  4. Iobroker startet nicht mehr
7 Beiträge 2 Kommentatoren 988 Aufrufe
  • sissiwupS Offline
    sissiwupS Offline
    sissiwup
    Starting iobroker controller daemon...
    /opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136
                throw new Error(msg.error);
    Error: Error: Invalid syslog protocol: UDP
        at new exports.Syslog (/opt/iobroker/node_modules/winston-syslog/lib/winston-syslog.js:70:11)
        at logger (/opt/iobroker/node_modules/iobroker.js-controller/lib/logger.js:99:45)
        at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/controller.js:67:51)
        at Module._compile (module.js:409:26)
        at Object.Module._extensions..js (module.js:416:10)
        at Module.load (module.js:343:32)
        at Function.Module._load (module.js:300:12)
        at Module.require (module.js:353:17)
        at require (internal/module.js:12:17)
        at init (/opt/iobroker/node_modules/daemonize2/lib/wrapper.js:105:17)
        at ChildProcess. <anonymous>(/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136:19)
        at emitTwo (events.js:87:13)
        at ChildProcess.emit (events.js:172:7)
        at handleMessage (internal/child_process.js:695:10)
        at Pipe.channel.onread (internal/child_process.js:440:11)</anonymous></anonymous>
    MfG
    Sissi
    • BluefoxB Offline
      BluefoxB Offline
      @sissiwup:
      Wie sieht dein /opt/iobroker/iobroker-data/iobroker.json aus?
      • sissiwupS Offline
        sissiwupS Offline
        sissiwup
          "network": {
            "IPv4": true,
            "IPv6": true,
            "bindAddress": null,
            "useSystemNpm": true
          "objects": {
            "type": "file",
            "typeComment": "Possible values: 'file' - [port 9001], redis - [port 6379], couch - [port 5984].",
            "host": "127.0.0.1",
            "port": 9001,
            "user": "",
            "pass": "",
            "noFileCache": false
          "states": {
            "type": "file",
            "typeComment": "Possible values: 'file' - [port 9000], 'redis' - [port 6379].",
            "port": 9000,
            "options": {
              "auth_pass": null,
              "retry_max_delay": 15000
          "log": {
            "level": "info",
            "maxDays": 30,
            "transport": {
              "file1": {
                "type": "file",
                "enabled": true,
                "filename": "log/iobroker",
                "fileext": ".log",
                "maxsize": null,
                "maxFiles": null
              "syslog": {
                       "type": "syslog",
                       "enabled": true,
                       "host": "192.168.1.14",
                       "port": "514",
                       "protocol":  "UDP",
                       "path": ""
          "dataDirComment": "Always relative to iobroker.js-controller/",
          "dataDir": "../../iobroker-data/"
        MfG
        Sissi
        • sissiwupS Offline
          sissiwupS Offline
          sissiwup
          soll das heissen, dass der Logger jetzt tut?
          Ich habe das loglevel bei yr.0 von info auf debug geändert. Danach ging nix mehr.
          Neustart iobroker. Fehler.
          MfG
          Sissi
          • BluefoxB Offline
            BluefoxB Offline
            @sissiwup:
            Neustart iobroker. Fehler. `
            Mach mal:
            "syslog": {
            "type": "syslog",
            "enabled": false,
            "port": "514",
            "protocol": "UDP",
            "path": ""
            • sissiwupS Offline
              sissiwupS Offline
              sissiwup
              lag wohl an den Versuchen den Logger zum laufen zu bekommen. Jetzt scheint er schon mehr zu tun.
              Hatte ja Zeile 10 auskommentiert und den winston Logger nachinstalliert.
              Habe die Module alle weggeworfen, danach ging es wieder.
              Danke.
              MfG
              Sissi
              • BluefoxB Offline
                BluefoxB Offline
                @sissiwup:
                Danke. `
                Schade… Ich dachte syslog geht schon. Dann muss man mehr untersuchen :?
