  4. [gelöst]Broker dreht durch
Geplant Angeheftet Gesperrt Verschoben Gelöst ioBroker Allgemein
loxone adapter rot
2 Beiträge 1 Kommentatoren 399 Aufrufe
  • L Offline
    Lollo79
    schrieb am zuletzt editiert von Lollo79
    loxone.0	2019-10-18 20:14:20.953	error	Unsupported control type ValueSelector: ReferenceError: loadValueSelectorControl is not defined
    loxone.0	2019-10-18 20:14:20.950	error	Unsupported control type Daytimer: ReferenceError: loadDaytimerControl is not defined
    loxone.0	2019-10-18 20:14:20.950	error	Unsupported control type LeftRightAnalog: ReferenceError: loadLeftRightAnalogControl is not defined
    loxone.0	2019-10-18 20:14:20.949	error	Unsupported control type LeftRightAnalog: ReferenceError: loadLeftRightAnalogControl is not defined
    loxone.0	2019-10-18 20:14:20.945	error	Unsupported control type IRoomController: ReferenceError: loadIRoomControllerControl is not defined
    loxone.0	2019-10-18 20:14:20.939	error	Unsupported control type IRoomController: ReferenceError: loadIRoomControllerControl is not defined
    loxone.0	2019-10-18 20:14:20.935	error	Unsupported control type IRoomController: ReferenceError: loadIRoomControllerControl is not defined
    loxone.0	2019-10-18 20:14:20.932	error	Unsupported control type UpDownAnalog: ReferenceError: loadUpDownAnalogControl is not defined
    loxone.0	2019-10-18 20:14:20.930	error	Unsupported control type UpDownAnalog: ReferenceError: loadUpDownAnalogControl is not defined
    loxone.0	2019-10-18 20:14:20.927	error	Unsupported control type Radio: ReferenceError: loadRadioControl is not defined
    loxone.0	2019-10-18 20:14:20.924	error	Unsupported control type IRoomController: ReferenceError: loadIRoomControllerControl is not defined
    loxone.0	2019-10-18 20:14:20.922	error	Unsupported control type IRoomController: ReferenceError: loadIRoomControllerControl is not defined
    loxone.0	2019-10-18 20:14:20.919	error	Unsupported control type IRoomController: ReferenceError: loadIRoomControllerControl is not defined
    loxone.0	2019-10-18 20:14:20.898	error	Unsupported control type IRoomController: ReferenceError: loadIRoomControllerControl is not defined
    loxone.0	2019-10-18 20:14:20.890	error	Unsupported control type TextState: ReferenceError: loadTextStateControl is not defined
    influxdb.0	2019-10-18 20:14:21.009	info	enabled logging of Regensensor, Alias=true
    influxdb.0	2019-10-18 20:14:21.006	info	enabled logging of Regen, Alias=true
    loxone.0	2019-10-18 20:14:20.874	info	got structure file; last modified on 2019-10-18 19:36:40
    loxone.0	2019-10-18 20:14:20.422	info	Miniserver connected
    loxone.0	2019-10-18 20:14:19.616	info	starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.loxone, node: v10.16.3
    host.IoT-Server	2019-10-18 20:14:18.804	info	instance system.adapter.loxone.0 started with pid 5403
    influxdb.0	2019-10-18 20:13:48.789	info	enabled logging of Wohnzimmerfenster AUF, Alias=true
    host.IoT-Server	2019-10-18 20:13:48.769	info	Restart adapter system.adapter.loxone.0 because enabled
    host.IoT-Server	2019-10-18 20:13:48.769	error	instance system.adapter.loxone.0 terminated with code 6 (uncaught exception)
    Caught	2019-10-18 20:13:48.769	error	by controller[9]: at Zlib.processCallback (zlib.js:548:8)
    Caught	2019-10-18 20:13:48.768	error	by controller[9]: at DeflateRaw.afterTransform (_stream_transform.js:94:3)
    Caught	2019-10-18 20:13:48.768	error	by controller[9]: at onwrite (_stream_writable.js:476:7)
    Caught	2019-10-18 20:13:48.768	error	by controller[9]: at afterWrite (_stream_writable.js:485:3)
    Caught	2019-10-18 20:13:48.768	error	by controller[9]: at /opt/iobroker/node_modules/ws/lib/PerMessageDeflate.js:313:5
    Caught	2019-10-18 20:13:48.768	error	by controller[9]: at /opt/iobroker/node_modules/ws/lib/Sender.js:127:7
    Caught	2019-10-18 20:13:48.768	error	by controller[9]: at /opt/iobroker/node_modules/ws/lib/Sender.js:270:10
    Caught	2019-10-18 20:13:48.768	error	by controller[9]: at Sender.flush (/opt/iobroker/node_modules/ws/lib/Sender.js:268:3)
    Caught	2019-10-18 20:13:48.768	error	by controller[9]: at /opt/iobroker/node_modules/ws/lib/Sender.js:120:10
    Caught	2019-10-18 20:13:48.768	error	by controller[9]: at Sender.applyExtensions (/opt/iobroker/node_modules/ws/lib/Sender.js:287:5)
    Hallo Leute seit gestern Abend dreht der IOBroker bzw. der Loxone Adapter am Rad alle 3 min Verbindungsabbrüche und diese Logmeldungen.
    das ganze hat jetzt gut ein halbes Jahr wunderbar funktioniert 😵
    • L Offline
      Lollo79
      Ok hat sich erledigt war evtl. der Linkeddevices Adapter den ich mir mal ansehen wollte und ein paar Testverbindungen angelegt hatte, nach entfernen der Testverbindungen und Deaktivierung des Adapters keine Auffälligkeiten mehr.
