  4. [SOLVED] Instal.auf FreeBSD funktioniert nicht.
    5.2k
freenasfreebsdinstaller
74 Beiträge 6 Kommentatoren 10.5k Aufrufe 2 Beobachtet
    mrMuppet
    @AlCalzone sagte in Neue Installation auf FreeBSD/FreeNAS 11.2 funktioniert nicht.:
    @mrMuppet Prima, kein Stress...
    Das war es noch nicht ganz:
    root@iobroker_v2:~ # curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/freebsd-fix/installer.sh | bash -
        Welcome to the ioBroker installer!
        Installer version: 2019-05-21
        You might need to enter your password a couple of times.
        Installing prerequisites (1/4)
    Installed sudo
    Installed unzip
    Installed avahi-libdns
    Installed nss_mdns
    Installed gcc
    dbus_enable:  -> YES
    avahi_daemon_enable:  -> YES
    Starting dbus.
    Starting avahi-daemon.
        Creating ioBroker user and directory (2/4)
    tty:*:4
    Directory /opt/iobroker created
        Installing ioBroker (3/4)
    ../src/unix_dgram.cc:53:13: warning: unused function 'SetNonBlock' [-Wunused-function]
    inline void SetNonBlock(int fd) {
    ../src/unix_dgram.cc:65:13: warning: unused function 'SetCloExec' [-Wunused-function]
    inline void SetCloExec(int fd) {
    2 warnings generated.
    ../src/serialport.cpp:95:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
      data->callback.Call(2, argv);
    ../../nan/nan.h:1739:3: note: 'Call' has been explicitly marked deprecated here
      NAN_DEPRECATED inline v8::Local<v8::Value>
    ../../nan/nan.h:104:40: note: expanded from macro 'NAN_DEPRECATED'
    # define NAN_DEPRECATED __attribute__((deprecated))
    ../src/serialport.cpp:150:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
      data->callback.Call(1, argv);
    ../src/serialport.cpp:188:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp:231:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp:285:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp:336:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp:383:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp:424:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
    8 warnings generated.
    ../src/serialport_unix.cpp:384:20: warning: variable 'outbaud' is uninitialized when used here
          [-Wuninitialized]
      data->baudRate = outbaud;
    ../src/serialport_unix.cpp:369:14: note: initialize the variable 'outbaud' to silence this
          warning
      int outbaud;
                  = 0
    1 warning generated.
    ../src/poller.cpp:69:17: warning: 'Call' is deprecated [-Wdeprecated-declarations]
      obj->callback.Call(2, argv);
        Finalizing installation (4/4)
    Enabling autostart...
    iobroker_enable:  -> YES
    platform: Undefined variable.
    Autostart enabled!
    root@iobroker_v2:~ # iobroker start
    Starting iobroker controller daemon...
    iobroker controller daemon failed to start:  Failed to write pidfile (EACCES)
    Error: Failed to write pidfile (EACCES)
    ioBroker auf NUC (Celeron mit Ubuntu-Server)
    Homematic, HMIP, Hue, Unifi, Plex, Nest, Roborock, Google Assistant
    • M mrMuppet
      Installed sudo
      Installed unzip
      Installed nss_mdns
      Installed gcc
      dbus_enable:  -> YES
      Starting dbus.
      tty:*:4
            [-Wuninitialized]
            warning
        int outbaud;
                    = 0
      Autostart enabled!
      AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      @mrMuppet Ok gib mir ein paar Minuten
      • AlCalzoneA Offline
        AlCalzoneA Offline
        AlCalzone
        @mrMuppet sagte in Neue Installation auf FreeBSD/FreeNAS 11.2 funktioniert nicht.:
        EACCES
        Was sagt ls -la /opt/iobroker/node_modules/iobroker.js-controller/lib ?
          AlCalzoneA Offline
          AlCalzone
          Kann es sein, dass ioBroker nach der Installation bereits läuft?
          • AlCalzoneA AlCalzone
            EACCES
            mrMuppet
            Läuft noch nicht.
            root@iobroker_v2:~ # ls -la /opt/iobroker/node_modules/iobroker.js-controller/lib
            total 382
            drwxr-xr-x  9 root  wheel      28 May 21 18:05 .
            drwxr-xr-x  6 root  wheel      17 May 21 18:06 ..
