant
                            Nov 17 16:17:05 raspberrypi kernel: [    7.534552] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
                            Nov 17 16:17:05 raspberrypi kernel: [    7.534563] brcmfmac: power management disabled
                            Nov 17 16:17:05 raspberrypi dhcpcd[351]: eth0: waiting for carrier
                            Nov 17 16:17:05 raspberrypi dhcpcd[351]: wlan0: waiting for carrier
                            Nov 17 16:17:05 raspberrypi dhcpcd[351]: wlan0: carrier acquired
                            Nov 17 16:17:05 raspberrypi kernel: [    7.882994] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
                            Nov 17 16:17:05 raspberrypi dhcpcd[351]: DUID 00:01:00:01:24:b7:ec:04:b8:27:eb:04:de:bc
                            Nov 17 16:17:05 raspberrypi dhcpcd[351]: wlan0: IAID eb:04:de:bc
                            Nov 17 16:17:05 raspberrypi dhcpcd[351]: wlan0: adding address fe80::9d5e:c4f3:4eb1:f245
                            Nov 17 16:17:05 raspberrypi avahi-daemon[333]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::9d5e:c4f3:4eb1:f245.
                            Nov 17 16:17:05 raspberrypi avahi-daemon[333]: New relevant interface wlan0.IPv6 for mDNS.
                            Nov 17 16:17:05 raspberrypi dhcpcd[351]: wlan0: carrier lost
                            Nov 17 16:17:05 raspberrypi avahi-daemon[333]: Registering new address record for fe80::9d5e:c4f3:4eb1:f245 on wlan0.*.
                            Nov 17 16:17:05 raspberrypi dhcpcd[351]: wlan0: deleting address fe80::9d5e:c4f3:4eb1:f245
                            Nov 17 16:17:05 raspberrypi avahi-daemon[333]: Withdrawing address record for fe80::9d5e:c4f3:4eb1:f245 on wlan0.
                            Nov 17 16:17:05 raspberrypi avahi-daemon[333]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::9d5e:c4f3:4eb1:f245.
                            Nov 17 16:17:05 raspberrypi avahi-daemon[333]: Interface wlan0.IPv6 no longer relevant for mDNS.
                            Nov 17 16:17:05 raspberrypi dhcpcd[351]: eth0: carrier acquired
                            Nov 17 16:17:05 raspberrypi dhcpcd[351]: eth0: IAID eb:51:8b:e9
                            Nov 17 16:17:05 raspberrypi dhcpcd[351]: eth0: adding address fe80::4fe3:6694:39c8:48c9
                            Nov 17 16:17:05 raspberrypi avahi-daemon[333]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::4fe3:6694:39c8:48c9.
                            Nov 17 16:17:05 raspberrypi avahi-daemon[333]: New relevant interface eth0.IPv6 for mDNS.
                            Nov 17 16:17:05 raspberrypi avahi-daemon[333]: Registering new address record for fe80::4fe3:6694:39c8:48c9 on eth0.*.
                            Nov 17 16:17:05 raspberrypi dhcpcd[351]: eth0: rebinding lease of 192.168.1.54
                            Nov 17 16:17:06 raspberrypi dhcpcd[351]: eth0: carrier lost
                            Nov 17 16:17:06 raspberrypi dhcpcd[351]: eth0: deleting address fe80::4fe3:6694:39c8:48c9
                            Nov 17 16:17:06 raspberrypi avahi-daemon[333]: Withdrawing address record for fe80::4fe3:6694:39c8:48c9 on eth0.
                            Nov 17 16:17:06 raspberrypi avahi-daemon[333]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::4fe3:6694:39c8:48c9.
                            Nov 17 16:17:06 raspberrypi avahi-daemon[333]: Interface eth0.IPv6 no longer relevant for mDNS.
