  4. Hilfe ich kann kein Adapter mehr installieren
    6.6k
15 Beiträge 3 Kommentatoren 2.2k Aufrufe
  • L Offline
    leo12318
    Ich bekomme nicht mehr installiert,
    bekomme immer ähnlichen fhler mit "npm" "Json"
    ! $ ./iobroker add yahka –host raspberrypi
    ! NPM version: 6.4.1
    ! npm install iobroker.yahka --production --save --prefix "/opt/iobroker" (System call)
    ! sh: 1:
    ! node-pre-gyp: Permission denied
    ! gyp
    ! WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/8.15.0"
    ! gyp
    ! WARN
    ! EACCES
    ! attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/curve25519-n/.node-gyp"
    ! gyp
    ! WARN install got an error, rolling back install
    ! gyp
    ! gyp ERR! configure error gyp ERR! stack Error: EACCES: permission denied, stat '/opt/iobroker/node_modules/curve25519-n/.node-gyp/8.15.0'
    ! gyp ERR! System Linux 4.14.79-v7+
    ! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd
    ! /opt/iobroker/node_modules/curve25519-ngyp ERR! node -v v8.15.0
    ! gyp ERR! node-gyp -v v3.8.0
    ! gyp
    ! ERR! not ok
    ! npm
    ! WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 (node_modules/bcrypt):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 install: node-pre-gyp install --fallback-to-build
    ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: spawn ENOENT
    ! npm
    ! ERR! code ELIFECYCLEnpm ERR! errno 1
    ! npm ERR! curve25519-n@1.4.0 install: node-gyp rebuild
    ! npm ERR! Exit status 1
    ! npm ERR!
    ! npm ERR! Failed at the curve25519-n@1.4.0 install script.
    ! npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    ! npm ERR! A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2019-01-04T02_03_06_279Z-debug.log
    ! host.raspberrypi install adapter yahka
    ! sh: 1:
    ! gyp
    ! WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/8.15.0"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/curve25519-n/.node-gyp"
    ! gyp WARN install got an error, rolling back install
    ! gyp ERR! System Linux 4.14.79-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    ! gyp ERR! cwd
    ! gyp ERR! not ok
    ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 (node_modules/bcrypt):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 install: node-pre-gyp install --fallback-to-build
    ! npm ERR! code ELIFECYCLEnpm ERR! errno 1
    ! npm ERR! curve25519-n@1.4.0 install: node-gyp rebuildnpm ERR! Exit status 1
    ! npm ERR!
    ! npm
    ! ERR!
    ! ERR! /root/.npm/_logs/2019-01-04T02_04_12_213Z-debug.log
    ! sh: 1:
    ! gyp
    ! gyp ERR! cwd /opt/iobroker/node_modules/curve25519-n
    ! gyp ERR! node -v v8.15.0
    ! gyp ERR! not ok
    ! npm ERR!
    ! npm ERR! /root/.npm/_logs/2019-01-04T02_05_17_919Z-debug.log
    ! ERROR: host.raspberrypi Cannot install yahka
    ! ERROR: process exited with code 13
    Ich mache die ganze Nacht schon rum und kriege es nicht hin,
    hier der komplette 04.01
    ! 2019-01-04 00:00:15.795 - error: iot.0 read ECONNRESET
    ! 2019-01-04 00:00:15.796 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 00:00:15.796 - info: iot.0 Connection lost
    ! 2019-01-04 00:00:21.116 - info: iot.0 Connection changed: connect
    ! 2019-01-04 00:03:28.387 - error: iot.0 read ECONNRESET
    ! 2019-01-04 00:03:28.388 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 00:03:28.388 - info: iot.0 Connection lost
    ! 2019-01-04 00:03:33.701 - info: iot.0 Connection changed: connect
    ! 2019-01-04 00:07:11.260 - error: iot.0 read ECONNRESET
    ! 2019-01-04 00:07:11.260 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 00:07:11.261 - info: iot.0 Connection lost
    ! 2019-01-04 00:07:16.598 - info: iot.0 Connection changed: connect
    ! 2019-01-04 00:10:47.603 - error: iot.0 read ECONNRESET
    ! 2019-01-04 00:10:47.603 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 00:10:47.604 - info: iot.0 Connection lost
    ! 2019-01-04 00:10:52.927 - info: iot.0 Connection changed: connect
    ! 2019-01-04 00:12:00.636 - info: iobroker url "https://github.com/ioBroker/ioBroker.ma … all/master" maxcube
    ! 2019-01-04 00:12:01.492 - info: iobroker install https://github.com/ioBroker/ioBroker.ma ... all/master
    ! 2019-01-04 00:12:02.441 - info: iobroker npm install https://github.com/ioBroker/ioBroker.ma ... all/master --production --save --prefix "/opt/iobroker" (System call)
    ! 2019-01-04 00:12:40.336 - info: iobroker got /opt/iobroker/node_modules/iobroker.maxcube/admin
    ! 2019-01-04 00:12:40.364 - info: iobroker upload [3] maxcube.admin /opt/iobroker/node_modules/iobroker.maxcube/admin/words.js words.js application/javascript
    ! 2019-01-04 00:12:40.468 - info: iobroker upload [2] maxcube.admin /opt/iobroker/node_modules/iobroker.maxcube/admin/maxcube.png maxcube.png image/png
    ! 2019-01-04 00:12:40.543 - info: iobroker upload [1] maxcube.admin /opt/iobroker/node_modules/iobroker.maxcube/admin/index_m.html index_m.html text/html
    ! 2019-01-04 00:12:40.605 - info: iobroker upload [0] maxcube.admin /opt/iobroker/node_modules/iobroker.maxcube/admin/index.html index.html text/html
    ! 2019-01-04 00:12:40.685 - info: iobroker exit 0
    ! 2019-01-04 00:12:41.894 - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    ! 2019-01-04 00:13:27.985 - info: host.raspberrypi object change system.adapter.maxcube.0
    ! 2019-01-04 00:13:27.987 - info: host.raspberrypi stopInstance system.adapter.maxcube.0
    ! 2019-01-04 00:13:27.987 - info: host.raspberrypi stopInstance system.adapter.maxcube.0 killing pid 11059
    ! 2019-01-04 00:13:28.048 - info: host.raspberrypi instance system.adapter.maxcube.0 terminated with code 0 (OK)
    ! 2019-01-04 00:13:30.531 - info: host.raspberrypi instance system.adapter.maxcube.0 started with pid 11555
    ! 2019-01-04 00:13:31.696 - info: maxcube.0 starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.maxcube, node: v8.15.0
    ! 2019-01-04 00:13:31.993 - info: maxcube.0 Connected
    ! 2019-01-04 00:13:32.415 - info: maxcube.0 object maxcube.0.maxcube.0.devices.thermostat_06a902 created
    ! 2019-01-04 00:13:32.422 - info: maxcube.0 object maxcube.0.maxcube.0.devices.thermostat_06a902.initialized created
    ! 2019-01-04 00:13:32.429 - info: maxcube.0 object maxcube.0.maxcube.0.devices.thermostat_06a902.error created
    ! 2019-01-04 00:13:32.435 - info: maxcube.0 object maxcube.0.maxcube.0.devices.thermostat_06a902.invalid created
    ! 2019-01-04 00:13:32.442 - info: maxcube.0 object maxcube.0.maxcube.0.devices.thermostat_06a902.mode created
    ! 2019-01-04 00:13:32.449 - info: maxcube.0 object maxcube.0.maxcube.0.devices.thermostat_06a902.panel_locked created
    ! 2019-01-04 00:13:32.455 - info: maxcube.0 object maxcube.0.maxcube.0.devices.thermostat_06a902.link_error created
    ! 2019-01-04 00:13:32.462 - info: maxcube.0 object maxcube.0.maxcube.0.devices.thermostat_06a902.battery_low created
    ! 2019-01-04 00:13:32.471 - info: maxcube.0 object maxcube.0.maxcube.0.devices.thermostat_06a902.valve created
    ! 2019-01-04 00:13:32.478 - info: maxcube.0 object maxcube.0.maxcube.0.devices.thermostat_06a902.setpoint created
    ! 2019-01-04 00:13:32.485 - info: maxcube.0 object maxcube.0.maxcube.0.devices.thermostat_06a902.temp created
    ! 2019-01-04 00:13:32.495 - info: maxcube.0 object maxcube.0.maxcube.0.devices.thermostat_06a902.working created
    ! 2019-01-04 00:13:32.563 - info: maxcube.0 object maxcube.0.maxcube.0.devices.thermostat_06a918 created
    ! 2019-01-04 00:13:32.569 - info: maxcube.0 object maxcube.0.maxcube.0.devices.thermostat_06a918.initialized created
    ! 2019-01-04 00:13:32.575 - info: maxcube.0 object maxcube.0.maxcube.0.devices.thermostat_06a918.error created
    ! 2019-01-04 00:13:32.581 - info: maxcube.0 object maxcube.0.maxcube.0.devices.thermostat_06a918.invalid created
    ! 2019-01-04 00:13:32.590 - info: maxcube.0 object maxcube.0.maxcube.0.devices.thermostat_06a918.mode created
    ! 2019-01-04 00:13:32.599 - info: maxcube.0 object maxcube.0.maxcube.0.devices.thermostat_06a918.panel_locked created
    ! 2019-01-04 00:13:32.605 - info: maxcube.0 object maxcube.0.maxcube.0.devices.thermostat_06a918.link_error created
    ! 2019-01-04 00:13:32.610 - info: maxcube.0 object maxcube.0.maxcube.0.devices.thermostat_06a918.battery_low created
    ! 2019-01-04 00:13:32.619 - info: maxcube.0 object maxcube.0.maxcube.0.devices.thermostat_06a918.valve created
    ! 2019-01-04 00:13:32.629 - info: maxcube.0 object maxcube.0.maxcube.0.devices.thermostat_06a918.setpoint created
    ! 2019-01-04 00:13:32.636 - info: maxcube.0 object maxcube.0.maxcube.0.devices.thermostat_06a918.temp created
    ! 2019-01-04 00:13:32.643 - info: maxcube.0 object maxcube.0.maxcube.0.devices.thermostat_06a918.working created
    ! 2019-01-04 00:14:27.704 - error: iot.0 read ECONNRESET
    ! 2019-01-04 00:14:27.704 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 00:14:27.705 - info: iot.0 Connection lost
    ! 2019-01-04 00:14:33.025 - info: iot.0 Connection changed: connect
    ! 2019-01-04 00:17:57.735 - error: iot.0 read ECONNRESET
    ! 2019-01-04 00:17:57.736 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 00:17:57.736 - info: iot.0 Connection lost
    ! 2019-01-04 00:18:02.999 - info: iot.0 Connection changed: connect
    ! 2019-01-04 00:21:14.379 - error: iot.0 read ECONNRESET
    ! 2019-01-04 00:21:14.379 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 00:21:14.379 - info: iot.0 Connection lost
    ! 2019-01-04 00:21:19.710 - info: iot.0 Connection changed: connect
    ! 2019-01-04 00:24:51.243 - error: iot.0 read ECONNRESET
    ! 2019-01-04 00:24:51.244 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 00:24:51.244 - info: iot.0 Connection lost
    ! 2019-01-04 00:24:56.573 - info: iot.0 Connection changed: connect
    ! 2019-01-04 00:26:36.724 - info: scenes.0 restartAdapter
    ! 2019-01-04 00:27:27.474 - info: scenes.0 restartAdapter
    ! 2019-01-04 00:27:38.169 - info: iot.0 Request devices
    ! 2019-01-04 00:28:27.230 - info: iot.0 Request devices
    ! 2019-01-04 00:28:38.044 - info: scenes.0 restartAdapter
    ! 2019-01-04 00:28:52.141 - info: scenes.0 restartAdapter
    ! 2019-01-04 00:28:52.162 - info: scenes.0 restartAdapter
    ! 2019-01-04 00:28:54.915 - error: iot.0 read ECONNRESET
    ! 2019-01-04 00:28:54.916 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 00:28:54.916 - info: iot.0 Connection lost
    ! 2019-01-04 00:29:00.237 - info: iot.0 Connection changed: connect
    ! 2019-01-04 00:29:04.548 - info: iot.0 Request devices
    ! 2019-01-04 00:29:15.784 - info: scenes.0 restartAdapter
    ! 2019-01-04 00:29:16.887 - info: iot.0 Request devices
    ! 2019-01-04 00:29:16.906 - info: iot.0 Request V3 devices
    ! 2019-01-04 00:29:23.662 - info: scenes.0 restartAdapter
    ! 2019-01-04 00:29:24.749 - info: iot.0 Request devices
    ! 2019-01-04 00:29:24.763 - info: iot.0 Request V3 devices
    ! 2019-01-04 00:32:28.624 - info: scenes.0 restartAdapter
    ! 2019-01-04 00:32:29.812 - info: iot.0 Request devices
    ! 2019-01-04 00:32:29.854 - info: iot.0 Request V3 devices
    ! 2019-01-04 00:32:39.401 - info: iot.0 Request devices
    ! 2019-01-04 00:32:43.528 - info: iot.0 Request devices
    ! 2019-01-04 00:36:41.800 - error: iot.0 read ECONNRESET
    ! 2019-01-04 00:36:41.801 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 00:36:41.801 - info: iot.0 Connection lost
    ! 2019-01-04 00:36:47.128 - info: iot.0 Connection changed: connect
    ! 2019-01-04 00:37:42.382 - info: iot.0 Request devices
    ! 2019-01-04 00:37:50.332 - info: scenes.0 restartAdapter
    ! 2019-01-04 00:37:55.520 - info: scenes.0 restartAdapter
    ! 2019-01-04 00:37:59.671 - info: scenes.0 restartAdapter
    ! 2019-01-04 00:38:00.795 - info: scenes.0 restartAdapter
    ! 2019-01-04 00:40:08.903 - error: iot.0 read ECONNRESET
    ! 2019-01-04 00:40:08.904 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 00:40:08.904 - info: iot.0 Connection lost
    ! 2019-01-04 00:40:14.256 - info: iot.0 Connection changed: connect
    ! 2019-01-04 00:43:21.492 - error: iot.0 read ECONNRESET
    ! 2019-01-04 00:43:21.492 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 00:43:21.492 - info: iot.0 Connection lost
    ! 2019-01-04 00:43:26.839 - info: iot.0 Connection changed: connect
    ! 2019-01-04 00:44:13.273 - info: iobroker _restart
    ! 2019-01-04 00:44:13.882 - info: iobroker Starting node restart.js
    ! 2019-01-04 00:44:13.903 - info: iobroker exit 0
    ! 2019-01-04 00:44:14.265 - info: host.raspberrypi received SIGTERM
