  4. Fehler bei Update SQL-Adapter
1 Beiträge 1 Kommentatoren 554 Aufrufe
  • eric2905E Offline
    eric2905E Offline
    eric2905
    Hallo bluefox,
    bim Update bekomme ich beim SQL-Adapter folgende Fehler aufgelistet:
    host.cubietruck Adapter "system.adapter.sql.1" is stopped.
    npm install iobroker.sql --production --prefix "/opt/iobroker" (System call)
    node-pre-gyp ERR! Tried to download: https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v3.1.4/node-v14-linux-arm.tar.gz
    node-pre-gyp ERR! Pre-built binaries not found for sqlite3@3.1.4 and node@0.12.6 (node-v14 ABI) (falling back to source compile with node-gyp)
    ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginOpen(node_sqlite3::Database::Baton*)’:
    ../src/database.cc:143:9: warning: unused variable ‘status’ [-Wunused-variable]
    ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginClose(node_sqlite3::Database::Baton*)’:
    ../src/database.cc:227:9: warning: unused variable ‘status’ [-Wunused-variable]
    ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginExec(node_sqlite3::Database::Baton*)’:
    ../src/database.cc:505:9: warning: unused variable ‘status’ [-Wunused-variable]
    ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginLoadExtension(node_sqlite3::Database::Baton*)’:
    ../src/database.cc:605:9: warning: unused variable ‘status’ [-Wunused-variable]
    ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginPrepare(node_sqlite3::Database::Baton*)’:
    ../src/statement.cc:118:9: warning: unused variable ‘status’ [-Wunused-variable]
    ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginBind(node_sqlite3::Statement::Baton*)’:
    ../src/statement.cc:322:5: warning: unused variable ‘status’ [-Wunused-variable]
    ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginGet(node_sqlite3::Statement::Baton*)’:
    ../src/statement.cc:370:5: warning: unused variable ‘status’ [-Wunused-variable]
    ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginRun(node_sqlite3::Statement::Baton*)’:
    ../src/statement.cc:438:5: warning: unused variable ‘status’ [-Wunused-variable]
    ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginAll(node_sqlite3::Statement::Baton*)’:
    ../src/statement.cc:504:5: warning: unused variable ‘status’ [-Wunused-variable]
    ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginEach(node_sqlite3::Statement::Baton*)’:
    ../src/statement.cc:601:5: warning: unused variable ‘status’ [-Wunused-variable]
    ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginReset(node_sqlite3::Statement::Baton*)’:
    ../src/statement.cc:724:5: warning: unused variable ‘status’ [-Wunused-variable]
    host.cubietruck Adapter "system.adapter.sql.1" is started
    npm install --production --prefix "/opt/iobroker/node_modules/iobroker.sql" (System call)
    Update "system.adapter.sql.1"
    got /opt/iobroker/node_modules/iobroker.sql/admin
    upload [2] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/storage.html storage.html text/html
    upload [1] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/sql.png sql.png image/png
    upload [0] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/index.html index.html text/html
    Adapter "sql" updated
    Ich denke, diese beiden Zeilen - vor allen Dingen die letzte ("Pre-built binaries not found for sqlite") - beinhaltet die Ursache, oder?
    Der SQL-Adapter (ich verwende den mySQL) läuft aber im Anschluss.
    Gruß,
    Eric