                            Nov 17 16:17:07 raspberrypi dhcpcd[351]: eth0: carrier acquired
                            Nov 17 16:17:07 raspberrypi kernel: [   10.366091] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC1E1
                            Nov 17 16:17:07 raspberrypi dhcpcd[351]: eth0: IAID eb:51:8b:e9
                            Nov 17 16:17:07 raspberrypi dhcpcd[351]: eth0: adding address fe80::4fe3:6694:39c8:48c9
                            Nov 17 16:17:07 raspberrypi avahi-daemon[333]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::4fe3:6694:39c8:48c9.
                            Nov 17 16:17:07 raspberrypi avahi-daemon[333]: New relevant interface eth0.IPv6 for mDNS.
                            Nov 17 16:17:07 raspberrypi avahi-daemon[333]: Registering new address record for fe80::4fe3:6694:39c8:48c9 on eth0.*.
                            Nov 17 16:17:08 raspberrypi dhcpcd[351]: eth0: soliciting an IPv6 router
                            Nov 17 16:17:08 raspberrypi dhcpcd[351]: eth0: rebinding lease of 192.168.1.54
                            Nov 17 16:17:08 raspberrypi systemd[1]: systemd-rfkill.service: Succeeded.
                            Nov 17 16:17:09 raspberrypi kernel: [   11.937946] Bluetooth: Core ver 2.22
                            Nov 17 16:17:09 raspberrypi kernel: [   11.938044] NET: Registered protocol family 31
                            Nov 17 16:17:09 raspberrypi kernel: [   11.938051] Bluetooth: HCI device and connection manager initialized
                            Nov 17 16:17:09 raspberrypi kernel: [   11.938074] Bluetooth: HCI socket layer initialized
                            Nov 17 16:17:09 raspberrypi kernel: [   11.938088] Bluetooth: L2CAP socket layer initialized
                            Nov 17 16:17:09 raspberrypi kernel: [   11.938127] Bluetooth: SCO socket layer initialized
                            Nov 17 16:17:09 raspberrypi kernel: [   11.957466] Bluetooth: HCI UART driver ver 2.3
                            Nov 17 16:17:09 raspberrypi kernel: [   11.957480] Bluetooth: HCI UART protocol H4 registered
                            Nov 17 16:17:09 raspberrypi kernel: [   11.957605] Bluetooth: HCI UART protocol Three-wire (H5) registered
                            Nov 17 16:17:09 raspberrypi kernel: [   11.957837] Bluetooth: HCI UART protocol Broadcom registered
                            Nov 17 16:17:09 raspberrypi btuart[336]: bcm43xx_init
                            Nov 17 16:17:09 raspberrypi btuart[336]: Flash firmware /lib/firmware/brcm/BCM43430A1.hcd
                            Nov 17 16:17:09 raspberrypi btuart[336]: Set BDADDR UART: b8:27:eb:fb:21:43
                            Nov 17 16:17:09 raspberrypi btuart[336]: Set Controller UART speed to 921600 bit/s
                            Nov 17 16:17:09 raspberrypi btuart[336]: Device setup complete
                            Nov 17 16:17:09 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status...
                            Nov 17 16:17:09 raspberrypi systemd[1]: Started Configure Bluetooth Modems connected by UART.
                            Nov 17 16:17:09 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
                            Nov 17 16:17:09 raspberrypi systemd[1]: Created slice system-bthelper.slice.
                            Nov 17 16:17:09 raspberrypi systemd[1]: Starting Bluetooth service...
                            Nov 17 16:17:09 raspberrypi bluetoothd[463]: Bluetooth daemon 5.50
                            Nov 17 16:17:09 raspberrypi systemd[1]: Started Bluetooth service.
                            Nov 17 16:17:09 raspberrypi systemd[1]: Reached target Bluetooth.
                            Nov 17 16:17:09 raspberrypi systemd[1]: Started Raspberry Pi bluetooth helper.