            -rw-r--r--  1 root  wheel  225379 Oct 26  1985 adapter.js
            -rw-r--r--  1 root  wheel    2012 Oct 26  1985 dbdump.js
            -rw-r--r--  1 root  wheel    1828 Oct 26  1985 defaultObjs.js
            drwxr-xr-x  2 root  wheel       3 May 21 18:05 img
            -rw-r--r--  1 root  wheel    9114 Oct 26  1985 letsencrypt.js
            -rw-r--r--  1 root  wheel   26624 Oct 26  1985 letsencryptStore.js
            -rw-r--r--  1 root  wheel   11236 Oct 26  1985 logger.js
            -rw-r--r--  1 root  wheel    7177 Oct 26  1985 multihostClient.js
            -rw-r--r--  1 root  wheel    9174 Oct 26  1985 multihostServer.js
            drwxr-xr-x  2 root  wheel       5 May 21 18:05 objects
            -rw-r--r--  1 root  wheel     531 Oct 26  1985 objects.js
            -rw-r--r--  1 root  wheel    2644 Oct 26  1985 password.js
            -rw-r--r--  1 root  wheel    4544 Oct 26  1985 preinstall_check.js
            -rw-r--r--  1 root  wheel    1755 Oct 26  1985 renewal.conf.tpl
            -rw-r--r--  1 root  wheel    6026 Oct 26  1985 restart.js
            drwxr-xr-x  2 root  wheel       3 May 21 18:05 scripts
            -rw-r--r--  1 root  wheel    1809 Oct 26  1985 session.js
            drwxr-xr-x  2 root  wheel      14 May 21 18:05 setup
            -rw-r--r--  1 root  wheel  154618 Oct 26  1985 setup.js
            drwxr-xr-x  2 root  wheel       5 May 21 18:05 states
            -rw-r--r--  1 root  wheel     523 Oct 26  1985 states.js
            -rw-r--r--  1 root  wheel   47344 Oct 26  1985 tools.js
            -rw-r--r--  1 root  wheel    3808 Oct 26  1985 uploadFiles.js
            drwxr-xr-x  2 root  wheel       3 May 21 18:05 vis
            drwxr-xr-x  3 root  wheel       3 May 21 18:05 www
            -rw-r--r--  1 root  wheel   13190 Oct 26  1985 zipFiles.js
              AlCalzoneA Offline
              AlCalzone
              Hmm, da werden die Berechtigungen nicht richtig gesetzt... Evtl hat das mit der Meldung oben zu tun "unknown variable platform". Ich hab mal den Debug-Mode aktiviert, um (hoffentlich) zu sehen was los ist, bitte nochmal installieren (ohne System neu aufsetzen):
              rm -rf /opt/iobroker
                mrMuppet
                + INSTALLER_VERSION=2019-05-21
                + [[ 0 -eq 0 ]]
                + IS_ROOT=true
                + ROOT_GROUP=root
                ++ uname
                + unamestr=FreeBSD
                + '[' FreeBSD = Linux ']'
                + '[' FreeBSD = Darwin ']'
                + '[' FreeBSD = FreeBSD ']'
                + platform=freebsd
                + ROOT_GROUP=wheel
                + IOB_DIR=/opt/iobroker
                + '[' freebsd = osx ']'
                + CONTROLLER_DIR=/opt/iobroker/node_modules/iobroker.js-controller
                + INSTALLER_INFO_FILE=/opt/iobroker/INSTALLER_INFO.txt
                + INSTALL_TARGET=iobroker
                + IOB_USER=iobroker
                + test -t 1
                ++ which tput
                ++ tput colors
                + ncolors=94
                + test -n 94
                + test 94 -ge 8
                ++ tput cols
                + termcols=94
                ++ tput bold
                + bold=
                ++ tput smul
                + underline=
                ++ tput smso
                + standout=
                ++ tput sgr0
                + normal=
                ++ tput setaf 0
                + black=''
                ++ tput setaf 1
                + red=''
                ++ tput setaf 2
                + green=''
                ++ tput setaf 3
                + yellow=''
                ++ tput setaf 4
                + blue=''
                ++ tput setaf 5
                + magenta=''
                ++ tput setaf 6
                + cyan=''
                ++ tput setaf 7
                + white=''
                + HLINE===========================================================================
                + print_bold 'Welcome to the ioBroker installer!' 'Installer version: 2019-05-21' '' 'You might need to enter your password a couple of times.'
                + title='Welcome to the ioBroker installer!'
                + echo
                + echo ==========================================================================
                + echo
                + echo '    Welcome to the ioBroker installer!'
                + for text in "${@:2}"
                + echo '    Installer version: 2019-05-21'
                + echo '    '
                + echo '    You might need to enter your password a couple of times.'
                + echo
                + echo
                + export AUTOMATED_INSTALLER=true
                + AUTOMATED_INSTALLER=true
                + NUM_STEPS=4
                + print_step 'Installing prerequisites' 1 4
                + stepname='Installing prerequisites'
                + stepnr=1
                + steptotal=4
                + echo
                + echo '    Installing prerequisites (1/4)'
                + echo
                + case "$platform" in
                + packages=("sudo" "git" "curl" "bash" "unzip" "avahi-libdns" "dbus" "nss_mdns" "gcc" "python")
                + declare -a packages
                + for pkg in "${packages[@]}"
                + install_package_freebsd sudo
                + package=sudo
                + pkg info sudo
                + install_package_freebsd git
                + package=git
                + pkg info git
                + install_package_freebsd curl
                + package=curl
                + pkg info curl
                + install_package_freebsd bash
                + package=bash
                + pkg info bash
                + install_package_freebsd unzip
                + package=unzip
                + pkg info unzip
                + install_package_freebsd avahi-libdns
                + package=avahi-libdns
                + pkg info avahi-libdns
                + install_package_freebsd dbus
                + package=dbus
                + pkg info dbus
                + install_package_freebsd nss_mdns
                + package=nss_mdns
                + pkg info nss_mdns
                + install_package_freebsd gcc
                + package=gcc
                + pkg info gcc
                + install_package_freebsd python
                + package=python
                + pkg info python
                + ln -s /usr/local/include/avahi-compat-libdns_sd/dns_sd.h /usr/include/dns_sd.h
                ln: /usr/include/dns_sd.h: File exists
                + sed -i -e s/#enable-dbus/enable-dbus/ /usr/local/etc/avahi/avahi-daemon.conf
                + sed -i -e 's/hosts: file dns/hosts: file dns mdns/' /etc/nsswitch.conf
                + sysrc -f /etc/rc.conf dbus_enable=YES
                dbus_enable: YES -> YES
                + sysrc -f /etc/rc.conf avahi_daemon_enable=YES
                avahi_daemon_enable: YES -> YES
                + service dbus start
                dbus already running?  (pid=55380).
                + service avahi-daemon start
                avahi_daemon already running?  (pid=55387).
