  4. Multihost, Problem nach backup Wiederherstellung
backupmultihost
6 Beiträge 2 Kommentatoren 599 Aufrufe 1 Beobachtet
    rascal
    Ich habe heute in der Früh mit dem backup Adapter ein normales Backup wiederhergestellt.
    Ich habe iobroker im Multihost laufen. Der Main läuft einwandfrei, nur die 3 Remotes melden alle das Selbe:
    root@Wetterstation:/opt/iobroker# iobroker status
    iobroker is running
     Ready check failed: Connection forcefully ended and command aborted. It might have been processed.
     AbortError: Ready check failed: Connection forcefully ended and command aborted. It might have been processed.
        at RedisClient.flush_and_error (/opt/iobroker/node_modules/redis/index.js:362:23)
        at RedisClient.end (/opt/iobroker/node_modules/redis/lib/extendedApi.js:52:14)
        at StateRedis.destroy (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:272:20)
        at processExit (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2820:44)
        at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:312:25
        at Object.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3124:70)
        at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemClient.js:120:68)
        at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
        at Socket.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:138:10)
        at Socket.onconnect (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:335:8)
    Was kann ich machen, damit die Remotes wieder laufen?
    • R rascal
      iobroker is running
      @rascal said in Multihost, Problem nach backup Wiederherstellung:
      Da war mal was!??
      Scheint aber problemlos zu laufen. Keine Panik
      Rainer
        rascal
        bin schon ein Stückchen weiter...
        root@Wetterstation:/opt/iobroker# iobroker multihost connect
        1 |        192.168.1.10 |  host |        192.168.1.10 | "authentication required"
        Please select host [1]: 1
        Enter secret phrase for connection: ******
        Cannot connect to "192.168.1.10": invalid password
        welches Passwort? Ich habe im Main keines gesetzt.
        Wo kann ich dieses definieren?
          rascal
          Berichtigung... der Main zeigt mir die selben Fehlermeldungen wie die Remotes
            rascal
            im Iobroker bekomme ich folgende Fehlermeldung:
            host.Mastermind	2019-02-11 17:48:12.506	error	multihost service error: Error: bind EADDRINUSE 0.0.0.0:50005 at Object._errnoException (util.js:1022:11) at _exceptionWithHostPort (util.js:1044:20) at _handle.lookup (dgram.js:266:18)
            host.Mastermind	2019-02-11 17:48:07.501	error	at process._tickCallback (internal/process/next_tick.js:180:9)
            host.Mastermind	2019-02-11 17:48:07.501	error	at _combinedTickCallback (internal/process/next_tick.js:141:11)
            host.Mastermind	2019-02-11 17:48:07.501	error	at _handle.lookup (dgram.js:266:18)
            host.Mastermind	2019-02-11 17:48:07.501	error	at _exceptionWithHostPort (util.js:1044:20)
            host.Mastermind	2019-02-11 17:48:07.501	error	at Object._errnoException (util.js:1022:11)
            host.Mastermind	2019-02-11 17:48:07.501	error	multihost service error: Error: bind EADDRINUSE 0.0.0.0:50005
            host.Mastermind	2019-02-11 17:48:02.500	error	at process._tickCallback (internal/process/next_tick.js:180:9)
            host.Mastermind	2019-02-11 17:48:02.500	error	at _combinedTickCallback (internal/process/next_tick.js:141:11)
            host.Mastermind	2019-02-11 17:48:02.500	error	at _handle.lookup (dgram.js:266:18)
            host.Mastermind	2019-02-11 17:48:02.500	error	at _exceptionWithHostPort (util.js:1044:20)
            host.Mastermind	2019-02-11 17:48:02.500	error	at Object._errnoException (util.js:1022:11)
            host.Mastermind	2019-02-11 17:48:02.500	error	multihost service error: Error: bind EADDRINUSE 0.0.0.0:50005
            LG
              rascal
              Ich habe im Main ein Passwort gesetzt über "iobroker multihost..."
              Ich habe die Remotes mit diesem Passwort wieder verbunden.
              Ich habe alle iobroker Instanzen gestoppt und schrittweise wieder gestartet.
              Im Iobroker Log habe ich jetzt keine Fehlermeldungen mehr und es scheint alles so zu laufen wie es soll.. nur wenn ich "iobroker status" eingebe bekomme ich die Fehlermeldung aus dem ersten Post.