                            Nov 17 16:17:09 raspberrypi bluetoothd[463]: Starting SDP server
                            Nov 17 16:17:09 raspberrypi kernel: [   12.204956] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                            Nov 17 16:17:09 raspberrypi kernel: [   12.204964] Bluetooth: BNEP filters: protocol multicast
                            Nov 17 16:17:09 raspberrypi kernel: [   12.204980] Bluetooth: BNEP socket layer initialized
                            Nov 17 16:17:09 raspberrypi bluetoothd[463]: Bluetooth management interface 1.14 initialized
                            Nov 17 16:17:09 raspberrypi dbus-daemon[353]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.5' (uid=0 pid=463 comm="/usr/lib/bluetooth/bluetoothd ")
                            Nov 17 16:17:09 raspberrypi bluetoothd[463]: Sap driver initialization failed.
                            Nov 17 16:17:09 raspberrypi bluetoothd[463]: sap-server: Operation not permitted (1)
                            Nov 17 16:17:09 raspberrypi systemd[1]: bthelper@hci0.service: Succeeded.
                            Nov 17 16:17:09 raspberrypi systemd[1]: Starting Hostname Service...
                            Nov 17 16:17:09 raspberrypi bluetoothd[463]: Failed to set privacy: Rejected (0x0b)
                            Nov 17 16:17:09 raspberrypi dhcpcd[351]: eth0: Router Advertisement from fe80::9a9b:cbff:fea9:c707
                            Nov 17 16:17:09 raspberrypi dhcpcd[351]: eth0: adding address 2003:ce:c71a:f100:67e5:fad9:8d9a:849/64
                            Nov 17 16:17:09 raspberrypi dhcpcd[351]: eth0: adding route to 2003:ce:c71a:f100::/64
                            Nov 17 16:17:09 raspberrypi avahi-daemon[333]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::4fe3:6694:39c8:48c9.
                            Nov 17 16:17:09 raspberrypi dhcpcd[351]: eth0: adding default route via fe80::9a9b:cbff:fea9:c707
                            Nov 17 16:17:09 raspberrypi avahi-daemon[333]: Joining mDNS multicast group on interface eth0.IPv6 with address 2003:ce:c71a:f100:67e5:fad9:8d9a:849.
                            Nov 17 16:17:09 raspberrypi avahi-daemon[333]: Registering new address record for 2003:ce:c71a:f100:67e5:fad9:8d9a:849 on eth0.*.
                            Nov 17 16:17:09 raspberrypi dhcpcd[351]: eth0: soliciting a DHCPv6 lease
                            Nov 17 16:17:09 raspberrypi avahi-daemon[333]: Withdrawing address record for fe80::4fe3:6694:39c8:48c9 on eth0.
                            Nov 17 16:17:09 raspberrypi dhcpcd[351]: eth0: Router Advertisement from fe80::3ece:73ff:fe8f:d03f
                            Nov 17 16:17:09 raspberrypi dhcpcd[351]: eth0: adding address fec0::8be3:3298:9264:245e/64
                            Nov 17 16:17:09 raspberrypi avahi-daemon[333]: Registering new address record for fec0::8be3:3298:9264:245e on eth0.*.
                            Nov 17 16:17:09 raspberrypi dhcpcd[351]: eth0: adding route to fec0::/64
                            Nov 17 16:17:10 raspberrypi dbus-daemon[353]: [system] Successfully activated service 'org.freedesktop.hostname1'
                            Nov 17 16:17:10 raspberrypi systemd[1]: Started Hostname Service.
                            Nov 17 16:17:10 raspberrypi dhcpcd[351]: eth0: DHCPv6 REPLY: in stateless mode
                            Nov 17 16:17:11 raspberrypi dhcpcd[351]: Too few arguments.
                            Nov 17 16:17:11 raspberrypi dhcpcd[351]: forked to background, child pid 531
                            Nov 17 16:17:11 raspberrypi dhcpcd[531]: eth0: DHCPv6 REPLY: in stateless mode
                            Nov 17 16:17:11 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
                            Nov 17 16:17:11 raspberrypi systemd[1]: Reached target Network.
                            Nov 17 16:17:11 raspberrypi systemd[1]: Starting Permit User Sessions...
