  2. Русский
  3. ioBroker
  4. Ошибка
  5. ioBroker ошибки
  6. Iobroker js-controller - ошибки
Geplant Angeheftet Gesperrt Verschoben ioBroker ошибки
27 Beiträge 13 Kommentatoren 13.3k Aufrufe
  • L Offline
    Lstt
    Шеф, всё пропало..)
    Всё как у немцев - http://forum.iobroker.com/viewtopic.php … bc9c49faf7 .
    Удалил папки, переустановил заново:
    npm install iobroker.js-controller
    npm install iobroker.admin
    В серверах написано:
    ! js-controller ioBroker.js-controller win32 доступен 0.8.7 установлен 0.8.9
    После небольшого времени сыпятся ошибки:
    ! iobroker 2016-04-23 21:21:31 info exit 1 iobroker 2016-04-23 21:21:30 error iobroker 2016-04-23 21:21:30 error at require (module.js:384:17) iobroker 2016-04-23 21:21:30 error at Module.require (module.js:365:17) iobroker 2016-04-23 21:21:30 error at Function.Module._load (module.js:310:12) iobroker 2016-04-23 21:21:30 error at Module.load (module.js:355:32) iobroker 2016-04-23 21:21:30 error at Object.Module._extensions..js (module.js:478:10) iobroker 2016-04-23 21:21:30 error at Module._compile (module.js:460:26) iobroker 2016-04-23 21:21:30 error at Object. (C:\iobroker\node_modules\iobroker.js-controller\lib\setup.js:310:9) iobroker 2016-04-23 21:21:30 error at restartController (C:\iobroker\node_modules\iobroker.js-controller\lib\setup.js:2113:18) iobroker 2016-04-23 21:21:30 error at Object.fs.openSync (fs.js:500:18) iobroker 2016-04-23 21:21:30 error at Error (native) iobroker 2016-04-23 21:21:30 error Error: ENOENT, no such file or directory 'C:\iobroker\node_modules\iobroker.js-controller\log\restart.log' iobroker 2016-04-23 21:21:30 error ^ iobroker 2016-04-23 21:21:30 error fs.js:500 return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode); host-OPENSERVER 2016-04-23 21:21:29 info instance system.adapter.javascript.0 terminated with code 0 (OK) iobroker 2016-04-23 21:21:29 info _restart TypeError: 2016-04-23 21:21:29 error at TCP.onread (net.js:540:20) TypeError: 2016-04-23 21:21:29 error at Socket.Readable.push (_stream_readable.js:126:10) TypeError: 2016-04-23 21:21:29 error at readableAddChunk (_stream_readable.js:163:16) TypeError: 2016-04-23 21:21:29 error at Socket.emit (events.js:107:17) TypeError: 2016-04-23 21:21:29 error at Socket.realHandler (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\WebSocket.js:800:20) TypeError: 2016-04-23 21:21:29 error at Receiver.add (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Receiver.js:95:24) TypeError: 2016-04-23 21:21:29 error at Receiver. (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Receiver.js:451:33) TypeError: 2016-04-23 21:21:29 error at Receiver.opcodes.1.finish (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Receiver.js:483:12) TypeError: 2016-04-23 21:21:29 error at Receiver.endPacket (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Receiver.js:247:18) TypeError: 2016-04-23 21:21:29 error Cannot read property 'fragmentedOperation' of null uncaught 2016-04-23 21:21:29 error exception: Cannot read property 'fragmentedOperation' of null !
    • BluefoxB Offline
      BluefoxB Offline
      @Lstt:
      Шеф, всё пропало..)
