  4. Div. Fehler beim Update
    6.8k
15 Beiträge 5 Kommentatoren 2.9k Aufrufe
  • P Offline
    pid5be0
    Ich habe gerade nochmal "nodejs" neu installiert und danach das "reinstall.sh" script ausgeführt. Das Ergebnis, das Script bricht ab, weil in der Zeile 34 & 37 nichts drin steht.
    Habe mich an die Anleitung von IOBROKER gehalten.
    root@debian-iobroker:/opt/iobroker# ./reinstall.sh
    Stopping iobroker controller daemon...
    iobroker controller daemon stopped.
    Exit code for "killall.sh": 123
    /opt/iobroker/node_modules
    + iobroker.admin@3.5.10
    added 173 packages from 128 contributors and audited 353 packages in 28.796s
    found 11 vulnerabilities (8 low, 3 high)
      run `npm audit fix` to fix them, or `npm audit` for details
    DONE iobroker.admin
    + iobroker.alexa2@1.1.3
    added 144 packages from 115 contributors and audited 1420 packages in 23.347s
    DONE iobroker.alexa2
    + iobroker.flot@1.9.2
    added 1 package from 1 contributor and audited 1421 packages in 10.688s
    DONE iobroker.flot
    + iobroker.fritzbox@0.2.1
    added 4 packages from 49 contributors and audited 1425 packages in 10.863s
    DONE iobroker.fritzbox
    + iobroker.geofency@0.3.2
    added 1 package from 2 contributors and audited 1489 packages in 10.593s
    DONE iobroker.geofency
    + iobroker.hm-rega@2.1.2
    added 4 packages from 39 contributors and audited 1562 packages in 11.134s
    DONE iobroker.hm-rega
    + iobroker.hm-rpc@1.9.1
    added 10 packages from 22 contributors and audited 1575 packages in 13.061s
    DONE iobroker.hm-rpc
    + iobroker.ical@1.7.0
    added 7 packages from 13 contributors and audited 1711 packages in 14.48s
    DONE iobroker.ical
    + iobroker.iot@0.2.2
    added 69 packages from 38 contributors and audited 2015 packages in 20.817s
    DONE iobroker.iot
    npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
    > iobroker.javascript@4.0.7 postinstall /opt/iobroker/node_modules/iobroker.javascript
    > node ./install/installTypings.js
    Installing NodeJS typings...
    latest @types: 10, installed node: 8
    + iobroker.javascript@4.0.7
    added 23 packages from 58 contributors and audited 2107 packages in 28.831s
    DONE iobroker.javascript
    > iobroker.js-controller@1.4.2 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstall_check.js
    NPM version: 6.4.1
    npm version >= 5: disabling package-lock
    > unix-dgram@0.2.3 install /opt/iobroker/node_modules/unix-dgram
    > node-gyp rebuild
    make: Entering directory '/opt/iobroker/node_modules/unix-dgram/build'
      CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
      SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
      COPY Release/unix_dgram.node
    make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
    > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
    > node rebuild.js
    > iobroker.js-controller@1.4.2 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    > rsa-compat@1.9.2 postinstall /opt/iobroker/node_modules/rsa-compat
    > node lib/telemetry.js event:install
    + iobroker.js-controller@1.4.2
    added 150 packages from 100 contributors and audited 2875 packages in 56.773s
    found 22 vulnerabilities (16 low, 6 high)
    DONE iobroker.js-controller
    + iobroker.mqtt@2.0.4
    added 17 packages from 11 contributors and audited 3266 packages in 23.388s
    DONE iobroker.mqtt
    + iobroker.shelly@2.0.5
    added 17 packages from 31 contributors and audited 3378 packages in 21.828s
    found 23 vulnerabilities (17 low, 6 high)
    DONE iobroker.shelly
    + iobroker.simple-api@2.0.0
    added 1 package from 2 contributors and audited 3379 packages in 20.079s
    DONE iobroker.simple-api
    + iobroker.socketio@2.1.1
    added 1 package from 1 contributor and audited 3548 packages in 19.626s
    found 34 vulnerabilities (25 low, 9 high)
    DONE iobroker.socketio
    npm WARN deprecated sprintf@0.1.5: The sprintf package is deprecated in favor of sprintf-js.
