  4. Update JS-Adapter 4.0.12 auf 4.1.12
updateerrorjavascript adapter
12 Beiträge 4 Kommentatoren 1.5k Aufrufe 5 Beobachtet
  • NegaleinN Offline
    NegaleinN Offline
    Negalein
    Nachdem ich durch was auch immer (vermute Blockly mit einem falschen Baustein) einen Fehler im JS-Adapter bekommen habe, wollte ich wiedermal den Adapter von 4.0.12 auf 4.1.12 updaten.
    Node.js ist auf 8.15.1 und NPM auf 6.4.1
    Beim Update kommt folgende Fehlermeldung:
    $ ./iobroker upgrade javascript
    Update javascript from @4.0.12 to @4.1.12
    NPM version: 6.4.1
    npm install iobroker.javascript@4.1.12 --production --save --prefix "/opt/iobroker" (System call)
    module.js:550    throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/install/installTypings.js'
        at Function.Module._resolveFilename (module.js:548:15)
        at Function.Module._load (module.js:475:25)
        at Function.Module.runMain (module.js:694:10)
        at startup (bootstrap_node.js:204:16)
        at bootstrap_node.js:625:3
    npm
     WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN
     optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm ERR! code ELIFECYCLEnpm ERR! errno 1
    npm ERR! iobroker.javascript@4.1.12 postinstall: `node ./install/installTypings.js`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.javascript@4.1.12 postinstall script.
    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR!     /root/.npm/_logs/2019-04-03T12_43_46_728Z-debug.log
    ERROR: Cannot find io-package.json in null
    ERROR: process exited with code 10
    Dann startet sich der JS-Adapter immer wieder neu.
    host.ioBroker	2019-04-03 14:45:51.393	info	iobroker exit 0
    host.ioBroker	2019-04-03 14:45:51.385	error	iobroker Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
    host.ioBroker	2019-04-03 14:45:51.365	error	iobroker host.ioBroker Adapter directory "null" does not exists
    host.ioBroker	2019-04-03 14:45:51.322	info	iobroker /root/.npm/_logs/2019-04-03T12_45_45_625Z-debug.log
    host.ioBroker	2019-04-03 14:45:51.322	info	iobroker ERR!
    host.ioBroker	2019-04-03 14:45:51.321	info	iobroker npm ERR! A complete log of this run can be found in:npm
    host.ioBroker	2019-04-03 14:45:51.319	info	iobroker
    host.ioBroker	2019-04-03 14:45:45.614	info	iobroker ERR! npm ERR! Failed at the iobroker.javascript@4.1.12 postinstall script. npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    host.ioBroker	2019-04-03 14:45:45.614	info	iobroker ERR! iobroker.javascript@4.1.12 postinstall: `node ./install/installTypings.js`npm ERR! Exit status 1 npm
    host.ioBroker	2019-04-03 14:45:45.610	info	iobroker
    host.ioBroker	2019-04-03 14:45:45.610	info	iobroker npm
    host.ioBroker	2019-04-03 14:45:45.610	info	iobroker 1
    host.ioBroker	2019-04-03 14:45:45.608	info	iobroker npm ERR! code ELIFECYCLEnpm ERR! errno
    host.ioBroker	2019-04-03 14:45:45.602	info	iobroker SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    host.ioBroker	2019-04-03 14:45:45.601	info	iobroker notsup
    host.ioBroker	2019-04-03 14:45:45.601	info	iobroker WARN
    host.ioBroker	2019-04-03 14:45:45.601	info	iobroker npm
    host.ioBroker	2019-04-03 14:45:45.601	info	iobroker optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
    host.ioBroker	2019-04-03 14:45:45.601	info	iobroker notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})npm WARN
    host.ioBroker	2019-04-03 14:45:45.600	info	iobroker WARN
    host.ioBroker	2019-04-03 14:45:45.595	info	iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm
    host.ioBroker	2019-04-03 14:45:45.595	info	iobroker npm
    host.ioBroker	2019-04-03 14:45:39.167	info	iobroker module.js:550 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/install/installTypings.js' at Function.Module._resolveFilename (module.js:548:
    host.ioBroker	2019-04-03 14:44:45.198	info	iobroker npm install iobroker.javascript --production --save --prefix "/opt/iobroker" (System call)
    host.ioBroker	2019-04-03 14:44:44.805	info	iobroker NPM version: 6.4.1
    iobroker	2019-04-03 14:44:43.308	info	install javascript
    host.ioBroker	2019-04-03 14:44:43.307	warn	startInstance cannot find adapter "javascript". Try to install it... 2 attempt
    Dann dachte ich, ok, starte ich mal ioBroker neu.
    Brachte auch nichts, ausser dass der JS-Adapter nun garnicht mehr da war.
    Konnte auch nicht installiert werden.
    Ok, dann hab ich das Backup von heute Nacht eingespielt und ich bin wieder auf 4.0.12
    Aber, warum kann ich nicht auf 4.1.12 updaten?
    Liest von euch wer was raus?
    ° Fixer ---> iob fix
    W 1 Antwort Letzte Antwort
    • NegaleinN Negalein
      NPM version: 6.4.1
      npm
      npm WARN
      npm ERR!
