  4. Div. Fehler beim Update
    6.8k
15 Beiträge 5 Kommentatoren 2.9k Aufrufe
    pid5be0
    Hallo, ich habe Probleme gesehen beim heutigen Update der Homematic ReGass und RPC Adapter.
    $ ./iobroker upgrade hm-rpc
    Update hm-rpc from @1.9.0 to @1.9.1
    NPM version: 6.4.1
    npm install iobroker.hm-rpc@1.9.1 --production --save --prefix "/opt/iobroker" (System call)
    npm
    WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/iobroker.type-detector'
    npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.hm-rpc"
    npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
    npm notice created a lockfile as package-lock.json. You should commit this file.
    got /opt/iobroker/node_modules/iobroker.hm-rpc/admin
    Update "system.adapter.hm-rpc.0"
    Update "system.adapter.hm-rpc.1"
    Ebenfalls wenn ich den cache vom NPM leeren will (Shell Access via "root")
    # npm cache clean
    npm ERR! As of npm@5, the npm cache self-heals from corruption issues and data extracted from the cache is guaranteed to be valid. If you want to make sure everything is consistent, use 'npm cache verify' instead. On the other hand, if you're debugging an issue with the installer, you can use `npm install --cache /tmp/empty-cache` to use a temporary cache instead of nuking the actual one.
    npm ERR!
    npm ERR! If you're sure you want to delete the entire cache, rerun this command with --force.
    npm ERR!     /root/.npm/_logs/2019-01-12T13_45_27_092Z-debug.log
    root@debian-iobroker:/opt/iobroker/backups# npm cache clean --force
    npm WARN using --force I sure hope you know what you are doing.
    Kann mir ggf. jemand helfen das Problem zu fixen?
    Meine Systemdaten:
    Iobroker auf debian 9.x vor ca. 1,5 Jahren installiert (alte Variante).
    Node Version: 8.15.0
    Jasion Version: 1.4.2
    Danke vorab fürs lesen :-)
    ****geändert: Code in Code-Tags; Homoran (Admin)****
    IOBROKER via VM auf QNAP TS453, Unify Network (Switch/WLAN), Hardware Firewall - SIF, Raspberry für Homematic
    • SegwayS Offline
      SegwayS Offline
      Segway
      Welche npm version ? (npm -v)
      Gruß Dirk
        pid5be0
        Hi
        ****root@debian-iobroker: # npm -v
        6.4.1****
          pid5be0
          Ich habe gerade nochmal "nodejs" neu installiert und danach das "reinstall.sh" script ausgeführt. Das Ergebnis, das Script bricht ab, weil in der Zeile 34 & 37 nichts drin steht.
          Habe mich an die Anleitung von IOBROKER gehalten.
          root@debian-iobroker:/opt/iobroker# ./reinstall.sh
          Stopping iobroker controller daemon...
          iobroker controller daemon stopped.
          Exit code for "killall.sh": 123
          + iobroker.admin@3.5.10
          added 173 packages from 128 contributors and audited 353 packages in 28.796s
          found 11 vulnerabilities (8 low, 3 high)
            run `npm audit fix` to fix them, or `npm audit` for details
          DONE iobroker.admin
          + iobroker.alexa2@1.1.3
          added 144 packages from 115 contributors and audited 1420 packages in 23.347s
          DONE iobroker.alexa2
          + iobroker.flot@1.9.2
          added 1 package from 1 contributor and audited 1421 packages in 10.688s
          DONE iobroker.flot
          + iobroker.fritzbox@0.2.1
          added 4 packages from 49 contributors and audited 1425 packages in 10.863s
          DONE iobroker.fritzbox
          + iobroker.geofency@0.3.2
          added 1 package from 2 contributors and audited 1489 packages in 10.593s
          DONE iobroker.geofency
          + iobroker.hm-rega@2.1.2
          added 4 packages from 39 contributors and audited 1562 packages in 11.134s
          DONE iobroker.hm-rega
          + iobroker.hm-rpc@1.9.1
          added 10 packages from 22 contributors and audited 1575 packages in 13.061s
          DONE iobroker.hm-rpc
          + iobroker.ical@1.7.0
          added 7 packages from 13 contributors and audited 1711 packages in 14.48s
          DONE iobroker.ical
          + iobroker.iot@0.2.2
          added 69 packages from 38 contributors and audited 2015 packages in 20.817s
          DONE iobroker.iot
          npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
          > iobroker.javascript@4.0.7 postinstall /opt/iobroker/node_modules/iobroker.javascript
          > node ./install/installTypings.js
          Installing NodeJS typings...
