  4. Scriptseite nur drehendes Zeichen
fehler script seite
3 Beiträge 3 Kommentatoren 439 Aufrufe
    stephan61
    Hallo habe folgendes Problem wenn ich auf die Seite script möchte erscheint nur das drehende Symbol
    Js controller 1.5.12 admin 3.6.3
    javascript 4.1.13
    in der console kommt folgende Meldung
    Subscribe logs
    blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_COMPARE_TOOLTIP_EQ}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_COMPARE_TOOLTIP_NEQ}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_COMPARE_TOOLTIP_LT}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_COMPARE_TOOLTIP_LTE}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_COMPARE_TOOLTIP_GT}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_COMPARE_TOOLTIP_GTE}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_OPERATION_TOOLTIP_AND}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_OPERATION_TOOLTIP_OR}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_CONTROLS_WHILEUNTIL_TOOLTIP_WHILE}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_CONTROLS_WHILEUNTIL_TOOLTIP_UNTIL}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_CONTROLS_FLOW_STATEMENTS_TOOLTIP_BREAK}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_CONTROLS_FLOW_STATEMENTS_TOOLTIP_CONTINUE}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_CONTROLS_FOR_TOOLTIP}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_CONTROLS_FOREACH_TOOLTIP}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ARITHMETIC_TOOLTIP_ADD}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ARITHMETIC_TOOLTIP_MINUS}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ARITHMETIC_TOOLTIP_MULTIPLY}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ARITHMETIC_TOOLTIP_DIVIDE}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ARITHMETIC_TOOLTIP_POWER}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_ROOT}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_ABS}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_NEG}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_LN}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_LOG10}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_EXP}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_POW10}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_TRIG_TOOLTIP_SIN}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_TRIG_TOOLTIP_COS}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_TRIG_TOOLTIP_TAN}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_TRIG_TOOLTIP_ASIN}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_TRIG_TOOLTIP_ACOS}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_TRIG_TOOLTIP_ATAN}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_SUM}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_MIN}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_MAX}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_AVERAGE}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_MEDIAN}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_MODE}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_STD_DEV}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_RANDOM}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_CHANGE_TOOLTIP}.
    blockly_compressed.js:893 WARNING: No message string for %{BKY_TEXT_APPEND_TOOLTIP}.
    manchmal offnet sich die Seite
    Gruß Stephan
    • SpegeliS Offline
      SpegeliS Offline
      Spegeli
      schrieb am zuletzt editiert von Spegeli
      Hab das Problem seit heute selber und konnte es etwas einschränken:
      Ist im Admin.0 Adapter bei "Ausführen als" der Standard "Admin" ausgewählt funktioniert alles ohne Probleme.
      Wählt man dort aber einen anderen User bzw. selbst angelegten Admin aus dann lässt sich der Skripte Tab nicht mehr öffnen.
      Auch wenn man die Authentifikation beim Admin.0 einschaltet und sich dann per Standard Admin einloggt geht es, mit dem selbst angelegten Admin allerdings nicht.
      Das Problem existiert wohl schon eine weile: https://github.com/ioBroker/ioBroker.javascript/issues/373
      Eine Fix, eine Lösung oder ein Workaround dafür wären schön.
      • S stephan61
        javascript 4.1.13
        Subscribe logs
        Gruß Stephan
        @stephan61
        Bitte hier weitemachen
        https://forum.iobroker.net/topic/23145/scriptseite-nur-drehendes-zeichen