    npm WARN deprecated node-uuid@1.4.8: Use uuid module instead
    > sqlite3@4.0.6 install /opt/iobroker/node_modules/sqlite3
    > node-pre-gyp install --fallback-to-build
    node-pre-gyp WARN Using request for node-pre-gyp https download
    [sqlite3] Success: "/opt/iobroker/node_modules/sqlite3/lib/binding/node-v57-linux-x64/node_sqlite3.node" is installed via remote
    + iobroker.sql@1.9.2
    added 91 packages from 111 contributors and audited 3872 packages in 37.166s
    DONE iobroker.sql
    + iobroker.telegram@1.3.6
    added 27 packages from 71 contributors and audited 4015 packages in 28.655s
    found 35 vulnerabilities (26 low, 9 high)
    DONE iobroker.telegram
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    + iobroker.tr-064@0.4.18
    added 11 packages from 7 contributors and audited 4098 packages in 24.763s
    found 36 vulnerabilities (27 low, 9 high)
    DONE iobroker.tr-064
    npm ERR! code ENOLOCAL
    npm ERR! Could not install from "node_modules/iobroker.type-detector" as it does not contain a package.json file.
    npm ERR!     /root/.npm/_logs/2019-01-12T16_08_56_695Z-debug.log
    FAIL iobroker.type-detector
    + iobroker.unifi@0.3.1
    added 3 packages from 2 contributors and audited 4165 packages in 26.234s
    DONE iobroker.unifi
    > iobroker.vis@1.1.8 install /opt/iobroker/node_modules/iobroker.vis
    > node main.js --install
    + iobroker.vis@1.1.8
    added 1 package from 2 contributors and audited 4182 packages in 31.589s
    DONE iobroker.vis
    + iobroker.web@2.4.1
    added 1 package from 1 contributor and audited 4642 packages in 25.868s
    found 52 vulnerabilities (38 low, 14 high)
    DONE iobroker.web
    got /opt/iobroker/node_modules/iobroker.iot/admin
    upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/words.js words.js application/javascript
    upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
    upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
    upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
    upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
    upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
    got /opt/iobroker/node_modules/iobroker.tr-064/admin
    upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
    upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
    upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index.html index.html text/html
    got /opt/iobroker/node_modules/iobroker.alexa2/admin
    upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript
    upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
    upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index.html index.html text/html
    upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
    upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
    upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
    upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
    upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
    upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
    upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
    upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
    upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
    upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
    upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot.png icons/echo_dot.png image/png
    upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo2.png icons/echo2.png image/png
    upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo.png icons/echo.png image/png
    upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
    got /opt/iobroker/node_modules/iobroker.shelly/admin
    upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
    upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
    upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/index_m.html index_m.html text/html
    Cannot find io-package.json in null
    Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
    got /opt/iobroker/node_modules/iobroker.mqtt/admin
    upload [3] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/words.js words.js application/javascript
    upload [2] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/mqtt.png mqtt.png image/png
    upload [1] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/index_m.html index_m.html text/html
    upload [0] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/index.html index.html text/html
    got /opt/iobroker/node_modules/iobroker.fritzbox/admin
    upload [1] fritzbox.admin /opt/iobroker/node_modules/iobroker.fritzbox/admin/index.html index.html text/html
    upload [0] fritzbox.admin /opt/iobroker/node_modules/iobroker.fritzbox/admin/fritzbox.png fritzbox.png image/png
    got /opt/iobroker/node_modules/iobroker.vis/admin
    upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
    upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
    upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
    upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
    Adapter "system.adapter.vis.0" restarted.
    got /opt/iobroker/node_modules/iobroker.vis/www
    upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/jquery.sliderTabs.js widgets/tabs/jquery.sliderTabs.js application/javascript
    (node:1292) [DEP0013] DeprecationWarning: Calling an asynchronous function without callback is deprecated.
    upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ValueBoolCtrlSvg.png widgets/basic/img/Prev_ValueBoolCtrlSvg.png image/png
    upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
    upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/js/visEditWelcome.js js/visEditWelcome.js application/javascript
    upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/actions/edit-rename.png js/fm/icon/actions/edit-rename.png image/png
    upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/js/app.js js/app.js application/javascript
    upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/img/garage-door-closed.png img/garage-door-closed.png image/png
    upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/img/bulb_off.png img/bulb_off.png image/png
    upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/img/bg-dots-10.svg img/bg-dots-10.svg image/svg+xml
    upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/tools.png icon/tools.png image/png
    upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/refresh-4.png icon/refresh-4.png image/png
    upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/door.png icon/door.png image/png
    upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/bar.png icon/bar.png image/png
    upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-width.png icon/align-width.png image/png
    upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-top-2.png icon/align-vertical-top-2.png image/png
    upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-center-2.png icon/align-vertical-center-2.png image/png
    upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-bottom-2.png icon/align-vertical-bottom-2.png image/png
    upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-right-2.png icon/align-horizontal-right-2.png image/png
    upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-left.png icon/align-horizontal-left.png image/png
    upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-center-2.png icon/align-horizontal-center-2.png image/png
    upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-height.png icon/align-height.png image/png
    upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/add.png icon/add.png image/png
    upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.html edit.html text/html
    upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis.css css/vis.css text/css
    upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis-editor.css css/vis-editor.css text/css
    upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/css/styles.css css/styles.css text/css
    upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/css/montserrat-regular-webfont.woff css/montserrat-regular-webfont.woff application/font-woff
    upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/css/doc.css css/doc.css text/css
    upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/css/backgrounds.css css/backgrounds.css text/css
    upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/css/app.css css/app.css text/css
    upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/css/add_kian.css css/add_kian.css text/css
    upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/cordova.js cordova.js application/javascript
    upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
    got /opt/iobroker/node_modules/iobroker.unifi/admin
    upload [1] unifi.admin /opt/iobroker/node_modules/iobroker.unifi/admin/unifi.png unifi.png image/png
    upload [0] unifi.admin /opt/iobroker/node_modules/iobroker.unifi/admin/index.html index.html text/html
    got /opt/iobroker/node_modules/iobroker.unifi/www
    upload [1] unifi /opt/iobroker/node_modules/iobroker.unifi/www/index.html index.html text/html
    upload [0] unifi /opt/iobroker/node_modules/iobroker.unifi/www/README.md README.md text/markdown
    got /opt/iobroker/node_modules/iobroker.telegram/admin
    upload [4] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/words.js words.js application/javascript
    upload [3] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/telegram.png telegram.png image/png
    upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index_m.html index_m.html text/html
    upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index.html index.html text/html
    upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blockly.js blockly.js application/javascript
    got /opt/iobroker/node_modules/iobroker.sql/admin
    upload [5] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/words.js words.js application/javascript
    upload [4] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/sql.png sql.png image/png
    upload [3] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/index_m.html index_m.html text/html
    upload [2] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/index.html index.html text/html
    upload [1] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/custom_m.html custom_m.html text/html
    upload [0] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/custom.html custom.html text/html
    got /opt/iobroker/node_modules/iobroker.javascript/admin
    upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/redshift/redshift.js vs/basic-languages/redshift/redshift.js application/javascript
    upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/objective-c/objective-c.js vs/basic-languages/objective-c/objective-c.js application/javascript
    upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/go/go.js vs/basic-languages/go/go.js application/javascript
    upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vendor/socket.io.js vendor/socket.io.js application/javascript
    upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/css/main.cd153a24.chunk.css static/css/main.cd153a24.chunk.css text/css
    upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/it.js google-blockly/own/msg/it.js application/javascript
    upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_timeout.js google-blockly/own/blocks_timeout.js application/javascript
    upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/pl.js google-blockly/msg/js/pl.js application/javascript
    upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/quote0.png google-blockly/media/quote0.png image/png
    upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handopen.cur google-blockly/media/handopen.cur application/octet-stream
    upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handdelete.cur google-blockly/media/handdelete.cur application/octet-stream
    upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handclosed.cur google-blockly/media/handclosed.cur application/octet-stream
    upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.wav google-blockly/media/disconnect.wav audio/x-wav
    upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.ogg google-blockly/media/disconnect.ogg audio/ogg
    upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.mp3 google-blockly/media/disconnect.mp3 audio/mpeg
    upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/x-wav
    upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.ogg google-blockly/media/delete.ogg audio/ogg
    upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.mp3 google-blockly/media/delete.mp3 audio/mpeg
    upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.wav google-blockly/media/click.wav audio/x-wav
    upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.ogg google-blockly/media/click.ogg audio/ogg
    upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
    upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/1x1.gif google-blockly/media/1x1.gif image/gif
    upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/javascript_compressed.js google-blockly/javascript_compressed.js application/javascript
    upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blocks_compressed.js google-blockly/blocks_compressed.js application/javascript
    upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly_compressed.js google-blockly/blockly_compressed.js application/javascript
    upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE application/octet-stream
    upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/favicon.ico favicon.ico image/x-icon
    upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/asset-manifest.json asset-manifest.json application/json
    upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
    got /opt/iobroker/node_modules/iobroker.ical/admin
    upload [3] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/words.js words.js application/javascript
    upload [2] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/index_m.html index_m.html text/html
    upload [1] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/index.html index.html text/html
    upload [0] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/ical.png ical.png image/png
    got /opt/iobroker/node_modules/iobroker.geofency/admin
    upload [2] geofency.admin /opt/iobroker/node_modules/iobroker.geofency/admin/words.js words.js application/javascript
    upload [1] geofency.admin /opt/iobroker/node_modules/iobroker.geofency/admin/index.html index.html text/html
    upload [0] geofency.admin /opt/iobroker/node_modules/iobroker.geofency/admin/geofency.png geofency.png image/png
    got /opt/iobroker/node_modules/iobroker.flot/admin
    upload [0] flot.admin /opt/iobroker/node_modules/iobroker.flot/admin/flot.png flot.png image/png
    got /opt/iobroker/node_modules/iobroker.flot/www
    upload [20] flot /opt/iobroker/node_modules/iobroker.flot/www/js/flot.js js/flot.js application/javascript
    upload [19] flot /opt/iobroker/node_modules/iobroker.flot/www/js/edit.js.map js/edit.js.map application/json
    upload [18] flot /opt/iobroker/node_modules/iobroker.flot/www/js/edit.js js/edit.js application/javascript
    upload [17] flot /opt/iobroker/node_modules/iobroker.flot/www/index.html.map index.html.map application/json
    upload [16] flot /opt/iobroker/node_modules/iobroker.flot/www/index.html index.html text/html
    upload [15] flot /opt/iobroker/node_modules/iobroker.flot/www/img/favicon.png img/favicon.png image/png
    upload [14] flot /opt/iobroker/node_modules/iobroker.flot/www/edit.html.map edit.html.map application/json
    upload [13] flot /opt/iobroker/node_modules/iobroker.flot/www/edit.html edit.html text/html
    upload [12] flot /opt/iobroker/node_modules/iobroker.flot/www/css/jquery.colorpicker.css css/jquery.colorpicker.css text/css
    upload [11] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/ui-colorpicker.png css/images/ui-colorpicker.png image/png
    upload [10] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/preview-opacity.png css/images/preview-opacity.png image/png
    upload [9] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/map.png css/images/map.png image/png
    upload [8] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/map-pointer.png css/images/map-pointer.png image/png
    upload [7] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/map-opacity.png css/images/map-opacity.png image/png
    upload [6] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar.png css/images/bar.png image/png
    upload [5] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar-pointer.png css/images/bar-pointer.png image/png
    upload [4] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar-opacity.png css/images/bar-opacity.png image/png
    upload [3] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar-alpha.png css/images/bar-alpha.png image/png
    upload [2] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/map.png css/images/128/map.png image/png