                            Nov 17 16:17:11 raspberrypi systemd[1]: Started ioBroker Server.
                            Nov 17 16:17:11 raspberrypi systemd[1]: Starting OpenBSD Secure Shell server...
                            Nov 17 16:17:11 raspberrypi systemd[1]: Starting /etc/rc.local Compatibility...
                            Nov 17 16:17:11 raspberrypi systemd[1]: Condition check resulted in fast remote file copy program daemon being skipped.
                            Nov 17 16:17:11 raspberrypi systemd[1]: Started Permit User Sessions.
                            Nov 17 16:17:11 raspberrypi systemd[1]: Started /etc/rc.local Compatibility.
                            Nov 17 16:17:11 raspberrypi systemd[1]: Started Getty on tty1.
                            Nov 17 16:17:11 raspberrypi systemd[1]: Reached target Login Prompts.
                            Nov 17 16:17:11 raspberrypi systemd[1]: Started OpenBSD Secure Shell server.
                            Nov 17 16:17:11 raspberrypi systemd[1]: Reached target Multi-User System.
                            Nov 17 16:17:11 raspberrypi systemd[1]: Reached target Graphical Interface.
                            Nov 17 16:17:11 raspberrypi systemd[1]: Starting Update UTMP about System Runlevel Changes...
                            Nov 17 16:17:12 raspberrypi systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
                            Nov 17 16:17:12 raspberrypi systemd[1]: Started Update UTMP about System Runlevel Changes.
                            Nov 17 16:17:12 raspberrypi systemd[1]: Startup finished in 2.064s (kernel) + 12.414s (userspace) = 14.479s.
                            Nov 17 16:17:12 raspberrypi dhcpcd[531]: eth0: probing address 192.168.1.54/24
                            Nov 17 16:17:13 raspberrypi dhcpcd[531]: eth0: DHCPv6 REPLY: in stateless mode
                            Nov 17 16:17:14 raspberrypi systemd[1]: systemd-rfkill.service: Succeeded.
                            Nov 17 16:17:16 raspberrypi dhcpcd[531]: eth0: DHCPv6 REPLY: in stateless mode
                            Nov 17 16:17:17 raspberrypi dhcpcd[531]: eth0: leased 192.168.1.54 for 864000 seconds
                            Nov 17 16:17:17 raspberrypi dhcpcd[531]: eth0: adding route to 192.168.1.0/24
                            Nov 17 16:17:17 raspberrypi dhcpcd[531]: eth0: adding default route via 192.168.1.1
                            Nov 17 16:17:17 raspberrypi avahi-daemon[333]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.1.54.
                            Nov 17 16:17:17 raspberrypi avahi-daemon[333]: New relevant interface eth0.IPv4 for mDNS.
                            Nov 17 16:17:17 raspberrypi avahi-daemon[333]: Registering new address record for 192.168.1.54 on eth0.IPv4.
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.admin.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.discovery.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.info.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.mqtt.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.web.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.vis.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.backitup.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.fritzbox.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.fritzdect.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.history.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.shelly.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.sonoff.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.javascript.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.onvif.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.sql.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.parser.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.vis-weather.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.dwd.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.vis-bars.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.vis-history.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.vis-keyboard.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.proxy.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.openweathermap.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.vis-timeandweather.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.scenes.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.daswetter.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.weatherunderground.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.pollenflug.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.mobile.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.vis-jqui-mfd.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.simple-api.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.worx.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.yahka.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.ical.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.vis-hqwidgets.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.vis-plumb.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.vis-materialdesign.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.landroid.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.telegram.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.text2command.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.hmip.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.hm-rpc.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.hm-rega.0" for host "raspberrypi"
                            Nov 17 16:17:17 raspberrypi bash[533]: host.raspberrypi check instance "system.adapter.hm-rpc.1" for host "raspberrypi"
                            Nov 17 16:17:24 raspberrypi dhcpcd[531]: eth0: DHCPv6 REPLY: in stateless mode
                            Nov 17 16:17:33 raspberrypi systemd[1]: systemd-fsckd.service: Succeeded.
