  4. Strom Weg - Iobroker startet nicht mehr
  • Weihnachtsangebot 2025! 🎄
    1.0k
    apollon77A
    48
    9.1k
    2.4k
stromausfall boot errorbooterror
9 Beiträge 4 Kommentatoren 840 Aufrufe 3 Watching
    DavidFD
    Hab aktuell ein Problem mit meiner IObroker Installation.
    Kurz war der Storm weg (hab bisschen umverkabelt ;)) und seitdem startet der Broker nicht mehr.
    Log sagt folgendes:
    root@odroidxu4:/opt/iobroker# node node_modules/iobroker.js-controller/controller.js --logs
    2019-02-23 12:12:00.225  - info: host.xu4 iobroker.js-controller version 1.4.2 js-controller starting
    2019-02-23 12:12:00.232  - info: host.xu4 Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
    2019-02-23 12:12:00.233  - info: host.xu4 hostname: xu4, node: v8.15.0
    2019-02-23 12:12:00.237  - info: host.xu4 ip addresses: 192.168.188.10 2003:e0:c3e4:c500:20a3:d49e:eded:53d3 fe80::c139:b5a4:d6cb:669
    2019-02-23 12:12:00.358  - info: host.xu4  inMem-objects listening on port 9001
    2019-02-23 12:12:00.378  - error: Another instance is running or some application uses port!
    2019-02-23 12:12:00.378  - error: uncaught exception: listen EADDRINUSE 127.0.0.1:9001
    2019-02-23 12:12:00.390  - info: iobroker _restart
    2019-02-23 12:12:00.434  - info: host.xu4 States connected to redis: 127.0.0.1:6379
    2019-02-23 12:12:00.436  - info: host.xu4 InMemoryDB connected
    2019-02-23 12:12:00.453  - info: host.xu4 no instances found
    2019-02-23 12:12:00.503  - info: host.xu4 terminated
    Cannot read property 'callback' of undefined
    TypeError: Cannot read property 'callback' of undefined
        at normal_reply (/opt/iobroker/node_modules/redis/index.js:722:28)
        at RedisClient.return_reply (/opt/iobroker/node_modules/redis/index.js:824:9)
        at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/redis/index.js:192:18)
        at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:574:12)
        at Socket.<anonymous> (/opt/iobroker/node_modules/redis/index.js:274:27)
        at emitOne (events.js:116:13)
        at Socket.emit (events.js:211:7)
        at addChunk (_stream_readable.js:263:12)
        at readableAddChunk (_stream_readable.js:250:11)
        at Socket.Readable.push (_stream_readable.js:208:10)
    objects und states bak datei hab ich schon getestet.
    Was hab ich noch für möglichkeiten?
    2 Raspis als Multihost, Homematic, Xiaomi und Hue.
    Bastelprojekte auf www.derfrickler.de zu finden.
    Aktuell:
    • D DavidFD
      Log sagt folgendes:
      sigi234S Online
      sigi234S Online
      sigi234
      @DavidFD
      Link Text
      Erst anschauen, ob admin aktiviert ist:
      cd /opt/iobroker
      iobroker list instances
      es muss so eine Zeile zu sehen sein:
      system.adapter.admin.0 : admin - enabled, port: 8081, bind: 0.0.0.0, run as: admin
      Falls da “disabled” statt “enabled” steht, man kann Adapter so aktivieren:
      iobroker start admin
      Immer Daten sichern!
      • wendy2702W Online
        wendy2702W Online
        wendy2702
        @DavidFD sagte in Strom Weg - Iobroker startet nicht mehr:
        Scheinbar nutzt irgendetwas anderes schon diesen Port oder läuft bereits.
          DavidFD
          list instances bleibt vollständig leer.
          Kein lebenszeichen im Iobroker
          Aktuell:
          • wendy2702W Online
            wendy2702W Online
            wendy2702
            Was kommt denn hier:
            netstat -a |grep 9001
            • apollon77A Offline
              ich tippe das es durch den Stromausfall die objects.json zerschossen hat und daher jetzt" alles weg" ist.
              Bitte im ioBroker-Verzeichnis in iobroker-data mal schauen. Es gibt eine objects.bak und auch weitere Backups in einem Unterverzeichnis. In so einem Fall hilft es meistens die File-Größe zu vergleichen.
              • wendy2702W wendy2702
                DavidFD
                @wendy2702 said in Strom Weg - Iobroker startet nicht mehr:
                tcp        0      0 localhost:9001          0.0.0.0:*               LISTEN
                bekomme ich da. leider nicht so aussagekräftig
                Aktuell:
                • apollon77A apollon77
                  DavidFD
                  @apollon77
                  die bak hab ich schon ersetzt, leider ohne erfolg.
                  liest sich eigentlich nach einem redisfehler für mich.
                  Kann man das irgendwie wieder zum laufen bringen?
                  Aktuell:
                    DavidFD
                    Problem konnt ich leider nicht ausfindig machen. Aber bin zumindest wieder Einsatzbereit.
                    Hab via setup custom die Ports 9001 und 9000 abgeändert und kann iobroker wieder normal nutzen
                    Aktuell:
                    32.5k
                    81.6k