                + print_step 'Creating ioBroker user and directory' 2 4
                + stepname='Creating ioBroker user and directory'
                + stepnr=2
                + steptotal=4
                + echo
                + echo '    Creating ioBroker user and directory (2/4)'
                + echo
                + '[' freebsd = linux ']'
                + '[' freebsd = freebsd ']'
                + create_user_freebsd iobroker
                + username=iobroker
                + id iobroker
                + '[' 0 -ne 0 ']'
                + groups=(audio bluetooth dialout gpio i2c redis tty)
                + declare -a groups
                + for grp in "${groups[@]}"
                + '[' true = true ']'
                + getent group audio
                + getent group bluetooth
                + getent group dialout
                + getent group gpio
                + getent group i2c
                + getent group redis
                + getent group tty
                tty:*:4:iobroker
                + pw group mod tty -m iobroker
                + mkdir -p /opt/iobroker
                + cd /opt/iobroker
                + echo 'Directory /opt/iobroker created'
                + touch /opt/iobroker/INSTALLER_INFO.txt
                + chmod 777 /opt/iobroker/INSTALLER_INFO.txt
                + echo 'Installer version: 2019-05-21'
                ++ date +%F
                + echo 'Installation date 2019-05-21'
                + echo 'Platform: freebsd'
                + print_step 'Installing ioBroker' 3 4
                + stepname='Installing ioBroker'
                + stepnr=3
                + steptotal=4
                + echo
                + echo '    Installing ioBroker (3/4)'
                + echo
                + echo 'Installed as root'
                + npm i iobroker --loglevel error --unsafe-perm
                + npm i --production --loglevel error --unsafe-perm
                      [-Wuninitialized]
                      warning
                  int outbaud;
                              = 0
                + print_step 'Finalizing installation' 4 4
                + stepname='Finalizing installation'
                + stepnr=4
                + steptotal=4
                + echo
                + echo '    Finalizing installation (4/4)'
                + echo
                + INITSYSTEM=unknown
                + [[ freebsd = \f\r\e\e\b\s\d ]]
                + [[ -d /usr/local/etc/rc.d ]]
                + INITSYSTEM=rc.d
                + [[ -n '' ]]
                + echo 'init system: rc.d'
                + IOB_NODE_CMDLINE=node
                ++ which bash
                + BASH_CMDLINE=/usr/local/bin/bash
                + '[' iobroker '!=' root ']'
                + IOB_NODE_CMDLINE='sudo -H -u iobroker node'
                + '[' rc.d = systemd ']'
                + '[' rc.d = launchctl ']'
                ++ cat
                + IOB_EXECUTABLE='#!/usr/local/bin/bash
                sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js $@'
                + IOB_BIN_PATH=/usr/local/bin
                + ln -sfn /opt/iobroker/iobroker /usr/local/bin/iobroker
                + ln -sfn /opt/iobroker/iobroker /opt/iobroker/iob
                + echo '#!/usr/local/bin/bash
                + make_executable /opt/iobroker/iobroker
                + file=/opt/iobroker/iobroker
                + chmod 755 /opt/iobroker/iobroker
                + [[ rc.d = \i\n\i\t\.\d ]]
                + '[' rc.d = rc.d ']'
                + echo 'Enabling autostart...'
                ++ cat
                + RCD_FILE='#!/bin/sh
                # PROVIDE: iobroker
                # REQUIRE: DAEMON
                # KEYWORD: shutdown
                . /etc/rc.subr
                name="iobroker"
                rcvar="iobroker_enable"
                load_rc_config $name
                iobroker_enable=${iobroker_enable-"NO"}
                iobroker_pidfile=${iobroker_pidfile-"/opt/iobroker/node_modules/iobroker.js-controller/lib/iobroker.pid"}
                PIDF=/opt/iobroker/node_modules/iobroker.js-controller/lib/iobroker.pid
                NODECMD=$(which node)
                iobroker_start ()
                su -m iobroker -s "/usr/local/bin/bash" -c "${NODECMD} /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js start"
                iobroker_stop ()
                su -m iobroker -s "/usr/local/bin/bash" -c "${NODECMD} /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js stop"
                iobroker_status ()
                su -m iobroker -s "/usr/local/bin/bash" -c "${NODECMD} /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js status"
                PATH="${PATH}:/usr/local/bin"
                pidfile="${iobroker_pidfile}"
                start_cmd=iobroker_start
                stop_cmd=iobroker_stop
                status_cmd=iobroker_status
                run_rc_command "$1"'
                + SERVICE_FILENAME=/usr/local/etc/rc.d/iobroker
                + echo '#!/bin/sh
                # PROVIDE: iobroker
                # REQUIRE: DAEMON
                # KEYWORD: shutdown
                . /etc/rc.subr
                name="iobroker"
                iobroker_start ()
                iobroker_stop ()
                iobroker_status ()
                + set_root_permissions /usr/local/etc/rc.d/iobroker
                + file=/usr/local/etc/rc.d/iobroker
                + chown root:wheel /usr/local/etc/rc.d/iobroker
                + chmod 755 /usr/local/etc/rc.d/iobroker
                + sysrc iobroker_enable=YES
                iobroker_enable: YES -> YES
                + service iobroker start
                Before fixing dir permissions...
                + echo 'Autostart enabled!'
                Autostart enabled!