                            Nov 17 16:46:08 raspberrypi systemd-timesyncd[288]: Synchronized to time server for the first time [2a01:4f8:211:2093::1]:123 (2.debian.pool.ntp.org).
                            Nov 17 16:46:13 raspberrypi dhcpcd[531]: eth0: DHCPv6 REPLY: in stateless mode
                            Nov 17 16:46:13 raspberrypi systemd[1]: systemd-hostnamed.service: Succeeded.
                            Nov 17 16:46:25 raspberrypi bash[533]: Send diag info: {"uuid":"856a113a-5105-9c48-b6cb-de7489b7d58a","language":"de","country":"Germany","hosts":[{"version":"2.1.0","platform":"Javascript/Node.js","type":"linux"}],"node":"v10.17.0","arch":"arm","adapters":{"admin":{"version":"3.6.12","platform":"Javascript/Node.js"},"discovery":{"version":"2.0.0","platform":"Javascript/Node.js"},"info":{"version":"1.5.7","platform":"Javascript/Node.js"},"mqtt":{"version":"2.1.1","platform":"Javascript/Node.js"},"web":{"version":"2.4.10","platform":"Javascript/Node.js"},"vis":{"version":"1.2.2","platform":"Javascript/Node.js"},"cloud":{"version":"2.8.0","platform":"Javascript/Node.js"},"backitup":{"version":"1.2.2","platform":"Javascript/Node.js"},"alexa2":{"version":"2.6.4","platform":"Javascript/Node.js"},"fritzbox":{"version":"0.2.1","platform":"Javascript/Node.js"},"fritzdect":{"version":"0.2.4","platform":"Javascript/Node.js"},"history":{"version":"1.8.7","platform":"Javascript/Node.js"},"js2fs":{"version":"0.1.5","platform":"Javascript/Node.js"},"shelly":{"version":"3.1.1","platform":"Javascript/Node.js"},"sonoff":{"version":"2.3.2","platform":"Javascript/Node.js"},"javascript":{"version":"4.3.3","platform":"Javascript/Node.js"},"onvif":{"version":"0.0.2","platform":"Javascript/Node.js"},"sql":{"version":"1.9.5","platform":"Javascript/Node.js"},"parser":{"version":"1.0.7","platform":"Javascript/Node.js"},"vis-weather":{"version":"2.4.0","platform":"Javascript/Node.js"},"yr":{"version":"2.0.3","platform":"Javascript/Node.js"},"dwd":{"version":"2.4.3","platform":"javascript/Node.js"},"daswetter":{"version":"2.8.1","platform":"Javascript/Node.js"},"iqontrol":{"version":"0.2.14","platform":"Javascript/Node.js"},"vis-bars":{"version":"0.1.4","platform":"Javascript/Node.js"},"vis-history":{"version":"1.0.0","platform":"Javascript/Node.js"},"vis-keyboard":{"version":"0.0.2","platform":"Javascript/Node.js"},"proxy":{"version":"1.1.1","platform":"Javascript/Node.js"},"openweathermap":{"version":"0.1.0","platform":"Javascript/Node.js"},"vis-timeandweather":{"version":"1.1.7","platform":"Javascript/Node.js"},"scenes":{"version":"1.1.0","platform":"Javascript/Node.js"},"weatherunderground":{"version":"3.1.6","platform":"Javascript/Node.js"},"pollenflug":{"version":"1.0.4","platform":"Javascript/Node.js"},"mobile":{"version":"0.5.0","platform":"javascript/Node.js"},"vis-jqui-mfd":{"version":"1.0.12","platform":"Javascript/Node.js"},"simple-api":{"version":"2.3.2","platform":"Javascript/Node.js"},"worx":{"version":"0.4.0","platform":"Javascript/Node.js"},"yahka":{"version":"0.9.2","pla:
