  4. Error bei History mit InfluxDB
1 Beiträge 1 Kommentatoren 886 Aufrufe
    Nachdem mir gestern ein netter Mensch geholfen hat die InfluxDB zu installieren, habe ich heute einige Datenpunkte begonnen in ioBroker mit der influxDB zu loggen.
    Jetzt bekomme ich folgende Fehlermeldungen:
    influxdb-0	2016-04-24 11:24:00	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
    influxdb-0	2016-04-24 11:23:00	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
    influxdb-0	2016-04-24 11:21:59	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
    influxdb-0	2016-04-24 11:20:59	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
    influxdb-0	2016-04-24 11:19:58	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
    influxdb-0	2016-04-24 11:18:57	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
    influxdb-0	2016-04-24 11:17:57	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
    influxdb-0	2016-04-24 11:16:56	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
    influxdb-0	2016-04-24 11:15:56	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
    influxdb-0	2016-04-24 11:14:55	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
    influxdb-0	2016-04-24 11:14:55	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.cpu.load5\" is type string, already exists as type float"}
    influxdb-0	2016-04-24 11:13:54	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
    influxdb-0	2016-04-24 11:12:57	error	Error: unsupported max iterator type: *influxql.stringInterruptIterator
    influxdb-0	2016-04-24 11:12:54	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.temperature.soc_temp\" is type string, already exists as type float"}
    influxdb-0	2016-04-24 11:12:54	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
    influxdb-0	2016-04-24 11:12:43	error	Error: unsupported max iterator type: *influxql.stringInterruptIterator
    influxdb-0	2016-04-24 11:12:12	error	Error: unsupported max iterator type: *influxql.stringInterruptIterator
    influxdb-0	2016-04-24 11:12:00	error	Error: unsupported mean iterator type: *influxql.stringInterruptIterator
    influxdb-0	2016-04-24 11:11:53	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
    influxdb-0	2016-04-24 11:10:53	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
    Rainer
    PS mir ist aufgefallen, dass Flot mehrere X-Achsen anlegt, kann man das synchronisieren?
