  4. SQL-Adpter streikt nach update
sql adapternpmupdatenpm versionnodejs 10nodenode update
4 Beiträge 2 Kommentatoren 794 Aufrufe 1 Beobachtet
    swordfisch
    schrieb am zuletzt editiert von swordfisch
    Hi
    mein SQL Adapter streikt nach dem update auf Nodejs 10
    host.iOBroker	2019-10-08 16:22:57.745	error	instance system.adapter.sql.0 terminated with code 1 ()
    Caught	2019-10-08 16:22:57.745	error	by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    Caught	2019-10-08 16:22:57.745	error	by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    Caught	2019-10-08 16:22:57.745	error	by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    Caught	2019-10-08 16:22:57.745	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/mmmagic/lib/index.js:1:13)
    Caught	2019-10-08 16:22:57.745	error	by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
    Caught	2019-10-08 16:22:57.745	error	by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
    Caught	2019-10-08 16:22:57.745	error	by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    Caught	2019-10-08 16:22:57.745	error	by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    Caught	2019-10-08 16:22:57.745	error	by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
    Caught	2019-10-08 16:22:57.745	error	by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    Caught	2019-10-08 16:22:57.744	error	by controller[0]: NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
    Caught	2019-10-08 16:22:57.744	error	by controller[0]: NODE_MODULE_VERSION 57. This version of Node.js requires
    Caught	2019-10-08 16:22:57.744	error	by controller[0]: was compiled against a different Node.js version using
    Caught	2019-10-08 16:22:57.744	error	by controller[0]: Error: The module '/opt/iobroker/node_modules/mmmagic/build/Release/magic.node'
    Caught	2019-10-08 16:22:57.744	error	by controller[0]: ^
    Caught	2019-10-08 16:22:57.744	error	by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
    Caught	2019-10-08 16:22:57.744	error	by controller[0]: internal/modules/cjs/loader.js:807
    host.iOBroker	2019-10-08 16:22:57.458	info	instance system.adapter.sql.0 started with pid 2363
    hoffentlich kann mir einer sagen was da falsch läuft
    Danke und grüße
    swordfisch
    • S swordfisch
      Hi
      Danke und grüße
      swordfisch
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      @swordfisch
      Nach dem Update durchführen :
      npm rebuild
        swordfisch
        @Glasfaser sagte in SQL-Adpter streikt nach update:
        npm rebuild
        das hab ich gemacht irgendwie habe ich das Problem
        das
        node -v
        v8.9.4
        ausspuckt und
        nodejs -v
        v10.16.3
        wie kann ich das beheben??
        mfg swordfisch
        • S swordfisch
          npm rebuild
          das
          node -v
          v8.9.4
          ausspuckt und
          nodejs -v
          v10.16.3
          mfg swordfisch
          swordfisch
          @swordfisch
          geholfen hat bei mir
          https://forum.iobroker.net/post/292949 und dann das reinstall.sh ausm iobroker ordner