                            Nov 17 16:46:25 raspberrypi bash[533]: Send diag info: {"uuid":"856a113a-5105-9c48-b6cb-de7489b7d58a","language":"de","country":"Germany","hosts":[{"version":"2.1.0","platform":"Javascript/Node.js","type":"linux"}],"node":"v10.17.0","arch":"arm","adapters":{"admin":{"version":"3.6.12","platform":"Javascript/Node.js"},"discovery":{"version":"2.0.0","platform":"Javascript/Node.js"},"info":{"version":"1.5.7","platform":"Javascript/Node.js"},"mqtt":{"version":"2.1.1","platform":"Javascript/Node.js"},"web":{"version":"2.4.10","platform":"Javascript/Node.js"},"vis":{"version":"1.2.2","platform":"Javascript/Node.js"},"cloud":{"version":"2.8.0","platform":"Javascript/Node.js"},"backitup":{"version":"1.2.2","platform":"Javascript/Node.js"},"alexa2":{"version":"2.6.4","platform":"Javascript/Node.js"},"fritzbox":{"version":"0.2.1","platform":"Javascript/Node.js"},"fritzdect":{"version":"0.2.4","platform":"Javascript/Node.js"},"history":{"version":"1.8.7","platform":"Javascript/Node.js"},"js2fs":{"version":"0.1.5","platform":"Javascript/Node.js"},"shelly":{"version":"3.1.1","platform":"Javascript/Node.js"},"sonoff":{"version":"2.3.2","platform":"Javascript/Node.js"},"javascript":{"version":"4.3.3","platform":"Javascript/Node.js"},"onvif":{"version":"0.0.2","platform":"Javascript/Node.js"},"sql":{"version":"1.9.5","platform":"Javascript/Node.js"},"parser":{"version":"1.0.7","platform":"Javascript/Node.js"},"vis-weather":{"version":"2.4.0","platform":"Javascript/Node.js"},"yr":{"version":"2.0.3","platform":"Javascript/Node.js"},"dwd":{"version":"2.4.3","platform":"javascript/Node.js"},"daswetter":{"version":"2.8.1","platform":"Javascript/Node.js"},"iqontrol":{"version":"0.2.14","platform":"Javascript/Node.js"},"vis-bars":{"version":"0.1.4","platform":"Javascript/Node.js"},"vis-history":{"version":"1.0.0","platform":"Javascript/Node.js"},"vis-keyboard":{"version":"0.0.2","platform":"Javascript/Node.js"},"proxy":{"version":"1.1.1","platform":"Javascript/Node.js"},"openweathermap":{"version":"0.1.0","platform":"Javascript/Node.js"},"vis-timeandweather":{"version":"1.1.7","platform":"Javascript/Node.js"},"scenes":{"version":"1.1.0","platform":"Javascript/Node.js"},"weatherunderground":{"version":"3.1.6","platform":"Javascript/Node.js"},"pollenflug":{"version":"1.0.4","platform":"Javascript/Node.js"},"mobile":{"version":"0.5.0","platform":"javascript/Node.js"},"vis-jqui-mfd":{"version":"1.0.12","platform":"Javascript/Node.js"},"simple-api":{"version":"2.3.2","platform":"Javascript/Node.js"},"worx":{"version":"0.4.0","platform":"Javascript/Node.js"},"yahka":{"version":"0.9.2","platform":"Javascript/Node.js"},"ical":{"version":"1.7.0","platform":"Javascript/Node.js"},"icons-icons8":{"version":"0.0.1","platform":"javascript/Node.js"},"vis-hqwidgets":{"version":"1.1.3","platform":"Javascript/Node.js"},"vis-plumb":{"version":"1.0.2","platform":"Javascript/Node.js"},"vis-materialdesign":{"version":"0.1.5","platform":"Javascript/Node.js"},"landroid":{"version":"1.0.3","platform":"Javascript/Node.js"},"telegram":{"version":"1.4.3","platform":"Javascript/Node.js"},"text2command":{"version":"1.3.1","platform":"Javascript/Node.js"},"hmip":{"version":"0.0.11","platform":"Javascript/Node.js"},"hm-rpc":{"version":"1.11.0","platform":"Javascript/Node.js"},"hm-rega":{"version":"2.4.12","platform":"Javascript/Node.js"},"flot":{"version":"1.9.2","platform":"javascript/Node.js"}},"statesType":"file","objectsType":"file","model":"ARMv7 Processor rev 4 (v7l)","cpus":4,"mem":971063296,"ostype":"Linux","city":"Windeck","vis":742}
