  4. [HowTo][Anleitung] Install von ioBroker auf Debian (Wheezy) in einer VM
    5.7k
27 Beiträge 8 Kommentatoren 17.4k Aufrufe
  • K Offline
    Kev0
    Ja alles so geschehen.
    Nach total Neustart der Maschine, nicht nur über reboot, gehts jetzt wundersamer Weise einwandfrei.
    Danke trotzdem
      Sebbo
      ich habe jetzt versucht anhand dieser Anleitung mein ioBroker zu virtualisieren.
      Bei mir kommt allerdings bei der Installation folgende Meldung:
      root@ioBrokerVM:/opt/iobroker# npm install iobroker
      > iobroker@0.5.6 install /opt/iobroker/node_modules/iobroker
      > node lib/setup.js
      npm install iobroker.js-controller --production --prefix /opt/iobroker
      gyp ERR! build error
      gyp ERR! stack Error: not found: make
      gyp ERR! stack     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:43:28)
      gyp ERR! stack     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:46:29)
      gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/which/which.js:57:16
      gyp ERR! stack     at Object.oncomplete (evalmachine.<anonymous>:108:15)
      gyp ERR! System Linux 3.16.0-4-amd64
      gyp ERR! command "node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/utf-8-validate
      gyp ERR! node -v v0.10.40
      gyp ERR! node-gyp -v v1.0.1
      gyp ERR! not ok
      npm WARN optional dep failed, continuing utf-8-validate@1.2.1
      gyp ERR! cwd /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/utf-8-validate
      gyp ERR! not ok
      gyp ERR! cwd /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/bufferutil
      gyp ERR! not ok
      npm WARN optional dep failed, continuing bufferutil@1.2.1
      gyp ERR! cwd /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/bufferutil
      gyp ERR! not ok
      npm install iobroker.admin --production --prefix /opt/iobroker
      gyp ERR! cwd /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/utf-8-validate
      gyp ERR! not ok
      gyp ERR! cwd /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/bufferutil
      gyp ERR! not ok
      gyp ERR! cwd /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/utf-8-validate
      gyp ERR! not ok
      gyp ERR! cwd /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/bufferutil
      gyp ERR! not ok
      Write "./iobroker start" to start the ioBroker
      Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start
      iobroker is started. Go to "http://ip-addr:8081" to open the admin UI.
      iobroker@0.5.6 node_modules/iobroker
      âââ yargs@1.2.6 (minimist@0.1.0)
      root@ioBrokerVM:/opt/iobroker#</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
      Ist das so normal?
      Grüße vom Sebbo
        samsungfreak
        Hallo *,
        ich habe vor ca. 4 Monaten meine Installation vom IOBroker auf einem Debian System durchgeführt.
        Allerdings habe ich auch das Problem, dass der IOBroker Dienst nach einem Reboot nicht startet.
        Leider komme ich hier nicht voran um das Problem zu lösen.
        Hat jemand noch weitere Ideen wie ich das Problem lösen kann?
        • BluefoxB Offline
          BluefoxB Offline
          @samsungfreak:
          Hallo *,
          Hat jemand noch weitere Ideen wie ich das Problem lösen kann? `
          Was passiert wenn du
          sudo /etc/init.d/iobroker.sh start
          Aufrufst?
            samsungfreak
            Hallo Bluefox,
            -bash: sudo: Kommando nicht gefunden.
            dann ist wohl doch noch was falsch :roll:
            • BluefoxB Offline
              BluefoxB Offline
              @samsungfreak:
              Hallo Bluefox,
              dann ist wohl doch noch was falsch :roll: `
              Kann jemand /etc/init.d/iobroker.sh hier posten? Bin nicht am Rechner gerade.
              • kmxakK Offline
                kmxakK Offline
                kmxak
                Das Problem mit dem Debian Autostart hatte ich gelöst. Sollte in einem meiner Beiträge stehen. Bin aber gerade nicht am Rechner. Edit http://forum.iobroker.net/viewtopic.php?t=6936
                Gesendet von meinem SM-G930F mit Tapatalk
                Gruß Alex
