  4. Update VIS 1.1.10 auf 1.2.0 Error 10
visupdateerror
59 Beiträge 4 Kommentatoren 4.8k Aufrufe 4 Beobachtet
  • NegaleinN Offline
    NegaleinN Offline
    Negalein
    Nachdem ich heute mein VIS von 1.1.10 auf 1.2.0 updaten wollte, wurde das Update mit Code 10 beendet.
    An was könnte das liegen und was könnte ich machen, damit es durchläuft?
    VIS und VIS-Edit funktionieren weiterhin.
    $ ./iobroker upgrade vis
    Update vis from @1.1.10 to @1.2.0
    NPM version: 6.4.1
    npm install iobroker.vis@1.2.0 --production --save --prefix "/opt/iobroker" (System call)
    module.js:550    throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.vis/main.js'
        at Function.Module._resolveFilename (module.js:548:15)
        at Function.Module._load (module.js:475:25)
        at Function.Module.runMain (module.js:694:10)
        at startup (bootstrap_node.js:204:16)
        at bootstrap_node.js:625:3
    npm
     WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.npm
     WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm ERR! code ELIFECYCLEnpm ERR! errno 1
    npm ERR! iobroker.vis@1.2.0 install: `node main.js --install`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.vis@1.2.0 install script.
    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2019-05-08T20_35_35_493Z-debug.log
    ERROR: Cannot find io-package.json in null
    ERROR: process exited with code 10
    Node.js: 8.15.1
    NPM: 6.4.1
    JS-Controller: 1.4.2
    installiert auf Synology im Docker
    ° Fixer ---> iob fix
    • sigi234S Online
      sigi234S Online
      sigi234
      Mach mal einen Neustart............
      Immer Daten sichern!
      NegaleinN 2 Antworten Letzte Antwort
      • sigi234S sigi234
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        @sigi234 sagte in Update VIS 1.1.10 auf 1.2.0 Error 10:
        Da trau ich mich wetten, dass VIS dann nicht mehr geht.
        Melde mich gleich zurück.
        • sigi234S sigi234
          NegaleinN Offline
          NegaleinN Offline
          Negalein
          So, nach einem Neustart läuft VIS und VIS-Edit noch.
          Im VIS-Edit wird 1.1.10 angezeigt.
          Im Admin wird es jetzt komisch.
          Als verfügbar wird mir 1.2.0 angezeigt.
          Aber das Feld für installiert ist leer!
          Dann hätte ich über das + eine Instanz hinzugefügt.
          host.ioBroker error: this adapter does not allow multiple instances
          $ ./iobroker add vis  --host ioBroker
          NPM version: 6.4.1
          npm install iobroker.vis --production --save --prefix "/opt/iobroker" (System call)
          npm
          npm
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
          npm ERR! iobroker.vis@1.2.0 install: `node main.js --install`npm ERR! Exit status 1
          npm ERR!
          npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2019-05-08T21_06_05_301Z-debug.log
          ERROR: host.ioBroker error: this adapter does not allow multiple instances
          ERROR: process exited with code 19
          • NegaleinN Negalein
            NPM version: 6.4.1
            npm
            npm
            npm ERR!
            sigi234S Online
            sigi234S Online
            sigi234
            @Negalein sagte in Update VIS 1.1.10 auf 1.2.0 Error 10:
            Das war Falsch, Vis geht nur eine Instanz!
            • NegaleinN Offline
              NegaleinN Offline
              Negalein
              das Verzeichnis iobroker.vis gibt es auch nicht.
              • sigi234S sigi234
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                Ja, aber es wird mir zwar unter Instanzen angezeigt, aber eben nicht unter Adapter.
                Hätte jetzt versucht wieder 1.1.10 zu installieren.
                Bricht mit Error 10 ab.
                Und in der 1. Zeile sieht man, dass er von 0.0.0 auf 1.1.10 updaten möchte.
                $ ./iobroker upgrade vis@1.1.10
                Update vis from @0.0.0 to @1.1.10
                NPM version: 6.4.1
                npm install iobroker.vis@1.1.10 --production --save --prefix "/opt/iobroker" (System call)
                npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                npm
                 ERR! iobroker.vis@1.1.10 install: `node main.js --install`npm ERR! Exit status 1
                npm ERR! npm ERR! Failed at the iobroker.vis@1.1.10 install script.
                npm ERR!
                npm ERR!     /root/.npm/_logs/2019-05-08T21_19_47_886Z-debug.log
                sigi234S 2 Antworten Letzte Antwort
                  NPM version: 6.4.1
                  npm
                  npm ERR!
                  sigi234S Online
                  sigi234S Online
                  sigi234
                  Hm...da muss ein Profi ran, ich bin mir nicht sicher ob Vis nicht einen höheren JS-Controller (du hast 1.4.2) braucht.
