  4. Probleme mit Update auf js-controller 1.5.7
js-controller 1.5.7
1 Beiträge 1 Kommentatoren 400 Aufrufe 1 Beobachtet
    dav71701
    vielleicht kennt jemand eine Lösung für den folgenden Fehler beim Update vom js-controller:
    Betriebssystem Ubuntu 18.4 LTS
    root@iobroker:/opt/iobroker# nodejs -v
    v8.15.0
    root@iobroker:/opt/iobroker# node -v
    v8.15.0
    root@iobroker:/opt/iobroker# npm -v
    6.4.1
    root@iobroker:/opt/iobroker# npm install iobroker.js-controller --production
    > iobroker.js-controller@1.5.7 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.4.1
    npm version >= 5: disabling package-lock
    > unix-dgram@0.2.3 install /opt/iobroker/node_modules/unix-dgram
    > node-gyp rebuild
    make: Entering directory '/opt/iobroker/node_modules/unix-dgram/build'
      CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
      SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
      COPY Release/unix_dgram.node
    make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
    > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
    > node rebuild.js
    > diskusage@0.2.6 install /opt/iobroker/node_modules/diskusage
    > node-gyp rebuild
    make: Entering directory '/opt/iobroker/node_modules/diskusage/build'
      CXX(target) Release/obj.target/diskusage/src/main.o
      CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
      SOLINK_MODULE(target) Release/obj.target/diskusage.node
      COPY Release/diskusage.node
    make: Leaving directory '/opt/iobroker/node_modules/diskusage/build'
    > iobroker.js-controller@1.5.7 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    > rsa-compat@1.9.2 postinstall /opt/iobroker/node_modules/rsa-compat
    > node lib/telemetry.js event:install
    npm WARN winston-daily-rotate-file@1.7.2 requires a peer of winston@2.x but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    + iobroker.js-controller@1.5.7
    added 19 packages from 39 contributors, removed 202 packages, updated 2 packages, moved 75 packages and audited 6331 packages in 96.711s
    found 75 vulnerabilities (54 low, 2 moderate, 19 high)
      run `npm audit fix` to fix them, or `npm audit` for details
    und beim starten kommt dann:
    root@iobroker:/opt/iobroker# iobroker start
    Starting iobroker controller daemon...
    /opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136
                throw new Error(msg.error);
    Error: TypeError: Cannot set property DailyRotateFile of #<Object> which has only a getter
        at Object.<anonymous> (/opt/iobroker/node_modules/winston-daily-rotate-file/index.js:184:36)
        at Module._compile (module.js:653:30)
        at Object.Module._extensions..js (module.js:664:10)
        at Module.load (module.js:566:32)
        at tryModuleLoad (module.js:506:12)
        at Function.Module._load (module.js:498:3)
        at Module.require (module.js:597:17)
        at require (internal/module.js:11:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/logger.js:7:25)
        at ChildProcess.<anonymous> (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136:19)
        at emitTwo (events.js:126:13)
        at ChildProcess.emit (events.js:214:7)
        at emit (internal/child_process.js:762:12)
        at _combinedTickCallback (internal/process/next_tick.js:142:11)
        at process._tickCallback (internal/process/next_tick.js:181:9)
    hat jemand eine Idee?