          latest @types: 10, installed node: 8
          + iobroker.javascript@4.0.7
          added 23 packages from 58 contributors and audited 2107 packages in 28.831s
          DONE iobroker.javascript
          > iobroker.js-controller@1.4.2 preinstall /opt/iobroker/node_modules/iobroker.js-controller
          > node lib/preinstall_check.js
          NPM version: 6.4.1
          npm version >= 5: disabling package-lock
          > unix-dgram@0.2.3 install /opt/iobroker/node_modules/unix-dgram
          > node-gyp rebuild
          make: Entering directory '/opt/iobroker/node_modules/unix-dgram/build'
            CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
            SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
            COPY Release/unix_dgram.node
          make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
          > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
          > node rebuild.js
          > iobroker.js-controller@1.4.2 install /opt/iobroker/node_modules/iobroker.js-controller
          > node iobroker.js setup first
          > rsa-compat@1.9.2 postinstall /opt/iobroker/node_modules/rsa-compat
          > node lib/telemetry.js event:install
          + iobroker.js-controller@1.4.2
          added 150 packages from 100 contributors and audited 2875 packages in 56.773s
          found 22 vulnerabilities (16 low, 6 high)
          DONE iobroker.js-controller
          + iobroker.mqtt@2.0.4
          added 17 packages from 11 contributors and audited 3266 packages in 23.388s
          DONE iobroker.mqtt
          + iobroker.shelly@2.0.5
          added 17 packages from 31 contributors and audited 3378 packages in 21.828s
          found 23 vulnerabilities (17 low, 6 high)
          DONE iobroker.shelly
          + iobroker.simple-api@2.0.0
          added 1 package from 2 contributors and audited 3379 packages in 20.079s
          DONE iobroker.simple-api
          + iobroker.socketio@2.1.1
          added 1 package from 1 contributor and audited 3548 packages in 19.626s
          found 34 vulnerabilities (25 low, 9 high)
          DONE iobroker.socketio
          npm WARN deprecated sprintf@0.1.5: The sprintf package is deprecated in favor of sprintf-js.
          npm WARN deprecated node-uuid@1.4.8: Use uuid module instead
          > sqlite3@4.0.6 install /opt/iobroker/node_modules/sqlite3
          > node-pre-gyp install --fallback-to-build
          node-pre-gyp WARN Using request for node-pre-gyp https download
          [sqlite3] Success: "/opt/iobroker/node_modules/sqlite3/lib/binding/node-v57-linux-x64/node_sqlite3.node" is installed via remote
          + iobroker.sql@1.9.2
          added 91 packages from 111 contributors and audited 3872 packages in 37.166s
          DONE iobroker.sql
          + iobroker.telegram@1.3.6
          added 27 packages from 71 contributors and audited 4015 packages in 28.655s
          found 35 vulnerabilities (26 low, 9 high)
          DONE iobroker.telegram
          npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
          + iobroker.tr-064@0.4.18
          added 11 packages from 7 contributors and audited 4098 packages in 24.763s
          found 36 vulnerabilities (27 low, 9 high)
          DONE iobroker.tr-064
          npm ERR! code ENOLOCAL
          npm ERR! Could not install from "node_modules/iobroker.type-detector" as it does not contain a package.json file.