    ! 2019-01-04 00:44:14.275 - info: admin.0 terminating http server on port 8081
    ! 2019-01-04 00:44:14.267 - info: host.raspberrypi stopInstance system.adapter.admin.0
    ! 2019-01-04 00:44:14.267 - info: host.raspberrypi stopInstance system.adapter.admin.0 killing pid 2529
    ! 2019-01-04 00:44:14.268 - info: host.raspberrypi stopInstance system.adapter.discovery.0
    ! 2019-01-04 00:44:14.268 - info: host.raspberrypi stopInstance system.adapter.discovery.0 killing pid 2539
    ! 2019-01-04 00:44:14.269 - info: host.raspberrypi stopInstance system.adapter.tr-064.0
    ! 2019-01-04 00:44:14.273 - warn: host.raspberrypi stopInstance system.adapter.tr-064.0 not running
    ! 2019-01-04 00:44:14.273 - info: host.raspberrypi stopInstance system.adapter.ping.0
    ! 2019-01-04 00:44:14.274 - info: host.raspberrypi stopInstance system.adapter.ping.0 killing pid 2576
    ! 2019-01-04 00:44:14.276 - info: host.raspberrypi stopInstance system.adapter.web.0
    ! 2019-01-04 00:44:14.276 - info: host.raspberrypi stopInstance system.adapter.web.0 killing pid 2596
    ! 2019-01-04 00:44:14.277 - info: host.raspberrypi stopInstance system.adapter.backitup.0
    ! 2019-01-04 00:44:14.277 - info: host.raspberrypi stopInstance system.adapter.backitup.0 killing pid 8461
    ! 2019-01-04 00:44:14.277 - info: host.raspberrypi stopInstance system.adapter.broadlink2.0
    ! 2019-01-04 00:44:14.278 - info: host.raspberrypi stopInstance system.adapter.broadlink2.0 killing pid 2662
    ! 2019-01-04 00:44:14.280 - info: host.raspberrypi stopInstance system.adapter.scenes.0
    ! 2019-01-04 00:44:14.281 - info: host.raspberrypi stopInstance system.adapter.scenes.0 killing pid 2936
    ! 2019-01-04 00:44:14.281 - info: host.raspberrypi stopInstance system.adapter.mihome-vacuum.0
    ! 2019-01-04 00:44:14.282 - info: host.raspberrypi stopInstance system.adapter.mihome-vacuum.0 killing pid 24704
    ! 2019-01-04 00:44:14.282 - info: host.raspberrypi stopInstance system.adapter.alexa2.0
    ! 2019-01-04 00:44:14.283 - warn: host.raspberrypi stopInstance system.adapter.alexa2.0 not running
    ! 2019-01-04 00:44:14.283 - info: host.raspberrypi stopInstance system.adapter.iot.0
    ! 2019-01-04 00:44:14.284 - info: host.raspberrypi stopInstance system.adapter.iot.0 killing pid 24562
    ! 2019-01-04 00:44:14.284 - info: host.raspberrypi stopInstance system.adapter.maxcube.0
    ! 2019-01-04 00:44:14.285 - info: host.raspberrypi stopInstance system.adapter.maxcube.0 killing pid 11555
    ! 2019-01-04 00:44:14.293 - info: maxcube.0 Connection closed
    ! 2019-01-04 00:44:14.318 - info: admin.0 terminating http server on port 8081
    ! 2019-01-04 00:44:14.332 - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 0 (OK)
    ! 2019-01-04 00:44:14.332 - info: host.raspberrypi All instances are stopped.
    ! 2019-01-04 00:44:14.337 - info: host.raspberrypi instance system.adapter.broadlink2.0 terminated with code 0 (OK)
    ! 2019-01-04 00:44:14.337 - info: host.raspberrypi All instances are stopped.
    ! 2019-01-04 00:44:14.341 - info: host.raspberrypi instance system.adapter.maxcube.0 terminated with code 0 (OK)
    ! 2019-01-04 00:44:14.341 - info: host.raspberrypi All instances are stopped.
    ! 2019-01-04 00:44:14.344 - info: host.raspberrypi instance system.adapter.web.0 terminated with code 0 (OK)
    ! 2019-01-04 00:44:14.345 - info: host.raspberrypi All instances are stopped.
    ! 2019-01-04 00:44:14.348 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated with code 0 (OK)
    ! 2019-01-04 00:44:14.348 - info: host.raspberrypi All instances are stopped.
    ! 2019-01-04 00:44:14.368 - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (OK)
    ! 2019-01-04 00:44:14.368 - info: host.raspberrypi All instances are stopped.
    ! 2019-01-04 00:44:14.373 - info: host.raspberrypi instance system.adapter.iot.0 terminated with code 0 (OK)
    ! 2019-01-04 00:44:14.373 - info: host.raspberrypi All instances are stopped.
    ! 2019-01-04 00:44:14.491 - info: host.raspberrypi terminated
    ! 2019-01-04 00:44:20.849 - info: host.raspberrypi iobroker.js-controller version 1.4.2 js-controller starting
    ! 2019-01-04 00:44:20.856 - info: host.raspberrypi Copyright © 2014-2018 bluefox, 2014 hobbyquaker
    ! 2019-01-04 00:44:20.856 - info: host.raspberrypi hostname: raspberrypi, node: v8.15.0
    ! 2019-01-04 00:44:20.861 - info: host.raspberrypi ip addresses: 192.168.178.76 2a02:908:186b:3780:c06a:666b:38a5:5eb4 fe80::828:8793:35b8:60d6
    ! 2019-01-04 00:44:21.088 - info: host.raspberrypi inMem-states listening on port 9000
    ! 2019-01-04 00:44:21.253 - info: host.raspberrypi inMem-objects listening on port 9001
    ! 2019-01-04 00:44:21.269 - info: host.raspberrypi InMemoryDB connected
    ! 2019-01-04 00:44:21.286 - info: host.raspberrypi 12 instances found
    ! 2019-01-04 00:44:21.302 - info: host.raspberrypi starting 10 instances
    ! 2019-01-04 00:44:21.352 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 11999
    ! 2019-01-04 00:44:25.129 - info: admin.0 starting. Version 3.5.10 in /opt/iobroker/node_modules/iobroker.admin, node: v8.15.0
    ! 2019-01-04 00:44:25.148 - info: admin.0 requesting all states
    ! 2019-01-04 00:44:25.151 - info: admin.0 requesting all objects
    ! 2019-01-04 00:44:25.152 - info: admin.0 Request actual repository...
    ! 2019-01-04 00:44:25.407 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 12009
    ! 2019-01-04 00:44:25.592 - info: admin.0 received all states
    ! 2019-01-04 00:44:26.308 - info: admin.0 received all objects
    ! 2019-01-04 00:44:26.716 - info: discovery.0 starting. Version 1.2.4 in /opt/iobroker/node_modules/iobroker.discovery, node: v8.15.0
    ! 2019-01-04 00:44:26.422 - info: admin.0 http server listening on port 8081
    ! 2019-01-04 00:44:26.423 - info: admin.0 Use link "http://localhost:8081" to configure.
    ! 2019-01-04 00:44:26.796 - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    ! 2019-01-04 00:44:28.275 - info: admin.0 Repository received successfully.
    ! 2019-01-04 00:44:29.320 - info: host.raspberrypi instance system.adapter.ping.0 started with pid 12019
    ! 2019-01-04 00:44:30.432 - info: ping.0 starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.ping, node: v8.15.0
    ! 2019-01-04 00:44:33.320 - info: host.raspberrypi instance system.adapter.web.0 started with pid 12036
    ! 2019-01-04 00:44:34.938 - error: web.0 setObject id missing!!
    ! 2019-01-04 00:44:34.952 - info: web.0 starting. Version 2.4.1 in /opt/iobroker/node_modules/iobroker.web, node: v8.15.0
    ! 2019-01-04 00:44:35.766 - info: web.0 socket.io server listening on port 8082
    ! 2019-01-04 00:44:35.770 - info: web.0 http server listening on port 8082
    ! 2019-01-04 00:44:37.332 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 12049
    ! 2019-01-04 00:44:38.730 - info: backitup.0 starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.15.0
    ! 2019-01-04 00:44:38.761 - info: backitup.0 [total] backup was activated at 04:00 every 3 day(s)
    ! 2019-01-04 00:44:41.335 - info: host.raspberrypi instance system.adapter.broadlink2.0 started with pid 12059
    ! 2019-01-04 00:44:42.438 - info: broadlink2.0 starting. Version 1.9.0 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v8.15.0
    ! 2019-01-04 00:44:43.476 - info: broadlink2.0 Discover UDP devices for 10sec on broadlink2.0
    ! 2019-01-04 00:44:45.330 - info: host.raspberrypi instance system.adapter.scenes.0 started with pid 12069
    ! 2019-01-04 00:44:46.471 - info: scenes.0 starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.scenes, node: v8.15.0
    ! 2019-01-04 00:44:48.676 - warn: broadlink2.0 device RM:Broadlink-RMPROPLUS-8a-61-96 not found, please rescan later again or delete it! It was: 192.168.178.57,IPv4,80,128,10026,rm,RM:Broadlink-RMPROPLUS-8a-61-96,RM2 Pro Plus,2a:27:39:b2:a8:c0
    ! 2019-01-04 00:44:48.686 - info: broadlink2.0 Adapter broadlink2.0 started and found 0 devices named ''.
    ! 2019-01-04 00:44:48.687 - info: broadlink2.0 1 were not found: RM:Broadlink-RMPROPLUS-8a-61-96
    ! 2019-01-04 00:44:49.328 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 started with pid 12079
    ! 2019-01-04 00:44:50.588 - info: mihome-vacuum.0 starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v8.15.0
    ! 2019-01-04 00:44:50.601 - info: mihome-vacuum.0 Expert mode enabled, states created
    ! 2019-01-04 00:44:50.602 - info: mihome-vacuum.0 Create state clean_home for controlling by cloud adapter
    ! 2019-01-04 00:44:50.855 - info: mihome-vacuum.0 New generation or new fw detected, create new states
    ! 2019-01-04 00:44:53.316 - info: host.raspberrypi instance system.adapter.iot.0 started with pid 12089
    ! 2019-01-04 00:44:56.167 - info: iot.0 starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.iot, node: v8.15.0
    ! 2019-01-04 00:44:56.201 - info: iot.0 Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
    ! 2019-01-04 00:44:56.929 - info: iot.0 Connection changed: connect
    ! 2019-01-04 00:44:57.325 - info: host.raspberrypi instance system.adapter.maxcube.0 started with pid 12099
    ! 2019-01-04 00:44:58.467 - info: maxcube.0 starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.maxcube, node: v8.15.0
    ! 2019-01-04 00:44:58.766 - info: maxcube.0 Connected
    ! 2019-01-04 00:45:20.695 - warn: broadlink2.0 Device RM:Broadlink-RMPROPLUS-8a-61-96 not reachable
    ! 2019-01-04 00:48:30.338 - error: iot.0 read ECONNRESET
    ! 2019-01-04 00:48:30.340 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 00:48:30.340 - info: iot.0 Connection lost
    ! 2019-01-04 00:48:35.671 - info: iot.0 Connection changed: connect
    ! 2019-01-04 00:49:20.819 - info: broadlink2.0 Device RM:Broadlink-RMPROPLUS-8a-61-96 dedected: 192.168.178.57,IPv4,80,128,10026,rm,RM:Broadlink-RMPROPLUS-8a-61-96,RM2 Pro Plus,2a:27:39:b2:a8:c0
    ! 2019-01-04 00:52:05.780 - error: iot.0 read ECONNRESET
    ! 2019-01-04 00:52:05.781 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 00:52:05.781 - info: iot.0 Connection lost
    ! 2019-01-04 00:52:11.461 - info: iot.0 Connection changed: connect
    ! 2019-01-04 00:55:07.130 - info: scenes.0 restartAdapter
    ! 2019-01-04 00:55:26.564 - error: iot.0 read ECONNRESET
    ! 2019-01-04 00:55:26.565 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 00:55:26.565 - info: iot.0 Connection lost
    ! 2019-01-04 00:55:31.893 - info: iot.0 Connection changed: connect
    ! 2019-01-04 00:55:49.781 - info: scenes.0 restartAdapter
    ! 2019-01-04 00:56:01.738 - info: scenes.0 restartAdapter
    ! 2019-01-04 00:56:21.286 - info: scenes.0 restartAdapter
    ! 2019-01-04 00:56:40.060 - info: scenes.0 restartAdapter
    ! 2019-01-04 00:56:59.067 - info: scenes.0 restartAdapter
    ! 2019-01-04 00:56:59.214 - info: scenes.0 restartAdapter
    ! 2019-01-04 00:57:11.638 - info: scenes.0 restartAdapter
    ! 2019-01-04 00:57:32.912 - info: iot.0 Request devices
    ! 2019-01-04 00:57:45.380 - info: scenes.0 restartAdapter
    ! 2019-01-04 00:57:46.545 - info: iot.0 Request devices
    ! 2019-01-04 00:57:46.566 - info: iot.0 Request V3 devices
    ! 2019-01-04 00:57:48.751 - info: scenes.0 restartAdapter
    ! 2019-01-04 00:57:49.939 - info: iot.0 Request devices
    ! 2019-01-04 00:57:49.955 - info: iot.0 Request V3 devices
    ! 2019-01-04 00:58:04.129 - info: scenes.0 restartAdapter
    ! 2019-01-04 00:58:05.288 - info: iot.0 Request devices
    ! 2019-01-04 00:58:05.308 - info: iot.0 Request V3 devices
    ! 2019-01-04 00:59:29.382 - info: iot.0 Request devices
    ! 2019-01-04 00:59:42.676 - info: iobroker add javascript –host raspberrypi
    ! 2019-01-04 00:59:44.949 - info: iobroker NPM version: 6.5.0
    ! 2019-01-04 00:59:45.686 - info: iobroker npm install iobroker.javascript --production --save --prefix "/opt/iobroker" (System call)
    ! 2019-01-04 01:00:03.556 - info: iobroker npm
    ! 2019-01-04 01:00:03.557 - info: iobroker WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
    ! 2019-01-04 01:00:34.399 - info: iobroker module.js:550 throw err;
    ! Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/install/installTypings.js'
    ! at Function.Module._resolveFilename (module.js:548:15)
    ! at Function.Module._load (module.js:475:25)
    ! at Function.Module.runMain (module.js:694:10)
    ! at startup (bootstrap_node.js:204:16)
    ! at bootstrap_node.js:625:3
    ! 2019-01-04 01:00:38.396 - info: iobroker npm
    ! 2019-01-04 01:00:38.397 - info: iobroker
    ! 2019-01-04 01:00:38.399 - info: iobroker ERR!