                    NPM version: 6.4.1
                    npm
                    npm ERR!
                    sigi234S Online
                    sigi234S Online
                    sigi234
                    @Negalein
                    Kommst du noch in Vis rein?
                    • sigi234S sigi234
                      @Negalein
                      NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      @Negalein
                      Ja, geht einwandfrei.
                      Ist auch unter Instanzen immer grün
                        @Negalein
                        sigi234S Online
                        sigi234S Online
                        sigi234
                        @Negalein
                        Mal Daten sichern..........
                        Ich hatte das auch, ging aber nach Neustart, Browser Cache geleert? Strg+F5?
                        • sigi234S sigi234
                          @Negalein
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          @Negalein
                          Cache werde ich versuchen.
                          Backup wird sowieso täglich 4fach erstellt.
                          • StabilostickS Offline
                            Stabilostick
                            schrieb am zuletzt editiert von Stabilostick
                            Geh mal in den ioBroker-Ordner und führe
                            npm i stream-browserify
                            aus.
                            Dann nochmal das vis Update.
                            Wobei, da erklärt nicht die fehlende main.js .... hmm.
                            Was steht in /root/.npm/_logs/2019-05-08T21_19_47_886Z-debug.log?
                            sigi234S NegaleinN 2 Antworten Letzte Antwort
                            • StabilostickS Stabilostick
                              aus.
                              sigi234S Online
                              sigi234S Online
                              sigi234
                              @Stabilostick sagte in Update VIS 1.1.10 auf 1.2.0 Error 10:
                              Hallo, das kenne ich noch nicht, kannst du mir erklären was das bewirkt? Um zu lernen...........
                              StabilostickS 1 Antwort Letzte Antwort
                              • sigi234S sigi234
                                Stabilostick
                                @sigi234
                                Das ist für die erste Warnung aus dem Log.
                                • apollon77A Offline
                                  ich frage mal frech: Genug Plattenplatz ist frei und so?
                                  Also vis läuft aber es gibt kein /opt/iobroker/node_modules/iobroker-vis Verzeichnis ... ok das kann sein weil am Ende vis geuploaded wird und das das wichtige ist.
                                  Der Fehler sagt das er das installations-Kommando nicht ausführen konnte nach der npm Installation.
                                  Führe doch mal
                                  manuell an der Kommandozeile aus
                                    aus.
                                    NegaleinN Offline
                                    NegaleinN Offline
                                    Negalein
                                    Du meinst in /opt/iobroker/ ?
                                    Ja, denn es existiert schon kein Verzeichnis iobroker.vis
                                    • apollon77A apollon77
                                      Führe doch mal
                                      NegaleinN Offline
                                      NegaleinN Offline
                                      Negalein
                                      @apollon77 sagte in Update VIS 1.1.10 auf 1.2.0 Error 10:
                                      Ja, mehrere TB :)
                                      Führe doch mal
                                      root@ioBroker:/opt/iobroker# npm install iobroker.vis@1.1.10 --production --save --prefix "/opt/iobroker"
                                      > iobroker.vis@1.1.10 install /opt/iobroker/node_modules/iobroker.vis
                                      module.js:550
                                          throw err;
                                      npm ERR! errno 1
                                      npm ERR! iobroker.vis@1.1.10 install: `node main.js --install`
                                      npm ERR!
                                      npm ERR!     /root/.npm/_logs/2019-05-08T21_48_42_503Z-debug.log
                                      Log von /root/.npm/_logs/2019-05-08T21_48_42_503Z-debug.log
                                        Stabilostick
                                        Hmm, da steht auch nur drin:
                                        108 silly lifecycle iobroker.vis@1.1.10~install: Args: [ '-c', 'node main.js --install' ]
                                        112 silly lifecycle iobroker.vis@1.1.10~install: Returned: code: 1  signal: null
                                        113 info lifecycle iobroker.vis@1.1.10~install: Failed to exec install script
                                        Vielleicht im iobroker Ordner
                                        npm i iobroker.vis@1.1.10 --production --force
                                        ausführen?
                                          Bitte nicht mit alten Versionen dinge tun, die 1.2.0 ist aktuell.
                                          Also ich habe es bei mir manuell gemacht und bei mir ist alles da.
                                          Bei Dir scheint im Verzeichnis iobroker.is die main,js zu fehlen nach dem entpacken ... und das kann an sich nicht sein. Irgendwas st da bei dir gerade komisch. Kann da irgendwas mit Docker dazwischenfunken?