          npm ERR!     /root/.npm/_logs/2019-01-12T16_08_56_695Z-debug.log
          FAIL iobroker.type-detector
          + iobroker.unifi@0.3.1
          added 3 packages from 2 contributors and audited 4165 packages in 26.234s
          DONE iobroker.unifi
          > iobroker.vis@1.1.8 install /opt/iobroker/node_modules/iobroker.vis
          > node main.js --install
          + iobroker.vis@1.1.8
          added 1 package from 2 contributors and audited 4182 packages in 31.589s
          DONE iobroker.vis
          + iobroker.web@2.4.1
          added 1 package from 1 contributor and audited 4642 packages in 25.868s
          found 52 vulnerabilities (38 low, 14 high)
          DONE iobroker.web
          got /opt/iobroker/node_modules/iobroker.iot/admin
          upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/words.js words.js application/javascript
          upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
          upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
          upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
          upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
          upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
          got /opt/iobroker/node_modules/iobroker.tr-064/admin
          upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
          upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
          upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index.html index.html text/html
          got /opt/iobroker/node_modules/iobroker.alexa2/admin
          upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript
          upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
          upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index.html index.html text/html
          upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
          upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
          upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
          upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
          upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
          upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
          upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
          upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
          upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
          upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
          upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot.png icons/echo_dot.png image/png
          upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo2.png icons/echo2.png image/png
          upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo.png icons/echo.png image/png
          upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
          got /opt/iobroker/node_modules/iobroker.shelly/admin
          upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
          upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
          upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/index_m.html index_m.html text/html
          Cannot find io-package.json in null
          Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
          got /opt/iobroker/node_modules/iobroker.mqtt/admin
          upload [3] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/words.js words.js application/javascript
          upload [2] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/mqtt.png mqtt.png image/png
          upload [1] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/index_m.html index_m.html text/html
          upload [0] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/index.html index.html text/html
          got /opt/iobroker/node_modules/iobroker.fritzbox/admin
          upload [1] fritzbox.admin /opt/iobroker/node_modules/iobroker.fritzbox/admin/index.html index.html text/html
          upload [0] fritzbox.admin /opt/iobroker/node_modules/iobroker.fritzbox/admin/fritzbox.png fritzbox.png image/png
          got /opt/iobroker/node_modules/iobroker.vis/admin
          upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
          upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
          upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
          upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
          Adapter "system.adapter.vis.0" restarted.
          got /opt/iobroker/node_modules/iobroker.vis/www
          upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/jquery.sliderTabs.js widgets/tabs/jquery.sliderTabs.js application/javascript
          (node:1292) [DEP0013] DeprecationWarning: Calling an asynchronous function without callback is deprecated.
          upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ValueBoolCtrlSvg.png widgets/basic/img/Prev_ValueBoolCtrlSvg.png image/png
          upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
          upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/js/visEditWelcome.js js/visEditWelcome.js application/javascript
          upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/actions/edit-rename.png js/fm/icon/actions/edit-rename.png image/png
          upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/js/app.js js/app.js application/javascript
          upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/img/garage-door-closed.png img/garage-door-closed.png image/png
          upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/img/bulb_off.png img/bulb_off.png image/png
          upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/img/bg-dots-10.svg img/bg-dots-10.svg image/svg+xml
          upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/tools.png icon/tools.png image/png
          upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/refresh-4.png icon/refresh-4.png image/png
          upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/door.png icon/door.png image/png
          upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/bar.png icon/bar.png image/png
          upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-width.png icon/align-width.png image/png
          upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-top-2.png icon/align-vertical-top-2.png image/png
          upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-center-2.png icon/align-vertical-center-2.png image/png
          upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-bottom-2.png icon/align-vertical-bottom-2.png image/png
          upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-right-2.png icon/align-horizontal-right-2.png image/png
          upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-left.png icon/align-horizontal-left.png image/png
          upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-center-2.png icon/align-horizontal-center-2.png image/png
          upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-height.png icon/align-height.png image/png
          upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/add.png icon/add.png image/png
          upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.html edit.html text/html
          upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis.css css/vis.css text/css
          upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis-editor.css css/vis-editor.css text/css
          upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/css/styles.css css/styles.css text/css
          upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/css/montserrat-regular-webfont.woff css/montserrat-regular-webfont.woff application/font-woff
          upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/css/doc.css css/doc.css text/css
          upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/css/backgrounds.css css/backgrounds.css text/css
          upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/css/app.css css/app.css text/css
          upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/css/add_kian.css css/add_kian.css text/css
          upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/cordova.js cordova.js application/javascript
          upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
          got /opt/iobroker/node_modules/iobroker.unifi/admin
          upload [1] unifi.admin /opt/iobroker/node_modules/iobroker.unifi/admin/unifi.png unifi.png image/png
          upload [0] unifi.admin /opt/iobroker/node_modules/iobroker.unifi/admin/index.html index.html text/html
          got /opt/iobroker/node_modules/iobroker.unifi/www
          upload [1] unifi /opt/iobroker/node_modules/iobroker.unifi/www/index.html index.html text/html
          upload [0] unifi /opt/iobroker/node_modules/iobroker.unifi/www/README.md README.md text/markdown
          got /opt/iobroker/node_modules/iobroker.telegram/admin
          upload [4] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/words.js words.js application/javascript
          upload [3] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/telegram.png telegram.png image/png
          upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index_m.html index_m.html text/html
          upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index.html index.html text/html
          upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blockly.js blockly.js application/javascript
          got /opt/iobroker/node_modules/iobroker.sql/admin
          upload [5] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/words.js words.js application/javascript
          upload [4] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/sql.png sql.png image/png
          upload [3] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/index_m.html index_m.html text/html
          upload [2] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/index.html index.html text/html
          upload [1] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/custom_m.html custom_m.html text/html
          upload [0] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/custom.html custom.html text/html
          got /opt/iobroker/node_modules/iobroker.javascript/admin
          upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/redshift/redshift.js vs/basic-languages/redshift/redshift.js application/javascript
          upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/objective-c/objective-c.js vs/basic-languages/objective-c/objective-c.js application/javascript
          upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/go/go.js vs/basic-languages/go/go.js application/javascript
          upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vendor/socket.io.js vendor/socket.io.js application/javascript
          upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/css/main.cd153a24.chunk.css static/css/main.cd153a24.chunk.css text/css
          upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/it.js google-blockly/own/msg/it.js application/javascript
          upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_timeout.js google-blockly/own/blocks_timeout.js application/javascript
          upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/pl.js google-blockly/msg/js/pl.js application/javascript
          upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/quote0.png google-blockly/media/quote0.png image/png
          upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handopen.cur google-blockly/media/handopen.cur application/octet-stream
          upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handdelete.cur google-blockly/media/handdelete.cur application/octet-stream
          upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handclosed.cur google-blockly/media/handclosed.cur application/octet-stream
          upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.wav google-blockly/media/disconnect.wav audio/x-wav
          upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.ogg google-blockly/media/disconnect.ogg audio/ogg
          upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.mp3 google-blockly/media/disconnect.mp3 audio/mpeg
          upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/x-wav
          upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.ogg google-blockly/media/delete.ogg audio/ogg
          upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.mp3 google-blockly/media/delete.mp3 audio/mpeg
          upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.wav google-blockly/media/click.wav audio/x-wav
          upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.ogg google-blockly/media/click.ogg audio/ogg
          upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
          upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/1x1.gif google-blockly/media/1x1.gif image/gif
          upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/javascript_compressed.js google-blockly/javascript_compressed.js application/javascript
          upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blocks_compressed.js google-blockly/blocks_compressed.js application/javascript
          upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly_compressed.js google-blockly/blockly_compressed.js application/javascript
          upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE application/octet-stream
          upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/favicon.ico favicon.ico image/x-icon
          upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/asset-manifest.json asset-manifest.json application/json
          upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
          got /opt/iobroker/node_modules/iobroker.ical/admin
          upload [3] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/words.js words.js application/javascript
          upload [2] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/index_m.html index_m.html text/html
          upload [1] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/index.html index.html text/html
          upload [0] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/ical.png ical.png image/png
          got /opt/iobroker/node_modules/iobroker.geofency/admin
          upload [2] geofency.admin /opt/iobroker/node_modules/iobroker.geofency/admin/words.js words.js application/javascript
          upload [1] geofency.admin /opt/iobroker/node_modules/iobroker.geofency/admin/index.html index.html text/html
          upload [0] geofency.admin /opt/iobroker/node_modules/iobroker.geofency/admin/geofency.png geofency.png image/png
          got /opt/iobroker/node_modules/iobroker.flot/admin
          upload [0] flot.admin /opt/iobroker/node_modules/iobroker.flot/admin/flot.png flot.png image/png
          got /opt/iobroker/node_modules/iobroker.flot/www
          upload [20] flot /opt/iobroker/node_modules/iobroker.flot/www/js/flot.js js/flot.js application/javascript
          upload [19] flot /opt/iobroker/node_modules/iobroker.flot/www/js/edit.js.map js/edit.js.map application/json
          upload [18] flot /opt/iobroker/node_modules/iobroker.flot/www/js/edit.js js/edit.js application/javascript
          upload [17] flot /opt/iobroker/node_modules/iobroker.flot/www/index.html.map index.html.map application/json
          upload [16] flot /opt/iobroker/node_modules/iobroker.flot/www/index.html index.html text/html
          upload [15] flot /opt/iobroker/node_modules/iobroker.flot/www/img/favicon.png img/favicon.png image/png
          upload [14] flot /opt/iobroker/node_modules/iobroker.flot/www/edit.html.map edit.html.map application/json
          upload [13] flot /opt/iobroker/node_modules/iobroker.flot/www/edit.html edit.html text/html
          upload [12] flot /opt/iobroker/node_modules/iobroker.flot/www/css/jquery.colorpicker.css css/jquery.colorpicker.css text/css
          upload [11] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/ui-colorpicker.png css/images/ui-colorpicker.png image/png
          upload [10] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/preview-opacity.png css/images/preview-opacity.png image/png
          upload [9] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/map.png css/images/map.png image/png
          upload [8] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/map-pointer.png css/images/map-pointer.png image/png
          upload [7] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/map-opacity.png css/images/map-opacity.png image/png
          upload [6] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar.png css/images/bar.png image/png
          upload [5] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar-pointer.png css/images/bar-pointer.png image/png
          upload [4] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar-opacity.png css/images/bar-opacity.png image/png
          upload [3] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar-alpha.png css/images/bar-alpha.png image/png
          upload [2] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/map.png css/images/128/map.png image/png
          upload [1] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/bar.png css/images/128/bar.png image/png
          upload [0] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/bar-alpha.png css/images/128/bar-alpha.png image/png
          got /opt/iobroker/node_modules/iobroker.web/admin
          upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/words.js words.js application/javascript
          upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
          upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
          upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index.html index.html text/html