                + echo 'Autostart: rc.d'
                AlCalzoneA HomoranH 4 Antworten Letzte Antwort
                • M mrMuppet
                  + [[ 0 -eq 0 ]]
                  + IS_ROOT=true
                  + ROOT_GROUP=root
                  ++ uname
                  + unamestr=FreeBSD
                  + platform=freebsd
                  + ROOT_GROUP=wheel
                  + IOB_USER=iobroker
                  + test -t 1
                  ++ which tput
                  ++ tput colors
                  + ncolors=94
                  + test -n 94
                  + test 94 -ge 8
                  ++ tput cols
                  + termcols=94
                  ++ tput bold
                  + bold=
                  ++ tput smul
                  + underline=
                  ++ tput smso
                  + standout=
                  ++ tput sgr0
                  + normal=
                  ++ tput setaf 0
                  + black=''
                  ++ tput setaf 1
                  + red=''
                  ++ tput setaf 2
                  + green=''
                  ++ tput setaf 3
                  + yellow=''
                  ++ tput setaf 4
                  + blue=''
                  ++ tput setaf 5
                  + magenta=''
                  ++ tput setaf 6
                  + cyan=''
                  ++ tput setaf 7
                  + white=''
                  + echo
                  + echo
                  + echo '    '
                  + echo
                  + echo
                  + NUM_STEPS=4
                  + stepnr=1
                  + steptotal=4
                  + echo
                  + echo
                  + package=sudo
                  + pkg info sudo
                  + package=git
                  + pkg info git
                  + package=curl
                  + pkg info curl
                  + package=bash
                  + pkg info bash
                  + package=unzip
                  + pkg info unzip
                  + package=dbus
                  + pkg info dbus
                  + package=nss_mdns
                  + pkg info nss_mdns
                  + package=gcc
                  + pkg info gcc
                  + package=python
                  + pkg info python
                  + stepnr=2
                  + steptotal=4
                  + echo
                  + echo
                  + username=iobroker
                  + id iobroker
                  + '[' 0 -ne 0 ']'
                  + declare -a groups
                  + getent group gpio
                  + getent group i2c
                  + getent group tty
                  tty:*:4:iobroker
                  + cd /opt/iobroker
                  ++ date +%F
                  + stepnr=3
                  + steptotal=4
                  + echo
                  + echo
                        [-Wuninitialized]
                        warning
                    int outbaud;
                                = 0
                  + stepnr=4
                  + steptotal=4
                  + echo
                  + echo
                  + INITSYSTEM=rc.d
                  + [[ -n '' ]]
                  ++ which bash
                  ++ cat
                  ++ cat
                  # PROVIDE: iobroker
                  # REQUIRE: DAEMON
                  # KEYWORD: shutdown
                  . /etc/rc.subr
                  name="iobroker"
                  iobroker_start ()
                  iobroker_stop ()
                  iobroker_status ()
                  + echo '#!/bin/sh
                  # PROVIDE: iobroker
                  # REQUIRE: DAEMON
                  # KEYWORD: shutdown
                  . /etc/rc.subr
                  name="iobroker"
                  iobroker_start ()
                  iobroker_stop ()
                  iobroker_status ()
                  Autostart enabled!
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  @mrMuppet Danke, schau ich mir später an
                  • M mrMuppet
                    + [[ 0 -eq 0 ]]
                    + IS_ROOT=true
                    + ROOT_GROUP=root
                    ++ uname
                    + unamestr=FreeBSD
                    + platform=freebsd
                    + ROOT_GROUP=wheel
                    + IOB_USER=iobroker
                    + test -t 1
                    ++ which tput
                    ++ tput colors
                    + ncolors=94
                    + test -n 94
                    + test 94 -ge 8
                    ++ tput cols
                    + termcols=94
                    ++ tput bold
                    + bold=
                    ++ tput smul
                    + underline=
                    ++ tput smso
                    + standout=
                    ++ tput sgr0
                    + normal=
                    ++ tput setaf 0
                    + black=''
                    ++ tput setaf 1
                    + red=''
                    ++ tput setaf 2
                    + green=''
                    ++ tput setaf 3
                    + yellow=''
                    ++ tput setaf 4
                    + blue=''
                    ++ tput setaf 5
                    + magenta=''
                    ++ tput setaf 6
                    + cyan=''
                    ++ tput setaf 7
                    + white=''
                    + echo
                    + echo
                    + echo '    '
                    + echo
                    + echo
                    + NUM_STEPS=4
                    + stepnr=1
                    + steptotal=4
                    + echo
                    + echo
                    + package=sudo
                    + pkg info sudo
                    + package=git
                    + pkg info git
                    + package=curl
                    + pkg info curl
                    + package=bash
                    + pkg info bash
                    + package=unzip
                    + pkg info unzip
                    + package=dbus
                    + pkg info dbus
                    + package=nss_mdns
                    + pkg info nss_mdns
                    + package=gcc
                    + pkg info gcc
                    + package=python
                    + pkg info python
                    + stepnr=2
                    + steptotal=4
                    + echo
                    + echo
                    + username=iobroker
                    + id iobroker
                    + '[' 0 -ne 0 ']'
                    + declare -a groups
                    + getent group gpio
                    + getent group i2c
                    + getent group tty
                    tty:*:4:iobroker
                    + cd /opt/iobroker
                    ++ date +%F
                    + stepnr=3
                    + steptotal=4
                    + echo
                    + echo
                          [-Wuninitialized]
                          warning
                      int outbaud;
                                  = 0
                    + stepnr=4
                    + steptotal=4
                    + echo
                    + echo
                    + INITSYSTEM=rc.d
                    + [[ -n '' ]]
                    ++ which bash
                    ++ cat
                    ++ cat
                    # PROVIDE: iobroker
                    # REQUIRE: DAEMON
                    # KEYWORD: shutdown
                    . /etc/rc.subr
                    name="iobroker"
                    iobroker_start ()
                    iobroker_stop ()
                    iobroker_status ()
                    + echo '#!/bin/sh
                    # PROVIDE: iobroker
                    # REQUIRE: DAEMON
                    # KEYWORD: shutdown
                    . /etc/rc.subr
                    name="iobroker"
                    iobroker_start ()
                    iobroker_stop ()
                    iobroker_status ()
                    Autostart enabled!
