  4. Google charts in visualization
    5.2k
vis
2 Beiträge 2 Kommentatoren 445 Aufrufe 1 Beobachtet
  • KarolisLK Offline
    KarolisLK Offline
    KarolisL
    Hello,
    does anybody have an idea how to render google charts?
    In editor everything seems to be ok, but in visualization debug window I get these errors
    Error: can't render tplHtml w00006 on "TEST":
    conn.js:1137 Error: 0 - ReferenceError: google is not definedReferenceError: google is not defined
    conn.js:1137 Error: 1 -     at eval (eval at <anonymous> (http://localhost:8082/lib/js/jquery-1.11.2.min.js:2:2622), <anonymous>:2:7)
    conn.js:1137 Error: 2 -     at eval (<anonymous>)
    conn.js:1137 Error: 3 -     at http://localhost:8082/lib/js/jquery-1.11.2.min.js:2:2622
    conn.js:1137 Error: 4 -     at Function.globalEval (http://localhost:8082/lib/js/jquery-1.11.2.min.js:2:2633)
    conn.js:1137 Error: 5 -     at m.fn.init.domManip (http://localhost:8082/lib/js/jquery-1.11.2.min.js:3:23107)
    conn.js:1137 Error: 6 -     at m.fn.init.t.fn.domManip (http://localhost:8082/vis/lib/js/can.custom.min.js:28:2469)
    conn.js:1137 Error: 7 -     at m.fn.init.append (http://localhost:8082/lib/js/jquery-1.11.2.min.js:3:20620)
    conn.js:1137 Error: 8 -     at Object.renderWidget (http://localhost:8082/vis/js/vis.js:1465:27)
    conn.js:1137 Error: 9 -     at http://localhost:8082/vis/js/vis.js:739:120
    conn.js:1137 Error: 10 -     at http://localhost:8082/vis/js/vis.js:2560:31
    hqwidgets.js:899 Version vis-hqwidgets: 1.1.2
    loader.js?_=1556481690293:229 Uncaught Error: Google Charts loader.js can only be loaded once.
        at loader.js?_=1556481690293:229
        at loader.js?_=1556481690293:233
    (anonymous) @ loader.js?_=1556481690293:229
    (anonymous) @ loader.js?_=1556481690293:233
    2VM6327:20 Uncaught (in promise) TypeError: google.visualization.PieChart is not a constructor
        at drawChart (eval at <anonymous> (jquery-1.11.2.min.js:2), <anonymous>:20:21)
    Code is:
    <html>
      <head>
        <script type="text/javascript" src="https://www.gstatic.com/charts/loader.js"></script>
        <script type="text/javascript">
          google.charts.load('current', {'packages':['corechart']});
          google.charts.setOnLoadCallback(drawChart);
          function drawChart() {
            var data = google.visualization.arrayToDataTable([
              ['Task', 'Hours per Day'],
              ['Work',     11],
              ['Eat',      2],
              ['Commute',  2],
              ['Watch TV', 2],
              ['Sleep',    7]
            var options = {
              title: 'My Daily Activities'
            var chart = new google.visualization.PieChart(document.getElementById('piechart'));
            chart.draw(data, options);
        </script>
      </head>
      <body>
        <div id="piechart" style="width: 900px; height: 500px;"></div>
      </body>
    </html>
    • MicM Offline
      MicM Offline
      Mic
      schrieb am zuletzt editiert von Mic
      I had the same issue, Google charts was not working reliable when using the HTML Basic widget in vis.
      Therefore, I generate an html file using the Javascript adapter and display it within an iframe widget. This way, it works perfectly, and I can also use all functions like getState(), etc.
      Example script: https://forum.iobroker.net/topic/22779/vorlage-google-charts-beispiel