          got /opt/iobroker/node_modules/iobroker.web/www
          upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_glass_95_fef1ec_1x400.png lib/css/themes/jquery-ui/vader/images/ui-bg_glass_95_fef1ec_1x400.png image/png
          upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_gloss-wave_60_fece2f_500x100.png lib/css/themes/jquery-ui/sunny/images/ui-bg_gloss-wave_60_fece2f_500x100.png image/png
          upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_inset-hard_100_fcfdfd_1x100.png lib/css/themes/jquery-ui/redmond/images/ui-bg_inset-hard_100_fcfdfd_1x100.png image/png
          upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_88a206_256x240.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_88a206_256x240.png image/png
          upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-icons_734d99_256x240.png lib/css/themes/jquery-ui/eggplant/images/ui-icons_734d99_256x240.png image/png
          upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-hard_20_0972a5_1x100.png lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-hard_20_0972a5_1x100.png image/png
          upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-icons_2e83ff_256x240.png lib/css/themes/jquery-ui/custom-light/images/ui-icons_2e83ff_256x240.png image/png
          upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/jquery-ui.min.css lib/css/themes/jquery-ui/custom-dark/jquery-ui.min.css text/css
          upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/images/ui-bg_glass_20_555555_1x400.png lib/css/themes/jquery-ui/custom-dark/images/ui-bg_glass_20_555555_1x400.png image/png
          upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_highlight-soft_100_deedf7_1x100.png lib/css/themes/jquery-ui/cupertino/images/ui-bg_highlight-soft_100_deedf7_1x100.png image/png
          upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/jquery-ui.css lib/css/themes/jquery-ui/blitzer/jquery-ui.css text/css
          upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_flat_0_333333_40x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_flat_0_333333_40x100.png image/png
          upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-icons_4ca300_256x240.png lib/css/themes/jquery-ui/black-tie/images/ui-icons_4ca300_256x240.png image/png
          upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png image/png
          upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/style.css lib/css/style.css text/css
          upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/materialize.css lib/css/materialize.css text/css
          upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ui.jqgrid-4.5.4.css lib/css/jqGrid/ui.jqgrid-4.5.4.css text/css
          upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ellipsis-xbl.xml lib/css/jqGrid/ellipsis-xbl.xml text/xml
          upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css.map lib/css/iob/selectID.css.map application/json
          upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css lib/css/iob/selectID.css text/css
          upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
          upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min-win7.css lib/css/fancytree/ui.fancytree.min-win7.css text/css
          upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.jquery.min.css lib/css/fancytree/ui.fancytree.jquery.min.css text/css
          upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.png lib/css/fancytree/state.png image/png
          upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.pdn lib/css/fancytree/state.pdn application/octet-stream
          upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/loading.gif lib/css/fancytree/loading.gif image/gif
          upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/icons.gif lib/css/fancytree/icons.gif image/gif
          upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.png lib/css/fancytree/device.png image/png
          upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.pdn lib/css/fancytree/device.pdn application/octet-stream
          upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.png lib/css/fancytree/channel.png image/png
          upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.pdn lib/css/fancytree/channel.pdn application/octet-stream
          upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
          upload [1] web /opt/iobroker/node_modules/iobroker.web/www/index.html index.html text/html
          upload [0] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
          got /opt/iobroker/node_modules/iobroker.hm-rega/admin
          upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
          upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
          upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
          upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
          upload [200] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/index_m.html index_m.html text/html
          upload [150] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/75_hm-pb-2-wm55_thumb.png icons/75_hm-pb-2-wm55_thumb.png image/png
          upload [100] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/27_hmw-lc-bl1-dr_thumb.png icons/27_hmw-lc-bl1-dr_thumb.png image/png
          upload [90] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/188_hmip-etrv-c_thumb.png icons/188_hmip-etrv-c_thumb.png image/png
          upload [80] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/179_hmip-swdm-b2_thumb.png icons/179_hmip-swdm-b2_thumb.png image/png
          upload [70] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/169_hmip-swo-pr_thumb.png icons/169_hmip-swo-pr_thumb.png image/png
          upload [60] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/150_hm-lc-dw-wm_thumb.png icons/150_hm-lc-dw-wm_thumb.png image/png