                    platform=freebsd
                    Und später
                      platform=freebsd
                      Und später
                      AlCalzoneA Offline
                      AlCalzoneA Offline
                      AlCalzone
                      schrieb am zuletzt editiert von AlCalzone
                      @Homoran Genau das verwirrt mich. Da scheint FreeBSD etwas anders zu machen als alle anderen Betriebssysteme. Muss ich morgen mal lesen. Heute Abend musste ich erst mal Blues Brothers schauen 😁
                      • M mrMuppet
                        + [[ 0 -eq 0 ]]
                        + IS_ROOT=true
                        + ROOT_GROUP=root
                        ++ uname
                        + unamestr=FreeBSD
                        + platform=freebsd
                        + ROOT_GROUP=wheel
                        + IOB_USER=iobroker
                        + test -t 1
                        ++ which tput
                        ++ tput colors
                        + ncolors=94
                        + test -n 94
                        + test 94 -ge 8
                        ++ tput cols
                        + termcols=94
                        ++ tput bold
                        + bold=
                        ++ tput smul
                        + underline=
                        ++ tput smso
                        + standout=
                        ++ tput sgr0
                        + normal=
                        ++ tput setaf 0
                        + black=''
                        ++ tput setaf 1
                        + red=''
                        ++ tput setaf 2
                        + green=''
                        ++ tput setaf 3
                        + yellow=''
                        ++ tput setaf 4
                        + blue=''
                        ++ tput setaf 5
                        + magenta=''
                        ++ tput setaf 6
                        + cyan=''
                        ++ tput setaf 7
                        + white=''
                        + echo
                        + echo
                        + echo '    '
                        + echo
                        + echo
                        + NUM_STEPS=4
                        + stepnr=1
                        + steptotal=4
                        + echo
                        + echo
                        + package=sudo
                        + pkg info sudo
                        + package=git
                        + pkg info git
                        + package=curl
                        + pkg info curl
                        + package=bash
                        + pkg info bash
                        + package=unzip
                        + pkg info unzip
                        + package=dbus
                        + pkg info dbus
                        + package=nss_mdns
                        + pkg info nss_mdns
                        + package=gcc
                        + pkg info gcc
                        + package=python
                        + pkg info python
                        + stepnr=2
                        + steptotal=4
                        + echo
                        + echo
                        + username=iobroker
                        + id iobroker
                        + '[' 0 -ne 0 ']'
                        + declare -a groups
                        + getent group gpio
                        + getent group i2c
                        + getent group tty
                        tty:*:4:iobroker
                        + cd /opt/iobroker
                        ++ date +%F
                        + stepnr=3
                        + steptotal=4
                        + echo
                        + echo
                              [-Wuninitialized]
                              warning
                          int outbaud;
                                      = 0
                        + stepnr=4
                        + steptotal=4
                        + echo
                        + echo
                        + INITSYSTEM=rc.d
                        + [[ -n '' ]]
                        ++ which bash
                        ++ cat
                        ++ cat
                        # PROVIDE: iobroker
                        # REQUIRE: DAEMON
                        # KEYWORD: shutdown
                        . /etc/rc.subr
                        name="iobroker"
                        iobroker_start ()
                        iobroker_stop ()
                        iobroker_status ()
                        + echo '#!/bin/sh
                        # PROVIDE: iobroker
                        # REQUIRE: DAEMON
                        # KEYWORD: shutdown
                        . /etc/rc.subr
                        name="iobroker"
                        iobroker_start ()
                        iobroker_stop ()
                        iobroker_status ()
                        Autostart enabled!
                        AlCalzoneA Offline
                        AlCalzoneA Offline
                        AlCalzone
                        • service iobroker start
                        • echo 'Autostart enabled!'
                          Autostart enabled!
                        • echo 'Autostart: rc.d'
                        Und auch das läuft in einer Reihenfolge ab, die eigentlich nicht sein kann 🤔
                        • M mrMuppet
                          + [[ 0 -eq 0 ]]
                          + IS_ROOT=true
                          + ROOT_GROUP=root
                          ++ uname
                          + unamestr=FreeBSD
                          + platform=freebsd
                          + ROOT_GROUP=wheel
                          + IOB_USER=iobroker
                          + test -t 1
                          ++ which tput
                          ++ tput colors
                          + ncolors=94
                          + test -n 94
                          + test 94 -ge 8
                          ++ tput cols
                          + termcols=94
                          ++ tput bold
                          + bold=
                          ++ tput smul
                          + underline=
                          ++ tput smso
                          + standout=
                          ++ tput sgr0
                          + normal=
                          ++ tput setaf 0
                          + black=''
                          ++ tput setaf 1
                          + red=''
                          ++ tput setaf 2
                          + green=''
                          ++ tput setaf 3
                          + yellow=''
                          ++ tput setaf 4
                          + blue=''
                          ++ tput setaf 5
                          + magenta=''
                          ++ tput setaf 6
                          + cyan=''
                          ++ tput setaf 7
                          + white=''
                          + echo
                          + echo
                          + echo '    '
                          + echo
                          + echo
                          + NUM_STEPS=4
                          + stepnr=1
                          + steptotal=4
                          + echo
                          + echo
                          + package=sudo
                          + pkg info sudo
                          + package=git
                          + pkg info git
                          + package=curl
                          + pkg info curl
                          + package=bash
                          + pkg info bash
                          + package=unzip
                          + pkg info unzip
                          + package=dbus
                          + pkg info dbus
                          + package=nss_mdns
                          + pkg info nss_mdns
                          + package=gcc
                          + pkg info gcc
                          + package=python
                          + pkg info python
                          + stepnr=2
                          + steptotal=4
                          + echo
                          + echo
                          + username=iobroker
                          + id iobroker
                          + '[' 0 -ne 0 ']'
                          + declare -a groups
                          + getent group gpio
                          + getent group i2c
                          + getent group tty
                          tty:*:4:iobroker
                          + cd /opt/iobroker
                          ++ date +%F
                          + stepnr=3
                          + steptotal=4
                          + echo
                          + echo
                                [-Wuninitialized]
                                warning
                            int outbaud;
                                        = 0
                          + stepnr=4
                          + steptotal=4
                          + echo
                          + echo
                          + INITSYSTEM=rc.d
                          + [[ -n '' ]]
                          ++ which bash
                          ++ cat
                          ++ cat
                          # PROVIDE: iobroker
                          # REQUIRE: DAEMON
                          # KEYWORD: shutdown
                          . /etc/rc.subr
                          name="iobroker"
                          iobroker_start ()
                          iobroker_stop ()
                          iobroker_status ()
                          + echo '#!/bin/sh
                          # PROVIDE: iobroker
                          # REQUIRE: DAEMON
                          # KEYWORD: shutdown
                          . /etc/rc.subr
                          name="iobroker"
                          iobroker_start ()
                          iobroker_stop ()
                          iobroker_status ()
                          Autostart enabled!
