  4. [Aufruf] Neuer Adapter Meteoalarm.eu
    6.0k
adaptertesterwetterunwetter
64 Beiträge 8 Kommentatoren 12.9k Aufrufe 13 Beobachtet
  • jackblacksonJ jackblackson
    @sigi234 Ah - du testest die neue js-controller, oder?
    sigi234S Online
    sigi234S Online
    sigi234
    #61
    @jackblackson sagte in [Aufruf] Neuer Adapter Meteoalarm.eu:
    Ja
    Neu installiert. Schaut gut aus.
    host.Medion(Test)	2019-09-22 20:48:09.369	info	instance system.adapter.meteoalarm.0 terminated with code 0 (NO_ERROR)
    meteoalarm.0	2019-09-22 20:48:09.365	info	(12496) Terminated (NO_ERROR): Without reason
    host.Medion(Test)	2019-09-22 20:48:01.896	info	instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
    dwd.0	2019-09-22 20:48:01.891	info	(10988) Terminated (NO_ERROR): Without reason
    meteoalarm.0	2019-09-22 20:48:01.343	info	(12496) Received data for "Oberösterreich"
    meteoalarm.0	2019-09-22 20:48:01.275	info	(12496) Requesting data from http://meteoalarm.eu/documents/rss/at/AT007.rss
    meteoalarm.0	2019-09-22 20:48:01.258	info	(12496) starting. Version 1.0.4 in C:/Program Files/iobroker/Test/node_modules/iobroker.meteoalarm, node: v10.16.3
    dwd.0	2019-09-22 20:48:01.088	info	(10988) starting. Version 2.4.3 in C:/Program Files/iobroker/Test/node_modules/iobroker.dwd, node: v10.16.3
    host.Medion(Test)	2019-09-22 20:48:00.018	info	instance system.adapter.dwd.0 started with pid 10988
    host.Medion(Test)	2019-09-22 20:48:00.013	info	instance system.adapter.meteoalarm.0 started with pid 12496
    host.Medion(Test)	2019-09-22 20:47:31.468	info	instance scheduled system.adapter.meteoalarm.0 */48 * * * *
    host.Medion(Test)	2019-09-22 20:47:28.956	info	stopInstance canceled schedule system.adapter.meteoalarm.0
    host.Medion(Test)	2019-09-22 20:47:28.955	info	stopInstance system.adapter.meteoalarm.0
    host.Medion(Test)	2019-09-22 20:47:28.955	info	object change system.adapter.meteoalarm.0 (from: system.adapter.admin.0)
    host.Medion(Test)	2019-09-22 20:47:12.332	info	instance scheduled system.adapter.meteoalarm.0 */30 * * * *
    Immer Daten sichern!
    jackblacksonJ 1 Antwort Letzte Antwort
    • sigi234S sigi234
      Ja
      jackblacksonJ Offline
      jackblackson
      #62
      @sigi234 Ich schau mir das an, sobald es im latest ist - sollte glaub nicht mehr ewig dauern.
      • NegaleinN Offline
        NegaleinN Offline
        Negalein
        #63
        Meteoalarm geht von grün auf rot!
        meteoalarm.0	2019-09-29 00:14:55.177	debug	All done
        meteoalarm.0	2019-09-29 00:14:52.351	debug	system.adapter.admin.0: logging false
        meteoalarm.0	2019-09-29 00:14:47.163	debug	Loaded tomorrow data
        meteoalarm.0	2019-09-29 00:14:47.162	debug	Loaded today data
        meteoalarm.0	2019-09-29 00:14:47.155	info	Received data for "Oberösterreich"
        meteoalarm.0	2019-09-29 00:14:47.078	info	Requesting data from http://meteoalarm.eu/documents/rss/at/AT007.rss
        meteoalarm.0	2019-09-29 00:14:46.946	info	starting. Version 1.0.5 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v8.16.0
        meteoalarm.0	2019-09-29 00:14:46.920	debug	statesDB connected
        meteoalarm.0	2019-09-29 00:14:46.896	debug	objectDB connected
        Der Link im Log funktioniert.
        <?xml version="1.0" encoding="utf-8" ?>
        <rss version="2.0" xmlns:atom="http://www.w3.org/2005/Atom">
        	<channel>
        		<atom:link href="http://meteoalarm.eu/documents/rss/at/AT007.rss" rel="self" type="application/rss+xml"/>
        		<title>Meteoalarm Austria, Oberösterreich</title>
        		<link>https://www.meteoalarm.eu/de_GE/0/0/AT007.html</link>
        		<description>Metoalarm actual warnings from Austria, Oberösterreich</description>
        		<ttl>10</ttl>
        		<language>eng</language>
        		<item>
        			<title>Oberösterreich</title>
        			<description><![CDATA[<table border="0" cellspacing="0" cellpadding="3"><tr><th colspan="3" align="left">Today</th></tr><tr><td width="28"><img border="1" src="https://www.meteoalarm.eu/documents/rss/wflag-l1-t2.jpg" alt="awt:2 level:1"></td></tr><tr><td width="28"></td><td>No special awareness required</td></tr><tr><th colspan="3" align="left"><br />Tomorrow</th></tr><tr><td width="28"><img border="1" src="https://www.meteoalarm.eu/documents/rss/wflag-l2-t1.jpg" alt="awt:1 level:2"></td><td><b>From: </b><i>30.09.2019 04:00 CET</i><b> Until: </b><i>30.09.2019 16:00 CET</i></td></tr><tr><td width="28"></td><td>deutsch:  Starker Wind mit Spitzen bis 80 km/h ist zu erwarten.
        english:  Gusts of 80 kph are possible.</td></tr></table>]]></description>
        			<pubDate>Sun, 29 Sep 2019 01:00:00 +0200</pubDate>
        			<guid isPermaLink="false">6a207c3e34b78b8c170e167a1a0bb1dd</guid>
        		</item>
        	</channel>
        </rss>
        ° Fixer ---> iob fix
          P-A-L-A-D-I-N
          #64
          Der Adapter ist wirklich eine tolle und sehr nützliche Idee! Tolle Sache!
          Eine Frage zur Ausgabe: An der VIS wird ja schon gebastelt, wenn ich das beim Überfliegen richtig gesehen habe. Gibt es aber auch eine Möglichkeit, die Unwetterwarnungen über Alexa ausgeben zu lassen? Vielleicht nochmal nach Bedrohlichkeit gestaffelt, mit Zeitkorridor u.ä.?
          Ich stelle mir das so vor, daß z.B. Glatteiswarnungen nur montags bis freitags in der Zeit von sechs bis sieben Uhr über Alexa ausgegeben werden (wenn man frühstückt und sich zur Arbeit aufmachen möchte), Warnungen vor Orkan, Hochwasser etc. aber zu quasi jeder Zeit.
          Toll wäre es natürlich auch, wenn zusätzlich noch Warnungen des Katastrophenschutzes noch mit eingebunden werden könnten, wie bspw. kürzlich beim Brand auf dem BASF-Werksgelände, als Anwohner unbedingt die Fenster schließen sollten.
