  2. Русский
  3. ioBroker
  4. Ошибка
  5. ioBroker ошибки
  6. Iobroker js-controller - ошибки
Geplant Angeheftet Gesperrt Verschoben ioBroker ошибки
27 Beiträge 13 Kommentatoren 13.3k Aufrufe
  • I Offline
    I Offline
    instalator
    Стоит обновляться нет? работает? попробовал через админку выдал ошибку.
    ! $ ./iobroker upgrade self
    ! npm install iobroker.js-controller –production --prefix "C:/ioBroker" (System call)
    ! npm
    ! ERR!
    ! Windows_NT 6.1.7601
    ! npm
    ! ERR!
    ! argv
    ! "C:\Program Files\nodejs\\node.exe" "C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js" "install" "iobroker.js-controller" "--production" "--prefix" "C:/ioBroker"
    ! npm
    ! ERR!
    ! node
    ! v0.12.2
    ! npm
    ! ERR!
    ! npm
    ! v2.7.4
    ! npm
    ! ERR!
    ! Cannot read property 'trim' of undefined
    ! npm
    ! ERR!
    ! npm
    ! ERR!
    ! If you need help, you may report this error at:
    ! npm
    ! ERR!
    ! <https://github.com/npm/npm/issues>
    ! npm
    ! WARN
    ! deprecated
    ! jade@0.26.3: Jade has been renamed to pug, please install the latest version of pug instead of jade
    ! npm
    ! WARN
    ! deprecated
    ! graceful-fs@2.0.3: graceful-fs version 3 and before will fail on newer node releases. Please update to graceful-fs@^4.0.0 as soon as possible.
    ! npm
    ! ERR!
    ! Please include the following file with any support request:
    ! npm
    ! ERR!
    ! C:\ioBroker\node_modules\iobroker\npm-debug.log
    ! ERROR: host.Server-PC Cannot install iobroker.js-controller: 1
    ! ERROR: process exited with code 25
    Высокий уровень Децибел вреден для здоровья!
    http://blog.instalator.ru/
    • I Offline
      I Offline
      instalator
      Обновился:
      чяднт?
        DAndre
        Тоже самое как у instalator Ж((
        <size size="50">Ubuntu 14.04 trusty DISTRIB_DESCRIPTION="Ubuntu 14.04.3 LTS, Android v4.4.2"
        Ubuntu 16.04.1 LTS (GNU/Linux 4.4.0-31-generic x86_64)</size>
        • I Offline
          I Offline
          instalator
          В логе выдает:
          Server-PC	2016-04-24 18:23:08	warn	host.Server-PC warning: Timeout by read all package.json (79) seconds
          Похоже рубится по таймауту?
          • BluefoxB Offline
            BluefoxB Offline
            @instalator:
            В логе выдает:
            Похоже рубится по таймауту? `
            Переставь репозиторий на fast-online
            • I Offline
              I Offline
              instalator
              @Bluefox:
              @instalator:
              В логе выдает:
              Похоже рубится по таймауту? Переставь репозиторий на fast-online
              ) Спасибо помогло
                DAndre
                Кто подскажет адрес этого faааааааst-online 😢
                • I Offline
                  I Offline
                  instalator
                  @DAndre:
                  Кто подскажет адрес этого faааааааst-online 😢 `
                  http://download.iobroker.net/sources-dist.json
                    spectrekr
                    Не знаю, тут не тут, опишу тут.
                    После обновления до версии 0.8.10 посыпались ошибки от rpi драйвера
                    ! rpi-0 2016-04-26 15:04:49 error No Value found for cpu_frequency
                    Хотя, на версии 0.8.9 работало все отлично.
                    • BluefoxB Offline
                      BluefoxB Offline
                      @spectrekr:
                      Хотя, на версии 0.8.9 работало все отлично. `
                      Надо сказать, что обновление 0.8.10 ничего с rpi не делало.
                      rpi читает данные из файлов:
                      > cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
                        spectrekr
                        Ну только что проверил, файл на месте и с него читаются данные. Странно то что после обновления появилась данная проблема. Попробую переустановить драйвер. Обновление nodejs до 4 версии ошибку тоже не исправило.