          upload [50] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/140_alpha-ip-rgb_thumb.png icons/140_alpha-ip-rgb_thumb.png image/png
          upload [40] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/132_hmip-smo_thumb.png icons/132_hmip-smo_thumb.png image/png
          upload [30] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/121_hmip-wth_thumb.png icons/121_hmip-wth_thumb.png image/png
          upload [20] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm_thumb.png icons/113_hmip-psm_thumb.png image/png
          upload [19] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-uk_thumb.png icons/113_hmip-psm-uk_thumb.png image/png
          upload [18] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-pe_thumb.png icons/113_hmip-psm-pe_thumb.png image/png
          upload [17] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-it_thumb.png icons/113_hmip-psm-it_thumb.png image/png
          upload [16] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-ch_thumb.png icons/113_hmip-psm-ch_thumb.png image/png
          upload [15] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/112_hmip-wrc2_thumb.png icons/112_hmip-wrc2_thumb.png image/png
          upload [14] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/111_hm-lc-rgbw-wm_thumb.png icons/111_hm-lc-rgbw-wm_thumb.png image/png
          upload [13] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/110_hm-es-pmsw1-dr_thump.png icons/110_hm-es-pmsw1-dr_thump.png image/png
          upload [12] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/109_hm-lc-sw1-pl-ct_thump.png icons/109_hm-lc-sw1-pl-ct_thump.png image/png
          upload [11] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/108_hm-rc-dis-h-x-eu_thump.png icons/108_hm-rc-dis-h-x-eu_thump.png image/png
          upload [10] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R5_thumb.png icons/107_hm-es-pmsw1-pl-R5_thumb.png image/png
          upload [9] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R4_thumb.png icons/107_hm-es-pmsw1-pl-R4_thumb.png image/png
          upload [8] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R3_thumb.png icons/107_hm-es-pmsw1-pl-R3_thumb.png image/png
          upload [7] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R2_thumb.png icons/107_hm-es-pmsw1-pl-R2_thumb.png image/png
          upload [6] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/105_hm-sec-sd-2-team_thumb.png icons/105_hm-sec-sd-2-team_thumb.png image/png
          upload [5] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/104_hm-sec-sd-2_thumb.png icons/104_hm-sec-sd-2_thumb.png image/png
          upload [4] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/103_hm-sen-mdir-wm55_thumb.png icons/103_hm-sen-mdir-wm55_thumb.png image/png
          upload [3] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/102_hm-es-tx-wm_thumb.png icons/102_hm-es-tx-wm_thumb.png image/png
          upload [2] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/101_hm-sen-db-pcb_thumb.png icons/101_hm-sen-db-pcb_thumb.png image/png
          upload [1] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/100_hm-rc-8_thumb.png icons/100_hm-rc-8_thumb.png image/png
          upload [0] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/homematic.png homematic.png image/png
          got /opt/iobroker/node_modules/iobroker.admin/admin
          upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
          upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
          upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
          upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
          Update "system.adapter.admin.0"
          ./reinstall.sh: line 34: unexpected EOF while looking for matching `"'
          ./reinstall.sh: line 37: syntax error: unexpected end of file
            Das muss nichts bedeuten - war IMHO schon immer so.
            Rainer
              pid5be0
              Okay, danke Rainer für die Info.
              mal eine frage… der js-controller läuft bei mir unter der Version 1.4.2
              Ist das die aktuelle Version? Auf GitHub habe ich die Version 1.5.3 gesehen. In der 1.5.x Version wurde ein Bug gefixt was mich interessiert.
              Warum auch immer kann ich nicht das System auf die 1.5.3 hochziehen. Das ist der eigentliche Grund meines Posts.
              Gruß Daniel
                Bitte lies mal hier:
                http://www.iobroker.net/docu/?page_id=8 … onsquellen
                Rainer
                  pid5be0
                  Moin moin…
                  Ich hatte gestern mal einen zusätzlichen REPO Eintrag "online" gesetzt nach der Anleitung.
                  Diesen haben ich auch in den Haupteinstellungen auf "aktiv" gesetzt. Im Admin Adapter ist das Intervall auf 12h definiert.
                  https://raw.githubusercontent.com/ioBroker/ioBroker.js-controller/master/conf/sources-dist.json
                  Die 12h Stunden sind bereits erreicht. Gibt es ggf. ein Logfile zu diesen Thema?
                  Gruß Daniel
                    pid5be0
                    Ich habe mir das Verzeichnis "/val/log/" und "/opt/iobroker/" angeschaut.
                    Zum Thema Updates für das System konnte ich hier nichts finden. Ggf. hat ja NPM oder noch ein anderes involviertes Tool ein eigenes LOG Verzeichnis!?
                      @pid5be0:
                      nach der Anleitung. `
                      Nach welcher Anleitung?
                      Dieses Repository gab es mal, aber ich fürchte es ist nicht mehr aktiv.
                      @pid5be0:
                      Gibt es ggf. ein Logfile `
                      Hast du mal im Reiter Adapter auf den reload button gedrückt. Danach muss es einen Eintrag im log geben.
                      Rainer
                        pid5be0
                        Hi… das habe ich ausprobiert (Reload Button) - leider ohne Erfolg.
                        Mit Anleitung meinte ich, den Link von Dir.