      ! iobroker 2016-04-23 21:21:31 info exit 1 iobroker 2016-04-23 21:21:30 error iobroker 2016-04-23 21:21:30 error at require (module.js:384:17) iobroker 2016-04-23 21:21:30 error at Module.require (module.js:365:17) iobroker 2016-04-23 21:21:30 error at Function.Module._load (module.js:310:12) iobroker 2016-04-23 21:21:30 error at Module.load (module.js:355:32) iobroker 2016-04-23 21:21:30 error at Object.Module._extensions..js (module.js:478:10) iobroker 2016-04-23 21:21:30 error at Module._compile (module.js:460:26) iobroker 2016-04-23 21:21:30 error at Object. (C:\iobroker\node_modules\iobroker.js-controller\lib\setup.js:310:9) iobroker 2016-04-23 21:21:30 error at restartController (C:\iobroker\node_modules\iobroker.js-controller\lib\setup.js:2113:18) iobroker 2016-04-23 21:21:30 error at Object.fs.openSync (fs.js:500:18) iobroker 2016-04-23 21:21:30 error at Error (native) iobroker 2016-04-23 21:21:30 error Error: ENOENT, no such file or directory 'C:\iobroker\node_modules\iobroker.js-controller\log\restart.log' iobroker 2016-04-23 21:21:30 error ^ iobroker 2016-04-23 21:21:30 error fs.js:500 return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode); host-OPENSERVER 2016-04-23 21:21:29 info instance system.adapter.javascript.0 terminated with code 0 (OK) iobroker 2016-04-23 21:21:29 info _restart TypeError: 2016-04-23 21:21:29 error at TCP.onread (net.js:540:20) TypeError: 2016-04-23 21:21:29 error at Socket.Readable.push (_stream_readable.js:126:10) TypeError: 2016-04-23 21:21:29 error at readableAddChunk (_stream_readable.js:163:16) TypeError: 2016-04-23 21:21:29 error at Socket.emit (events.js:107:17) TypeError: 2016-04-23 21:21:29 error at Socket.realHandler (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\WebSocket.js:800:20) TypeError: 2016-04-23 21:21:29 error at Receiver.add (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Receiver.js:95:24) TypeError: 2016-04-23 21:21:29 error at Receiver. (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Receiver.js:451:33) TypeError: 2016-04-23 21:21:29 error at Receiver.opcodes.1.finish (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Receiver.js:483:12) TypeError: 2016-04-23 21:21:29 error at Receiver.endPacket (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Receiver.js:247:18) TypeError: 2016-04-23 21:21:29 error Cannot read property 'fragmentedOperation' of null uncaught 2016-04-23 21:21:29 error exception: Cannot read property 'fragmentedOperation' of null ! `
      А комп перестартовывал?
      К меня подозрения, что ты не остановил контролер перед обновлением. Или он не до конца остановился.
      • I Offline
        I Offline
        instalator
        Стоит обновляться нет? работает? попробовал через админку выдал ошибку.
        ! $ ./iobroker upgrade self
        ! npm install iobroker.js-controller –production --prefix "C:/ioBroker" (System call)
        ! npm
        ! ERR!
        ! Windows_NT 6.1.7601
        ! npm
        ! ERR!
        ! argv
        ! "C:\Program Files\nodejs\\node.exe" "C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js" "install" "iobroker.js-controller" "--production" "--prefix" "C:/ioBroker"
        ! npm
        ! ERR!
        ! node
        ! v0.12.2
        ! npm
        ! ERR!
        ! npm
        ! v2.7.4
        ! npm
        ! ERR!
        ! Cannot read property 'trim' of undefined
        ! npm
        ! ERR!
        ! npm
        ! ERR!
        ! If you need help, you may report this error at:
        ! npm
        ! ERR!
        ! <https://github.com/npm/npm/issues>
        ! npm
        ! WARN
        ! deprecated
        ! jade@0.26.3: Jade has been renamed to pug, please install the latest version of pug instead of jade
        ! npm
        ! WARN
        ! deprecated
        ! graceful-fs@2.0.3: graceful-fs version 3 and before will fail on newer node releases. Please update to graceful-fs@^4.0.0 as soon as possible.
        ! npm
        ! ERR!
        ! Please include the following file with any support request:
        ! npm
        ! ERR!
        ! C:\ioBroker\node_modules\iobroker\npm-debug.log
        ! ERROR: host.Server-PC Cannot install iobroker.js-controller: 1
        ! ERROR: process exited with code 25
        Высокий уровень Децибел вреден для здоровья!
        http://blog.instalator.ru/
        • I Offline
          I Offline
          instalator
          Обновился:
          чяднт?
            DAndre
            Тоже самое как у instalator Ж((
            <size size="50">Ubuntu 14.04 trusty DISTRIB_DESCRIPTION="Ubuntu 14.04.3 LTS, Android v4.4.2"
            Ubuntu 16.04.1 LTS (GNU/Linux 4.4.0-31-generic x86_64)</size>
            • I Offline
              I Offline
              instalator
              В логе выдает:
              Server-PC	2016-04-24 18:23:08	warn	host.Server-PC warning: Timeout by read all package.json (79) seconds
              Похоже рубится по таймауту?
              • BluefoxB Offline
                BluefoxB Offline
                @instalator:
                В логе выдает:
                Похоже рубится по таймауту? `
                Переставь репозиторий на fast-online
                • I Offline
                  I Offline
                  instalator
                  @Bluefox:
                  @instalator:
                  В логе выдает:
                  Похоже рубится по таймауту? Переставь репозиторий на fast-online
                  ) Спасибо помогло
                    DAndre
                    Кто подскажет адрес этого faааааааst-online 😢
                    • I Offline
                      I Offline
                      instalator
                      @DAndre:
                      Кто подскажет адрес этого faааааааst-online 😢 `
                      http://download.iobroker.net/sources-dist.json
                        spectrekr
                        Не знаю, тут не тут, опишу тут.
