  4. Nach Update ADMIN auf 3.6-5 Probleme mit Alexa.20
fehleradapateradmin
6 Beiträge 3 Kommentatoren 842 Aufrufe 4 Beobachtet
  • sissiwupS Offline
    sissiwupS Offline
    sissiwup
    nach Update vom Admin-Adapter kommt folgende Fehlermeldung:
    host.zotac	2019-09-18 22:42:56.772	info	Restart adapter system.adapter.alexa2.0 because enabled
    host.zotac	2019-09-18 22:42:56.772	error	instance system.adapter.alexa2.0 terminated with code 0 (OK)
    host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[2]: at process._tickCallback (internal/process/next_tick.js:63:19)
    host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[2]: at endReadableNT (_stream_readable.js:1125:12)
    host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[2]: at IncomingMessage.emit (events.js:194:15)
    host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[2]: at IncomingMessage.res.on (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-remote2/alexa-remote.js:752:58)
    host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[2]: at alexa.querySmarthomeDevices (/opt/iobroker/node_modules/iobroker.alexa2/main.js:607:13)
    host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[2]: at updateSmarthomeDeviceStates (/opt/iobroker/node_modules/iobroker.alexa2/main.js:792:46)
    host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[2]: at handleObject (/opt/iobroker/node_modules/iobroker.alexa2/main.js:748:37)
    host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[2]: 2019-09-18 22:42:56.748 - alexa2.0 TypeError: native.valueMap.indexOf is not a function
    host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[1]: 2019-09-18 22:42:56.748 - alexa2.0 uncaught exception: native.valueMap.indexOf is not a function
    host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:63:19)
    host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[0]: at endReadableNT (_stream_readable.js:1125:12)
    host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[0]: at IncomingMessage.emit (events.js:194:15)
    host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[0]: at IncomingMessage.res.on (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-remote2/alexa-remote.js:752:58)
    host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[0]: at alexa.querySmarthomeDevices (/opt/iobroker/node_modules/iobroker.alexa2/main.js:607:13)
    host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[0]: at updateSmarthomeDeviceStates (/opt/iobroker/node_modules/iobroker.alexa2/main.js:792:46)
    host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[0]: at handleObject (/opt/iobroker/node_modules/iobroker.alexa2/main.js:748:37)
    host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[0]: TypeError: native.valueMap.indexOf is not a function
    alexa2.0	2019-09-18 22:42:56.753	error	TypeError: native.valueMap.indexOf is not a function at handleObject (/opt/iobroker/node_modules/iobroker.alexa2/main.js:748:37) at updateSmarthomeDeviceStates (/opt/iobroker/node_modules/iobr
    alexa2.0	2019-09-18 22:42:56.753	error	uncaught exception: native.valueMap.indexOf is not a function
    alexa2.0	2019-09-18 22:42:56.753	warn	Exception: TypeError: native.valueMap.indexOf is not a function
    alexa2.0	2019-09-18 22:42:46.802	info	Alexa-Push-Connection established. Disable Polling
    alexa2.0	2019-09-18 22:42:41.231	info	starting. Version 2.6.4 in /opt/iobroker/node_modules/iobroker.alexa2, node: v10.15.3
    MfG
    Sissi
    sissiwupS 1 Antwort Letzte Antwort
    • sissiwupS sissiwup
      sissiwupS Offline
      sissiwupS Offline
      sissiwup
      @sissiwup
      Hab den fix von dklinger (Thx) eingesetzt. Jetzt läuft es wieder.
      GIT
      Damit geht es wieder. Hoffe das ist in nächsten Alexa-Adapter enthalten.
      Anzupassen in:
      MfG
      Sissi
        @sissiwup
        GIT
        Anzupassen in:
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        @sissiwup sagte in Nach Update ADMIN auf 3.6-5 Probleme mit Alexa.20:
        @sissiwup
        Perfekt!
        Wenn ein Thema gelöst wurde bitte den Beitrag der die Lösung beinhaltet als gelöst markieren.
        -> 3 Punkte Menü rechts unten am Beitrag -> Mark this post as the correct answer
        ° Fixer ---> iob fix
          Springreiter
          Bei mir weiterhin die selbe Fehlermeldung-trotz Aänderung
          • S Springreiter
            Springreiter
            2019-11-05 11:32:37.441 - error: host.ioBroker-RasPi Caught by controller[0]: TypeError: native.valueMap.indexOf is not a function
            2019-11-05 11:32:37.443 - error: host.ioBroker-RasPi Caught by controller[0]: at handleObject (/opt/iobroker/node_modules/iobroker.alexa2/main.js:748:37)
            2019-11-05 11:32:37.443 - error: host.ioBroker-RasPi Caught by controller[0]: at updateSmarthomeDeviceStates (/opt/iobroker/node_modules/iobroker.alexa2/main.js:792:46)
            2019-11-05 11:32:37.443 - error: host.ioBroker-RasPi Caught by controller[0]: at alexa.querySmarthomeDevices (/opt/iobroker/node_modules/iobroker.alexa2/main.js:607:13)
            2019-11-05 11:32:37.444 - error: host.ioBroker-RasPi Caught by controller[0]: at IncomingMessage.res.on (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-remote2/alexa-remote.js:752:58)
            2019-11-05 11:32:37.444 - error: host.ioBroker-RasPi Caught by controller[0]: at emitNone (events.js:111:20)
            2019-11-05 11:32:37.444 - error: host.ioBroker-RasPi Caught by controller[0]: at IncomingMessage.emit (events.js:208:7)
            2019-11-05 11:32:37.444 - error: host.ioBroker-RasPi Caught by controller[0]: at endReadableNT (_stream_readable.js:1064:12)
            2019-11-05 11:32:37.445 - error: host.ioBroker-RasPi Caught by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:139:11)
            2019-11-05 11:32:37.445 - error: host.ioBroker-RasPi Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:181:9)
            • S Springreiter
              Springreiter
              Nehme alles zurück- habe es hinbekommen - Danke