                          AlCalzoneA Offline
                          AlCalzoneA Offline
                          AlCalzone
                          @mrMuppet Ich habe nochmal einen Versuch gestartet. Probierst du bitte nochmal:
                            mrMuppet
                            schrieb am zuletzt editiert von mrMuppet
                            @AlCalzone komme gerade nur über's Smartphone dran, aber versucht hab ichs trotzdem Mal:
                            root@iobroker_v2:~ # rm -rf /opt/iobroker
                            + [[ 0 -eq 0 ]]
                            + IS_ROOT=true
                            + ROOT_GROUP=root
                            ++ get_platform
                            +++ uname
                            ++ unamestr=FreeBSD
                            ++ local platform=
                            ++ '[' FreeBSD = Linux ']'
                            ++ '[' FreeBSD = Darwin ']'
                            ++ '[' FreeBSD = FreeBSD ']'
                            ++ platform=freebsd
                            ++ ROOT_GROUP=wheel
                            ++ echo freebsd
                            + platform=freebsd
                            + '[' freebsd = '' ']'
                            + IOB_USER=iobroker
                            + test -t 1
                            ++ which tput
                            ++ tput colors
                            + ncolors=83
                            + test -n 83
                            + test 83 -ge 8
                            ++ tput cols
                            + termcols=83
                            ++ tput bold
                            + bold=
                            ++ tput smul
                            + underline=
                            ++ tput smso
                            + standout=
                            ++ tput sgr0
                            + normal=
                            ++ tput setaf 0
                            + black=''
                            ++ tput setaf 1
                            + red=''
                            ++ tput setaf 2
                            + green=''
                            ++ tput setaf 3
                            + yellow=''
                            ++ tput setaf 4
                            + blue=''
                            ++ tput setaf 5
                            + magenta=''
                            ++ tput setaf 6
                            + cyan=''
                            ++ tput setaf 7
                            + white=''
                            + echo
                            + echo
                            + echo '    '
                            + echo
                            + echo
                            + NUM_STEPS=4
                            + stepnr=1
                            + steptotal=4
                            + echo
                            + echo
                            + package=sudo
                            + pkg info sudo
                            + package=git
                            + pkg info git
                            + package=curl
                            + pkg info curl
                            + package=bash
                            + pkg info bash
                            + package=unzip
                            + pkg info unzip
                            + package=dbus
                            + pkg info dbus
                            + package=nss_mdns
                            + pkg info nss_mdns
                            + package=gcc
                            + pkg info gcc
                            + package=python
                            + pkg info python
                            Starting dbus.
                            + stepnr=2
                            + steptotal=4
                            + echo
                            + echo
                            + username=iobroker
                            + id iobroker
                            + '[' 0 -ne 0 ']'
                            + declare -a groups
                            + getent group gpio
                            + getent group i2c
                            + getent group tty
                            tty:*:4:iobroker
                            + cd /opt/iobroker
                            ++ date +%F
                            + echo 'Installation date 2019-05-22'
                            + stepnr=3
                            + steptotal=4
                            + echo
                            + echo
                                  [-Wunused-function]
                                  [-Wunused-function]
                                  when used here [-Wuninitialized]
                                  silence this warning
                              int outbaud;
                                          = 0
                            + stepnr=4
                            + steptotal=4
                            + echo
                            + echo
                            + INITSYSTEM=rc.d
                            + [[ -n '' ]]
                            ++ which bash
                            ++ cat
                            ++ cat
                            # PROVIDE: iobroker
                            # REQUIRE: DAEMON
                            # KEYWORD: shutdown
                            . /etc/rc.subr
                            name="iobroker"
                            iobroker_start ()
                            iobroker_stop ()
                            iobroker_status ()
                            + echo '#!/bin/sh
                            # PROVIDE: iobroker
                            # REQUIRE: DAEMON
                            # KEYWORD: shutdown
                            . /etc/rc.subr
                            name="iobroker"
                            iobroker_start ()
                            iobroker_stop ()
                            iobroker_status ()
                            + chown root:root /usr/local/etc/rc.d/iobroker
                            chown: root: illegal group name
                            Illegal variable name.
                            Autostart enabled!