                            Nov 17 16:46:42 raspberrypi dhcpcd[531]: eth0: DHCPv6 REPLY: in stateless mode
                            Nov 17 16:47:01 raspberrypi bash[533]: Sun, 17 Nov 2019 15:47:01 GMT EventedHTTPServer Server listening on port 33513
                            Nov 17 16:47:01 raspberrypi bash[533]: Sun, 17 Nov 2019 15:47:01 GMT EventedHTTPServer Server listening on port 37451
                            Nov 17 16:47:05 raspberrypi bash[533]: Sun, 17 Nov 2019 15:47:05 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
                            Nov 17 16:47:05 raspberrypi bash[533]: In the future, you will have to enable it yourself.
                            Nov 17 16:47:05 raspberrypi bash[533]: See https://github.com/yagop/node-telegram-bot-api/issues/319. at internal/modules/cjs/loader.js:778:30
                            Nov 17 16:47:27 raspberrypi bash[533]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
                            Nov 17 16:47:43 raspberrypi dhcpcd[531]: eth0: DHCPv6 REPLY: in stateless mode
                            Nov 17 16:49:49 raspberrypi dhcpcd[531]: eth0: DHCPv6 REPLY: in stateless mode
                            Nov 17 16:54:11 raspberrypi dhcpcd[531]: eth0: DHCPv6 REPLY: in stateless mode
                            Nov 17 17:00:53 raspberrypi systemd[1]: Starting Cleanup of Temporary Directories...
                            Nov 17 17:00:54 raspberrypi systemd[1]: systemd-tmpfiles-clean.service: Succeeded.
                            Nov 17 17:00:54 raspberrypi systemd[1]: Started Cleanup of Temporary Directories.
                            Nov 17 17:02:22 raspberrypi systemd[1]: Created slice User Slice of UID 1000.
                            Nov 17 17:02:22 raspberrypi systemd[1]: Starting User Runtime Directory /run/user/1000...
                            Nov 17 17:02:22 raspberrypi systemd[1]: Started User Runtime Directory /run/user/1000.
                            Nov 17 17:02:22 raspberrypi systemd[1]: Starting User Manager for UID 1000...
                            Nov 17 17:02:23 raspberrypi systemd[20168]: Listening on GnuPG network certificate management daemon.
                            Nov 17 17:02:23 raspberrypi systemd[20168]: Reached target Timers.
                            Nov 17 17:02:23 raspberrypi systemd[20168]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
                            Nov 17 17:02:23 raspberrypi systemd[20168]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
                            Nov 17 17:02:23 raspberrypi systemd[20168]: Listening on GnuPG cryptographic agent and passphrase cache.
                            Nov 17 17:02:23 raspberrypi systemd[20168]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
                            Nov 17 17:02:23 raspberrypi systemd[20168]: Reached target Sockets.
                            Nov 17 17:02:23 raspberrypi systemd[20168]: Reached target Paths.
                            Nov 17 17:02:23 raspberrypi systemd[20168]: Reached target Basic System.
                            Nov 17 17:02:23 raspberrypi systemd[1]: Started User Manager for UID 1000.
                            Nov 17 17:02:23 raspberrypi systemd[1]: Started Session c1 of user pi.
                            Nov 17 17:02:23 raspberrypi systemd[20168]: Reached target Default.
