  4. Web stürzt ab 2. Benutzer für VIS
visbenutzerweb
9 Beiträge 3 Kommentatoren 621 Aufrufe 1 Beobachtet
  • C Offline
    ChrisXY
    seit ich eine 2. Gruppe gemacht habe ( Tablet ) ALLE RECHTE GEGEBEN. Und dort den User Tablet hinzugefügt habe, stürzt mein WEB Adapter rimmer ab.
    host.iobroker	2019-06-04 09:20:17.440	info	Restart adapter system.adapter.web.0 because enabled
    host.iobroker	2019-06-04 09:20:17.440	error	instance system.adapter.web.0 terminated with code 0 (OK)
    host.iobroker	2019-06-04 09:20:17.440	error	Caught by controller[0]: at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
    host.iobroker	2019-06-04 09:20:17.440	error	Caught by controller[0]: at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    host.iobroker	2019-06-04 09:20:17.440	error	Caught by controller[0]: at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
    host.iobroker	2019-06-04 09:20:17.440	error	Caught by controller[0]: at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
    host.iobroker	2019-06-04 09:20:17.440	error	Caught by controller[0]: at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    host.iobroker	2019-06-04 09:20:17.440	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    host.iobroker	2019-06-04 09:20:17.440	error	Caught by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
    host.iobroker	2019-06-04 09:20:17.440	error	Caught by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:237:14)
    host.iobroker	2019-06-04 09:20:17.440	error	Caught by controller[0]: at decodeString (/opt/iobroker/node_modules/socket.io-parser/index.js:325:9)
    host.iobroker	2019-06-04 09:20:17.440	error	Caught by controller[0]: at tryParse (/opt/iobroker/node_modules/socket.io-parser/index.js:336:12)
    host.iobroker	2019-06-04 09:20:17.439	error	Caught by controller[0]: RangeError: Maximum call stack size exceeded
    web.0	2019-06-04 09:20:17.407	error	uncaught exception: Maximum call stack size exceeded
    Ich öffne einmal Lokal zuhause per IP und 8082 eine VIS und zusätzlich bin ich draußen per reserve proxy vis.domain.de am versuchen zu arbeiten ...
    Bevor ich den tablet User angelegt habe und zuhause eingeloggt hatte ging es per Admin Problemlos
    • C Offline
      ChrisXY
      also wenn ich im Tablet zuhause nichts aufrufe ( Browser zu ) ddann kkann ich extern wieder arbeiten ohne absturz...
      • apollon77A Online
        apollon77A Online
        Welcher js-controller? Nodejs? Sonstige Adapterversionen?
        • C Offline
          ChrisXY
          schrieb am zuletzt editiert von ChrisXY
          Node.js
          v8.16.0
          NPM
          6.4.1
          JS: 1.5.11
          Web: 2.4.1
          VIS: 1.2.0
          Gerade vom git WEB Update gemacht auf 2.4.3. Aktuell keine Probleme :)
          • apollon77A Online
            apollon77A Online
            Hast Du mehr logging oder Warnungen oberhalb der crash Meldung?
            • apollon77A Online
              apollon77A Online
              Und zeig bitte mal die Gruppendefinition und den neuen User
              • C Offline
                ChrisXY
                hatte ein edit gemacht :)
                Nach neuste WEB Update scheint es ohne Fehler zu laufen
                • apollon77A Online
                  apollon77A Online
                  Ich verstehe die Aussagen gerade nicht? Was hast Du "edit gemacht"? Welche web Version nutzt du jetzt wo es wieder tut?
                  • C ChrisXY
                    Node.js
                    v8.16.0
                    NPM
                    6.4.1
                    JS: 1.5.11
                    Web: 2.4.1
                    VIS: 1.2.0
                    @ChrisXY sagte in Web stürzt ab 2. Benutzer für VIS:
                    Bitte auch als "EDIT" kennzeichnen!