                            Edit:
                            • M mrMuppet
                              + [[ 0 -eq 0 ]]
                              + IS_ROOT=true
                              + ROOT_GROUP=root
                              ++ get_platform
                              +++ uname
                              ++ unamestr=FreeBSD
                              ++ local platform=
                              ++ platform=freebsd
                              ++ ROOT_GROUP=wheel
                              ++ echo freebsd
                              + platform=freebsd
                              + IOB_USER=iobroker
                              + test -t 1
                              ++ which tput
                              ++ tput colors
                              + ncolors=83
                              + test -n 83
                              + test 83 -ge 8
                              ++ tput cols
                              + termcols=83
                              ++ tput bold
                              + bold=
                              ++ tput smul
                              + underline=
                              ++ tput smso
                              + standout=
                              ++ tput sgr0
                              + normal=
                              ++ tput setaf 0
                              + black=''
                              ++ tput setaf 1
                              + red=''
                              ++ tput setaf 2
                              + green=''
                              ++ tput setaf 3
                              + yellow=''
                              ++ tput setaf 4
                              + blue=''
                              ++ tput setaf 5
                              + magenta=''
                              ++ tput setaf 6
                              + cyan=''
                              ++ tput setaf 7
                              + white=''
                              + echo
                              + echo
                              + echo '    '
                              + echo
                              + echo
                              + NUM_STEPS=4
                              + stepnr=1
                              + steptotal=4
                              + echo
                              + echo
                              + package=sudo
                              + pkg info sudo
                              + package=git
                              + pkg info git
                              + package=curl
                              + pkg info curl
                              + package=bash
                              + pkg info bash
                              + package=unzip
                              + pkg info unzip
                              + package=dbus
                              + pkg info dbus
                              + package=nss_mdns
                              + pkg info nss_mdns
                              + package=gcc
                              + pkg info gcc
                              + package=python
                              + pkg info python
                              Starting dbus.
                              + stepnr=2
                              + steptotal=4
                              + echo
                              + echo
                              + username=iobroker
                              + id iobroker
                              + '[' 0 -ne 0 ']'
                              + declare -a groups
                              + getent group gpio
                              + getent group i2c
                              + getent group tty
                              tty:*:4:iobroker
                              + cd /opt/iobroker
                              ++ date +%F
                              + stepnr=3
                              + steptotal=4
                              + echo
                              + echo
                                    [-Wunused-function]
                                    [-Wunused-function]
                                int outbaud;
                                            = 0
                              + stepnr=4
                              + steptotal=4
                              + echo
                              + echo
                              + INITSYSTEM=rc.d
                              + [[ -n '' ]]
                              ++ which bash
                              ++ cat
                              ++ cat
                              # PROVIDE: iobroker
                              # REQUIRE: DAEMON
                              # KEYWORD: shutdown
                              . /etc/rc.subr
                              name="iobroker"
                              iobroker_start ()
                              iobroker_stop ()
                              iobroker_status ()
                              + echo '#!/bin/sh
                              # PROVIDE: iobroker
                              # REQUIRE: DAEMON
                              # KEYWORD: shutdown
                              . /etc/rc.subr
                              name="iobroker"
                              iobroker_start ()
                              iobroker_stop ()
                              iobroker_status ()
                              Autostart enabled!
                              Edit:
                              AlCalzoneA Offline
                              AlCalzoneA Offline
                              AlCalzone
                              Das ist was neues - ich schaue später nochmal rein.
                                AlCalzoneA Offline
                                AlCalzone
                                Ich habe nochmal was geändert. Magst du bitte nochmal testen?
                                  mrMuppet
                                  @AlCalzone Hier der nächste Versuch:
                                  + [[ 0 -eq 0 ]]
                                  + IS_ROOT=true
                                  + ROOT_GROUP=root
                                  ++ uname
                                  + unamestr=FreeBSD
                                  + HOST_PLATFORM=freebsd
                                  + ROOT_GROUP=wheel
                                  + IOB_USER=iobroker
                                  + test -t 1
                                  ++ which tput
                                  ++ tput colors
                                  + ncolors=80
                                  + test -n 80
                                  + test 80 -ge 8
                                  ++ tput cols
                                  + termcols=80
                                  ++ tput bold
                                  + bold=
                                  ++ tput smul
                                  + underline=
                                  ++ tput smso
                                  + standout=
                                  ++ tput sgr0
                                  + normal=
                                  ++ tput setaf 0
                                  + black=''
                                  ++ tput setaf 1
                                  + red=''
                                  ++ tput setaf 2
                                  + green=''
                                  ++ tput setaf 3
                                  + yellow=''
                                  ++ tput setaf 4
                                  + blue=''
                                  ++ tput setaf 5
                                  + magenta=''
                                  ++ tput setaf 6
                                  + cyan=''
                                  ++ tput setaf 7
                                  + white=''
                                  + echo
                                  + echo
                                  + echo '    '
                                  + echo
                                  + echo
                                  + NUM_STEPS=4
                                  + stepnr=1
                                  + steptotal=4
                                  + echo
                                  + echo
                                  + case "$HOST_PLATFORM" in
                                  + package=sudo
                                  + pkg info sudo
                                  + package=git
                                  + pkg info git
                                  + package=curl
                                  + pkg info curl
                                  + package=bash
                                  + pkg info bash
                                  + package=unzip
                                  + pkg info unzip
                                  + package=dbus
                                  + pkg info dbus
                                  + package=nss_mdns
                                  + pkg info nss_mdns
                                  + package=gcc
                                  + pkg info gcc
                                  + package=python
                                  + pkg info python
                                  dbus already running?  (pid=66501).