                            Nov 17 17:02:23 raspberrypi systemd[20168]: Startup finished in 267ms.
                            Nov 17 17:02:44 raspberrypi dhcpcd[531]: eth0: DHCPv6 REPLY: in stateless mode
                            Nov 17 17:03:05 raspberrypi bash[533]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
                            @RalfEngelberth also wenn ich das richtig deute bin ich dabei das deine sd Karte blockiert hat und danach der Raspi hängengeblieben ist und so ... ich würde mit die ansehen und lieber ersetzen. Schau und Google mal vor allem bei den dingen 16:17 die vom Kernel kommen und nach dem „tainted“ ... Begriffe dabei waren mmc und hung und freeze ...
                            • J JoergK
                              Hi zusammen,
                              das Problem mit dem abgestürztem Pi hatte ich in letzter Zeit auch ab und zu.
                              Aufgetreten ist dies immer bei einem Update eines Adapters.
                              So wahnsinnig viele Adapter habe ich nicht installiert aber die Auslagerungsdatei war immer recht voll.
                              Standardmäßig ist die Auslagerungsdatei bei 100MB. Diesen Wert habe ich auf 500MB erhöht. Seit dem läuft das System stabil und ohne Abstütze. Auch einige Updates hatte ich schon wieder durchgeführt.
                              Jetzt ist die Auslagerungsdatei bei mir im Normalbetrieb mit 140MB gefüllt.
                              Wie es geht, habe ich hier gelesen.
                              Vielleicht hilft es euch auch weiter?
                              Jörg
                              @JoergK du meinst „swap“? Ich sage es mal so (siehe auch ein anderer Erfahrungsbericht thread von heute) wenn dein System überhaupt swapper dann nutzt du Zuviel RAM. Vor allem auf einem sd Karten System ist swapping tödlich für die sd Karte!!
                              Auf solchen system ist meiner Meinung nach das Ziel ist es an sich das man NIE swapping braucht! Es ist der Notfall für kurze Spitzen.
                              Also rausfinden was Zuviel ist und Hardware für die Anforderungen wählen. Ggf Compact Modus im neuen Controller 2 ansehen.
                              R J 2 Antworten Letzte Antwort
                                RalfEngelberth
                                Danke für die Info´s
                                Ich werde mir das mit der Auslagerungsdatei mal ansehen und auch die SD-Karte mal ersetzen.
                                Ich melde mich dann wieder.
                                • apollon77A apollon77
                                  RalfEngelberth
                                  @apollon77 sagte in IoBroker läuft nicht stabiel, stürzt ab:
                                  Wo finde ich denn diesen Compact Modus
                                    JoergK
                                    @apollon77 OK bei der Dauerlast bin ich sofort bei dir. Das kann dann echt blöd werden.
                                    Zur Fehlersuche sollte es gehen.
                                    Auf Dauer hilft dann wohl nur ein Pi4 mit 2 oder 4GB.
                                    Da muss ich nochmal in mich gehen! 🤕
                                    R 1 Antwort Letzte Antwort
                                    • J JoergK
                                      RalfEngelberth
                                      schrieb am zuletzt editiert von RalfEngelberth
                                      @JoergK sagte in IoBroker läuft nicht stabiel, stürzt ab:
                                      Was wäre denn zu empfehlen?
                                      Besser umsteigen auf einen Raspberry 4 mit 4GB oder welche System wären besser?
                                      jmeister79J 1 Antwort Letzte Antwort
                                      • R RalfEngelberth
                                        jmeister79J Offline
                                        jmeister79J Offline
                                        jmeister79
                                        @RalfEngelberth ich kauf morgen nen raspi 4.
                                        • jmeister79J jmeister79
                                          RalfEngelberth
                                          @jmeister79 sagte in IoBroker läuft nicht stabiel, stürzt ab:
                                          Habe ich heute auch. raspi 4 4 GB
                                          Werde von meine Erfahrungen damit berichten.
                                          Hoffe, dass das Problem mit dem RAM damit gelöst ist.