    ! 2019-01-04 01:00:38.400 - info: iobroker code
    ! 2019-01-04 01:00:38.402 - info: iobroker ELIFECYCLE
    ! 2019-01-04 01:00:38.404 - info: iobroker npm ERR! errno 1
    ! 2019-01-04 01:00:38.408 - info: iobroker npm
    ! 2019-01-04 01:00:38.410 - info: iobroker ERR! iobroker.javascript@4.0.7 postinstall: node ./install/installTypings.jsnpm ERR! Exit status 1
    ! npm ERR!
    ! npm
    ! 2019-01-04 01:00:38.411 - info: iobroker ERR! Failed at the iobroker.javascript@4.0.7 postinstall script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    ! 2019-01-04 01:00:38.621 - info: iobroker
    ! 2019-01-04 01:00:38.622 - info: iobroker npm ERR! A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2019-01-04T00_00_38_451Z-debug.log
    ! 2019-01-04 01:00:38.706 - info: iobroker host.raspberrypi install adapter javascript
    ! 2019-01-04 01:00:39.918 - info: iobroker NPM version: 6.5.0
    ! 2019-01-04 01:00:39.921 - info: iobroker npm install iobroker.javascript --production --save --prefix "/opt/iobroker" (System call)
    ! 2019-01-04 01:00:58.187 - info: iobroker npm
    ! 2019-01-04 01:00:58.191 - info: iobroker WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
    ! 2019-01-04 01:01:24.919 - info: iobroker module.js:550 throw err;
    ! 2019-01-04 01:01:29.205 - info: iobroker npm
    ! 2019-01-04 01:01:29.207 - info: iobroker
    ! 2019-01-04 01:01:29.208 - info: iobroker ERR!
    ! 2019-01-04 01:01:29.210 - info: iobroker code ELIFECYCLE
    ! 2019-01-04 01:01:29.211 - info: iobroker npm ERR! errno 1
    ! 2019-01-04 01:01:29.220 - info: iobroker npm ERR! iobroker.javascript@4.0.7 postinstall: node ./install/installTypings.jsnpm ERR! Exit status 1
    ! npm ERR!
    ! npm
    ! 2019-01-04 01:01:29.231 - info: iobroker ERR! Failed at the iobroker.javascript@4.0.7 postinstall script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    ! 2019-01-04 01:01:29.289 - info: iobroker
    ! 2019-01-04 01:01:29.291 - info: iobroker npm ERR! A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2019-01-04T00_01_29_259Z-debug.log
    ! 2019-01-04 01:01:29.331 - info: iobroker host.raspberrypi install adapter javascript
    ! 2019-01-04 01:01:30.673 - info: iobroker NPM version: 6.5.0
    ! 2019-01-04 01:01:30.675 - info: iobroker npm install iobroker.javascript --production --save --prefix "/opt/iobroker" (System call)
    ! 2019-01-04 01:01:37.565 - error: iot.0 read ECONNRESET
    ! 2019-01-04 01:01:37.565 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 01:01:37.566 - info: iot.0 Connection lost
    ! 2019-01-04 01:01:42.829 - info: iot.0 Connection changed: connect
    ! 2019-01-04 01:01:49.174 - info: iobroker npm
    ! 2019-01-04 01:01:49.180 - info: iobroker WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
    ! 2019-01-04 01:02:10.662 - info: iobroker module.js:550 throw err;
    ! 2019-01-04 01:02:18.724 - info: iobroker npm
    ! 2019-01-04 01:02:18.728 - info: iobroker ERR! code ELIFECYCLEnpm
    ! 2019-01-04 01:02:18.733 - info: iobroker ERR! errno 1
    ! 2019-01-04 01:02:18.737 - info: iobroker npm
    ! 2019-01-04 01:02:18.741 - info: iobroker ERR! iobroker.javascript@4.0.7 postinstall: node ./install/installTypings.jsnpm ERR! Exit status 1
    ! npm
    ! 2019-01-04 01:02:18.746 - info: iobroker ERR! npm ERR! Failed at the iobroker.javascript@4.0.7 postinstall script.
    ! npm
    ! 2019-01-04 01:02:18.751 - info: iobroker ERR! This is probably not a problem with npm. There is likely additional logging output above.
    ! 2019-01-04 01:02:18.834 - info: iobroker
    ! 2019-01-04 01:02:18.835 - info: iobroker npm
    ! 2019-01-04 01:02:18.837 - info: iobroker ERR!
    ! 2019-01-04 01:02:18.838 - info: iobroker A complete log of this run can be found in:npm
    ! 2019-01-04 01:02:18.839 - info: iobroker ERR! /root/.npm/_logs/2019-01-04T00_02_18_772Z-debug.log
    ! 2019-01-04 01:02:18.881 - info: iobroker host.raspberrypi install adapter javascript
    ! 2019-01-04 01:02:18.886 - error: iobroker host.raspberrypi Cannot install javascript
    ! 2019-01-04 01:02:18.905 - info: iobroker exit 13
    ! 2019-01-04 01:04:26.047 - info: iobroker url "https://github.com/ioBroker/ioBroker.ja ... all/master" javascript
    ! 2019-01-04 01:04:26.899 - info: iobroker install https://github.com/ioBroker/ioBroker.ja ... all/master
    ! 2019-01-04 01:04:27.828 - info: iobroker npm install https://github.com/ioBroker/ioBroker.ja ... all/master --production --save --prefix "/opt/iobroker" (System call)
    ! 2019-01-04 01:04:51.594 - info: iobroker npm
    ! 2019-01-04 01:04:51.595 - info: iobroker WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
    ! 2019-01-04 01:05:18.778 - error: iot.0 read ECONNRESET
    ! 2019-01-04 01:05:18.778 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 01:05:18.779 - info: iot.0 Connection lost
    ! 2019-01-04 01:05:24.156 - info: iot.0 Connection changed: connect
    ! 2019-01-04 01:05:25.327 - info: iobroker module.js:550 throw err;
    ! 2019-01-04 01:05:30.040 - info: iobroker npm ERR! code ELIFECYCLEnpm ERR! errno 1
    ! 2019-01-04 01:05:30.048 - info: iobroker npm ERR! iobroker.javascript@4.0.7 postinstall: node ./install/installTypings.jsnpm ERR! Exit status 1
    ! npm ERR!
    ! 2019-01-04 01:05:30.163 - info: iobroker npm ERR! A complete log of this run can be found in:
    ! npm ERR! /root/.npm/_logs/2019-01-04T00_05_30_069Z-debug.log
    ! 2019-01-04 01:05:30.263 - error: iobroker Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
    ! 2019-01-04 01:05:30.275 - info: iobroker exit 0
    ! 2019-01-04 01:05:31.831 - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    ! 2019-01-04 01:08:02.925 - info: iobroker del alexa2.0
    ! 2019-01-04 01:08:03.931 - info: iobroker Delete adapter "alexa2.0"
    ! 2019-01-04 01:08:03.985 - info: iobroker host.raspberrypi Counted 1 instances of alexa2
    ! 2019-01-04 01:08:04.009 - info: iobroker host.raspberrypi Counted 1 channels of alexa2.0
    ! 2019-01-04 01:08:04.049 - info: iobroker host.raspberrypi Counted 11 states of alexa2.0
    ! 2019-01-04 01:08:04.085 - info: iobroker host.raspberrypi Counted 1 states (io.alexa2.0.) from states
    ! 2019-01-04 01:08:04.097 - info: iobroker host.raspberrypi Counted 8 states (system.adapter.alexa2.0.
    ) from states
    ! 2019-01-04 01:08:05.090 - info: iobroker host.raspberrypi Deleting 13 object(s).
    ! 2019-01-04 01:08:05.144 - info: host.raspberrypi object change system.adapter.alexa2.0
    ! 2019-01-04 01:08:05.145 - info: host.raspberrypi object deleted system.adapter.alexa2.0
    ! 2019-01-04 01:08:05.149 - info: iobroker host.raspberrypi Deleting 9 state(s).
    ! 2019-01-04 01:08:05.188 - info: iobroker exit 0
    ! 2019-01-04 01:09:03.652 - info: iobroker del tr-064.0
    ! 2019-01-04 01:09:04.291 - error: iot.0 read ECONNRESET
    ! 2019-01-04 01:09:04.291 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 01:09:04.291 - info: iot.0 Connection lost
    ! 2019-01-04 01:09:04.690 - info: iobroker Delete adapter "tr-064.0"
    ! 2019-01-04 01:09:04.745 - info: iobroker host.raspberrypi Counted 1 instances of tr-064
    ! 2019-01-04 01:09:04.753 - info: iobroker host.raspberrypi Counted 6 devices of tr-064.0
    ! 2019-01-04 01:09:04.809 - info: iobroker host.raspberrypi Counted 22 states of tr-064.0
    ! 2019-01-04 01:09:04.843 - info: iobroker host.raspberrypi Counted 21 states (io.tr-064.0.) from states
    ! 2019-01-04 01:09:04.856 - info: iobroker host.raspberrypi Counted 9 states (system.adapter.tr-064.0.
    ) from states
    ! 2019-01-04 01:09:05.966 - info: iobroker host.raspberrypi Counted 1 objects of tr-064.0
    ! 2019-01-04 01:09:05.967 - info: iobroker host.raspberrypi Deleting 30 object(s).
    ! 2019-01-04 01:09:06.099 - info: host.raspberrypi object change system.adapter.tr-064.0
    ! 2019-01-04 01:09:06.099 - info: host.raspberrypi object deleted system.adapter.tr-064.0
    ! 2019-01-04 01:09:06.105 - info: iobroker host.raspberrypi Deleting 30 state(s).
    ! 2019-01-04 01:09:06.207 - info: iobroker exit 0
    ! 2019-01-04 01:09:09.833 - info: iot.0 Connection changed: connect
    ! 2019-01-04 01:09:40.050 - info: iot.0 Request devices
    ! 2019-01-04 01:09:50.142 - info: iot.0 Request enums
    ! 2019-01-04 01:10:08.487 - info: iot.0 Request enums
    ! 2019-01-04 01:10:09.438 - info: iot.0 Request devices
    ! 2019-01-04 01:10:27.219 - info: iot.0 Request devices
    ! 2019-01-04 01:10:37.744 - info: iobroker url "https://github.com/ioBroker/ioBroker.ja ... all/master" javascript
    ! 2019-01-04 01:10:38.593 - info: iobroker install https://github.com/ioBroker/ioBroker.ja ... all/master
    ! 2019-01-04 01:10:39.534 - info: iobroker npm install https://github.com/ioBroker/ioBroker.ja ... all/master --production --save --prefix "/opt/iobroker" (System call)
    ! 2019-01-04 01:11:03.145 - info: iobroker npm
    ! 2019-01-04 01:11:03.146 - info: iobroker WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
    ! 2019-01-04 01:11:31.241 - info: iobroker module.js:550 throw err;
    ! 2019-01-04 01:11:35.767 - info: iobroker npm
    ! 2019-01-04 01:11:35.769 - info: iobroker ERR! code ELIFECYCLE
    ! 2019-01-04 01:11:35.771 - info: iobroker npm ERR! errno 1
    ! 2019-01-04 01:11:35.775 - info: iobroker npm ERR! iobroker.javascript@4.0.7 postinstall: node ./install/installTypings.jsnpm ERR! Exit status 1
    ! 2019-01-04 01:11:35.778 - info: iobroker npm ERR! npm ERR! Failed at the iobroker.javascript@4.0.7 postinstall script.