                                  avahi_daemon already running?  (pid=66508).
                                  + stepnr=2
                                  + steptotal=4
                                  + echo
                                  + echo
                                  + username=iobroker
                                  + id iobroker
                                  + '[' 0 -ne 0 ']'
                                  + declare -a groups
                                  + getent group gpio
                                  + getent group i2c
                                  + getent group tty
                                  tty:*:4:iobroker
                                  + cd /opt/iobroker
                                  ++ date +%F
                                  + echo 'Installation date 2019-05-23'
                                  + stepnr=3
                                  + steptotal=4
                                  + echo
                                  + echo
                                        [-Wunused-function]
                                        [-Wunused-function]
                                    int outbaud;
                                                = 0
                                  + stepnr=4
                                  + steptotal=4
                                  + echo
                                  + echo
                                  + INITSYSTEM=rc.d
                                  + [[ -n '' ]]
                                  ++ which bash
                                  ++ cat
                                  ++ cat
                                  # PROVIDE: iobroker
                                  # REQUIRE: DAEMON
                                  # KEYWORD: shutdown
                                  . /etc/rc.subr
                                  name="iobroker"
                                  iobroker_start ()
                                  iobroker_stop ()
                                  iobroker_status ()
                                  + echo '#!/bin/sh
                                  # PROVIDE: iobroker
                                  # REQUIRE: DAEMON
                                  # KEYWORD: shutdown
                                  . /etc/rc.subr
                                  name="iobroker"
                                  iobroker_start ()
                                  iobroker_stop ()
                                  iobroker_status ()
                                  HOST_PLATFORM: Undefined variable.
                                  Autostart enabled!
                                  • M mrMuppet
                                    + [[ 0 -eq 0 ]]
                                    + IS_ROOT=true
                                    + ROOT_GROUP=root
                                    ++ uname
                                    + unamestr=FreeBSD
                                    + ROOT_GROUP=wheel
                                    + IOB_USER=iobroker
                                    + test -t 1
                                    ++ which tput
                                    ++ tput colors
                                    + ncolors=80
                                    + test -n 80
                                    + test 80 -ge 8
                                    ++ tput cols
                                    + termcols=80
                                    ++ tput bold
                                    + bold=
                                    ++ tput smul
                                    + underline=
                                    ++ tput smso
                                    + standout=
                                    ++ tput sgr0
                                    + normal=
                                    ++ tput setaf 0
                                    + black=''
                                    ++ tput setaf 1
                                    + red=''
                                    ++ tput setaf 2
                                    + green=''
                                    ++ tput setaf 3
                                    + yellow=''
                                    ++ tput setaf 4
                                    + blue=''
                                    ++ tput setaf 5
                                    + magenta=''
                                    ++ tput setaf 6
                                    + cyan=''
                                    ++ tput setaf 7
                                    + white=''
                                    + echo
                                    + echo
                                    + echo '    '
                                    + echo
                                    + echo
                                    + NUM_STEPS=4
                                    + stepnr=1
                                    + steptotal=4
                                    + echo
                                    + echo
                                    + package=sudo
                                    + pkg info sudo
                                    + package=git
                                    + pkg info git
                                    + package=curl
                                    + pkg info curl
                                    + package=bash
                                    + pkg info bash
                                    + package=unzip
                                    + pkg info unzip
                                    + package=dbus
                                    + pkg info dbus
                                    + package=nss_mdns
                                    + pkg info nss_mdns
                                    + package=gcc
                                    + pkg info gcc
                                    + package=python
                                    + pkg info python
                                    + stepnr=2
                                    + steptotal=4
                                    + echo
                                    + echo
                                    + username=iobroker
                                    + id iobroker
                                    + '[' 0 -ne 0 ']'
                                    + declare -a groups
                                    + getent group gpio
                                    + getent group i2c
                                    + getent group tty
                                    tty:*:4:iobroker
                                    + cd /opt/iobroker
                                    ++ date +%F
                                    + stepnr=3
                                    + steptotal=4
                                    + echo
                                    + echo
                                          [-Wunused-function]
                                          [-Wunused-function]
                                      int outbaud;
                                                  = 0
                                    + stepnr=4
                                    + steptotal=4
                                    + echo
                                    + echo
                                    + INITSYSTEM=rc.d
                                    + [[ -n '' ]]
                                    ++ which bash
                                    ++ cat
                                    ++ cat
                                    # PROVIDE: iobroker
                                    # REQUIRE: DAEMON
                                    # KEYWORD: shutdown
                                    . /etc/rc.subr
                                    name="iobroker"
                                    iobroker_start ()
                                    iobroker_stop ()
                                    iobroker_status ()
                                    + echo '#!/bin/sh
                                    # PROVIDE: iobroker
                                    # REQUIRE: DAEMON
                                    # KEYWORD: shutdown
                                    . /etc/rc.subr
                                    name="iobroker"
                                    iobroker_start ()
                                    iobroker_stop ()
                                    iobroker_status ()
                                    Autostart enabled!
                                    AlCalzoneA Offline
                                    AlCalzoneA Offline
                                    AlCalzone
                                    @mrMuppet 😕
                                    Irgendwas macht FreeBSD da komisch mit den variablen. Zum nächsten versuch komme ich erst am Wochenende.
                                      @mrMuppet 😕
                                      mrMuppet
                                      @AlCalzone Gibt es schon eine neue "beta"?
                                        AlCalzoneA Offline
                                        AlCalzone
                                        Ich wusste doch, da war was... 😓
                                          mrMuppet
                                          @AlCalzone kannst du bei gelegenheit noch mal reinschauen? 😁
                                          AlCalzoneA 2 Antworten Letzte Antwort
