  2. Русский
  3. ioBroker
  4. Ошибка
  5. ioBroker ошибки
  6. Iobroker js-controller - ошибки
Geplant Angeheftet Gesperrt Verschoben ioBroker ошибки
27 Beiträge 13 Kommentatoren 13.3k Aufrufe
  • Z Offline
    Z Offline
    znammut
    Спасибо, заработало
      sukuy
      Кто подскажет адрес этого faааааааst-online.
      https://gclub.bbet88.com/
      • BluefoxB Offline
        BluefoxB Offline
        http://download.iobroker.net/sources-dist-latest.json
        • F Offline
          ford7
          Обновил js, сейчас не запускается брокер. Подскажите, как исправить?
          ! /opt/iobroker# sudo iobroker upgrade self
          ! Update js-controller from @1.4.2 to @1.5.1
          ! NPM version: 4.6.1
          ! npm install iobroker.js-controller@1.5.1 –unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
          ! ../src/diskusage_posix.cpp: In function ‘DiskUsage GetDiskUsage(const char*)’:
          ! ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_bsize’ [-Wmissing-field-initializers]
          ! struct statvfs info = {};
          ! ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_frsize’ [-Wmissing-field-initializers]
          ! ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_blocks’ [-Wmissing-field-initializers]
          ! ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_bfree’ [-Wmissing-field-initializers]
          ! ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_bavail’ [-Wmissing-field-initializers]
          ! ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_files’ [-Wmissing-field-initializers]
          ! ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_ffree’ [-Wmissing-field-initializers]
          ! ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_favail’ [-Wmissing-field-initializers]
          ! ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_fsid’ [-Wmissing-field-initializers]
          ! ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_flag’ [-Wmissing-field-initializers]
          ! ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_namemax’ [-Wmissing-field-initializers]
          ! ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::__f_spare’ [-Wmissing-field-initializers]
          ! npm WARN winston-daily-rotate-file@1.7.2 requires a peer of winston@2.x but none was installed.
          ! Host "zvmubn" (linux) updated
          ! Execute: chmod -R 777 /opt/iobroker
          ! Chmod finished. Restart controller
          ! Starting node restart.js
          ! root@zvmubn:/opt/iobroker# sudo iobroker start
          ! Starting iobroker controller daemon…
          ! /opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136
          ! throw new Error(msg.error);
          ! Error: TypeError: Cannot set property DailyRotateFile of # <object>which has only a getter
          ! at Object. <anonymous>(/opt/iobroker/node_modules/winston-daily-rotate-file/index.js:184:36)
          ! at Module._compile (module.js:577:32)
          ! at Object.Module._extensions..js (module.js:586:10)
          ! at Module.load (module.js:494:32)
          ! at tryModuleLoad (module.js:453:12)
          ! at Function.Module._load (module.js:445:3)
          ! at Module.require (module.js:504:17)
          ! at require (internal/module.js:20:19)
          ! at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/logger.js:7:25)
          ! at ChildProcess. <anonymous>(/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136:19)
          ! at emitTwo (events.js:106:13)
          ! at ChildProcess.emit (events.js:191:7)
          ! at process.nextTick (internal/child_process.js:787:12)
          ! at _combinedTickCallback (internal/process/next_tick.js:73:7)
          ! at process._tickCallback (internal/process/next_tick.js:104:9)</anonymous></anonymous></anonymous></object>
            Pooh
            Для начала вернуть версию 1.4.2
            npm install iobroker.js-controller@1.4.2 –production
            https://play.google.com/store/apps/details?id=com.roy.royclub - код: UMI201155
            https://play.google.com/store/apps/details?id=com.blockchainvault - код приглашения: Freepooh
            https://play.google.com/store/apps/details?id=games.bee.app - код приглашения: freepooh
            https://www.timestope.com/freepooh - witness code: freepooh
            • StabilostickS Offline
              Stabilostick
              @ford7:
              npm WARN winston-daily-rotate-file@1.7.2 requires a peer of winston@2.x but none was installed. `
              Try installing the missing module:
              cd /opt/iobroker
              sudo npm i winston@2 --save --production --force
              The other warnings (missing initializer) are unproblematic.
                Bonus
                Пытаюсь обновить js-controller.
                Версия остается старой. Что делаю не так?
                bonus@server:~$ npm install iobroker.js-controller
                npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning EHOSTUNREACH: request to https://registry.npmjs.org/iobroker.js-controller failed, reason: connect EHOSTUNREACH 104.16.16.35:443
                npm WARN registry Using stale data from https://registry.npmjs.org/ due to a request error during revalidation.
                iobroker.js-controller@2.0.25 preinstall /home/bonus/node_modules/iobroker.js-controller
                node lib/preinstallCheck.js
                NPM version: 6.12.0
                iobroker.js-controller@2.0.25 install /home/bonus/node_modules/iobroker.js-controller
                node iobroker.js setup first
                npm WARN saveError ENOENT: no such file or directory, open '/home/bonus/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/home/bonus/package.json'
                npm WARN bonus No description
                npm WARN bonus No repository field.
                npm WARN bonus No README data
                npm WARN bonus No license field.
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.0 (node_modules/fsevents):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.0: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                • iobroker.js-controller@2.0.25
                  updated 1 package and audited 1785 packages in 6.701s
                  found 0 vulnerabilities
                bonus@server:~$ iobroker js-controller -v
                1.5.14
                bonus@server:~$ iobroker restart
                1.5.14
                bonus@server:~$