    ! 2019-01-04 01:11:35.837 - info: iobroker npm ERR! A complete log of this run can be found in:
    ! npm ERR! /root/.npm/_logs/2019-01-04T00_11_35_801Z-debug.log
    ! 2019-01-04 01:11:35.918 - error: iobroker Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
    ! 2019-01-04 01:11:35.929 - info: iobroker exit 0
    ! 2019-01-04 01:11:36.059 - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    ! 2019-01-04 01:12:44.816 - error: iot.0 read ECONNRESET
    ! 2019-01-04 01:12:44.817 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 01:12:44.817 - info: iot.0 Connection lost
    ! 2019-01-04 01:12:50.140 - info: iot.0 Connection changed: connect
    ! 2019-01-04 01:16:46.408 - error: iot.0 read ECONNRESET
    ! 2019-01-04 01:16:46.409 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 01:16:46.409 - info: iot.0 Connection lost
    ! 2019-01-04 01:16:51.710 - info: iot.0 Connection changed: connect
    ! 2019-01-04 01:19:06.690 - info: scenes.0 restartAdapter
    ! 2019-01-04 01:19:28.036 - info: scenes.0 restartAdapter
    ! 2019-01-04 01:19:44.342 - info: scenes.0 restartAdapter
    ! 2019-01-04 01:20:20.485 - error: iot.0 read ECONNRESET
    ! 2019-01-04 01:20:20.485 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 01:20:20.486 - info: iot.0 Connection lost
    ! 2019-01-04 01:20:25.825 - info: iot.0 Connection changed: connect
    ! 2019-01-04 01:20:26.109 - info: scenes.0 restartAdapter
    ! 2019-01-04 01:20:46.939 - info: scenes.0 restartAdapter
    ! 2019-01-04 01:21:18.689 - info: scenes.0 restartAdapter
    ! 2019-01-04 01:21:33.587 - info: scenes.0 restartAdapter
    ! 2019-01-04 01:21:39.484 - info: scenes.0 restartAdapter
    ! 2019-01-04 01:21:42.327 - info: scenes.0 restartAdapter
    ! 2019-01-04 01:23:32.118 - info: scenes.0 restartAdapter
    ! 2019-01-04 01:23:43.828 - info: scenes.0 restartAdapter
    ! 2019-01-04 01:23:44.610 - info: scenes.0 restartAdapter
    ! 2019-01-04 01:23:50.849 - error: iot.0 read ECONNRESET
    ! 2019-01-04 01:23:50.850 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 01:23:50.850 - info: iot.0 Connection lost
    ! 2019-01-04 01:23:56.218 - info: iot.0 Connection changed: connect
    ! 2019-01-04 01:25:05.222 - info: iot.0 Request devices
    ! 2019-01-04 01:25:27.746 - info: scenes.0 restartAdapter
    ! 2019-01-04 01:25:28.902 - info: iot.0 Request devices
    ! 2019-01-04 01:25:28.917 - info: iot.0 Request V3 devices
    ! 2019-01-04 01:25:32.484 - info: scenes.0 restartAdapter
    ! 2019-01-04 01:25:33.577 - info: iot.0 Request devices
    ! 2019-01-04 01:25:33.604 - info: iot.0 Request V3 devices
    ! 2019-01-04 01:25:37.255 - info: scenes.0 restartAdapter
    ! 2019-01-04 01:25:38.399 - info: iot.0 Request devices
    ! 2019-01-04 01:25:38.412 - info: iot.0 Request V3 devices
    ! 2019-01-04 01:28:23.369 - info: iot.0 Request devices
    ! 2019-01-04 01:28:58.957 - info: iot.0 Request devices
    ! 2019-01-04 01:29:07.304 - info: iot.0 Request enums
    ! 2019-01-04 01:29:46.378 - error: iot.0 read ECONNRESET
    ! 2019-01-04 01:29:46.379 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 01:29:46.379 - info: iot.0 Connection lost
    ! 2019-01-04 01:29:51.705 - info: iot.0 Connection changed: connect
    ! 2019-01-04 01:30:25.858 - info: iot.0 Request devices
    ! 2019-01-04 01:30:37.402 - info: scenes.0 restartAdapter
    ! 2019-01-04 01:30:38.560 - info: iot.0 Request devices
    ! 2019-01-04 01:30:38.583 - info: iot.0 Request V3 devices
    ! 2019-01-04 01:35:01.513 - error: iot.0 read ECONNRESET
    ! 2019-01-04 01:35:01.514 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 01:35:01.514 - info: iot.0 Connection lost
    ! 2019-01-04 01:35:06.838 - info: iot.0 Connection changed: connect
    ! 2019-01-04 01:38:59.363 - error: iot.0 read ECONNRESET
    ! 2019-01-04 01:38:59.364 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 01:38:59.364 - info: iot.0 Connection lost
    ! 2019-01-04 01:39:04.677 - info: iot.0 Connection changed: connect
    ! 2019-01-04 01:40:53.125 - info: iot.0 Request devices
    ! 2019-01-04 01:41:10.011 - info: iot.0 Request devices
    ! 2019-01-04 01:41:10.014 - info: iot.0 Request V3 devices
    ! 2019-01-04 01:41:19.483 - info: iot.0 Request devices
    ! 2019-01-04 01:41:19.505 - info: iot.0 Request V3 devices
    ! 2019-01-04 01:46:27.956 - error: iot.0 read ECONNRESET
    ! 2019-01-04 01:46:27.957 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 01:46:27.957 - info: iot.0 Connection lost
    ! 2019-01-04 01:46:33.283 - info: iot.0 Connection changed: connect
    ! 2019-01-04 01:49:33.652 - error: iot.0 read ECONNRESET
    ! 2019-01-04 01:49:33.652 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 01:49:33.653 - info: iot.0 Connection lost
    ! 2019-01-04 01:49:38.967 - info: iot.0 Connection changed: connect
    ! 2019-01-04 01:53:11.343 - error: iot.0 read ECONNRESET
    ! 2019-01-04 01:53:11.344 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 01:53:11.344 - info: iot.0 Connection lost
    ! 2019-01-04 01:53:16.658 - info: iot.0 Connection changed: connect
    ! 2019-01-04 01:55:54.616 - info: iobroker url "https://github.com/ioBroker/ioBroker.no ... all/master" node-red
    ! 2019-01-04 01:55:55.475 - info: iobroker install https://github.com/ioBroker/ioBroker.no ... all/master
    ! 2019-01-04 01:55:56.397 - info: iobroker npm install https://github.com/ioBroker/ioBroker.no ... all/master --production --save --prefix "/opt/iobroker" (System call)
    ! 2019-01-04 01:56:22.710 - error: iot.0 read ECONNRESET
    ! 2019-01-04 01:56:22.711 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 01:56:22.711 - info: iot.0 Connection lost
    ! 2019-01-04 01:56:23.671 - info: iobroker npm WARN deprecated nodemailer@1.11.0: All versions below 4.0.1 of Nodemailer are deprecated. See https://nodemailer.com/status/
    ! 2019-01-04 01:56:23.678 - info: iobroker npm WARN deprecated mailparser@0.6.2: Mailparser versions older than v2.3.0 are deprecated
    ! 2019-01-04 01:56:23.943 - info: iobroker npm WARN deprecated mimelib@0.3.1: This project is unmaintained
    ! 2019-01-04 01:56:24.436 - info: iobroker npm WARN deprecated mailcomposer@2.1.0: This project is unmaintained
    ! 2019-01-04 01:56:24.671 - info: iobroker npm WARN deprecated buildmail@2.0.0: This project is unmaintained
    ! 2019-01-04 01:56:27.968 - info: iot.0 Connection changed: connect
    ! 2019-01-04 01:57:07.380 - info: iobroker sh: 1: node-pre-gyp: Permission denied
    ! 2019-01-04 01:57:13.868 - info: iobroker npm
    ! 2019-01-04 01:57:13.869 - info: iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 (node_modules/bcrypt):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 install: node-pre-gyp install --fallback-to-build
    ! 2019-01-04 01:57:13.875 - info: iobroker
    ! 2019-01-04 01:57:13.985 - info: iobroker got /opt/iobroker/node_modules/iobroker.node-red/admin
    ! 2019-01-04 01:57:14.012 - info: iobroker upload [3] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/words.js words.js application/javascript
    ! 2019-01-04 01:57:14.101 - info: iobroker upload [2] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
    ! 2019-01-04 01:57:14.172 - info: iobroker upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index_m.html index_m.html text/html
    ! 2019-01-04 01:57:14.238 - info: iobroker upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index.html index.html text/html
    ! 2019-01-04 01:57:14.324 - info: iobroker exit 0
    ! 2019-01-04 01:57:15.811 - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    ! 2019-01-04 01:59:31.934 - error: iot.0 read ECONNRESET
    ! 2019-01-04 01:59:31.934 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 01:59:31.935 - info: iot.0 Connection lost
    ! 2019-01-04 01:59:37.247 - info: iot.0 Connection changed: connect
    ! 2019-01-04 02:01:26.001 - info: iobroker add node-red –host raspberrypi
    ! 2019-01-04 02:01:27.075 - info: iobroker host.raspberrypi install adapter node-red
    ! 2019-01-04 02:01:27.817 - info: iobroker npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.node-red"
    ! 2019-01-04 02:01:36.705 - info: iobroker npm
    ! 2019-01-04 02:01:36.706 - info: iobroker WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
    ! 2019-01-04 02:01:40.197 - info: iobroker npm
    ! 2019-01-04 02:01:40.198 - info: iobroker WARN deprecated nodemailer@1.11.0: All versions below 4.0.1 of Nodemailer are deprecated. See https://nodemailer.com/status/
    ! 2019-01-04 02:01:40.278 - info: iobroker npm
    ! 2019-01-04 02:01:40.279 - info: iobroker WARN deprecated mailparser@0.6.2: Mailparser versions older than v2.3.0 are deprecated
    ! 2019-01-04 02:01:42.260 - info: iobroker npm WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
    ! 2019-01-04 02:01:44.206 - info: iobroker npm WARN deprecated mailcomposer@2.1.0: This project is unmaintained
    ! 2019-01-04 02:01:44.413 - info: iobroker npm WARN deprecated mimelib@0.3.1: This project is unmaintained
    ! 2019-01-04 02:01:45.947 - info: iobroker npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
    ! 2019-01-04 02:01:47.385 - info: iobroker npm WARN deprecated buildmail@2.0.0: This project is unmaintained
    ! 2019-01-04 02:01:50.666 - info: iobroker npm WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
    ! 2019-01-04 02:01:51.330 - info: iobroker npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
    ! 2019-01-04 02:02:41.716 - info: iobroker sh: 1: node-pre-gyp: Permission denied
    ! 2019-01-04 02:02:45.590 - info: iobroker npm
    ! 2019-01-04 02:02:45.593 - info: iobroker notice created a lockfile as package-lock.json. You should commit this file.
    ! 2019-01-04 02:02:45.600 - info: iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 (node_modules/bcrypt):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 install: node-pre-gyp install --fallback-to-build
    ! 2019-01-04 02:02:45.702 - info: iobroker got /opt/iobroker/node_modules/iobroker.node-red/admin
    ! 2019-01-04 02:02:45.734 - info: iobroker upload [3] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/words.js words.js application/javascript
    ! 2019-01-04 02:02:45.816 - info: iobroker upload [2] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
    ! 2019-01-04 02:02:45.884 - info: iobroker upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index_m.html index_m.html text/html
    ! 2019-01-04 02:02:45.946 - info: iobroker upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index.html index.html text/html
    ! 2019-01-04 02:02:46.052 - info: iobroker host.raspberrypi object system.adapter.node-red created
    ! 2019-01-04 02:02:46.099 - info: iobroker host.raspberrypi create instance node-red
    ! 2019-01-04 02:02:46.109 - info: iobroker host.raspberrypi object node-red.0 created
    ! 2019-01-04 02:02:46.141 - info: iobroker host.raspberrypi object system.adapter.node-red.0.outputCount created
    ! 2019-01-04 02:02:46.172 - info: iobroker host.raspberrypi object system.adapter.node-red.0.inputCount created
    ! 2019-01-04 02:02:46.202 - info: iobroker host.raspberrypi object system.adapter.node-red.0.uptime created
    ! 2019-01-04 02:02:46.233 - info: iobroker host.raspberrypi object system.adapter.node-red.0.memRss created
    ! 2019-01-04 02:02:46.263 - info: iobroker host.raspberrypi object system.adapter.node-red.0.memHeapTotal created
    ! 2019-01-04 02:02:46.296 - info: iobroker host.raspberrypi object system.adapter.node-red.0.memHeapUsed created
    ! 2019-01-04 02:02:46.329 - info: iobroker host.raspberrypi object system.adapter.node-red.0.connected created
    ! 2019-01-04 02:02:46.366 - info: iobroker host.raspberrypi object system.adapter.node-red.0.alive created
    ! 2019-01-04 02:02:46.402 - info: host.raspberrypi object change system.adapter.node-red.0
    ! 2019-01-04 02:02:46.416 - info: host.raspberrypi instance system.adapter.node-red.0 started with pid 13339
    ! 2019-01-04 02:02:46.434 - info: iobroker host.raspberrypi object system.adapter.node-red.0 created
    ! 2019-01-04 02:02:46.442 - info: iobroker exit 0
    ! 2019-01-04 02:02:47.726 - info: node-red.0 starting. Version 1.7.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v8.15.0
    ! 2019-01-04 02:02:47.869 - info: node-red.0 Starting node-red: –max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    ! 2019-01-04 02:02:56.001 - warn: node-red.0 4 Jan 02:02:56 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    ! 2019-01-04 02:03:26.842 - error: iot.0 read ECONNRESET
    ! 2019-01-04 02:03:26.843 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 02:03:26.843 - info: iot.0 Connection lost
    ! 2019-01-04 02:03:32.176 - info: iot.0 Connection changed: connect
    ! 2019-01-04 02:06:32.412 - warn: node-red.0 4 Jan 02:06:32 - [warn] Installation of module @boneskull/node-red-contrib-homekit failed:
    ! 2019-01-04 02:06:32.413 - warn: node-red.0 4 Jan 02:06:32 - [warn] –----------------------------------------
    ! 2019-01-04 02:06:32.414 - warn: node-red.0 4 Jan 02:06:32 - [warn]
    ! > curve25519-n@1.4.0 install /opt/iobroker/iobroker-data/node-red/node_modules/curve25519-n
    ! > node-gyp rebuild
    ! gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/8.15.0"
    ! gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/iobroker-data/node-red/node_modules/curve25519-n/.node-gyp"
    ! gyp ERR! stack Error: EACCES: permission denied, stat '/opt/iobroker/iobroker-data/node-red/node_modules/curve25519-n/.node-gyp/8.15.0'
    ! gyp ERR! cwd /opt/iobroker/iobroker-data/node-red/node_modules/curve25519-n
    ! gyp ERR! not ok
    ! npm ERR! errno 1
    ! npm ERR!