                        Da ich den iobroker aktuell als VM auf dem QNAP laufen habe, bin ich am überlegen das System neu aufzusetzen. Klappt das Backup Recovery und würde das Sinnvoll sein?
                        Gruß Daniel
                        Gesendet von iPad mit Tapatalk
                          @pid5be0:
                          Hi… das habe ich ausprobiert (Reload Button) - leider ohne Erfolg. `
                          kein Eintrag im log?
                          so etwas wie:
                          host.linaro-alip	2019-01-13 16:35:23.970	info	Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                          da muss etwas kommen - wahrscheinlich mit …failed
                          Rainer
                            pid5be0
                            Hi
                            Ich konnte so einen Eintrag im aktuellen LOG nicht finden. Ich schaue gerade im Verzeichnis "/opt/iobroker/log/" -> Datei: -rw-rw-rw- 1 root root 278713 Jan 13 19:53 iobroker.2019-01-13.log
                            2019-01-13 19:25:01.432 - info: admin.0 Repository received successfully.
                            Einen Eintrag wie Du ihn hast habe ich so nicht gefunden. In welchen Log File schaust Du?
                            Gruß Daniel
                            • O Offline
                              O Offline
                              OMCastle
                              ich habe auch die Probleme.
                              root@orangepiplus2e:/opt/iobroker/log# npm install
                              npm ERR! Could not install from "../node_modules/iobroker.type-detector" as it does not contain a package.json file.
                              npm ERR! /root/.npm/_logs/2019-02-03T13_08_12_533Z-debug.log
                              Log:
                              root@orangepiplus2e:/opt/iobroker/log# cat /root/.npm/_logs/2019-02-03T13_08_12_533Z-debug.log
                              0 info it worked if it ends with ok
                              1 verbose cli [ '/usr/local/bin/node', '/usr/local/bin/npm', 'install' ]
                              2 info using npm@6.4.1
                              3 info using node@v8.15.0
                              4 verbose npm-session 2a798a6bb228acbe
                              5 silly install runPreinstallTopLevelLifecycles
                              6 silly preinstall iobroker@1.0.0
                              7 info lifecycle iobroker@1.0.0~preinstall: iobroker@1.0.0
                              8 silly install loadCurrentTree
                              9 silly install readLocalPackageData
                              157 silly resolveWithNewModule iobroker.socketio@2.1.1 checking installable status
                              158 silly fetchPackageMetaData error for iobroker.type-detector@file:node_modules/iobroker.type-detector Could not install from "../node_modules/iobroker.type-detector" as it does not contain a package.json file.
                              159 http fetch GET 200 https://github.com/iobroker-community-a ... all/master 4217ms
                              167 silly saveTree └── zstack-constants@0.2.0
                              168 verbose stack Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.type-detector/package.json'
                              169 verbose cwd /opt/iobroker/log
                              170 verbose Linux 3.4.113-sun8i
                              171 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install"
                              172 verbose node v8.15.0
                              173 verbose npm v6.4.1
                              174 error code ENOLOCAL
                              175 error Could not install from "../node_modules/iobroker.type-detector" as it does not contain a package.json file.
                              176 verbose exit [ 1, true ]
                              Bitte um Unterstützung…
                              Grüße
                              Raspberrymatic auf Pi3 mit CUL für Eltako
                              • 30 HomeMatic Aktoren, 10 Eltako Aktoren
                              IOBroker auf OrangePi Plus 2e
                              • 30 Xiamoi, 5 Netatmo, VW Golf Skript, Viessmann Heizung, ICal, PluseCounter für Strom und Gas, Instar Kameras
                              • AlCalzoneA Offline
                                AlCalzoneA Offline
                                AlCalzone
                                Ich habe keine ahnung was für ein Paket das sein soll aber es scheint nicht sauber zu sein und aus einer lokalen Quelle installiert.
                                Schau mal in /opt/iobroker, bearbeite die package.json und lösche unter dependencies einen möglichen Verweis auf iobroker.type-detector (ganze Zeile löschen)
                                Gesendet von unterwegs
