  4. UPNP Cannot read property match of undefined
    6.6k
upnperrorcode6match of undefined
7 Beiträge 3 Kommentatoren 684 Aufrufe 3 Beobachtet
  • crunchipC Offline
    crunchipC Offline
    hatt da eventuell jemand eine Idee?
    Diese Fehlermeldung bekomm ich täglich 1 mal und kann ehrlich gesagt nichts damit anfangen
    2019-07-06 23:49:31.512 - error: upnp.0 uncaught exception: Cannot read property 'match' of undefined
    2019-07-06 23:49:31.513 - error: upnp.0 TypeError: Cannot read property 'match' of undefined
    at setNewState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1390:28)
    at Socket.adapter.getState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1361:17)
    at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
    at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
    at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
    at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
    at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
    at Socket. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
    at WS. (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
    at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    2019-07-06 23:49:32.542 - error: Caught by controller[0]: TypeError: Cannot read property 'match' of undefined
    2019-07-06 23:49:32.543 - error: Caught by controller[0]: at setNewState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1390:28)
    2019-07-06 23:49:32.543 - error: Caught by controller[0]: at Socket.adapter.getState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1361:17)
    2019-07-06 23:49:32.543 - error: Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
    2019-07-06 23:49:32.543 - error: Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
    2019-07-06 23:49:32.543 - error: Caught by controller[0]: at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    2019-07-06 23:49:32.543 - error: Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    2019-07-06 23:49:32.543 - error: Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    2019-07-06 23:49:32.543 - error: Caught by controller[0]: at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    2019-07-06 23:49:32.543 - error: Caught by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
    2019-07-06 23:49:32.543 - error: Caught by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
    2019-07-06 23:49:32.543 - error: Caught by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
    2019-07-06 23:49:32.543 - error: Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    2019-07-06 23:49:32.543 - error: Caught by controller[0]: at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    2019-07-06 23:49:32.543 - error: Caught by controller[0]: at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
    2019-07-06 23:49:32.543 - error: Caught by controller[0]: at WS. (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
    2019-07-06 23:49:32.544 - error: Caught by controller[0]: at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    2019-07-06 23:49:32.544 - error: host.IoBroker instance system.adapter.upnp.0 terminated with code 6 (uncaught exception)
    2019-07-06 23:49:32.544 - info: host.IoBroker Restart adapter system.adapter.upnp.0 because enabled
    habe schon alle Geräte rausgenommen, bis auf die Fritzbox
    das ist das einzigste was abgefragt wird
    im Adapter version 1.0.12 ist nur dieses an
      Jey CeeJ Online
      Jey CeeJ Online
      Jey Cee
      @crunchip sagte in UPNP Cannot read property match of undefined:
      Ja, das ist ein Fehler der im Adapter nicht abgefangen wird. Da kannst du aus User Sicht nichts machen.
      Persönlicher Support
      Spenden -> paypal.me/J3YC33
      • sigi234S Online
        sigi234S Online
        sigi234
        Hallo, bekommst du Werte wenn du auf den Request Button klickst?
        Immer Daten sichern!
        • sigi234S sigi234
          crunchipC Offline
          crunchipC Offline
          @sigi234 ja, es läuft ja auch alles, bis auf die Fehlermeldung 1mal täglich und ab und an auch ein zweites mal.
          Daten werden in Influx geschrieben und in Grafana dargestellt
            Jey CeeJ Online
            Jey CeeJ Online
            Jey Cee
            • Jey CeeJ Jey Cee
              crunchipC Offline
              crunchipC Offline
              @Jey-Cee und woher kommt das, lief ja Tage und Wochen ohne jeglichen Probleme.
                Jey CeeJ Online
                Jey CeeJ Online
                Jey Cee
                @crunchip da steht nicht welche Daten in die Funktion gekippt werden oder woher sie kommen, also wie soll ich das beantworten?
                Wird schon irgendein Gerät ein Update bekommen haben und jetzt andere/zusätzliche Daten senden.
                • Jey CeeJ Jey Cee
                  crunchipC Offline
                  crunchipC Offline
                  @Jey-Cee es ist ja nur die Fritzbox drin und diese hat kein neues update bekommen.
