  4. Homematic IP (Beschleunigungssensor): Kein Datenpunkt
8 Beiträge 5 Kommentatoren 832 Aufrufe 1 Beobachtet
    derrapf
    Hallo
    Habe heute mein erstes Homematic IP Gerät (Beschleunigungssensor) eingebunden und deshalb in iobroker eine neue Adapterinstanz angelegt.
    Im Log findet sich Folgendes.
    Im Log steht ich soll das hier bitte dem Entwickler schicken ;-)
    hm-rpc.2	2019-01-07 01:05:33.480	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"MOTION":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":1,"ID":"MOTION","TYP
    hm-rpc.2	2019-01-07 01:05:33.480	warn	Send this info to developer: _id: "hm-rpc.meta.VALUES.HmIP-SAM.ACCELERATION_TRANSCEIVER.1"
    hm-rpc.2	2019-01-07 01:05:33.429	info	xmlrpc -> getParamsetDescription ["000F18A98C92BD:1","VALUES"]
    hm-rpc.2	2019-01-07 01:05:33.381	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"CONFIG_PENDING":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"CONF
    hm-rpc.2	2019-01-07 01:05:33.380	warn	Send this info to developer: _id: "hm-rpc.meta.VALUES.HmIP-SAM.MAINTENANCE.1"
    hm-rpc.2	2019-01-07 01:05:33.080	info	xmlrpc -> getParamsetDescription ["000F18A98C92BD:0","VALUES"]
    hm-rpc.2	2019-01-07 01:05:32.895	info	xmlrpc <- newDevices 6
    hm-rpc.2	2019-01-07 01:05:32.683	info	xmlrpc -> 0 devices
    hm-rpc.2	2019-01-07 01:05:32.676	info	xmlrpc <- listDevices ["hm-rpc.2"]
    hm-rpc.2	2019-01-07 01:05:32.446	info	Connected
    hm-rpc.2	2019-01-07 01:05:32.362	info	xmlrpc client is trying to connect to 192.168.111.160:2010/ with ["http://192.168.111.176:2010","hm-rpc.2"]
    hm-rpc.2	2019-01-07 01:05:32.362	info	xmlrpc server is trying to listen on 192.168.111.176:2010
    hm-rpc.2	2019-01-07 01:05:32.203	info	starting. Version 1.8.3 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v8.14.0
    hm-rpc.2	2019-01-07 01:05:32.060	info	States connected to redis: 127.0.0.1:6379
    Ausserdem werden die Ämderungen nicht an iobroker gemeldet, bzw. ich sehe sie nicht:
    Man sieht nirgend die Meldung wie sie in der CCU steht ("Bewegung erkannt/senkrecht"). Es gibt nur den Datenpunkt Motion.
    Version von hm-rpc ist 1.8.3, Node ist v8.14.0, Nodejs ist v8.14.0
    Gruss Ralf
    • foxriver76F Offline
      foxriver76F Offline
      foxriver76
      Bitte mal die send this Info to developer Zeilen aus dem Log auf der Platte oder per log herunterladen kopieren, da sonst angeschnitten.
      Videotutorials & mehr
      • malorossM Offline
        malorossM Offline
        maloross
        Ich nutze diesen Sensor auch, der Datenpunkt Motion ist der, der die Bewegung meldet (true/false); waagerecht/senkrecht wird nur in der CCU angezeigt.