                        Отправлено с моего C6603 через Tapatalk
                        • BluefoxB Offline
                          BluefoxB Offline
                          @spectrekr:
                          Отправлено с моего C6603 через Tapatalk `
                          Здесь можно увидеть, как происходит добыча информации:
                          https://github.com/husky-koglhof/iobrok … e.json#L40
                            spectrekr
                            Странно как до этого работало, сейчас проверил по всем процессорам cpuinfo_cur_frequently доступ на чтение только root, остальным вообще все запрещено. Но есть scaling_cur_frequently с теме же показателями, может стоит с него читать? Он по крайней мере всем доступен
                              kID
                              Обновился до версии 0.11.1 после чего перестали обновляться драйвера.
                              Не получается ни через админку, ни через командную строку. брокер через секунду рапортует о том, что драйвер обновлен, при этом все остается как прежде.
                              Если драйвер снести, то новая установка проходит без проблем.
                              • H Offline
                                Haus
                                @kID:
                                Если драйвер снести, то новая установка проходит без проблем. `
                                Потверждаю,
                                Я тут megaESP драйвер делаю :roll: , псле неправильных конфигураций 😢 иногда слетала в eror думал сломал чего :)
                                js-controller: 1.5.7 / node.js: v8.15.1/ npm: 6.4.1
                                admin: 3.6.0
                                javascript: 4.1.10
                                web: 2.4.1 vis: 1.1.10
                                cloud: 2.6.2
                                Server: DELL FX170 / linux: Debian 9.5 Stretch
                                Adapter: MegaD-2561, Mega-ES…
                                • Z Offline
                                  Z Offline
                                  znammut
                                  Здравствуйте, обновил контроллеры до версии 1.1.3 - отвалились ноды. Что делать непонятно, конфигурацию не менял… Может, что изменилось?
                                  Логи нод:
                                  2017-08-23 10:08:05.593 - .[32minfo.[39m: host.orangepipc-2 iobroker.js-controller version 1.1.3 js-controller starting 2017-08-23 10:08:05.613 - .[32minfo.[39m: host.orangepipc-2 Copyright (c) 2014-2017 bluefox, hobbyquaker 2017-08-23 10:08:05.615 - .[32minfo.[39m: host.orangepipc-2 hostname: orangepipc-2, node: v4.8.4 2017-08-23 10:08:05.618 - .[32minfo.[39m: host.orangepipc-2 ip addresses: 192.168.17.67 fe80::81:d4ff:fe54:4964[/code]
                                  ! и все
                                  • Z Offline
                                    Z Offline
                                    znammut
                                    похоже что контроллер поднимается на 127.0.0.1:
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      31156/iobroker.js-c
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      31156/iobroker.js-c
                                    Что надо поправить?
                                    С уважением
                                      spectrekr
                                      @znammut:
                                      Что надо поправить?
                                      С уважением `
                                      На мастере открываешь /opt/iobroker/iobroker-data/iobroker.json и правишь 127.0.0.1 на 0.0.0.0, сохраняешь и перезапускаешь, должны подключится остальные хосты.
                                      Второй вариант
                                      iobroker stop
                                      iobroker setup custom
                                      Type of objects DB [file, couch, redis], default [file]: нажать enter
                                      Host of objects DB(file), default[127.0.0.1]: ввести 0.0.0.0 и нажать enter
                                      Port of objects DB(file), default[9001]: нажать enter
                                      Type of states DB [file, redis], default [file]: redis нажать enter
                                      Host of states DB (redis), default[127.0.0.1]: ввести 0.0.0.0 и нажать enter
                                      Port of states DB (redis), default[6379]: нажать enter
                                      Data directory (file), default[../../../iobroker-data/]: нажать enter
                                      Host name of this machine [FastPC]: нажать enter
                                      creating conf/iobroker.json
                                      • Z Offline
                                        Z Offline
                                        znammut
                                        Спасибо, заработало
                                          sukuy
                                          Кто подскажет адрес этого faааааааst-online.
                                          https://gclub.bbet88.com/