    upload [1] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/bar.png css/images/128/bar.png image/png
    upload [0] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/bar-alpha.png css/images/128/bar-alpha.png image/png
    got /opt/iobroker/node_modules/iobroker.web/admin
    upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/words.js words.js application/javascript
    upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
    upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
    upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index.html index.html text/html
    got /opt/iobroker/node_modules/iobroker.web/www
    upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_glass_95_fef1ec_1x400.png lib/css/themes/jquery-ui/vader/images/ui-bg_glass_95_fef1ec_1x400.png image/png
    upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_gloss-wave_60_fece2f_500x100.png lib/css/themes/jquery-ui/sunny/images/ui-bg_gloss-wave_60_fece2f_500x100.png image/png
    upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_inset-hard_100_fcfdfd_1x100.png lib/css/themes/jquery-ui/redmond/images/ui-bg_inset-hard_100_fcfdfd_1x100.png image/png
    upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_88a206_256x240.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_88a206_256x240.png image/png
    upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-icons_734d99_256x240.png lib/css/themes/jquery-ui/eggplant/images/ui-icons_734d99_256x240.png image/png
    upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-hard_20_0972a5_1x100.png lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-hard_20_0972a5_1x100.png image/png
    upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-icons_2e83ff_256x240.png lib/css/themes/jquery-ui/custom-light/images/ui-icons_2e83ff_256x240.png image/png
    upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/jquery-ui.min.css lib/css/themes/jquery-ui/custom-dark/jquery-ui.min.css text/css
    upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/images/ui-bg_glass_20_555555_1x400.png lib/css/themes/jquery-ui/custom-dark/images/ui-bg_glass_20_555555_1x400.png image/png
    upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_highlight-soft_100_deedf7_1x100.png lib/css/themes/jquery-ui/cupertino/images/ui-bg_highlight-soft_100_deedf7_1x100.png image/png
    upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/jquery-ui.css lib/css/themes/jquery-ui/blitzer/jquery-ui.css text/css
    upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_flat_0_333333_40x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_flat_0_333333_40x100.png image/png
    upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-icons_4ca300_256x240.png lib/css/themes/jquery-ui/black-tie/images/ui-icons_4ca300_256x240.png image/png
    upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png image/png
    upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/style.css lib/css/style.css text/css
    upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/materialize.css lib/css/materialize.css text/css
    upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ui.jqgrid-4.5.4.css lib/css/jqGrid/ui.jqgrid-4.5.4.css text/css
    upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ellipsis-xbl.xml lib/css/jqGrid/ellipsis-xbl.xml text/xml
    upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css.map lib/css/iob/selectID.css.map application/json
    upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css lib/css/iob/selectID.css text/css
    upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
    upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min-win7.css lib/css/fancytree/ui.fancytree.min-win7.css text/css
    upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.jquery.min.css lib/css/fancytree/ui.fancytree.jquery.min.css text/css
    upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.png lib/css/fancytree/state.png image/png
    upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.pdn lib/css/fancytree/state.pdn application/octet-stream
    upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/loading.gif lib/css/fancytree/loading.gif image/gif
    upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/icons.gif lib/css/fancytree/icons.gif image/gif
    upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.png lib/css/fancytree/device.png image/png
    upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.pdn lib/css/fancytree/device.pdn application/octet-stream
    upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.png lib/css/fancytree/channel.png image/png
    upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.pdn lib/css/fancytree/channel.pdn application/octet-stream
    upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
    upload [1] web /opt/iobroker/node_modules/iobroker.web/www/index.html index.html text/html
    upload [0] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
    got /opt/iobroker/node_modules/iobroker.hm-rega/admin
    upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
    upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
    upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
    upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
    got /opt/iobroker/node_modules/iobroker.hm-rpc/admin
    upload [200] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/index_m.html index_m.html text/html
    upload [150] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/75_hm-pb-2-wm55_thumb.png icons/75_hm-pb-2-wm55_thumb.png image/png
    upload [100] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/27_hmw-lc-bl1-dr_thumb.png icons/27_hmw-lc-bl1-dr_thumb.png image/png
    upload [90] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/188_hmip-etrv-c_thumb.png icons/188_hmip-etrv-c_thumb.png image/png
    upload [80] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/179_hmip-swdm-b2_thumb.png icons/179_hmip-swdm-b2_thumb.png image/png
