  4. Problem bei nodejs upgrade
nodejs
3 Beiträge 2 Kommentatoren 900 Aufrufe
    Smartuser
    Hallo Zusammen,
    ich wollte heute die nodejs v.6.x auf v.8. upgraden.
    Verwendet habe ich folgende Anleitung: klick
    Die neue Version wurde auch erfolgreich installiert.
    Leider crashed es beim Kompilieren der bereits installierten Adapter, also bei
    npm rebuild
    Hier fliegt er raus:
    In file included from ../src/poller.cpp:1:0:
    ../../nan/nan.h:1674:3: note: declared here
       Call(int argc, v8::Local<v8::Value> argv[]) const {
    npm notice created a lockfile as package-lock.json. You should commit this file.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
    npm install iobroker.admin --production --prefix /opt/iobroker
    sh: 0: getcwd() failed: No such file or directory
    path.js:1165
            path = process.cwd();
    Error: ENOENT: no such file or directory, uv_cwd
        at Object.resolve (path.js:1165:24)
        at Function.Module._resolveLookupPaths (module.js:424:17)
        at Function.Module._resolveFilename (module.js:542:20)
        at Function.Module._load (module.js:475:25)
        at Module.require (module.js:597:17)
        at require (internal/module.js:11:18)
        at /usr/lib/node_modules/npm/bin/npm-cli.js:19:21
        at Object.<anonymous> (/usr/lib/node_modules/npm/bin/npm-cli.js:153:3)
        at Module._compile (module.js:653:30)
        at Object.Module._extensions..js (module.js:664:10)
    npm install iobroker.js-controller --production --prefix /opt/iobroker
    path.js:1165
    Could not find "/opt/iobroker/node_modules/iobroker/lib/../../iobroker.js-controller/conf/iobroker-dist.json". Possible iobroker.js-controller was not installed
    Non-critical error: ENOENT: no such file or directory, mkdir '/opt/iobroker/node_modules/iobroker/lib/../../../log'
    npm ERR! path /opt/iobroker/node_modules/yargs/package.json
    npm ERR! code ENOENT
    npm ERR! errno -2
    npm ERR! syscall open
    npm ERR! enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/yargs/package.json'
    npm ERR! enoent This is related to npm not being able to find a file.
    npm ERR! enoent
    npm ERR!     /root/.npm/_logs/2019-05-11T12_12_34_461Z-debug.log
    root@ioBroker-Rock64:/opt/iobroker#
    System: Rock64
    Könnt ihr mir dabei weiterhelfen?
    Gruß Smartuser
      Smartuser
      @Homoran
      Danke für die Rückmeldung.
      Ich glaube der Fehler lag darin, dass nach dem system reboot iobroker erneut gestopt werden muss.
      Ein erneutes Starten von
      npm rebuild
      ohne laufende iobroker instanze lief ohne probleme durch.
      Danke!
      Smartuser
      • S Smartuser
        Hallo Zusammen,
        npm rebuild
        path.js:1165
        path.js:1165
        npm ERR! errno -2
        npm ERR! enoent
        System: Rock64
        Gruß Smartuser
        @Smartuser sagte in Problem bei nodejs upgrade:
        Wann wurde installiert?
        Ggf. Mit dem fixer bearbeitet?
          Smartuser
          @Homoran
          npm rebuild
          Danke!
          Smartuser