    ! npm ERR! /root/.npm/_logs/2019-01-04T01_06_32_281Z-debug.log
    ! 4 Jan 02:06:32 - [warn] –----------------------------------------
    ! 2019-01-04 02:07:23.133 - error: iot.0 read ECONNRESET
    ! 2019-01-04 02:07:23.134 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 02:07:23.134 - info: iot.0 Connection lost
    ! 2019-01-04 02:07:28.450 - info: iot.0 Connection changed: connect
    ! 2019-01-04 02:08:00.607 - warn: node-red.0 4 Jan 02:08:00 - [warn] Installation of module @plasma2450/node-red-contrib-homekit-bridged failed:
    ! 2019-01-04 02:08:00.608 - warn: node-red.0 4 Jan 02:08:00 - [warn] –----------------------------------------
    ! 2019-01-04 02:08:00.609 - warn: node-red.0 4 Jan 02:08:00 - [warn]
    ! gyp ERR! not ok
    ! npm ERR! errno 1
    ! npm ERR!
    ! npm ERR! /root/.npm/_logs/2019-01-04T01_08_00_528Z-debug.log
    ! 4 Jan 02:08:00 - [warn] –----------------------------------------
    ! 2019-01-04 02:11:26.405 - error: iot.0 read ECONNRESET
    ! 2019-01-04 02:11:26.406 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 02:11:26.406 - info: iot.0 Connection lost
    ! 2019-01-04 02:11:31.795 - info: iot.0 Connection changed: connect
    ! 2019-01-04 02:12:24.528 - warn: node-red.0 4 Jan 02:12:24 - [warn] Installation of module @boneskull/node-red-contrib-homekit failed:
    ! 2019-01-04 02:12:24.528 - warn: node-red.0 4 Jan 02:12:24 - [warn] –----------------------------------------
    ! 2019-01-04 02:12:24.529 - warn: node-red.0 4 Jan 02:12:24 - [warn]
    ! gyp ERR! not ok
    ! npm ERR! errno 1
    ! npm ERR!
    ! npm ERR! /root/.npm/_logs/2019-01-04T01_12_24_493Z-debug.log
    ! 4 Jan 02:12:24 - [warn] –----------------------------------------
    ! 2019-01-04 02:13:28.617 - info: iobroker add yahka --host raspberrypi
    ! 2019-01-04 02:13:30.857 - info: iobroker NPM version: 6.5.0
    ! 2019-01-04 02:13:31.628 - info: iobroker npm install iobroker.yahka --production --save --prefix "/opt/iobroker" (System call)
    ! 2019-01-04 02:14:29.801 - info: iobroker sh: 1: node-pre-gyp: Permission denied
    ! 2019-01-04 02:14:31.317 - info: iobroker gyp
    ! 2019-01-04 02:14:31.318 - info: iobroker WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/8.15.0"
    ! 2019-01-04 02:14:31.321 - info: iobroker gyp
    ! 2019-01-04 02:14:31.323 - info: iobroker
    ! 2019-01-04 02:14:31.324 - info: iobroker WARN
    ! 2019-01-04 02:14:31.326 - info: iobroker EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/curve25519-n/.node-gyp"
    ! 2019-01-04 02:14:31.335 - info: iobroker gyp
    ! 2019-01-04 02:14:31.336 - info: iobroker WARN install got an error, rolling back install
    ! 2019-01-04 02:14:31.340 - info: iobroker gyp
    ! 2019-01-04 02:14:31.342 - info: iobroker WARN install got an error, rolling back install
    ! 2019-01-04 02:14:31.343 - info: iobroker gyp ERR! configure error
    ! 2019-01-04 02:14:31.345 - info: iobroker gyp ERR! stack Error: EACCES: permission denied, stat '/opt/iobroker/node_modules/curve25519-n/.node-gyp/8.15.0'gyp ERR!
    ! 2019-01-04 02:14:31.347 - info: iobroker System Linux 4.14.79-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    ! gyp ERR!
    ! 2019-01-04 02:14:31.349 - info: iobroker cwd /opt/iobroker/node_modules/curve25519-ngyp ERR! node -v v8.15.0
    ! gyp ERR! not ok
    ! 2019-01-04 02:14:37.849 - info: iobroker npm
    ! 2019-01-04 02:14:37.850 - info: iobroker
    ! 2019-01-04 02:14:37.851 - info: iobroker WARN
    ! 2019-01-04 02:14:37.853 - info: iobroker optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 (node_modules/bcrypt):
    ! 2019-01-04 02:14:37.855 - info: iobroker npm
    ! 2019-01-04 02:14:37.857 - info: iobroker WARN
    ! 2019-01-04 02:14:37.858 - info: iobroker optional
    ! 2019-01-04 02:14:37.860 - info: iobroker SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 install: node-pre-gyp install --fallback-to-buildnpm
    ! 2019-01-04 02:14:37.861 - info: iobroker WARN
    ! 2019-01-04 02:14:37.863 - info: iobroker optional
    ! 2019-01-04 02:14:37.864 - info: iobroker SKIPPING OPTIONAL DEPENDENCY: spawn ENOENT
    ! 2019-01-04 02:14:37.866 - info: iobroker
    ! 2019-01-04 02:14:37.877 - info: iobroker npm
    ! 2019-01-04 02:14:37.878 - info: iobroker
    ! 2019-01-04 02:14:37.879 - info: iobroker ERR!
    ! 2019-01-04 02:14:37.880 - info: iobroker code
    ! 2019-01-04 02:14:37.882 - info: iobroker ELIFECYCLE
    ! 2019-01-04 02:14:37.883 - info: iobroker npm
    ! 2019-01-04 02:14:37.885 - info: iobroker ERR! errno 1
    ! 2019-01-04 02:14:37.888 - info: iobroker npm ERR! curve25519-n@1.4.0 install: node-gyp rebuildnpm ERR! Exit status 1
    ! npm ERR!
    ! npm ERR!
    ! 2019-01-04 02:14:37.900 - info: iobroker Failed at the curve25519-n@1.4.0 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    ! 2019-01-04 02:14:38.029 - info: iobroker
    ! 2019-01-04 02:14:38.030 - info: iobroker npm ERR! A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2019-01-04T01_14_37_947Z-debug.log
    ! 2019-01-04 02:14:38.103 - info: iobroker host.raspberrypi install adapter yahka
    ! 2019-01-04 02:14:39.362 - info: iobroker NPM version: 6.5.0npm install iobroker.yahka --production --save --prefix "/opt/iobroker" (System call)
    ! 2019-01-04 02:15:28.653 - error: iot.0 read ECONNRESET
    ! 2019-01-04 02:15:28.654 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 02:15:28.654 - info: iot.0 Connection lost
    ! 2019-01-04 02:15:33.919 - info: iot.0 Connection changed: connect
    ! 2019-01-04 02:15:38.887 - info: iobroker sh: 1: node-pre-gyp: Permission denied
    ! 2019-01-04 02:15:40.394 - info: iobroker gyp
    ! 2019-01-04 02:15:40.396 - info: iobroker
    ! 2019-01-04 02:15:40.397 - info: iobroker WARN
    ! 2019-01-04 02:15:40.398 - info: iobroker EACCES
    ! 2019-01-04 02:15:40.399 - info: iobroker user "root" does not have permission to access the dev dir "/root/.node-gyp/8.15.0"
    ! 2019-01-04 02:15:40.400 - info: iobroker gyp
    ! 2019-01-04 02:15:40.401 - info: iobroker
    ! 2019-01-04 02:15:40.402 - info: iobroker WARN
    ! 2019-01-04 02:15:40.403 - info: iobroker EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/curve25519-n/.node-gyp"
    ! 2019-01-04 02:15:40.419 - info: iobroker gyp WARN install got an error, rolling back install
    ! 2019-01-04 02:15:40.421 - info: iobroker gyp WARN
    ! 2019-01-04 02:15:40.434 - info: iobroker install got an error, rolling back installgyp ERR! configure error
    ! gyp ERR! stack Error: EACCES: permission denied, stat '/opt/iobroker/node_modules/curve25519-n/.node-gyp/8.15.0'
    ! gyp
    ! 2019-01-04 02:15:40.439 - info: iobroker ERR! System Linux 4.14.79-v7+gyp ERR!
    ! 2019-01-04 02:15:40.441 - info: iobroker command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    ! 2019-01-04 02:15:40.442 - info: iobroker gyp ERR!
    ! 2019-01-04 02:15:40.450 - info: iobroker cwd /opt/iobroker/node_modules/curve25519-ngyp ERR! node -v v8.15.0
    ! gyp ERR! not ok
    ! 2019-01-04 02:15:47.119 - info: iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 (node_modules/bcrypt):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 install: node-pre-gyp install --fallback-to-build
    ! 2019-01-04 02:15:47.122 - info: iobroker
    ! 2019-01-04 02:15:47.130 - info: iobroker npm ERR! code ELIFECYCLE
    ! 2019-01-04 02:15:47.131 - info: iobroker npm ERR! errno 1
    ! 2019-01-04 02:15:47.138 - info: iobroker npm ERR! curve25519-n@1.4.0 install: node-gyp rebuildnpm ERR! Exit status 1
    ! npm ERR!
    ! 2019-01-04 02:15:47.259 - info: iobroker npm ERR! A complete log of this run can be found in:
    ! npm ERR! /root/.npm/_logs/2019-01-04T01_15_47_176Z-debug.log
    ! 2019-01-04 02:15:47.307 - info: iobroker host.raspberrypi install adapter yahka
    ! 2019-01-04 02:15:48.683 - info: iobroker NPM version: 6.5.0
    ! 2019-01-04 02:15:48.685 - info: iobroker npm install iobroker.yahka --production --save --prefix "/opt/iobroker" (System call)
    ! 2019-01-04 02:16:45.005 - info: iobroker sh: 1: node-pre-gyp: Permission denied
    ! 2019-01-04 02:16:46.491 - info: iobroker gyp
    ! 2019-01-04 02:16:46.492 - info: iobroker
    ! 2019-01-04 02:16:46.494 - info: iobroker WARN
    ! 2019-01-04 02:16:46.495 - info: iobroker EACCES
    ! 2019-01-04 02:16:46.497 - info: iobroker user "root" does not have permission to access the dev dir "/root/.node-gyp/8.15.0"
    ! 2019-01-04 02:16:46.499 - info: iobroker gyp
    ! 2019-01-04 02:16:46.501 - info: iobroker WARN
    ! 2019-01-04 02:16:46.503 - info: iobroker EACCES
    ! 2019-01-04 02:16:46.504 - info: iobroker attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/curve25519-n/.node-gyp"
    ! 2019-01-04 02:16:46.514 - info: iobroker gyp WARN install got an error, rolling back install
    ! 2019-01-04 02:16:46.518 - info: iobroker gyp
    ! 2019-01-04 02:16:46.520 - info: iobroker WARN install got an error, rolling back install
    ! 2019-01-04 02:16:46.523 - info: iobroker gyp ERR! configure error gyp ERR! stack Error: EACCES: permission denied, stat '/opt/iobroker/node_modules/curve25519-n/.node-gyp/8.15.0'
    ! 2019-01-04 02:16:46.524 - info: iobroker gyp ERR! System Linux 4.14.79-v7+
    ! 2019-01-04 02:16:46.526 - info: iobroker gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/curve25519-n
    ! gyp ERR!
    ! 2019-01-04 02:16:46.531 - info: iobroker node -v v8.15.0gyp ERR! node-gyp -v v3.8.0
    ! gyp ERR! not ok
    ! 2019-01-04 02:16:53.875 - info: iobroker npm
    ! 2019-01-04 02:16:53.877 - info: iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 (node_modules/bcrypt):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 install: node-pre-gyp install --fallback-to-build
    ! 2019-01-04 02:16:53.878 - info: iobroker
    ! 2019-01-04 02:16:53.886 - info: iobroker npm
    ! 2019-01-04 02:16:53.888 - info: iobroker ERR! code ELIFECYCLEnpm ERR!