    upload [70] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/169_hmip-swo-pr_thumb.png icons/169_hmip-swo-pr_thumb.png image/png
    upload [60] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/150_hm-lc-dw-wm_thumb.png icons/150_hm-lc-dw-wm_thumb.png image/png
    upload [50] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/140_alpha-ip-rgb_thumb.png icons/140_alpha-ip-rgb_thumb.png image/png
    upload [40] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/132_hmip-smo_thumb.png icons/132_hmip-smo_thumb.png image/png
    upload [30] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/121_hmip-wth_thumb.png icons/121_hmip-wth_thumb.png image/png
    upload [20] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm_thumb.png icons/113_hmip-psm_thumb.png image/png
    upload [19] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-uk_thumb.png icons/113_hmip-psm-uk_thumb.png image/png
    upload [18] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-pe_thumb.png icons/113_hmip-psm-pe_thumb.png image/png
    upload [17] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-it_thumb.png icons/113_hmip-psm-it_thumb.png image/png
    upload [16] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-ch_thumb.png icons/113_hmip-psm-ch_thumb.png image/png
    upload [15] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/112_hmip-wrc2_thumb.png icons/112_hmip-wrc2_thumb.png image/png
    upload [14] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/111_hm-lc-rgbw-wm_thumb.png icons/111_hm-lc-rgbw-wm_thumb.png image/png
    upload [13] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/110_hm-es-pmsw1-dr_thump.png icons/110_hm-es-pmsw1-dr_thump.png image/png
    upload [12] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/109_hm-lc-sw1-pl-ct_thump.png icons/109_hm-lc-sw1-pl-ct_thump.png image/png
    upload [11] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/108_hm-rc-dis-h-x-eu_thump.png icons/108_hm-rc-dis-h-x-eu_thump.png image/png
    upload [10] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R5_thumb.png icons/107_hm-es-pmsw1-pl-R5_thumb.png image/png
    upload [9] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R4_thumb.png icons/107_hm-es-pmsw1-pl-R4_thumb.png image/png
    upload [8] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R3_thumb.png icons/107_hm-es-pmsw1-pl-R3_thumb.png image/png
    upload [7] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R2_thumb.png icons/107_hm-es-pmsw1-pl-R2_thumb.png image/png
    upload [6] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/105_hm-sec-sd-2-team_thumb.png icons/105_hm-sec-sd-2-team_thumb.png image/png
    upload [5] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/104_hm-sec-sd-2_thumb.png icons/104_hm-sec-sd-2_thumb.png image/png
    upload [4] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/103_hm-sen-mdir-wm55_thumb.png icons/103_hm-sen-mdir-wm55_thumb.png image/png
    upload [3] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/102_hm-es-tx-wm_thumb.png icons/102_hm-es-tx-wm_thumb.png image/png
    upload [2] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/101_hm-sen-db-pcb_thumb.png icons/101_hm-sen-db-pcb_thumb.png image/png
    upload [1] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/100_hm-rc-8_thumb.png icons/100_hm-rc-8_thumb.png image/png
    upload [0] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/homematic.png homematic.png image/png
    got /opt/iobroker/node_modules/iobroker.admin/admin
    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    Update "system.adapter.admin.0"
    ./reinstall.sh: line 34: unexpected EOF while looking for matching `"'
    ./reinstall.sh: line 37: syntax error: unexpected end of file
    IOBROKER via VM auf QNAP TS453, Unify Network (Switch/WLAN), Hardware Firewall - SIF, Raspberry für Homematic
    • HomoranH Offline
      HomoranH Offline
      Das muss nichts bedeuten - war IMHO schon immer so.
      • P Offline
        pid5be0
        Okay, danke Rainer für die Info.
        mal eine frage… der js-controller läuft bei mir unter der Version 1.4.2
        Ist das die aktuelle Version? Auf GitHub habe ich die Version 1.5.3 gesehen. In der 1.5.x Version wurde ein Bug gefixt was mich interessiert.
        Warum auch immer kann ich nicht das System auf die 1.5.3 hochziehen. Das ist der eigentliche Grund meines Posts.
        Gruß Daniel
        • HomoranH Offline
          HomoranH Offline
          Bitte lies mal hier:
          http://www.iobroker.net/docu/?page_id=8 … onsquellen
          • P Offline
            pid5be0
            Moin moin…
            Ich hatte gestern mal einen zusätzlichen REPO Eintrag "online" gesetzt nach der Anleitung.
            Diesen haben ich auch in den Haupteinstellungen auf "aktiv" gesetzt. Im Admin Adapter ist das Intervall auf 12h definiert.
            https://raw.githubusercontent.com/ioBroker/ioBroker.js-controller/master/conf/sources-dist.json
            Die 12h Stunden sind bereits erreicht. Gibt es ggf. ein Logfile zu diesen Thema?
            Gruß Daniel
            • P Offline
              pid5be0
              Ich habe mir das Verzeichnis "/val/log/" und "/opt/iobroker/" angeschaut.
              Zum Thema Updates für das System konnte ich hier nichts finden. Ggf. hat ja NPM oder noch ein anderes involviertes Tool ein eigenes LOG Verzeichnis!?
              • HomoranH Offline
                HomoranH Offline
                @pid5be0:
                nach der Anleitung. `
                Nach welcher Anleitung?
                Dieses Repository gab es mal, aber ich fürchte es ist nicht mehr aktiv.
                @pid5be0:
                Gibt es ggf. ein Logfile `
                Hast du mal im Reiter Adapter auf den reload button gedrückt. Danach muss es einen Eintrag im log geben.
