  4. [GELÖST] Flot und Rickshaw Adapter - Installation schlägt fehl
7 Beiträge 4 Kommentatoren 1.4k Aufrufe
  • G Offline
    GerdSo
    ich schaffe es nicht die beiden Adapter zu installieren.
    iobroker	2016-03-27 16:44:09	info	exit 25
    iobroker	2016-03-27 16:44:09	info	Cannot install iobroker.flot: 4294963228
    iobroker	2016-03-27 16:44:09	info	npm ERR! C:\WINDOWS\system32\npm-debug.log
    iobroker	2016-03-27 16:44:09	info	npm ERR! Please include the following file with any support request:
    iobroker	2016-03-27 16:44:09	info	eisdir a package you are trying to install.
    iobroker	2016-03-27 16:44:09	info	ERR!
    iobroker	2016-03-27 16:44:09	info	and is related to npm not being able to find a package.json innpm
    iobroker	2016-03-27 16:44:09	info	eisdir This is most likely not a problem with npm itselfnpm
    iobroker	2016-03-27 16:44:09	info	ERR! eisdir EISDIR: illegal operation on a directory, read
    iobroker	2016-03-27 16:44:09	info	syscall read
    iobroker	2016-03-27 16:44:09	info	-4068npm
    iobroker	2016-03-27 16:44:09	info	errno
    iobroker	2016-03-27 16:44:09	info	EISDIR
    iobroker	2016-03-27 16:44:09	info	code
    iobroker	2016-03-27 16:44:09	info	ERR! npm v3.7.3
    iobroker	2016-03-27 16:44:09	info	ERR! node v5.9.0
    iobroker	2016-03-27 16:44:09	info	"C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "--production" "--prefix" "C:/Program Files/ioBroker/node_modules/iobroker.flot"
    iobroker	2016-03-27 16:44:09	info	argv
    iobroker	2016-03-27 16:44:09	info	ERR! Windows_NT 10.0.10586
    iobroker	2016-03-27 16:44:09	info	addLocal Could not install C:\WINDOWS\system32
    iobroker	2016-03-27 16:44:06	info	npm install --production --prefix "C:/Program Files/ioBroker/node_modules/iobroker.flot" (System call)
    iobroker	2016-03-27 16:44:06	info	host.DauerlaufLaptop install adapter flot
    iobroker	2016-03-27 16:44:05	info	add flot
    Andere Adapter lassen sich problemlos installieren.
    "npm cache clean" habe ich schon durchgeführt, führte aber nicht zum Erfolg
    Jemand eine Idee, was bei mir falsch läuft?
    Folgende Adapter sind installiert und sind aktiv (außer email.0 und fritzbox.0)
    • Instanz Titel Zeitplanung
    admin.0 ioBroker Admin
    dwd.0 DWD */5 * * * *
    email.0 Email Adapter
    fritzbox.0 fritzbox Adapter
    history.0 history
    hm-rega.0 HomeMatic ReGaHSS
    hm-rpc.0 HomeMatic RPC
    hmm.0 Homematic Manager
    ical.0 iCal Adapter 0 */6 * * *
    javascript.0 Javascript/Coffescript Script Engine
    simple-api.0 simpleAPI Adapter
    socketio.0 socket.io Adapter
    vis.0 iobroker Visualisation
    web.0 ioBroker simple web Adapter
    yr.0 yr.no */5 * * * *
    • derAugeD Offline
      derAugeD Offline
      derAuge
      Hallo GerdSo,
      willkommen im Forum
      Habe die Installation des Adapters gerade mal auf einem RPi2 getestet. Da läuft es durch
      Hast du dein System schon einmal neu gestartet?
      Jürgen
        Wenn ich das aber richtig sehe ist es hier eine WIN10 Installation.
        Angemeckert wird sowohl die nodejs version mit 5.9.0 und die wohl dazugehörige npm-Version von 3.7.3
        Kann dazu mal ein Windows USer etwas sagen - ich kann das leider nicht.
        Rainer
        • G Offline
          GerdSo
          mehrfach neu gestartet, inkl. Rechnerneustart. Richtig, ist ein Win10 System.
          Alle Installationen sind aktuell, d.h. ioBroker etc. ist aktuell, node.js und npm aktuelle Version. Dachte vorher, dass es daran liegt und habe alles aktualisiert.
          Ergänzung: Mit diesen Versionen läßt sich z.B. der vCard-Adapter problemlos installieren
          Viele Grüße Gerd.
          • BluefoxB Offline
            BluefoxB Offline
            Das ist Rechtenproblem. In der neuen Installation habe ich iobroker aus Programm Files verschoben .
            Ich empfehle dir aus der Konsole mit admin rechten, das Kommando ausführen:
            cd C:/Program Files/ioBroker/
            npm install iobroker.flot
            iobroker add flot
            • G Offline
              GerdSo
              @Bluefox:
              iobroker add flot `
              Hab es probiert, schlägt trotzdem fehl, davor wurde wie vorgeschlagen npm install iobroker.flot ausgeführt, alles mit admin-Rechten:
              C:\Program Files\ioBroker>iobroker add flot
              C:\Program Files\ioBroker>node node_modules/iobroker.js-controller/iobroker.js add flot
              npm ERR! addLocal Could not install C:\Program Files\ioBroker
              npm ERR! Windows_NT 10.0.10586
              npm ERR! argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\Kerstin\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js" "install" "--production" "--prefix" "C:/Program Files/ioBroker/node_modules/iobroker.flot"
              npm ERR! node v5.9.0
              npm ERR! npm  v3.8.5
              npm ERR! code EISDIR
              npm ERR! errno -4068
              npm ERR! syscall read
              npm ERR! eisdir EISDIR: illegal operation on a directory, read
              npm ERR! eisdir This is most likely not a problem with npm itself
              npm ERR! eisdir and is related to npm not being able to find a package.json in
              npm ERR! eisdir a package you are trying to install.
              npm ERR!     C:\Program Files\ioBroker\npm-debug.log
              • G Offline
                GerdSo
                Lösung gefunden. Nachdem Aufruf von
                npm -g install npm@latest-2
                funktioniert es und ich konnte flot und auch rickshaw installieren. Jetzt ist npm=2.2.2