        Auch Frauen können sich für Technik begeistern! ;)
        Equipment:
        diverse HM-, HMIP-, Aeotec- Tradfri- Sonos- und Fibaro-Geräte, NAS, Proxmox mit div. LXC,
          derrapf
          Hallo
          Anbei ein Auszg aus dem Logfile
          2019-01-07 01:05:32.060  - [32minfo[39m: hm-rpc.2 States connected to redis: 127.0.0.1:6379
          2019-01-07 01:05:32.203  - [32minfo[39m: hm-rpc.2 starting. Version 1.8.3 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v8.14.0
          2019-01-07 01:05:32.362  - [32minfo[39m: hm-rpc.2 xmlrpc server is trying to listen on 192.168.111.176:2010
          2019-01-07 01:05:32.362  - [32minfo[39m: hm-rpc.2 xmlrpc client is trying to connect to 192.168.111.160:2010/ with ["http://192.168.111.176:2010","hm-rpc.2"]
          2019-01-07 01:05:32.446  - [32minfo[39m: hm-rpc.2 Connected
          2019-01-07 01:05:32.676  - [32minfo[39m: hm-rpc.2 xmlrpc <- listDevices ["hm-rpc.2"]
          2019-01-07 01:05:32.683  - [32minfo[39m: hm-rpc.2 xmlrpc -> 0 devices
          2019-01-07 01:05:32.895  - [32minfo[39m: hm-rpc.2 xmlrpc <- newDevices 6
          2019-01-07 01:05:33.080  - [32minfo[39m: hm-rpc.2 xmlrpc -> getParamsetDescription ["000F18A98C92BD:0","VALUES"]
          2019-01-07 01:05:33.380  - [33mwarn[39m: hm-rpc.2 Send this info to developer: _id: "hm-rpc.meta.VALUES.HmIP-SAM.MAINTENANCE.1"
          2019-01-07 01:05:33.381  - [33mwarn[39m: hm-rpc.2 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"CONFIG_PENDING":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"CONFIG_PENDING","TYPE":"BOOL","DEFAULT":false},"DUTY_CYCLE":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":1,"ID":"DUTY_CYCLE","TYPE":"BOOL","DEFAULT":false},"LOW_BAT":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"LOW_BAT","TYPE":"BOOL","DEFAULT":false},"UNREACH":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":25,"ID":"UNREACH","TYPE":"BOOL","DEFAULT":false},"RSSI_DEVICE":{"MIN":-128,"OPERATIONS":5,"MAX":127,"FLAGS":1,"ID":"RSSI_DEVICE","TYPE":"INTEGER","DEFAULT":0},"SENSOR_ERROR":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"SENSOR_ERROR","TYPE":"BOOL","DEFAULT":false},"OPERATING_VOLTAGE":{"MIN":0,"OPERATIONS":5,"MAX":25.2,"FLAGS":1,"ID":"OPERATING_VOLTAGE","TYPE":"FLOAT","DEFAULT":0},"RSSI_PEER":{"MIN":-128,"OPERATIONS":5,"MAX":127,"FLAGS":1,"ID":"RSSI_PEER","TYPE":"INTEGER","DEFAULT":0},"ERROR_CODE":{"MIN":0,"OPERATIONS":5,"MAX":255,"FLAGS":9,"ID":"ERROR_CODE","TYPE":"INTEGER","DEFAULT":0},"UPDATE_PENDING":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"UPDATE_PENDING","TYPE":"BOOL","DEFAULT":false}}}
          2019-01-07 01:05:33.429  - [32minfo[39m: hm-rpc.2 xmlrpc -> getParamsetDescription ["000F18A98C92BD:1","VALUES"]
          2019-01-07 01:05:33.480  - [33mwarn[39m: hm-rpc.2 Send this info to developer: _id: "hm-rpc.meta.VALUES.HmIP-SAM.ACCELERATION_TRANSCEIVER.1"
          2019-01-07 01:05:33.480  - [33mwarn[39m: hm-rpc.2 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"MOTION":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":1,"ID":"MOTION","TYPE":"BOOL","DEFAULT":false}}}
          2019-01-07 01:05:33.534  - [32minfo[39m: host.ioBroker-Tinker object change system.adapter.hm-rpc.2
          2019-01-07 01:05:33.535  - [32minfo[39m: host.ioBroker-Tinker stopInstance system.adapter.hm-rpc.2
          2019-01-07 01:05:34.535  - [32minfo[39m: host.ioBroker-Tinker stopInstance timeout "1000 system.adapter.hm-rpc.2 killing pid  10497