                • P Offline
                  pid5be0
                  Hi… das habe ich ausprobiert (Reload Button) - leider ohne Erfolg.
                  Mit Anleitung meinte ich, den Link von Dir.
                  Da ich den iobroker aktuell als VM auf dem QNAP laufen habe, bin ich am überlegen das System neu aufzusetzen. Klappt das Backup Recovery und würde das Sinnvoll sein?
                  Gruß Daniel
                  Gesendet von iPad mit Tapatalk
                  • HomoranH Offline
                    HomoranH Offline
                    @pid5be0:
                    Hi… das habe ich ausprobiert (Reload Button) - leider ohne Erfolg. `
                    kein Eintrag im log?
                    so etwas wie:
                    host.linaro-alip	2019-01-13 16:35:23.970	info	Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                    da muss etwas kommen - wahrscheinlich mit …failed
                    • P Offline
                      pid5be0
                      Hi
                      Ich konnte so einen Eintrag im aktuellen LOG nicht finden. Ich schaue gerade im Verzeichnis "/opt/iobroker/log/" -> Datei: -rw-rw-rw- 1 root root 278713 Jan 13 19:53 iobroker.2019-01-13.log
                      2019-01-13 19:25:01.432 - info: admin.0 Repository received successfully.
                      Einen Eintrag wie Du ihn hast habe ich so nicht gefunden. In welchen Log File schaust Du?
                      Gruß Daniel
                      • O Offline
                        O Offline
                        OMCastle
                        ich habe auch die Probleme.
                        root@orangepiplus2e:/opt/iobroker/log# npm install
                        npm ERR! Could not install from "../node_modules/iobroker.type-detector" as it does not contain a package.json file.
                        npm ERR! /root/.npm/_logs/2019-02-03T13_08_12_533Z-debug.log
                        Log:
                        root@orangepiplus2e:/opt/iobroker/log# cat /root/.npm/_logs/2019-02-03T13_08_12_533Z-debug.log
                        0 info it worked if it ends with ok
                        1 verbose cli [ '/usr/local/bin/node', '/usr/local/bin/npm', 'install' ]
                        2 info using npm@6.4.1
                        3 info using node@v8.15.0
                        4 verbose npm-session 2a798a6bb228acbe
                        5 silly install runPreinstallTopLevelLifecycles
                        6 silly preinstall iobroker@1.0.0
                        7 info lifecycle iobroker@1.0.0~preinstall: iobroker@1.0.0
                        8 silly install loadCurrentTree
                        9 silly install readLocalPackageData
                        157 silly resolveWithNewModule iobroker.socketio@2.1.1 checking installable status
                        158 silly fetchPackageMetaData error for iobroker.type-detector@file:node_modules/iobroker.type-detector Could not install from "../node_modules/iobroker.type-detector" as it does not contain a package.json file.
                        159 http fetch GET 200 https://github.com/iobroker-community-a ... all/master 4217ms
                        167 silly saveTree └── zstack-constants@0.2.0
                        168 verbose stack Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.type-detector/package.json'
                        169 verbose cwd /opt/iobroker/log
                        170 verbose Linux 3.4.113-sun8i
                        171 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install"
                        172 verbose node v8.15.0
                        173 verbose npm v6.4.1
                        174 error code ENOLOCAL
                        175 error Could not install from "../node_modules/iobroker.type-detector" as it does not contain a package.json file.
                        176 verbose exit [ 1, true ]
                        Bitte um Unterstützung…
                        Raspberrymatic auf Pi3 mit CUL für Eltako
                        • 30 HomeMatic Aktoren, 10 Eltako Aktoren
                        IOBroker auf OrangePi Plus 2e
                        • 30 Xiamoi, 5 Netatmo, VW Golf Skript, Viessmann Heizung, ICal, PluseCounter für Strom und Gas, Instar Kameras
                        • AlCalzoneA Offline
                          AlCalzoneA Offline
                          AlCalzone
                          Ich habe keine ahnung was für ein Paket das sein soll aber es scheint nicht sauber zu sein und aus einer lokalen Quelle installiert.
                          Schau mal in /opt/iobroker, bearbeite die package.json und lösche unter dependencies einen möglichen Verweis auf iobroker.type-detector (ganze Zeile löschen)
                          Gesendet von unterwegs