    ! 2019-01-04 02:16:53.891 - info: iobroker errno 1npm ERR! curve25519-n@1.4.0 install: node-gyp rebuild
    ! 2019-01-04 02:16:53.893 - info: iobroker npm ERR! npm ERR! Failed at the curve25519-n@1.4.0 install script.
    ! 2019-01-04 02:16:54.008 - info: iobroker
    ! 2019-01-04 02:16:54.009 - info: iobroker npm ERR! A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2019-01-04T01_16_53_935Z-debug.log
    ! 2019-01-04 02:16:54.047 - info: iobroker host.raspberrypi install adapter yahka
    ! 2019-01-04 02:16:54.048 - error: iobroker host.raspberrypi Cannot install yahka
    ! 2019-01-04 02:16:54.062 - info: iobroker exit 13
    ! 2019-01-04 02:18:48.620 - error: iot.0 read ECONNRESET
    ! 2019-01-04 02:18:48.621 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 02:18:48.621 - info: iot.0 Connection lost
    ! 2019-01-04 02:18:53.887 - info: iot.0 Connection changed: connect
    ! 2019-01-04 02:21:59.022 - error: iot.0 read ECONNRESET
    ! 2019-01-04 02:21:59.023 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 02:21:59.023 - info: iot.0 Connection lost
    ! 2019-01-04 02:22:04.274 - info: iot.0 Connection changed: connect
    ! 2019-01-04 02:22:59.403 - info: host.raspberrypi received SIGTERM
    ! 2019-01-04 02:22:59.406 - info: admin.0 terminating http server on port 8081
    ! 2019-01-04 02:28:55.192 - info: host.raspberrypi iobroker.js-controller version 1.4.2 js-controller starting
    ! 2019-01-04 02:28:55.199 - info: host.raspberrypi Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
    ! 2019-01-04 02:28:55.199 - info: host.raspberrypi hostname: raspberrypi, node: v8.15.0
    ! 2019-01-04 02:28:55.204 - info: host.raspberrypi ip addresses: 192.168.178.76 2a02:908:186b:3780:c06a:666b:38a5:5eb4 fe80::828:8793:35b8:60d6
    ! 2019-01-04 02:28:55.359 - info: host.raspberrypi inMem-states listening on port 9000
    ! 2019-01-04 02:28:55.609 - info: host.raspberrypi inMem-objects listening on port 9001
    ! 2019-01-04 02:28:55.629 - info: host.raspberrypi InMemoryDB connected
    ! 2019-01-04 02:28:55.645 - info: host.raspberrypi 11 instances found
    ! 2019-01-04 02:28:55.660 - info: host.raspberrypi starting 11 instances
    ! 2019-01-04 02:28:55.710 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 985
    ! 2019-01-04 02:28:58.668 - info: admin.0 starting. Version 3.5.10 in /opt/iobroker/node_modules/iobroker.admin, node: v8.15.0
    ! 2019-01-04 02:28:58.686 - info: admin.0 requesting all states
    ! 2019-01-04 02:28:58.689 - info: admin.0 requesting all objects
    ! 2019-01-04 02:28:58.690 - info: admin.0 Request actual repository...
    ! 2019-01-04 02:28:59.165 - info: admin.0 received all states
    ! 2019-01-04 02:28:59.676 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 995
    ! 2019-01-04 02:28:59.838 - info: admin.0 received all objects
    ! 2019-01-04 02:29:00.081 - info: admin.0 http server listening on port 8081
    ! 2019-01-04 02:29:00.082 - info: admin.0 Use link "http://localhost:8081" to configure.
    ! 2019-01-04 02:29:00.309 - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    ! 2019-01-04 02:29:01.940 - info: discovery.0 starting. Version 1.2.4 in /opt/iobroker/node_modules/iobroker.discovery, node: v8.15.0
    ! 2019-01-04 02:29:02.825 - info: admin.0 Repository received successfully.
    ! 2019-01-04 02:29:03.691 - info: host.raspberrypi instance system.adapter.ping.0 started with pid 1005
    ! 2019-01-04 02:29:05.001 - info: ping.0 starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.ping, node: v8.15.0
    ! 2019-01-04 02:29:07.676 - info: host.raspberrypi instance system.adapter.web.0 started with pid 1034
    ! 2019-01-04 02:29:09.286 - error: web.0 setObject id missing!!
    ! 2019-01-04 02:29:09.301 - info: web.0 starting. Version 2.4.1 in /opt/iobroker/node_modules/iobroker.web, node: v8.15.0
    ! 2019-01-04 02:29:09.927 - info: web.0 socket.io server listening on port 8082
    ! 2019-01-04 02:29:09.931 - info: web.0 http server listening on port 8082
    ! 2019-01-04 02:29:11.684 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 1046
    ! 2019-01-04 02:29:13.046 - info: backitup.0 starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.15.0
    ! 2019-01-04 02:29:13.078 - info: backitup.0 [total] backup was activated at 04:00 every 3 day(s)
    ! 2019-01-04 02:29:15.686 - info: host.raspberrypi instance system.adapter.broadlink2.0 started with pid 1059
    ! 2019-01-04 02:29:16.765 - info: broadlink2.0 starting. Version 1.9.0 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v8.15.0
    ! 2019-01-04 02:29:17.855 - info: broadlink2.0 Discover UDP devices for 10sec on broadlink2.0
    ! 2019-01-04 02:29:18.078 - info: broadlink2.0 Device RM:Broadlink-RMPROPLUS-8a-61-96 dedected: 192.168.178.57,IPv4,80,128,10026,rm,RM:Broadlink-RMPROPLUS-8a-61-96,RM2 Pro Plus,2a:27:39:b2:a8:c0
    ! 2019-01-04 02:29:19.687 - info: host.raspberrypi instance system.adapter.scenes.0 started with pid 1069
    ! 2019-01-04 02:29:20.822 - info: scenes.0 starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.scenes, node: v8.15.0
    ! 2019-01-04 02:29:23.145 - info: broadlink2.0 Adapter broadlink2.0 started and found 1 devices named 'RM:Broadlink-RMPROPLUS-8a-61-96'.
    ! 2019-01-04 02:29:23.673 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 started with pid 1079
    ! 2019-01-04 02:29:24.888 - info: mihome-vacuum.0 starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v8.15.0
    ! 2019-01-04 02:29:24.903 - info: mihome-vacuum.0 Expert mode enabled, states created
    ! 2019-01-04 02:29:24.904 - info: mihome-vacuum.0 Create state clean_home for controlling by cloud adapter
    ! 2019-01-04 02:29:25.165 - info: mihome-vacuum.0 New generation or new fw detected, create new states
    ! 2019-01-04 02:29:27.683 - info: host.raspberrypi instance system.adapter.iot.0 started with pid 1089
    ! 2019-01-04 02:29:30.689 - info: iot.0 starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.iot, node: v8.15.0
    ! 2019-01-04 02:29:30.729 - info: iot.0 Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
    ! 2019-01-04 02:29:31.559 - info: iot.0 Connection changed: connect
    ! 2019-01-04 02:29:31.683 - info: host.raspberrypi instance system.adapter.maxcube.0 started with pid 1099
    ! 2019-01-04 02:29:32.957 - info: maxcube.0 starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.maxcube, node: v8.15.0
    ! 2019-01-04 02:29:33.311 - info: maxcube.0 Connected
    ! 2019-01-04 02:29:35.690 - info: host.raspberrypi instance system.adapter.node-red.0 started with pid 1109
    ! 2019-01-04 02:29:36.870 - info: node-red.0 starting. Version 1.7.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v8.15.0
    ! 2019-01-04 02:29:37.054 - info: node-red.0 Starting node-red: –max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    ! 2019-01-04 02:29:49.056 - warn: node-red.0 4 Jan 02:29:49 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    ! 2019-01-04 02:30:19.125 - warn: node-red.0 4 Jan 02:30:19 - [warn] Installation of module @boneskull/node-red-contrib-homekit failed:
    ! 2019-01-04 02:30:19.126 - warn: node-red.0 4 Jan 02:30:19 - [warn] –----------------------------------------
    ! 2019-01-04 02:30:19.127 - warn: node-red.0 4 Jan 02:30:19 - [warn]
    ! gyp WARN install got an error, rolling back install
    ! gyp ERR! configure error
    ! gyp ERR! System Linux 4.14.79-v7+
    ! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    ! gyp ERR! node -v v8.15.0
    ! gyp ERR! node-gyp -v v3.8.0
    ! gyp ERR! not ok
    ! npm ERR! code ELIFECYCLE
    ! npm ERR! errno 1
    ! npm ERR! curve25519-n@1.4.0 install: node-gyp rebuild
    ! npm ERR! Exit status 1
    ! npm ERR!
    ! npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    ! npm ERR! A complete log of this run can be found in:
    ! npm ERR! /root/.npm/_logs/2019-01-04T01_30_19_063Z-debug.log
    ! 2019-01-04 02:30:19.128 - warn: node-red.0 4 Jan 02:30:19 - [warn] –----------------------------------------
    ! 2019-01-04 02:31:40.063 - info: iobroker del node-red.0
    ! 2019-01-04 02:31:41.081 - info: iobroker Delete adapter "node-red.0"
    ! 2019-01-04 02:31:41.139 - info: iobroker host.raspberrypi Counted 1 instances of node-red
    ! 2019-01-04 02:31:41.181 - info: iobroker host.raspberrypi Counted 1 channels of node-red.0
    ! 2019-01-04 02:31:41.217 - info: iobroker host.raspberrypi Counted 8 states of node-red.0
    ! 2019-01-04 02:31:41.242 - info: iobroker host.raspberrypi Counted 8 states (system.adapter.node-red.0.) from states
    ! 2019-01-04 02:31:42.243 - info: iobroker host.raspberrypi Deleting 10 object(s).
    ! 2019-01-04 02:31:42.304 - info: host.raspberrypi object change system.adapter.node-red.0
    ! 2019-01-04 02:31:42.305 - info: host.raspberrypi object deleted system.adapter.node-red.0
    ! 2019-01-04 02:31:42.307 - info: host.raspberrypi stopInstance system.adapter.node-red.0
    ! 2019-01-04 02:31:42.311 - info: iobroker host.raspberrypi Deleting 8 state(s).
    ! 2019-01-04 02:31:42.311 - info: node-red.0 kill node-red task
    ! 2019-01-04 02:31:42.359 - info: iobroker exit 0
    ! 2019-01-04 02:31:42.839 - info: node-red.0 node-red exited with 0
    ! 2019-01-04 02:31:43.308 - info: host.raspberrypi stopInstance timeout "1000 system.adapter.node-red.0 killing pid 1109
    ! 2019-01-04 02:31:43.332 - error: host.raspberrypi instance system.adapter.node-red.0 terminated with code 0 (OK)
    ! 2019-01-04 02:31:43.332 - info: host.raspberrypi Do not restart adapter system.adapter.node-red.0 because disabled or deleted
    ! 2019-01-04 02:32:58.704 - error: iot.0 read ECONNRESET
    ! 2019-01-04 02:32:58.706 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 02:32:58.707 - info: iot.0 Connection lost
    ! 2019-01-04 02:33:03.973 - info: iot.0 Connection changed: connect
    ! 2019-01-04 02:37:54.898 - error: iot.0 read ECONNRESET
    ! 2019-01-04 02:37:54.899 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 02:37:54.900 - info: iot.0 Connection lost
    ! 2019-01-04 02:38:00.209 - info: iot.0 Connection changed: connect
    ! 2019-01-04 02:41:38.550 - error: iot.0 read ECONNRESET
    ! 2019-01-04 02:41:38.551 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 02:41:38.551 - info: iot.0 Connection lost
    ! 2019-01-04 02:41:43.879 - info: iot.0 Connection changed: connect
    ! 2019-01-04 02:42:51.487 - info: iobroker url "https://github.com/jensweigele/ioBroker ... all/master" yahka
    ! 2019-01-04 02:42:52.321 - info: iobroker install https://github.com/jensweigele/ioBroker ... all/master
    ! 2019-01-04 02:42:53.245 - info: iobroker npm install https://github.com/jensweigele/ioBroker ... all/master --production --save --prefix "/opt/iobroker" (System call)
    ! 2019-01-04 02:43:31.068 - info: iobroker npm ERR! code 128
    ! 2019-01-04 02:43:31.071 - info: iobroker npm
    ! 2019-01-04 02:43:31.073 - info: iobroker ERR! Command failed: /usr/bin/git submodule update -q --init --recursivenpm ERR! fatal: Could not change back to '/root/.npm/_cacache/tmp/git-clone-18d7577c': Keine Berechtigung
    ! npm ERR!
