  4. ZWAVE adapter funkt auf BEELINK Gemini X nicht
zwave adapter
2 Beiträge 1 Kommentatoren 303 Aufrufe
  • G Offline
    geka79
    Hallo
    Ich bräuchte Eure Hilfe.
    Bin von RPI3 auf BEELINK Gemini x umgestiegen.
    Der ZWAVE Adapter startet nach einem Neustart leider nicht.
    Hab den Adapter schon manuell installiert, dann läuft er.
    Jem eine Idee?
    Gerhard
    Fehlermeldung:
    undefined2019-02-20 17:51:11.437 - info: host.geka-Gemini-X instance system.adapter.zwave.0 started with pid 3567
    2019-02-20 17:51:11.935 - info: zwave.0 starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.zwave, node: v8.15.0
    2019-02-20 17:51:12.006 - error: zwave.0 uncaught exception: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
    2019-02-20 17:51:12.007 - error: zwave.0 Error: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
    at Object.Module._extensions..node (module.js:682:18)
    at Module.load (module.js:566:32)
    at tryModuleLoad (module.js:506:12)
    at Function.Module._load (module.js:498:3)
    at Module.require (module.js:597:17)
    at require (internal/module.js:11:18)
    at Object. (/opt/iobroker/node_modules/openzwave-shared/lib/openzwave-shared.js:24:22)
    at Module._compile (module.js:653:30)
    at Object.Module._extensions..js (module.js:664:10)
    2019-02-20 17:51:12.014 - info: zwave.0 terminating
    2019-02-20 17:51:12.025 - error: Caught by controller[0]: Error: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
    2019-02-20 17:51:12.026 - error: Caught by controller[0]: at Object.Module._extensions..node (module.js:682:18)
    2019-02-20 17:51:12.026 - error: Caught by controller[0]: at Module.load (module.js:566:32)
    2019-02-20 17:51:12.026 - error: Caught by controller[0]: at tryModuleLoad (module.js:506:12)
    2019-02-20 17:51:12.026 - error: Caught by controller[0]: at Function.Module._load (module.js:498:3)
    2019-02-20 17:51:12.026 - error: Caught by controller[0]: at Module.require (module.js:597:17)
    2019-02-20 17:51:12.026 - error: Caught by controller[0]: at require (internal/module.js:11:18)
    2019-02-20 17:51:12.026 - error: Caught by controller[0]: at Object. (/opt/iobroker/node_modules/openzwave-shared/lib/openzwave-shared.js:24:22)
    2019-02-20 17:51:12.026 - error: Caught by controller[0]: at Module._compile (module.js:653:30)
    2019-02-20 17:51:12.026 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
    2019-02-20 17:51:12.026 - error: host.geka-Gemini-X instance system.adapter.zwave.0 terminated with code 0 (OK)
    2019-02-20 17:51:12.026 - info: host.geka-Gemini-X Restart adapter system.adapter.zwave.0 because enabled
    • G Offline
      geka79
      gelöst nach kompletter Neuinstallation mit Hilfe von Beitrag:
      https://forum.iobroker.net/topic/6607/gelöst-problem-mit-der-installation-des-zwave-adapters/7
      kann ich dass irgendwie automatisieren?
      muss bei jeden Neustart gemacht werde. :(
