  4. Yahka Fehlermeldung
Yahka Fehlermeldung
error im log
1 Beiträge 1 Kommentatoren 242 Aufrufe 1 Beobachtet
  • KusselinK Offline
    KusselinK Offline
    Kusselin
    schrieb am zuletzt editiert von Kusselin
    Hallo, ich habe auf einmal keien Verbindung mehr...kommt diese meldung...könnt ihr mir sagen was da los ist?
    Danke und Gruss
    yahka.0	2019-09-09 21:15:27.676	error	at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
    yahka.0	2019-09-09 21:15:27.676	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
    yahka.0	2019-09-09 21:15:27.676	error	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    yahka.0	2019-09-09 21:15:27.676	error	at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    yahka.0	2019-09-09 21:15:27.676	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    yahka.0	2019-09-09 21:15:27.676	error	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    yahka.0	2019-09-09 21:15:27.676	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
    yahka.0	2019-09-09 21:15:27.676	error	at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
    yahka.0	2019-09-09 21:15:27.676	error	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.yahka/main.js:2282:21)
    yahka.0	2019-09-09 21:15:27.676	error	at convertStateValueToNumber (/opt/iobroker/node_modules/iobroker.yahka/main.js:2331:41)
    yahka.0	2019-09-09 21:15:27.676	error	TypeError: Cannot read property 'val' of null
    yahka.0	2019-09-09 21:15:27.674	error	uncaught exception: Cannot read property 'val' of null
    host.raspberrypi	2019-09-09 22:17:08.004	info	Restart adapter system.adapter.yahka.0 because enabled
    host.raspberrypi	2019-09-09 22:17:08.004	error	instance system.adapter.yahka.0 terminated with code 6 (uncaught exception)
    host.raspberrypi	2019-09-09 22:17:08.003	error	Caught by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
    host.raspberrypi	2019-09-09 22:17:08.003	error	Caught by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
    host.raspberrypi	2019-09-09 22:17:08.003	error	Caught by controller[0]: at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    host.raspberrypi	2019-09-09 22:17:08.003	error	Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    host.raspberrypi	2019-09-09 22:17:08.003	error	Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    host.raspberrypi	2019-09-09 22:17:08.002	error	Caught by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    host.raspberrypi	2019-09-09 22:17:08.002	error	Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
    host.raspberrypi	2019-09-09 22:17:08.002	error	Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
    host.raspberrypi	2019-09-09 22:17:08.002	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.yahka/main.js:2282:21)
    host.raspberrypi	2019-09-09 22:17:08.002	error	Caught by controller[0]: at convertStateValueToNumber (/opt/iobroker/node_modules/iobroker.yahka/main.js:2331:41)
    host.raspberrypi	2019-09-09 22:17:08.001	error	Caught by controller[0]: TypeError: Cannot read property 'val' of null
    host.raspberrypi	2019-09-09 22:17:08.000	error	Caught by controller[0]: Mon, 09 Sep 2019 20:17:06 GMT EventedHTTPServer Server listening on port 38545
    EDIT: mit Aktualisireung von npm läufts wieder!!!