                        После обновления до версии 0.8.10 посыпались ошибки от rpi драйвера
                        ! rpi-0 2016-04-26 15:04:49 error No Value found for cpu_frequency
                        Хотя, на версии 0.8.9 работало все отлично.
                        • BluefoxB Offline
                          BluefoxB Offline
                          @spectrekr:
                          Хотя, на версии 0.8.9 работало все отлично. `
                          Надо сказать, что обновление 0.8.10 ничего с rpi не делало.
                          rpi читает данные из файлов:
                          > cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
                            spectrekr
                            Ну только что проверил, файл на месте и с него читаются данные. Странно то что после обновления появилась данная проблема. Попробую переустановить драйвер. Обновление nodejs до 4 версии ошибку тоже не исправило.
                            Отправлено с моего C6603 через Tapatalk
                            • BluefoxB Offline
                              BluefoxB Offline
                              @spectrekr:
                              Отправлено с моего C6603 через Tapatalk `
                              Здесь можно увидеть, как происходит добыча информации:
                              https://github.com/husky-koglhof/iobrok … e.json#L40
                                spectrekr
                                Странно как до этого работало, сейчас проверил по всем процессорам cpuinfo_cur_frequently доступ на чтение только root, остальным вообще все запрещено. Но есть scaling_cur_frequently с теме же показателями, может стоит с него читать? Он по крайней мере всем доступен
                                • K Offline
                                  kID
                                  Обновился до версии 0.11.1 после чего перестали обновляться драйвера.
                                  Не получается ни через админку, ни через командную строку. брокер через секунду рапортует о том, что драйвер обновлен, при этом все остается как прежде.
                                  Если драйвер снести, то новая установка проходит без проблем.
                                  • H Offline
                                    Haus
                                    @kID:
                                    Если драйвер снести, то новая установка проходит без проблем. `
                                    Потверждаю,
                                    Я тут megaESP драйвер делаю :roll: , псле неправильных конфигураций 😢 иногда слетала в eror думал сломал чего :)
                                    js-controller: 1.5.7 / node.js: v8.15.1/ npm: 6.4.1
                                    admin: 3.6.0
                                    javascript: 4.1.10
                                    web: 2.4.1 vis: 1.1.10
                                    cloud: 2.6.2
                                    Server: DELL FX170 / linux: Debian 9.5 Stretch
                                    Adapter: MegaD-2561, Mega-ES…
                                    • Z Offline
                                      Z Offline
                                      znammut
                                      Здравствуйте, обновил контроллеры до версии 1.1.3 - отвалились ноды. Что делать непонятно, конфигурацию не менял… Может, что изменилось?
                                      Логи нод:
                                      2017-08-23 10:08:05.593 - .[32minfo.[39m: host.orangepipc-2 iobroker.js-controller version 1.1.3 js-controller starting 2017-08-23 10:08:05.613 - .[32minfo.[39m: host.orangepipc-2 Copyright (c) 2014-2017 bluefox, hobbyquaker 2017-08-23 10:08:05.615 - .[32minfo.[39m: host.orangepipc-2 hostname: orangepipc-2, node: v4.8.4 2017-08-23 10:08:05.618 - .[32minfo.[39m: host.orangepipc-2 ip addresses: 192.168.17.67 fe80::81:d4ff:fe54:4964[/code]
                                      ! и все
                                      • Z Offline
                                        Z Offline
                                        znammut
                                        похоже что контроллер поднимается на 127.0.0.1:
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      31156/iobroker.js-c
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      31156/iobroker.js-c
                                        Что надо поправить?
                                        С уважением
                                          spectrekr
                                          @znammut:
                                          Что надо поправить?
                                          С уважением `
                                          На мастере открываешь /opt/iobroker/iobroker-data/iobroker.json и правишь 127.0.0.1 на 0.0.0.0, сохраняешь и перезапускаешь, должны подключится остальные хосты.
                                          Второй вариант
                                          iobroker stop
                                          iobroker setup custom
                                          Type of objects DB [file, couch, redis], default [file]: нажать enter
                                          Host of objects DB(file), default[127.0.0.1]: ввести 0.0.0.0 и нажать enter
                                          Port of objects DB(file), default[9001]: нажать enter
                                          Type of states DB [file, redis], default [file]: redis нажать enter
                                          Host of states DB (redis), default[127.0.0.1]: ввести 0.0.0.0 и нажать enter
                                          Port of states DB (redis), default[6379]: нажать enter
                                          Data directory (file), default[../../../iobroker-data/]: нажать enter
                                          Host name of this machine [FastPC]: нажать enter
                                          creating conf/iobroker.json