    ! 2019-01-04 02:43:31.123 - info: iobroker
    ! 2019-01-04 02:43:31.124 - info: iobroker npm ERR! A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2019-01-04T01_43_31_084Z-debug.log
    ! 2019-01-04 02:43:31.214 - error: iobroker Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
    ! 2019-01-04 02:43:31.231 - info: iobroker exit 0
    ! 2019-01-04 02:43:31.393 - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    ! 2019-01-04 02:44:49.076 - error: iot.0 read ECONNRESET
    ! 2019-01-04 02:44:49.077 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 02:44:49.077 - info: iot.0 Connection lost
    ! 2019-01-04 02:44:54.351 - info: iot.0 Connection changed: connect
    ! 2019-01-04 02:47:59.624 - error: iot.0 read ECONNRESET
    ! 2019-01-04 02:47:59.625 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 02:47:59.625 - info: iot.0 Connection lost
    ! 2019-01-04 02:48:04.952 - info: iot.0 Connection changed: connect
    ! 2019-01-04 02:50:09.701 - info: host.raspberrypi object change system.adapter.admin.1
    ! 2019-01-04 02:50:09.717 - info: host.raspberrypi instance system.adapter.admin.1 started with pid 1648
    ! 2019-01-04 02:50:12.372 - info: admin.1 starting. Version 3.5.10 in /opt/iobroker/node_modules/iobroker.admin, node: v8.15.0
    ! 2019-01-04 02:50:12.414 - info: admin.1 requesting all states
    ! 2019-01-04 02:50:12.419 - info: admin.1 requesting all objects
    ! 2019-01-04 02:50:12.421 - info: admin.1 Request actual repository...
    ! 2019-01-04 02:50:12.827 - info: admin.1 received all states
    ! 2019-01-04 02:50:13.694 - info: admin.1 received all objects
    ! 2019-01-04 02:50:14.067 - error: admin.1 port 8081 already in use
    ! 2019-01-04 02:50:14.143 - error: host.raspberrypi instance system.adapter.admin.1 terminated with code 1 ()
    ! 2019-01-04 02:50:14.144 - info: host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
    ! 2019-01-04 02:50:14.145 - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    ! 2019-01-04 02:50:44.153 - info: host.raspberrypi instance system.adapter.admin.1 started with pid 1682
    ! 2019-01-04 02:50:46.421 - info: admin.1 starting. Version 3.5.10 in /opt/iobroker/node_modules/iobroker.admin, node: v8.15.0
    ! 2019-01-04 02:50:46.450 - info: admin.1 requesting all states
    ! 2019-01-04 02:50:46.454 - info: admin.1 requesting all objects
    ! 2019-01-04 02:50:46.456 - info: admin.1 Request actual repository...
    ! 2019-01-04 02:50:46.877 - info: admin.1 received all states
    ! 2019-01-04 02:50:47.652 - info: admin.1 received all objects
    ! 2019-01-04 02:50:47.933 - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    ! 2019-01-04 02:50:47.998 - error: admin.1 port 8081 already in use
    ! 2019-01-04 02:50:48.030 - error: host.raspberrypi instance system.adapter.admin.1 terminated with code 1 ()
    ! 2019-01-04 02:50:48.030 - info: host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
    ! 2019-01-04 02:51:10.241 - error: iot.0 read ECONNRESET
    ! 2019-01-04 02:51:10.242 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 02:51:10.242 - info: iot.0 Connection lost
    ! 2019-01-04 02:51:15.778 - info: iot.0 Connection changed: connect
    ! 2019-01-04 02:51:18.049 - info: host.raspberrypi instance system.adapter.admin.1 started with pid 1701
    ! 2019-01-04 02:51:20.259 - info: admin.1 starting. Version 3.5.10 in /opt/iobroker/node_modules/iobroker.admin, node: v8.15.0
    ! 2019-01-04 02:51:20.289 - info: admin.1 requesting all states
    ! 2019-01-04 02:51:20.293 - info: admin.1 requesting all objects
    ! 2019-01-04 02:51:20.295 - info: admin.1 Request actual repository...
    ! 2019-01-04 02:51:20.703 - info: admin.1 received all states
    ! 2019-01-04 02:51:21.446 - info: admin.1 received all objects
    ! 2019-01-04 02:51:21.754 - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    ! 2019-01-04 02:51:21.782 - error: admin.1 port 8081 already in use
    ! 2019-01-04 02:51:21.816 - error: host.raspberrypi instance system.adapter.admin.1 terminated with code 1 ()
    ! 2019-01-04 02:51:21.816 - info: host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
    ! 2019-01-04 02:51:25.722 - info: iobroker del admin.1
    ! 2019-01-04 02:51:26.792 - info: iobroker Delete adapter "admin.1"
    ! 2019-01-04 02:51:26.851 - info: iobroker host.raspberrypi Counted 1 instances of admin
    ! 2019-01-04 02:51:26.876 - info: iobroker host.raspberrypi Counted 1 channels of admin.1
    ! 2019-01-04 02:51:26.916 - info: iobroker host.raspberrypi Counted 10 states of admin.1
    ! 2019-01-04 02:51:26.948 - info: iobroker host.raspberrypi Counted 2 states (io.admin.1.
    ) from states
    ! 2019-01-04 02:51:26.960 - info: iobroker host.raspberrypi Counted 9 states (system.adapter.admin.1.*) from states
    ! 2019-01-04 02:51:28.144 - info: iobroker host.raspberrypi Counted 1 objects of admin.1
    ! 2019-01-04 02:51:28.146 - info: iobroker host.raspberrypi Deleting 13 object(s).
    ! 2019-01-04 02:51:28.199 - info: host.raspberrypi object change system.adapter.admin.1
    ! 2019-01-04 02:51:28.199 - info: host.raspberrypi object deleted system.adapter.admin.1
    ! 2019-01-04 02:51:28.203 - info: iobroker host.raspberrypi Deleting 11 state(s).
    ! 2019-01-04 02:51:28.253 - info: iobroker exit 0
    ! 2019-01-04 02:51:47.603 - info: host.raspberrypi object change system.adapter.admin.0
    ! 2019-01-04 02:51:47.604 - info: host.raspberrypi stopInstance system.adapter.admin.0
    ! 2019-01-04 02:51:47.604 - info: host.raspberrypi stopInstance system.adapter.admin.0 killing pid 985
    ! 2019-01-04 02:51:47.607 - info: admin.0 terminating http server on port 8081
    ! 2019-01-04 02:51:47.619 - info: admin.0 terminating http server on port 8081
    ! 2019-01-04 02:51:47.642 - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (OK)
    ! 2019-01-04 02:51:50.127 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 1731
    ! 2019-01-04 02:51:51.816 - error: host.raspberrypi startInstance system.adapter.admin.1: object not found!
    ! 2019-01-04 02:51:52.333 - info: admin.0 starting. Version 3.5.10 in /opt/iobroker/node_modules/iobroker.admin, node: v8.15.0
    ! 2019-01-04 02:51:52.362 - info: admin.0 requesting all states
    ! 2019-01-04 02:51:52.365 - info: admin.0 requesting all objects
    ! 2019-01-04 02:51:52.366 - info: admin.0 Request actual repository...
    ! 2019-01-04 02:51:52.822 - info: admin.0 received all states
    ! 2019-01-04 02:51:53.572 - info: admin.0 received all objects
    ! 2019-01-04 02:51:53.701 - info: admin.0 http server listening on port 8081
    ! 2019-01-04 02:51:53.701 - info: admin.0 Use link "http://localhost:8081" to configure.
    ! 2019-01-04 02:51:53.877 - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    ! 2019-01-04 02:51:55.090 - info: admin.0 Repository received successfully.
    ! 2019-01-04 02:52:30.111 - info: iobroker url "https://github.com/jensweigele/ioBroker ... all/master" yahka --debug
    ! 2019-01-04 02:52:30.964 - info: iobroker install https://github.com/jensweigele/ioBroker ... all/master
    ! 2019-01-04 02:52:31.952 - info: iobroker npm install https://github.com/jensweigele/ioBroker ... all/master --production --save --prefix "/opt/iobroker" (System call)
    ! 2019-01-04 02:53:09.355 - info: iobroker npm
    ! 2019-01-04 02:53:09.356 - info: iobroker ERR! code 128
    ! 2019-01-04 02:53:09.360 - info: iobroker npm
    ! 2019-01-04 02:53:09.361 - info: iobroker ERR! Command failed: /usr/bin/git submodule update -q --init --recursivenpm ERR! fatal: Could not change back to '/root/.npm/_cacache/tmp/git-clone-98386997': Keine Berechtigung
    ! npm ERR!
    ! 2019-01-04 02:53:09.411 - info: iobroker
    ! 2019-01-04 02:53:09.412 - info: iobroker npm ERR! A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2019-01-04T01_53_09_372Z-debug.log
    ! 2019-01-04 02:53:09.485 - error: iobroker Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
    ! 2019-01-04 02:53:09.498 - info: iobroker exit 0
    ! 2019-01-04 02:53:09.611 - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    ! 2019-01-04 02:54:47.457 - error: iot.0 read ECONNRESET
    ! 2019-01-04 02:54:47.458 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 02:54:47.458 - info: iot.0 Connection lost
    ! 2019-01-04 02:54:52.738 - info: iot.0 Connection changed: connect
    ! 2019-01-04 02:58:49.217 - error: iot.0 read ECONNRESET
    ! 2019-01-04 02:58:49.218 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 02:58:49.218 - info: iot.0 Connection lost
    ! 2019-01-04 02:58:54.515 - info: iot.0 Connection changed: connect
    ! 2019-01-04 02:59:27.056 - info: iobroker url "https://github.com/jensweigele/ioBroker ... all/master" yahka --debug
    ! 2019-01-04 02:59:27.885 - info: iobroker install https://github.com/jensweigele/ioBroker ... all/master
    ! 2019-01-04 02:59:28.809 - info: iobroker npm install https://github.com/jensweigele/ioBroker ... all/master --production --save --prefix "/opt/iobroker" (System call)
    ! 2019-01-04 03:00:05.191 - info: iobroker npm ERR! code 128
    ! 2019-01-04 03:00:05.197 - info: iobroker npm
    ! 2019-01-04 03:00:05.199 - info: iobroker ERR! Command failed: /usr/bin/git submodule update -q --init --recursivenpm ERR! fatal: Could not change back to '/root/.npm/_cacache/tmp/git-clone-5aa004ff': Keine Berechtigung
    ! npm ERR!
    ! 2019-01-04 03:00:05.264 - info: iobroker npm ERR! A complete log of this run can be found in:
    ! npm ERR! /root/.npm/_logs/2019-01-04T02_00_05_224Z-debug.log
    ! 2019-01-04 03:00:05.335 - error: iobroker Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
    ! 2019-01-04 03:00:05.346 - info: iobroker exit 0
    ! 2019-01-04 03:00:05.476 - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    ! 2019-01-04 03:01:56.993 - info: iobroker add yahka --host raspberrypi
    ! 2019-01-04 03:01:59.166 - info: iobroker NPM version: 6.4.1
    ! 2019-01-04 03:01:59.896 - info: iobroker npm install iobroker.yahka --production --save --prefix "/opt/iobroker" (System call)
    ! 2019-01-04 03:02:15.760 - error: iot.0 read ECONNRESET
    ! 2019-01-04 03:02:15.761 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 03:02:15.761 - info: iot.0 Connection lost
    ! 2019-01-04 03:02:21.058 - info: iot.0 Connection changed: connect
    ! 2019-01-04 03:02:57.540 - info: iobroker sh: 1:
    ! 2019-01-04 03:02:57.542 - info: iobroker node-pre-gyp: Permission denied
    ! 2019-01-04 03:02:59.033 - info: iobroker gyp
    ! 2019-01-04 03:02:59.034 - info: iobroker WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/8.15.0"
    ! 2019-01-04 03:02:59.037 - info: iobroker gyp
    ! 2019-01-04 03:02:59.039 - info: iobroker
    ! 2019-01-04 03:02:59.041 - info: iobroker WARN
    ! 2019-01-04 03:02:59.042 - info: iobroker EACCES
    ! 2019-01-04 03:02:59.044 - info: iobroker attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/curve25519-n/.node-gyp"
    ! 2019-01-04 03:02:59.054 - info: iobroker gyp
    ! 2019-01-04 03:02:59.055 - info: iobroker WARN install got an error, rolling back install
    ! 2019-01-04 03:02:59.061 - info: iobroker gyp
    ! 2019-01-04 03:02:59.062 - info: iobroker WARN install got an error, rolling back install
    ! 2019-01-04 03:02:59.064 - info: iobroker gyp ERR! configure error gyp ERR! stack Error: EACCES: permission denied, stat '/opt/iobroker/node_modules/curve25519-n/.node-gyp/8.15.0'
    ! 2019-01-04 03:02:59.066 - info: iobroker gyp ERR! System Linux 4.14.79-v7+
    ! 2019-01-04 03:02:59.068 - info: iobroker gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd
    ! 2019-01-04 03:02:59.070 - info: iobroker /opt/iobroker/node_modules/curve25519-ngyp ERR! node -v v8.15.0
    ! gyp
    ! 2019-01-04 03:02:59.072 - info: iobroker ERR! not ok
    ! 2019-01-04 03:03:05.640 - info: iobroker npm
    ! 2019-01-04 03:03:05.645 - info: iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 (node_modules/bcrypt):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 install: node-pre-gyp install --fallback-to-build
    ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: spawn ENOENT
    ! 2019-01-04 03:03:06.189 - info: iobroker npm
    ! 2019-01-04 03:03:06.197 - info: iobroker ERR! code ELIFECYCLEnpm ERR! errno 1
    ! npm ERR!
