  4. (Erledigt) Flot Adapter Installationsfehler
flot adapter
1 Beiträge 1 Kommentatoren 318 Aufrufe
  • premoP Online
    premoP Online
    premo
    schrieb am zuletzt editiert von premo
    Hallo
    Bekomme es leider nicht hin den Flot Adapter zu installieren. Flot war aber schon am Laufen und konnte diesen nicht mehr unter Instanzen finden.
    Darauf habe ich den Adapter deinstalliert und bei Neuinstallation kommt dieser Error.
    iobroker.admin 3.6.3
    js-controller 1.5.11
    Platform: linux
    Architecture: arm
    CPUs: 4
    Speed: 1200 MHz
    Model: ARMv7 Processor rev 4 (v7l)
    RAM: 923.3 MB
    System uptime: 00:18:40
    Node.js: v8.15.1
    NPM: 6.4.1
    Disk size: 7.2 GiB
    Disk free: 2.4 GiB
    adapters count: 244
    Uptime: 00:18:16
    Active instances: 8
    Fehler Ausgabe sieht so aus.
    []Fertig mit Fehler: reading io-package.json Error: ENOENT: no such file or directory, open 'null/io-package.json']
    $ ./iobroker add flot  --host raspberrypi
    host.raspberrypi install adapter flot
    got /opt/iobroker/node_modules/iobroker.flot/admin
    upload [0] flot.admin /opt/iobroker/node_modules/iobroker.flot/admin/flot.png flot.png image/png
    got /opt/iobroker/node_modules/iobroker.flot/www
    upload [20] flot /opt/iobroker/node_modules/iobroker.flot/www/js/flot.js js/flot.js application/javascript
    upload [19] flot /opt/iobroker/node_modules/iobroker.flot/www/js/edit.js.map js/edit.js.map application/json
    upload [18] flot /opt/iobroker/node_modules/iobroker.flot/www/js/edit.js js/edit.js application/javascript
    upload [17] flot /opt/iobroker/node_modules/iobroker.flot/www/index.html.map index.html.map application/json
    upload [16] flot /opt/iobroker/node_modules/iobroker.flot/www/index.html index.html text/html
    upload [15] flot /opt/iobroker/node_modules/iobroker.flot/www/img/favicon.png img/favicon.png image/png
    upload [14] flot /opt/iobroker/node_modules/iobroker.flot/www/edit.html.map edit.html.map application/json
    upload [13] flot /opt/iobroker/node_modules/iobroker.flot/www/edit.html edit.html text/html
    upload [12] flot /opt/iobroker/node_modules/iobroker.flot/www/css/jquery.colorpicker.css css/jquery.colorpicker.css text/css
    upload [11] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/ui-colorpicker.png css/images/ui-colorpicker.png image/png
    upload [10] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/preview-opacity.png css/images/preview-opacity.png image/png
    upload [9] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/map.png css/images/map.png image/png
    upload [8] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/map-pointer.png css/images/map-pointer.png image/png
    upload [7] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/map-opacity.png css/images/map-opacity.png image/png
    upload [6] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar.png css/images/bar.png image/png
    upload [5] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar-pointer.png css/images/bar-pointer.png image/png
    upload [4] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar-opacity.png css/images/bar-opacity.png image/png
    upload [3] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar-alpha.png css/images/bar-alpha.png image/png
    upload [2] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/map.png css/images/128/map.png image/png
    upload [1] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/bar.png css/images/128/bar.png image/png
    upload [0] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/bar-alpha.png css/images/128/bar-alpha.png image/png
    host.raspberrypi create instance web
    ERROR: host.raspberrypi error: reading io-package.json Error: ENOENT: no such file or directory, open 'null/io-package.json'
    ERROR: process exited with code 20
    MfG premo