      W Offline
      W Offline
      w00dy
      schrieb am zuletzt editiert von w00dy
      @Negalein
      Hi, hast du mal versucht den Adapter über die Konsole zu installieren:
      cd /opt/iobroker
      iobroker update javascript
      Ich hatte auch mal das Problem mit einer jüngeren Version und so ging es dann bei mir.
      Viele Grüße
      w00dy
      NegaleinN 2 Antworten Letzte Antwort
      • W w00dy
        @Negalein
        cd /opt/iobroker
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        @Hicks sagte in Update JS-Adapter 4.0.12 auf 4.1.12:
        Danke, werd ich morgen versuchen.
        Muss blad weg und da hätte ich keine Zeit für noch einen Restore.
        • W w00dy
          @Negalein
          cd /opt/iobroker
          NegaleinN Offline
          NegaleinN Offline
          Negalein
          Sorry für die Verspätung!
          Dies hat leider auch nicht funktioniert.
          • MyzerATM Offline
            MyzerATM Offline
            MyzerAT
            mach mal "upload" beim JS Adapter
            lg Rudi
            Node 22.23.0
            Nodejs 22.23.0
            npm 10.9.8
            js-controller 7.2.2
            • MyzerATM MyzerAT
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              @MyzerAT sagte in Update JS-Adapter 4.0.12 auf 4.1.12:
              ist ohne Fehler durchgelaufen.
              $ ./iobroker upload javascript
              got /opt/iobroker/node_modules/iobroker.javascript/admin
              upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/redshift/redshift.js vs/basic-languages/redshift/redshift.js application/javascript
              upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/objective-c/objective-c.js vs/basic-languages/objective-c/objective-c.js application/javascript
              upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/go/go.js vs/basic-languages/go/go.js application/javascript
              upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vendor/socket.io.js vendor/socket.io.js application/javascript
              upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/css/main.071206b3.chunk.css static/css/main.071206b3.chunk.css text/css
              upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/it.js google-blockly/own/msg/it.js application/javascript
              upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_timeout.js google-blockly/own/blocks_timeout.js application/javascript
              upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/pl.js google-blockly/msg/js/pl.js application/javascript
              upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/quote0.png google-blockly/media/quote0.png image/png
              upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handopen.cur google-blockly/media/handopen.cur application/octet-stream
              upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handdelete.cur google-blockly/media/handdelete.cur application/octet-stream
              upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handclosed.cur google-blockly/media/handclosed.cur application/octet-stream
              upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.wav google-blockly/media/disconnect.wav audio/wav
              upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.ogg google-blockly/media/disconnect.ogg audio/ogg
              upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.mp3 google-blockly/media/disconnect.mp3 audio/mpeg
              upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/wav
              upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.ogg google-blockly/media/delete.ogg audio/ogg
              upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.mp3 google-blockly/media/delete.mp3 audio/mpeg
              upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.wav google-blockly/media/click.wav audio/wav
              upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.ogg google-blockly/media/click.ogg audio/ogg
              upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
              upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/1x1.gif google-blockly/media/1x1.gif image/gif
              upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/javascript_compressed.js google-blockly/javascript_compressed.js application/javascript
              upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blocks_compressed.js google-blockly/blocks_compressed.js application/javascript
              upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly_compressed.js google-blockly/blockly_compressed.js application/javascript
              upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE application/octet-stream
              upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/favicon.ico favicon.ico image/x-icon
              upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/asset-manifest.json asset-manifest.json application/json
              upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
              process exited with code 0
              Meinst, ich kann jetzt ein Update auf 4.1.12 wagen?
              • MyzerATM Offline
                MyzerATM Offline
                MyzerAT
                leider kenn ich mich da zu wenig aus, was ich rauslese, das er als error angibt die datei "io-package.json" nicht zu finden, mach mal eine suche nach dieser datei, bei mir liegt die unter
                \\DS216II\docker\iobroker_mount\node_modules\iobroker.milight-smart-light\io-package.json
                lg Rudi
                Node 22.23.0
                Nodejs 22.23.0
                npm 10.9.8
                js-controller 7.2.2
                paul53P NegaleinN 2 Antworten Letzte Antwort
                • MyzerATM MyzerAT
                  @MyzerAT sagte:
                  Das ist eine andere io-package.json. Jeder Adapter hat eine Datei io-package.json. Die für den JS-Adapter ist /opt/iobroker/node_modules/iobroker.javascript/io-package.json.
                  • MyzerATM MyzerAT
                    NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    die io-package.json liegt bei mir in jedem Adapterverzeichnis.
                    Unter anderem auch in /docker/iobroker_mount/node_modules/iobroker.javascript
                      W Offline
                      W Offline
                      w00dy
                      @Negalein
                      Ich würde den JS-Adapter über den Expertenmodus komplett löschen, dann neu installieren und danach uploaden.
                      Ist evtl. einen Versuch wert.
                      Viele Grüße
                      w00dy
                      • W w00dy
                        @Negalein
                        NegaleinN Offline
                        NegaleinN Offline
                        Negalein
                        Danke, werde ich auch versuchen.
                        • NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          Da mich bis jetzt nichts weitergebracht hat, möchte ich fragen, ob noch jemand einen Tipp hat.