    ! 2019-01-04 03:03:06.359 - info: iobroker
    ! 2019-01-04 03:03:06.362 - info: iobroker npm ERR! A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2019-01-04T02_03_06_279Z-debug.log
    ! 2019-01-04 03:03:06.438 - info: iobroker host.raspberrypi install adapter yahka
    ! 2019-01-04 03:03:07.714 - info: iobroker NPM version: 6.4.1
    ! 2019-01-04 03:03:07.724 - info: iobroker npm install iobroker.yahka --production --save --prefix "/opt/iobroker" (System call)
    ! 2019-01-04 03:04:03.852 - info: iobroker sh: 1:
    ! 2019-01-04 03:04:03.858 - info: iobroker node-pre-gyp: Permission denied
    ! 2019-01-04 03:04:05.321 - info: iobroker gyp
    ! 2019-01-04 03:04:05.326 - info: iobroker WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/8.15.0"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/curve25519-n/.node-gyp"
    ! 2019-01-04 03:04:05.333 - info: iobroker gyp WARN install got an error, rolling back install
    ! 2019-01-04 03:04:05.337 - info: iobroker gyp WARN install got an error, rolling back install
    ! 2019-01-04 03:04:05.340 - info: iobroker gyp ERR! configure error gyp ERR! stack Error: EACCES: permission denied, stat '/opt/iobroker/node_modules/curve25519-n/.node-gyp/8.15.0'
    ! 2019-01-04 03:04:05.342 - info: iobroker gyp ERR! System Linux 4.14.79-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    ! gyp ERR! cwd
    ! 2019-01-04 03:04:05.343 - info: iobroker /opt/iobroker/node_modules/curve25519-ngyp ERR! node -v v8.15.0
    ! gyp ERR! not ok
    ! 2019-01-04 03:04:11.842 - info: iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 (node_modules/bcrypt):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 install: node-pre-gyp install --fallback-to-build
    ! 2019-01-04 03:04:11.844 - info: iobroker
    ! 2019-01-04 03:04:12.148 - info: iobroker npm ERR! code ELIFECYCLEnpm ERR! errno 1
    ! 2019-01-04 03:04:12.151 - info: iobroker npm ERR! curve25519-n@1.4.0 install: node-gyp rebuildnpm ERR! Exit status 1
    ! npm ERR!
    ! 2019-01-04 03:04:12.284 - info: iobroker
    ! 2019-01-04 03:04:12.285 - info: iobroker npm
    ! 2019-01-04 03:04:12.286 - info: iobroker ERR!
    ! 2019-01-04 03:04:12.288 - info: iobroker A complete log of this run can be found in:npm
    ! 2019-01-04 03:04:12.289 - info: iobroker
    ! 2019-01-04 03:04:12.291 - info: iobroker ERR! /root/.npm/_logs/2019-01-04T02_04_12_213Z-debug.log
    ! 2019-01-04 03:04:12.330 - info: iobroker host.raspberrypi install adapter yahka
    ! 2019-01-04 03:04:13.618 - info: iobroker NPM version: 6.4.1
    ! 2019-01-04 03:04:13.620 - info: iobroker npm install iobroker.yahka --production --save --prefix "/opt/iobroker" (System call)
    ! 2019-01-04 03:05:09.827 - info: iobroker sh: 1:
    ! 2019-01-04 03:05:09.830 - info: iobroker node-pre-gyp: Permission denied
    ! 2019-01-04 03:05:11.303 - info: iobroker gyp
    ! 2019-01-04 03:05:11.305 - info: iobroker WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/8.15.0"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/curve25519-n/.node-gyp"
    ! 2019-01-04 03:05:11.314 - info: iobroker gyp WARN install got an error, rolling back install
    ! 2019-01-04 03:05:11.320 - info: iobroker gyp WARN install got an error, rolling back install
    ! 2019-01-04 03:05:11.326 - info: iobroker gyp ERR! configure error gyp ERR! stack Error: EACCES: permission denied, stat '/opt/iobroker/node_modules/curve25519-n/.node-gyp/8.15.0'
    ! gyp ERR! cwd /opt/iobroker/node_modules/curve25519-n
    ! gyp ERR! not ok
    ! 2019-01-04 03:05:17.866 - info: iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 (node_modules/bcrypt):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 install: node-pre-gyp install --fallback-to-build
    ! 2019-01-04 03:05:17.868 - info: iobroker
    ! 2019-01-04 03:05:17.878 - info: iobroker npm ERR! code ELIFECYCLEnpm ERR! errno 1
    ! npm ERR!
    ! 2019-01-04 03:05:17.996 - info: iobroker npm ERR! A complete log of this run can be found in:
    ! npm ERR! /root/.npm/_logs/2019-01-04T02_05_17_919Z-debug.log
    ! 2019-01-04 03:05:18.033 - info: iobroker host.raspberrypi install adapter yahka
    ! 2019-01-04 03:05:18.034 - error: iobroker host.raspberrypi Cannot install yahka
    ! 2019-01-04 03:05:18.045 - info: iobroker exit 13
    ! 2019-01-04 03:05:59.588 - error: iot.0 read ECONNRESET
    ! 2019-01-04 03:05:59.588 - info: iot.0 Connection changed: disconnect
    ! 2019-01-04 03:05:59.589 - info: iot.0 Connection lost
    ! 2019-01-04 03:06:04.905 - info: iot.0 Connection changed: connect
    • wendy2702W Online
      wendy2702W Online
      wendy2702
      Moin,
      was genau bekommst du nicht mehr installiert und warum nutzt du für die Installation nicht wie vorgesehen den "Admin" oder ist es das log nach Admin versuch?
      Mal das Wiki gelesen: https://github.com/jensweigele/ioBroker … leshooting
      Was ergibt:
      node -v
      npm -v
      • L Offline
        leo12318
        Hey sorry für die späte antwort.
        node -v
        8.15.0
        npm -v
        6.4.1
        Admin bereich, denke ich ja :)
        melde über Adpater versucht es zu installieren, sowie über GitHub direkt Link.
        Ich kann Javascript nicht installieren
        Note glaube ich
        Homekit
        alle die Programm kann ich nicht installieren
        hier der Fehler bei Installation von HomeKit Adapter über da Feld "Adapter "
        ! $ ./iobroker add yahka –host raspberrypi
        ! NPM version: 6.4.1
        ! npm install iobroker.yahka --production --save --prefix "/opt/iobroker" (System call)
        ! sh: 1:
        ! node-pre-gyp: Permission denied
        ! gyp
        ! WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/8.15.0"
        ! gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/curve25519-n/.node-gyp"
        ! gyp
        ! WARN install got an error, rolling back install
        ! gyp WARN
        ! install got an error, rolling back install
        ! gyp ERR! configure error gyp
        ! ERR! stack Error: EACCES: permission denied, stat '/opt/iobroker/node_modules/curve25519-n/.node-gyp/8.15.0'gyp
        ! ERR! System Linux 4.14.79-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        ! gyp ERR!
        ! node -v v8.15.0gyp ERR! node-gyp -v v3.8.0
        ! gyp ERR! not ok
        ! npm
        ! WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 (node_modules/bcrypt):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 install: node-pre-gyp install --fallback-to-build
        ! npm ERR! code ELIFECYCLEnpm ERR! errno 1
        ! npm ERR!
        ! Exit status 1npm ERR!
        ! npm ERR! /root/.npm/_logs/2019-01-06T21_06_11_628Z-debug.log
        ! host.raspberrypi install adapter yahka
        ! NPM version: 6.4.1npm install iobroker.yahka --production --save --prefix "/opt/iobroker" (System call)
        ! sh: 1: node-pre-gyp: Permission denied
        ! gyp
        ! gyp
        ! WARN
        ! EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/curve25519-n/.node-gyp"
        ! gyp
        ! WARN
        ! install
        ! got an error, rolling back install
        ! gyp
        ! WARN
        ! install got an error, rolling back installgyp ERR! configure error
        ! gyp
        ! ERR! node-gyp -v v3.8.0gyp ERR! not ok
        ! npm
        ! WARN
        ! optional
        ! SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 (node_modules/bcrypt):npm
        ! WARN
        ! optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 install: node-pre-gyp install --fallback-to-build
        ! npm
        ! WARN optional SKIPPING OPTIONAL DEPENDENCY: spawn ENOENT
        ! npm ERR!
        ! npm ERR! A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2019-01-06T21_07_18_076Z-debug.log
        ! gyp
        ! gyp WARN install got an error, rolling back installgyp ERR! configure error
        ! gyp ERR! stack Error: EACCES: permission denied, stat '/opt/iobroker/node_modules/curve25519-n/.node-gyp/8.15.0'gyp
        ! gyp ERR! cwd /opt/iobroker/node_modules/curve25519-ngyp ERR! node -v v8.15.0
        ! gyp ERR! node-gyp -v v3.8.0gyp ERR! not ok
        ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 (node_modules/bcrypt):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 install: node-pre-gyp install --fallback-to-build
        ! npm ERR! errno 1npm ERR! curve25519-n@1.4.0 install: node-gyp rebuild
        ! npm ERR!
        ! npm ERR! /root/.npm/_logs/2019-01-06T21_08_24_307Z-debug.log
        ! ERROR: host.raspberrypi Cannot install yahka
        ! ERROR: process exited with code 13
        • wendy2702W Online
          wendy2702W Online
          wendy2702
          Mach mal bitte den Versuch eines von denen über den Admin zu installieren und poste nur das log von dem installations Versuch.
          • L Offline
            leo12318
            hab den Fehler im oberen Post eingefügt
            Du meinst das als Admin oder ?
            • wendy2702W Online
              wendy2702W Online
              wendy2702
              Ist das bei einem anderen Adapter der gleiche Fehler?
              Ja, den Admin meine ich.
              • L Offline
                leo12318
                würde sagen ja
                Javascript / Blockly
                ! $ ./iobroker add javascript –host raspberrypi
                ! npm install iobroker.javascript --production --save --prefix "/opt/iobroker" (System call)
                ! npm
                ! WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
                ! module.js:550 throw err;
                ! Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/install/installTypings.js'
                ! at Function.Module._resolveFilename (module.js:548:15)
                ! at Function.Module._load (module.js:475:25)
                ! at Function.Module.runMain (module.js:694:10)
                ! at startup (bootstrap_node.js:204:16)
                ! at bootstrap_node.js:625:3
                ! npm
                ! WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                ! npm WARN optional
                ! SKIPPING OPTIONAL DEPENDENCY: spawn ENOENT
                ! npm
                ! ERR! code ELIFECYCLEnpm
                ! ERR! errno 1npm ERR! iobroker.javascript@4.0.7 postinstall: node ./install/installTypings.js
                ! npm ERR! npm ERR! Failed at the iobroker.javascript@4.0.7 postinstall script.
                ! npm ERR! A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2019-01-06T21_21_51_202Z-debug.log
                ! host.raspberrypi install adapter javascript
                ! npm
                ! WARN
                ! deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
                ! npm
                ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 install: node-pre-gyp install --fallback-to-build
                ! npm ERR! iobroker.javascript@4.0.7 postinstall: node ./install/installTypings.js
                ! npm
                ! ERR! npm ERR! Failed at the iobroker.javascript@4.0.7 postinstall script.
                ! npm ERR! A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2019-01-06T21_23_21_287Z-debug.log
                ! npm
                ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                ! npm
                ! ERR! iobroker.javascript@4.0.7 postinstall: node ./install/installTypings.jsnpm ERR! Exit status 1
                ! npm
                ! npm ERR! /root/.npm/_logs/2019-01-06T21_24_51_674Z-debug.log
                ! ERROR: host.raspberrypi Cannot install javascript
                • wendy2702W Online
                  wendy2702W Online
                  wendy2702
                  Darf ich mal fragen wann und wie ioBroker installiert wurde?
                  Welcher User?
                  Fertiges Image oder selber installiert?
                  • L Offline
                    leo12318
                    Vor knapp 1 Woche
                    Nach dieser Anleitung
                    http://www.iobroker.net/docu/?page_id=8323&lang=de
                    Was meinst du mit dem User ?
                    • wendy2702W Online
                      wendy2702W Online
                      wendy2702
                      Warst du als root user oder als PI user eingeloggt?
                      • AlCalzoneA Offline
                        AlCalzoneA Offline
                        AlCalzone
                        @wendy2702:
                        Warst du als root user oder als PI user eingeloggt? `
                        Das wäre wichtig zu wissen, um an der richtigen Stelle anzusetzen.
                        Außerdem: Hast du nach der Installation irgendeinen Adapter manuell per <u>sudo npm …</u> installiert?
                        • L Offline
                          leo12318
                          Ja hab das Max! Cube probiert zu installieren.
                          Also ich habe auf dem Pi die SSH Datei gespeichert, kann also auf root umstellen, mit sudo -s Dann Hab ich root..
                          Hab natürlich per terminal die Adapter zu installieren
                            AlCalzoneA Offline
                            AlCalzone
                            Ich habe dich gefragt, ob du als root installiert hast, nicht ob du das kannst :)
                            Ich schubse dich daher schon mal vorsichtig in die Richtung => viewtopic.php?f=8&t=19209
                            Lesen, verstehen und anwenden.
                            @leo12318:
                            Hab natürlich per terminal die Adapter zu installieren `
                            Die bevorzugte Variante, Adapter zu installieren, ist über den Admin!
                            Bitte auch unbedingt lesen => http://www.iobroker.net/docu/?page_id=8 … n_Adapters
                            Insbesondere, das was fett und rot ist ;)
                            > Achtung! Auf neueren Installationen verursacht die direkte Verwendung von npm install Rechteprobleme nach der Installation oder schlägt fehl. Es wird empfohlen, auf die iobroker-Kommandos zurückzugreifen.!!
                            • L Offline
                              leo12318
                              Hab es gelöst :D
                              Hab alles neu aufgesetzte, jetzt läuft alles
                              • wendy2702W Online
                                wendy2702W Online
                                wendy2702
                                Weißt du denn was du jetzt anders gemacht hast. Wenn ja wäre es nett das hier für andere kurz zu beschreiben.
                                Auch bitte noch den Titel vom ersten Post um ein````
                                Gelöst