          2019-01-07 01:05:34.537  - [32minfo[39m: hm-rpc.2 xmlrpc -> 192.168.111.160:2010/ init ["http://192.168.111.176:2010",""]
          2019-01-07 01:05:34.596  - [32minfo[39m: hm-rpc.2 Disconnected
          2019-01-07 01:05:34.600  - [32minfo[39m: hm-rpc.2 xmlrpc -> 192.168.111.160:2010/ init ["http://192.168.111.176:2010",""]
          2019-01-07 01:05:34.614  - [32minfo[39m: host.ioBroker-Tinker instance system.adapter.hm-rpc.2 terminated with code 0 (OK)
          2019-01-07 01:05:37.053  - [32minfo[39m: host.ioBroker-Tinker instance system.adapter.hm-rpc.2 started with pid 10507
          2019-01-07 01:05:37.737  - [32minfo[39m: hm-rpc.2 States connected to redis: 127.0.0.1:6379
          2019-01-07 01:05:37.877  - [32minfo[39m: hm-rpc.2 starting. Version 1.8.3 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v8.14.0
          2019-01-07 01:05:38.025  - [32minfo[39m: hm-rpc.2 xmlrpc server is trying to listen on 192.168.111.176:2010
          2019-01-07 01:05:38.025  - [32minfo[39m: hm-rpc.2 xmlrpc client is trying to connect to 192.168.111.160:2010/ with ["http://192.168.111.176:2010","hm-rpc.2"]
          2019-01-07 01:05:38.126  - [32minfo[39m: hm-rpc.2 Connected
          2019-01-07 01:05:38.419  - [32minfo[39m: hm-rpc.2 xmlrpc <- listDevices ["hm-rpc.2"]
          2019-01-07 01:05:38.426  - [32minfo[39m: hm-rpc.2 xmlrpc -> 0 devices
          2019-01-07 01:05:38.691  - [32minfo[39m: hm-rpc.2 xmlrpc <- newDevices 6
          2019-01-07 01:05:38.698  - [32minfo[39m: hm-rpc.2 new HmIP devices/channels after filter: 0
          2019-01-07 01:06:01.232  - [32minfo[39m: tvspielfilm.0 force terminating adapter after 1 minute
          2019-01-07 01:06:01.751  - [32minfo[39m: host.ioBroker-Tinker instance system.adapter.tvspielfilm.0 terminated with code 0 (OK)
          2019-01-07 01:06:47.973  - [32minfo[39m: javascript.0 script.js.common.Statusansagen: TempUnter. im Hauswirtschaftsraum:16.6
          2019-01-07 01:08:38.132  - [33mwarn[39m: hm-rpc.2 [KEEPALIVE] Connection timed out
          2019-01-07 01:09:01.659  - [32minfo[39m: javascript.0 script.js.common.Statusansagen: TempUnter. im Hauswirtschaftsraum:16.7
          2019-01-07 01:09:08.624  - [32minfo[39m: hm-rpc.2 xmlrpc <- listDevices ["hm-rpc.2"]
          Die Date selbst ist zu gross.
          Gruss Ralf
            derrapf
            @maloross:
            Ich nutze diesen Sensor auch, der Datenpunkt Motion ist der, der die Bewegung meldet (true/false); waagerecht/senkrecht wird nur in der CCU angezeigt. `
            Ach, echt? Sonst gibt's da nichts?
            Dann muss ich nochmal schauen. Ich hab mit dem Ding rumgewackelt; in der CCU hat sich was getan, beim IOBroker nicht. Ich prüf das aber nochmal.
            Gruss Ralf
            • J Offline
              J Riemann
              ****Viele Grüße!
              Jörg****
                derrapf
                Jetzt gehts bei mir auch.
                Der Trick war ,dass man im Rega Adapter auch HM-IP eintragen muss!
                Gruss Ralf
                  skokarl
                  Moin,
                  kann man den nun fürs Garagentor nehmen oder nicht ?
                  ( ich habe keine CCU, nur den hmip Adapter )
                  Gibt es da nur den Zustand true/false oder auch senkrecht waagrecht ?
                  Ich habs noch nicht ganz verstanden.
                  Danke, Gruß
